查看: 2511|回复: 23
[allegro17.2][6层]Type-C Charge-Through Dongle(PMEG45A10EPD+LTC3789+MCDP2900...
发表于 2020-1-6 14:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][6层]Type-C Charge-Through Dongle(PMEG45A10EPD+LTC3789+MCDP2900-A0 DP to HDMI)原理图和pcb文件
文件描述:
1. 作品用途:Type-C Charge-Through Dongle
2. 软件版本:allegro17.2
3. 层数:6层
4. 用到的主要芯片:PMEG45A10EPD+LTC3789+MCDP2900-A0 DP to HDMI
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
17479811_HDMIHDMI_4_17479811_HDMI_TYCO HDMITYCO HDMI Receptacle, 1747981-1IC1CN1
B3U1000PSW1B3U1000PIC1SW2
BAS16_215B340LA_2_BAS16_215_BAS16,215_BABAS16,215IC1D10
BSN20-7BSN20-7_BSN20-7_BSN20-7_BSN20-7BSN20-7IC1Q16
BSZ097N04LSMOSFET_P_SO8_0_BSZ097N04LS_BSZ0BSZ097N04LS GIC4Q1; Q2; Q5; Q7
BZX84C5V1_SOT23BZX84C2V4-C51_BZX84C5V1_SOT23_BBZX84C5V1IC1D17
C0402CAP NP_C0402_0.1UF_C1005X7R1E100.1uFIC21C6; C16; C17; C34; C36; C37; C57; C58; C59; C88; C89; C94; C97; C98; C99; C101; C108; C110; C111; C116; C130
C0402CAP-NP_0_C0402_10PF_C0402C100J510pFIC2C7; C8
C0402CAPACITOR NON-POL_C0402_0.1UF_10.1uF_16VIC9C9; C11; C15; C66; C70; C71; C72; C83; C84
C0402CAP NP_C0402_22PF_C1005C0G1H22022pFIC2C18; C19
C04020_1_UF_0402_C0402_DISCRETE_0.2U0.2uFDISCRETE4C22; C24; C27; C29
C0402C250.1uFIC1C25
C0402CAP NP_C0402_22NF/25V/X5R_C100522nF/25V/X5RIC4C26; C31; C96; C100
C0402CAP-NP_0_C0402_0.1UF_C1005X7R1E0.1uFIC1C35
C0402C_0_C0402_2.2UF_C0402C225M8PACT2.2uFIC1C45
C0402CAP0603_C0402_100PF_GRM0335C1E1100pFIC1C47
C0402CAP0603_C0402_68PF_0201YA680JAT68pFIC1C52
C0402CAP0603_C0402_22PF_C1005C0G1H2222pFIC1C53
C0402EMK107BJ224MA_C0402_0.22UF_C1000.22uFIC2C54; C170
C0402C1608X5R0J475MT_C0402_1UF_CGB2A1uFIC1C55
C0402CAPACITOR NON-POL_C0402_0.01UF_0.01uF_10VIC10C67; C73; C74; C75; C78; C79; C80; C81; C82; C86
C0402CAP NP_C0402_1.5UF_C1005X5R1E151.5uFIC1C85
C0402CAPACITOR NON-POL_C0402_0.1UF_C0.1uFIC1C87
C0402CAP NP_C0402_0.01UF_GRM155R71E10.01uFIC3C92; C105; C109
C0402LMK107BJ105MA_C0402_1UF_CGB2A1X1uFIC1C122
C0402C1608X5R0J475MT_C0402_10UF_CL0510uFIC1C124
C040206033C223KAT1A_0_C0402_0.01UF_G0.01uFIC1C126
C0402CAP NP_C0402_0.1UF_0.1uFIC1C128
C0402CAP-NP_0_C0402_1UF_C1005X5R1V101uFIC1C168
C0402C_NP_C0402_1UF1uFIC1C178
C0402C270.1uFIC1C189
C0402C715pFIC1C190
C0402C1015pFIC1C191
C0402C37NC,0.1uFIC1C192
C0402C160.1uFIC1C193
C0402C171uFIC1C194
C0402C150.1uFIC1C195
C0402C140.1uFIC1C196
C0402C380.1uFIC1C197
C0402CAP NP_C0402_0.1UF_C0402C104K8R0.1uFIC1C198
C0402C220.1uFIC1C199
C0402C360.1uFIC1C200
