! r: j& J4 C' N. p* I0 h
. G" y1 ^) ~' [& q6 _. q作品名:[AD 10][4 层]千兆路由器(MT7620A+ZTP1117SA+MX25L3205DM2I)PCB源文件
, O9 H" f* b7 R( Q" m# |& i) }9 J- s文件描述 1. 作品用途:千兆路由器 2. 软件版本:AD 10 3. 层数:4 层 4. 用到的主要芯片:MT7620A+ZTP1117SA+MX25L3205DM2I 5. PCB尺寸:114.7mm*123.5mm
( h. l' ~0 N% E作品截图如下: 1 W& g- L7 w& m0 a# k
顶层截图: 底层截图: 全层截图: 叠层信息截图如下: BOM: 8 E: ^4 ?/ y. Y5 T9 p8 D
* a; g0 B' y5 t T- E6 SComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Cap Pol1 | C1, C5 | 470UF/6.3V(477J) | 2 | Cap | C2, C3, C4, C6, C8, C9, C10, C11, C12, C14, C15, C17, C18, C19, C20, C21, C24, C25, C26, C27, C47, C52, C200, C336 | 0603-C | 24 | Cap2 | C13, C23, C30, C33, C34, C42, C45, C48, C53, C56, C136, C456, C457, C631, C637, C661, C680, C682, C686, C687, C797, C799, RC1, RC2, RC3 | 0603-C | 25 | Cap | C16 | 470UF/6.3V(477J) | 1 | Cap | C22 | 3225[1210] | 1 | 0.1uF/NI | C29, C129, C132, C133, C137, C138, C139, C140 | 0402-C | 8 | 4.7nF | C31 | 0402-C | 1 | 0.1uF | C36, C39, C40, C41, C44, C50, C51, C54, C57, C70, C72, C75, C76, C91, C93, C97, C103, C104, C110, C121, C124, C125, C130, C131, C134, C135, C166, C210, C215, C633, C634, C635, C636, C639, C640, C641, C642, C643, C644, C645, C646, C647, C648, C649, C650, C651, C652, C653, C654, C655, C657, C659, C660, C662, C664, C666, C667, C668, C669, C670, C672, C673, C674, C675, C676, C677, C678, C681, C683, C684, C688, C714, C715, C716, C717, C726, C727, C728, C730, C768, C769, C820, C821 | 0402-C | 83 | 3.9nF | C37 | 0402-C | 1 | 100pF | C38 | 0402-C | 1 | 1nF | C58, C167, C807, C808, C809, C811, C812, C813, C815 | 0402-C | 9 | 4.7uF | C73 | 0603-C | 1 | Cap | C82, C796, C806, C848 | 0402-C | 4 | 100pF/NI | C83 | 0402-C | 1 | 10pF | C84, C89, C95, C102, C706, C707, C708, C709, C710, C711, C712, C713, C718, C719, C720, C721, C722, C723, C724, C725, L7 | 0402-C | 21 | 2.7nH | C85, C90, L9, L11, L623, L624, L625, L626 | 0402-R | 8 | 0.8pF | C86, C101 | 0402-C | 2 | NI | C87, C99 | 0402-C | 2 | 1.8pF/NI | C88, C100 | 0402-C | 2 | 10nF | C94 | 0402-C | 1 | 1.2pF | C96, C105, L6, L8 | 0402-C | 4 | 3.9pF | C107, C849 | 0402-C | 2 | 33pF | C108 | 0402-C | 1 | 0 ohm 0 ohm/SB | C116, C118 | 0603-C | 2 | 0 ohm/SB | C117, C119, C120, C122 | 0603-C | 4 | Cap2 | C123, C735 | 1206-C | 2 | 10pF/NI | C127, C656, C658, C663, C665 | 0402-C | 5 | 1uF/NI | C128 | 0402-C | 1 | 1uF | C632, C638, C798 | 0402-C | 3 | 10uF | C671 | 0603-C | 1 | 0.1uF/100V | C729, C731, C733, C734, C810, C814, C816, C817 | 0402-C | 8 | 1000pF/2KV/NI | C732 | 1206-C | 1 | 22pF/NI | C801, C802 | 0402-C | 2 | 22pF | C803, C804 | 0402-C | 2 | 2pF | C841, C842 | 0402-C | 2 | 2.7pF | C843, C844 | 0402-C | 2 | SMA/UFLR/RF | CON53, CON54 | 外置天线插头 | 2 | TVS SMCJ16A/NI | D1 | DO-214AB(SMC) | 1 | LED | D6, D7, D8, D20, D26 | 0603LED | 5 | LED(Green) | D15, D40 | 0603LED | 2 | LED(Orange) | D16, D41 | 0603LED | 2 | 1N4148/NI | D32 | 1N4148 | 1 | Header 4 | J2 | 1*4插针-2.0 | 1 | Header 9 | J3 | HDR1X9 | 1 | 7SDCN-B0-1X14-SD Card Slot/NI/SLT | J44 | SD-PCB | 1 | Inductor | L1, L35, L36, R225, R227 | 0805-R | 5 | Inductor | L2, L3 | SLF12575 | 2 | 4.7uH/VLC5045 | L4 | VLCF4020 | 1 | Inductor | L5 | 0402-R | 1 | 10pF | L10 | 0402-R | 1 | 3.0nH | L12 | 0402-R | 1 | 0 ohm | L608, L610, L616, L622 | 0805-R | 4 | 0 ohm | L613, R159, R745, R748, R808, R809, R814, R815, R825, R829 | 0402-R | 10 | 0 ohm | L618 | 0603-R | 1 | 3.9nH | L627, L628 | 0402-R | 2 | Header 6 | P1 | 1*6 单排 2.0 插针 | 1 | Comment | PIN | 1*4插针-2.0 | 1 | 2SB1386 | Q600, Q601, Q602, Q603 | 2SB1386 | 4 | Res1 | R1, R2, R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R17, R19, R343, R356 | 0603-R | 19 | 2K 1% | R21 | 0402-R | 1 | 68 ohm 1% | R22 | 0402-R | 1 | 0 ohm/SB | R23, R27, R28 | 0805-R | 3 | 2K1% | R24 | 0402-R | 1 | 4.7K 1% | R26 | 0402-R | 1 | 0 ohm/SB | R29, R55 | 0603-R | 2 | 6.19K 1% | R42, R723 | 0402-R | 2 | 8.2K 1% | R51 | 0402-R | 1 | 1K | R54 | 0402-R | 1 | 22 | R61, R62, R63, R102, R207, R421, R553, R554, R555, R556, R557, R558, R692, R693, R697, R702, R703, R708, R722, R724, R727, R729, R730, R736 | 0402-R | 24 | 47 ohm | R64, R65, R66, R67, R68, R69, R70, R71, R72, R73, R74, R75, R76, R77, R78, R79, R80, R81, R82, R83, R84, R85, R86, R87, R88, R89, R90, R91, R92, R93, R94, R95, R96, R97, R98, R99, R100, R101, R103, R104, R105, R106, R479, R826, R827 | 0402-R | 45 | 24K 1% | R107 | 0402-R | 1 | 100 | R108 | 0402-R | 1 | 75 | R121, R122, R123, R795, R796, R797, R798, R803, R804, R805, R806 | 0402-R | 11 | 4.7K/NI | R124, R125, R130, R131, R133, R134, R137, R714, R740 | 0402-R | 9 | 4.7K | R126, R127, R128, R129, R132, R135, R136, R139, R142, R154, R170, R221, R355, R676, R678, R679, R680, R686, R690, R691, R694, R696, R698, R710, R718, R721, R728 | 0402-R | 27 | 120 | R150 | 0402-R | 1 | 10K | R151, R371, R373, R375, R376, R377, R388, R389, SR2 | 0402-R | 9 | 330 | R155 | 0402-R | 1 | 330 ohm | R158, R160, R467, R468, R560, R561, R824 | 0402-R | 7 | 1K 1% | R350, R351, R812, R813 | 0402-R | 4 | 330 ohm/NI | R370 | 0402-R | 1 | Res1 | R372, R682, R699, R720, R743, R746, R823, R832, R833 | 0402-R | 9 | 300 | R374 | 0402-R | 1 | 12K 1% | R381 | 0402-R | 1 | 0 ohm | R707, R711, R735, R738 | 0402-R | 4 | 22/NI | R709, R737 | 0402-R | 2 | 10K/NI | R716, R741 | 0402-R | 2 | 22 ohm/NI | R733 | 0402-R | 1 | 1Mohm/NI | R734, R747 | 0402-R | 2 | 6.19KR 1% | R744 | 0402-R | 1 | 49.9 | R783, R784, R785, R786, R787, R788, R789, R790, R791, R792, R793, R794, R799, R800, R801, R802 | 0402-R | 16 | 0 ohm/NI | R830 | 0402-R | 1 | 22/NI | R831 | 0402-R | 1 | SW TACT-SPST-RA | S2, S3 | 开关 | 2 | Comment | SPI | W25Q128BV | 1 | 22 | SR1 | 0402-R | 1 | | T600 | HST1041A-2 | 1 | 24HST1041A-2 | T601 | HST1041A-2 | 1 | MT7620A | U1 | MT7620A | 1 | IT-76520 | U2 | SO-8带焊盘(150MIL) | 1 | IT-76530 | U3 | SO-8带焊盘(150MIL) | 1 | G693L_R3132Q/NI | U4 | G693L-R3132Q | 1 | ZTP1117SA | U5 | ZTP1117SA | 1 | APM2701AC | U6 | APM2701 | 1 | DDR2_FBGA84_8X14 | U7 | K4T1G164QF-BCF7 | 1 | BTA1664M3 | U8 | SOT-89-3 | 1 | XTAL/3.2X2.5/20MHz/NI | U11 | XTAL-4025 | 1 | RJ-45X1P | U15, U614, U615 | RJ45(不带灯) | 3 | HN1674CG | U16 | HN1674CG | 1 | MX25L3205DM2I | U18 | SO-8(200MIL) | 1 | IP1001 | U607, U609 | IP1001 | 2 | FST9718 | U616 | FST9718 | 1 | Comment | USB | USB-A母 | 1 | C-UBR27-00-00 | USB1 | Micro USB母 | 1 | 25MHz/NI | X601, X602 | XTAL-4025 | 2 |
' q# Z3 I6 q4 D. Y* q附件: 原理图和PCB源文件如下: " `9 P4 f. a3 c _