C0402C340.1uFIC1C201
C0402C300.1uFIC1C202
C0402C400.1uFIC1C204
C0402C330.1uFIC1C205
C0402C80.1uFIC1C206
C0402C320.1uFIC1C207
C0402C560.1uFIC1C208
C0402C410.1uFIC1C210
C0402C190.1uFIC1C211
C0402C240.1uFIC1C213
C0402C430.1uFIC1C214
C0402C260.1uFIC1C216
C0402C420.1uFIC1C218
C0402C290.1uFIC1C219
C0402C280.1uFIC1C220
C0402C310.1uFIC1C221
C0402C210.1uFIC1C223
C0603CAP-NP_0_C0603_1UF_TMK107B7105K1uFIC5C1; C60; C106; C107; C131
C0603C_NP_C0603_22UF22uFIC3C2; C177; C179
C0603CAP-NP_0_C0603_390PF_C0603C391J390pFDISCRETE4C4; C5; C112; C151
C0603C_NP_C0603_10UF10uFIC4C10; C180; C182; C184
C0603CAP1210_C0603_1UF_UMK107AB7105K1uFIC1C48
C0603CAPACITOR NON-POL_C0603_4.7UF_14.7uF_10VIC2C68; C69
C0603CAPACITOR NON-POL_C0603_10UF_1010uF_10VIC1C76
C0603CAP POL_C0603_10UF_16V_C1608X5R10uF_16VIC1C77
C0603CAP NP_C0603_2.2UF_C1608X5R1E222.2uFIC1C90
C0603CAP NP_C0603_22UF_C1608X5R1A22622uFIC1C115
C0603CAP1206_C0603_1000PF_GRM188R71H1000pFIC1C117
C0603CAP1206_C0603_200PF_GRM1885C1H2200pFIC1C120
C060306033C103KAT2A_C0603_0.015UF_C00.015uFIC1C123
C0603CAP-NP_0_C0603_1UF_1uFIC1C129
C0603C_NP_C0603_NSNSIC4C181; C183; C185; C186
C0603C3910uF/10V/X5RIC1C203
C0603C1810uF/10V/X5RIC1C209
C0603C2310uF/10V/X5RIC1C212
C0603C3510uF/6.3V/X5RIC1C215
C0603C4510uF/6.3V/X5RIC1C217
C0603C2010uF/6.3V/X5RIC1C222
C0805C3225X7R1H335M_0_C0805_22UF_C2022uFIC4C42; C43; C187; C188
C0805CAP NP_C0805_22UF_C2012X5R0J22622uFIC1C114
C1210CAP NP_C1210_10UF_TMK325BJ106MN10uFIC1C3
C1210C3225X5R1C226M_0_C1210_10UF_GMK10uFIC3C49; C50; C51
C1210CAP NP_C1210_10UF_GRM32ER71H10610uFIC1C144
C1210CAP NP_C1210_4.7UF_GRJ32ER71H474.7uFIC2C147; C150
C7343CAP POL_C7343_100UF_T521V107M01100uFIC3C28; C156; C157
CCG2_QFN_SOCKETCCG1_31_CCG2_QFN_SOCKET_CCG2_CYCCG2IC1U2
CRY-3_2X2_5Y125M CRYSTALIC1Y3
DFN_LCC3P2X2P5CRYSTAL_0_DFN_LCC3P2X2P5_26MHZ_26MHzIC1Y1
ECS_4SMDCRYSTAL_0_ECS_4SMD_27.000MHZ CR27.000MHz CrystalIC1Y2
EMIFILL6LECM2012H-900QT / ACM2012H-900-2P-T00,ChokeIC1L6
EMIFILL7LECM2012H-900QT / ACM2012H-900-2P-T00,ChokeIC1L7
EMIFILL8LECM2012H-900QT / ACM2012H-900-2P-T00,ChokeIC1L8
EMIFILL9LECM2012H-900QT / ACM2012H-900-2P-T00,ChokeIC1L9
FB0603FERRITE BEAD_FB0603_120 OHMS @120 ohms @ 100MHz, 2AIC2FB1; FB2
HDR22 PIN HEADER _6_HDR2_IO_2 PIN H2 PIN HDRIO2J8; J9
HDR2103185_22 PIN HDRIO7J20; J21; J22; J23; J24; J26; J28
HDR5_KEYED_M1X5_100MIL_HDR_0_HDR5_KEYED_M_HHDR 1x5IC2J1; J12
HDR_1X3_100MILHDR_4X2_2_HDR_1X3_100MIL_HDR_1XHDR_1X3_100MILIC3J15; J18; J19
HDR_1X4_SELDPR25PWR_SELIC1J17
HDR_2X2_100MILRECEPT 9X2 100 MIL_4_HDR_2X2_102X2 HEADERIO1J27
HDR_05X2_100MILRECEPT 9X2 100 MIL_5_HDR_05X2_15X2 HeaderIO1J5
HDR_10X2_100MILRECEPT 9X2 100 MIL_3_HDR_10X2_110X2 RECPIO1J14
IND_4P4X4P1X1P5MMINDUCTOR_IND_4P4X4P1X1P5MM_1.5U1.5uHIC1L2
IND_4P4X4P1X1P5MMINDUCTOR_IND_4P4X4P1X1P5MM_1UH1uHIC1L3
L0402L12BK1005HS100-TIC1L10
L0402L11BK1005HS100-TIC1L11
L0402L13BK1005HS100-TIC1L12
L0402L10BK1005HS100-TIC1L13
LA1S109-43-LFJ2LA1S109-43LFIC1J25
LED-0603LED2Yellow LEDIC1LED1
LED-0603LED1Green LEDIC1LED2
LED_0603LED_GREEN2_0603_LED_0603_GREEN_GREENIC9D2; D3; D4; D5; D6; D7; D28; D29; D30
LFBGA64_7X7MMMCDP2800_1_LFBGA64_7X7MM_MCDP29MCDP2900-A0 DP to HDMIIC1U7
LPS3015-152MLCINDUCTOR_LPS3015-152MLC_1.5UH_L1.5uHIC1L1
LTC3789_QFN28LTC3789_LTC3789_QFN28_LTC3789_LLTC3789IC1U14
PMEG45A10EPDPMEG3050EP_0_PMEG45A10EPD_PMEG4PMEG45A10EPDIC1D22
POWERDI123DFLS160_0_POWERDI123_DFLS160_DFDFLS160IC2D16; D19
QFN6-1X1P5MMMP2148GQD_QFN6-1X1P5MM_MP2148GQMP2148GQDIC2U22; U23
QFN11_2X3MMMP28164_QFN11_2X3MM_MP28164MP28164IC1U21
QFN40_CYPD3125-40LQXITCCG3_QFN40_CYPD3125-40LQXIT_CCGCCG3IC1U17
QFN68U2AX88179 QFIC1U24
QFN-68CYUSB3304-68LTXC_1_QFN-68_CYUSBCYUSB3304-68LTXCIC1U4
R0402R_R0402_1M1MIC1R2
R0402R_R0402_105K105KIC1R3
R0402R_R0402_NSNSIC1R10
R0402R_R0402_100_ERJ-2GEJ101X100IC3R52; R53; R55
R0402CR16-1002FM_0_R0402_0_ERJ-1GN0R0IC2R56; R60
R0402R_R0402_10K_ERJ-1GEJ103C10KIC1R57
R0402CR16-1002FM_0_R0402_121K_ERJ-1G121KIC1R58
R0402CR16-1241FM_R0402_1.24K_ERJ-1GE1.24KIC2R61; R65
R0402CR16-1133FM_R0402_56.2K_ERJ-1GE56.2KIC1R62
R0402CR10-100JM_R0402_0_ERJ-1GN0R00C0IC3R63; R64; R117
R0402R_R0402_100_ERJ-1GEJ101C100IC1R107
R0402CR16-1002FM_0_R0402_DNL_ERJ-1GEDNLIC1R108
R0402R_R0402_5.6_ERJ-2GEJ5R6X5.6IC1R111
R0402CR16-1002FM_0_R0402_1K_ERJ-1GEF1KIC1R114
R0402CR16-1003FM_R0402_4.99K_ERJ-1GE4.99kIC1R116
R0402R_R0402_10_ERJ-1GEF10R0C10IC1R120
R0402CR16-8061FM_R0402_10K_ERJ-1GEF110KIC1R121
R0402CR16-1002FM_0_R0402_10K_ERJ-1GE10KIC1R122
R0402R_R0402_0_CRCW04020000Z0ED0IC2R159; R165
R0402R_R0402_1K__ERJ-2RKF1001X1KIC1R225
R0402R_R0402_49.9K_ERJ-2RKF4992X49.9KIC1R226
R0402R_R0402_10K__ERJ-2RKF1002X10KIC5R227; R233; R234; R239; R240
R0402CR16-1002FM_0_R0402_10K_ERJ-1_110kIC1R229
R0402R_R0402_44.2K44.2kIC1R230
R0402R_R0402_100K100kIC2R231; R235
R0402R_R0402_10_RC0402FR-0710RL10IC1R232
R0402R_R0402_200K200kIC3R236; R237; R238
R0402R2NC,1MIC1R243
R0402R20NC,10KIC1R244
R0402R3200IC1R245
R0402R11330RIC1R246
R0402R164.7KIC1R247
R0402R224.7KIC1R248
R0402R12330RIC1R249
R0402R74.7KIC1R250
R0402R101MIC1R251
R0402R254.7KIC1R252
R0402R1333RIC1R253
R0402R9330RIC1R254
R0402R8330RIC1R255
R0402R422RIC1R256
R0402R142.49K1%IC1R257
R0402R5NC,4.7KIC1R258
R0402R154.7KIC1R259
R0402R64.7KIC1R260
R0402R_R0402_100K_ERJ-2RKF1003X100KIC1R263
R0402R_R0402_226K_ERJ-2RKF1003X226KIC1R264
R0603R_R0603_10K_1%_RC0603JR-0710KL10KIC1R7
R0603R_R0603_6.04K_RC0603FR-076K04L6.04KIC1R14
R0603R_R0603_10K_RC0603JR-0710KL10KIC15R15; R17; R19; R20; R21; R22; R23; R81; R84; R85; R101; R123; R241; R242; R262
R0603R_R0603_0 OHMS_ERJ-3GEY0R00V0 ohmsIC6R16; R39; R40; R87; R90; R134
R0603R_R0603_22.1K_1%_RC0603FR-0722K22.1K_1%IC1R18
R0603R490IC2R24; R26
R0603R_R0603_100K_RC0603JR-07100KL100KIC6R25; R27; R41; R93; R102; R103
R0603R_R0603_2.2K_RC0603FR-072K2L2.2KIC3R28; R47; R48
R0603R_R0603_5.1 OHMS_RL0816S-5R1-F5.1 ohmsIC8R30; R31; R32; R33; R34; R35; R37; R38
R0603R_R0603_27K_RC0603FR-0727KL27KIC1R45
R0603R_R0603_47K_RC0603FR-0747KL47KIC1R46
R0603R_R0603_4.7K_1%_RC0603FR-074K7L4.7KIC1R69
R0603RESD,0402,5%,1/32W,10K_R0603_10100IC1R70
R0603RESD,0402,5%,1/32W,10K_R0603_15150IC2R71; R91
R0603R_R0603_100K_1%_RC0603JR-07100K100KIC1R72
R0603RESD,0402,5%,1/32W,10K_R0603__1330IC1R77
R0603RESD,0402,5%,1/32W,10K_R0603_33330IC4R78; R86; R98; R261
R0603R_R0603_200R_RC0603FR-07200RL200RIC1R80
R0603R_R0603_0_ERJ-3GEY0R00V0IC1R82
R0603RESISTOR_R0603_200R_RC0603FR-07200RIC1R83
R0603R_R0603_1M_5%_RC0603FR-071ML1MIC1R88
R0603R_R0603_1M_1%_RC0603FR-071ML1MIC1R89
R0603R_R0603_249 1%_RC0603FR-07249RL249 1%IC1R92
R0603RESISTOR_R0603_2.2K_RC0603FR-072.2KIC8R126; R127; R128; R173; R174; R175; R265; R266
R0603RESD,0402,5%,1/32W,10K_R0603_1.1.6KIC2R267; R268
R0805R_R0805_0 OHMS_ERJ-6GEY0R00V0 ohmsIC4R148; R151; R152; R228
R0815RL3720WT-R018-G_R0815_0.015_RL30.015IC1R54
R0815RL3720WT-R018-G_R0815_0.012_RL30.012IC1R59
R1206AAC-1206_R1206_8.06_CRCW12068R08.06IC1R113
R2010AAC-1206_R2010_5_PWR2010W5R00JE5IC1R106
R2512R_R2512_10M_CRCW251210M0FKEG10MIC4R158; R160; R164; R166
RES2512R_RES2512_200_3522200RFT200IC1R154
RESC6432X67NRESISTOR_RESC6432X67N__10M__PMR10mIC1R172
RJU003N03T106MOSFET_N_GDS_RJU003N03T106_RJU0RJU003N03IC1Q24
S2AF_SOIC8SST25VF020_0_S2AF_SOIC8_SST25VFSST25VF080B-50-4C-S2AFIC1U11
SIP1AATP1T POINT RIC1TP10
SIP1AATP2T POINT RIC1TP11
SIP1AATP3T POINT RIC1TP12
SIP1AATP4T POINT RIC1TP13
SMB_SMBJ20CADIODE TS_0_SMB_SMBJ20CA_SMBJ20CSMBJ20CAIC2D20; D21
SMT_1070-MSB1-0048-X4-TYPEUSB-PD_TYPE-C_8_SMT_1070-MSB1-0USB-PD_TYPE-C_ReceptacleIC1J3
SO8_DMN3018SSDMOSFET_N_GDS_10_SO8_DMN3018SSD_DMN3018SSD-13IC2Q22; Q23
SOD128PMEG3050EP_SOD128_PMEG 3050_PMEPMEG 3050IC4D23; D24; D25; D26
SOIC127P600X175-8N_TIMOSFET_N_GDS_9_SOIC127P600X175-AO4807IC1Q25
SON-8TPS2556DRBT_SON-8_TPS2556DRBT_TTPS2556DRBTIC1U5
SOT23_3_MMBT3904NPN BCE_1_SOT23_3_MMBT3904_MMBTMMBT3904IC1Q15
SRP1038A_2R2MFDA1254-4R7M_SRP1038A_2R2M_2.2U2.2uHIC1L5
SS2P4_M3_84AB340LA_2_SS2P4_M3_84A_SS2P4-M3/SS2P4-M3/84AIC3D15; D18; D27
ST_SOD523DIODE_ST_SOD523_SCHOTTKY DIODE_Schottky DiodeIC3D8; D13; D14
ST_ST0201DIODE-SCHOTTKY-SK32_ST_ST0201_EESD, 8.5VIC1D9
SWITCH-EVQ-PE105K_5MMSWITCH EVQ-PE105K 5_0.0MM_SWITCEVQ-PE105KIO1SW1
TP-43R_STEST_POINT_TP-43R_S_DISCRETE_BLBLACKDISCRETE2TP1; TP3
TP-43R_STEST_POINT_TP-43R_S_DISCRETE_REREDDISCRETE8TP2; TP6; TP7; TP8; TP9; TP14; TP15; TP16
TPS2553AOZ1050PI_9_TPS2553_TPS2553_TPSTPS2553IC1U26
TSSLP2-4PGB1010603MR_TSSLP2-4_ESD105-B1ESD105-B1-02ELIC8ESD1; ESD2; ESD3; ESD4; ESD6; ESD7; ESD8; ESD9
TSSOP8_0_65U5AT93C66AIC1U25
TSSOP-824LC128_1_TSSOP-8_128KBIT_CAT24128KBITIC1U6
UEA1112C-4HK1-4HUEB111_TX_UEA1112C-4HK1-4H_UEA1UEA1112C-4HK1-4HIC1J6
USB-PD_TYPE-CUSB-PD_TYPE-C_9_USB-PD_TYPE-C_UUSB-PD_TYPE-C_PLUGIC1J10
附件:
原理图和Pcb文件
游客,如果您要查看本帖隐藏内容请回复
: t0 m' h6 @* M2 L* T4 [  K
推荐
发表于 2021-6-8 11:21 | 只看该作者
楼主您好,关于LTC3789的使用,特别是LAYOUT是否有参考设计呢?想借鉴一下,多谢
推荐
发表于 2021-12-7 14:59 | 只看该作者
学习学习学习学习学习学习学习学习学习学习学习学习学习
- d, }& j' Q) N+ J
推荐
发表于 2021-5-4 13:58 | 只看该作者
无意中看到学习学习   多谢楼主
4 ~) U* U& y& P6 |
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2020-4-15 17:58 | 只看该作者
    谢谢楼主的分享
    “来自电巢APP”
    发表于 2020-4-30 08:25 | 只看该作者
    谢谢楼主的分享!
    2024-8-26 15:16
    发表于 2020-4-30 12:14 | 只看该作者
    多谢分享资料
    ( Q1 ~2 c/ A% K) o
    2020-6-29 15:14
    发表于 2021-4-9 17:19 | 只看该作者
    大牛啊啊啊
    发表于 2021-5-4 11:17 | 只看该作者
    1111111111
    发表于 2021-6-4 09:29 | 只看该作者
    多谢分享,支持
    4 x+ ~! B4 c. n2 e* ^3 M8 b
    发表于 2021-6-7 13:20 | 只看该作者
    谢谢楼主的分享
    发表于 2021-8-3 16:14 | 只看该作者
    谢谢楼主的分享
    13#
    发表于 2021-8-10 14:37 | 只看该作者
    以后有有有有有有# H# u# z  W7 C' U( W& r$ y: y
    15#
    发表于 2021-12-6 13:50 | 只看该作者
    6 ~, ?1 j( d' G; X/ c+ \8 k  N
    谢谢楼主的分享!
    2025-7-11 15:10
  • 签到天数: 556 天
    [LV.9]以坛为家II
    16#
    发表于 2021-12-6 19:55 | 只看该作者
    下载看看。学习一下。
    GMT+8, 2025-7-17 04:23 , Processed in 0.187500 second(s), 29 queries , Gzip On.
