查看: 216|回复: 0
[AD 10][2层] 开发板(S3C4510B+AC101TF+MAX232)原理图、PCB源文件
发表于 2020-1-6 13:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][2层] 开发板(S3C4510B+AC101TF+MAX232)原理图、PCB源文件
! R( K9 P$ s' H
4 N) O3 ]* N; D8 A* \* R文件描述1 N# H$ G, M! W+ c: N1 |
1. 作品用途:开发板6 [# Y( O& s6 R& K- ~/ K6 ^
2. 软件版本:AD 10# [) S: u" ~3 D( r  c0 o; c
3. 层数:2层板% m8 u* q8 @2 v) C
4. 用到的主要芯片:S3C4510B+AC101TF+MAX232
5 b' h# r% i5 U3 p6 C; \+ j9 h6 T5. PCB尺寸:172mm*121mm7 @) h& u; F1 v, d6 n7 ^1 T
7 ~4 t9 W# J$ t) r) W; t
作品截图如下:
  f' b" H$ }1 F) o顶层截图:3 C* s2 X1 ?1 S
9 m+ Z7 W! T5 w底层截图:
4 s1 a0 }, m7 P" K$ A4 w
, u8 z2 `& u- {+ x' i! h& D全层截图:
( F3 u/ g1 `5 c( t
( h2 O6 R9 q  i* j" V- R6 a- C叠层信息截图如下:# E( \/ h) c6 }6 k5 f
4 B- C8 F  ]1 g3 r" f3 [BOM:" L& q6 ]; U1 U1 c' T0 ?- s
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
0.1uC1, C2, C3, C4, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C41, C42, C43, C51, C52, C53, C54, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C95, C101, C102, C103, C104, C105, C106, C107, C108, C109, C110, C111, C114, C118, C131, C1320603
83
820pFC330805
0.1uC340805
0.01uC350805
18PC112, C1130805
0.001u(2kV)C115, C116RAD0.2
CON3CON1POWER
CON2FKV14SN
DB9CON3, CON4DB9MLE
DB25CON5DB25SLW
RJ45CON6RJ45
CON2CON7POWER2
CON26X2-2.54CON10, CON11, CON12, CON13CON26X2-2.54
IN4148D10805
IN4004D21812
200uF/25VE1BIG_ELEC1
100uF/16VE2, E3BIG_ELEC2
4.7uF/16VE4BIG_ELEC3
10u(Tan)E5, E6, E7, E83216
FUSE1.5AF1RAD0.2
CON3J1, J2, J3, J4, J8SIP3
CON2J9SIP2
1uHL13528
GREENLED1, LED2, LED3, LED4, LED5, LED6LED
GRELED7, LED8, LED9, LED10, LED11LED
REDLED12, LED15, LED16, LED17, LED18, LED19, LED20, LED21, LED22LED
9
S3C4510BmcuQUAD208
50MHzOSC1OSC-50MHZ
25MHzOSC2XTAL1
LM7805POWER1D-PAK
MIC29150POWER2TO-220-3S
10kPTPT
680R10805
10kR2, R30805
0/33R40805
4.7kR5, R6, R7, R12, R13, R14, R89, R90, R91, R920805
10
22R11, R22, R260805
22R21, R23, R24, R250603
330/680R31, R32, R33, R34, R35, R81, R82, R83, R84, R85, R86, R87, R880805
13
1.5kR410805
0R420805
10k(1%)R430805
1kR44, R450805
100R460805
49.9R47, R480603
75R49, R50, R51, R520805
330R53, R54, R55, R56, R57, R580805
2kR93, R940805
S1SWITCH1
SWS2, S4SWITCH4
S3RESET
SW-PBS5, S6, S7, S8RESET
7414U1, U18SO-14
7408U2SO-14
FLASHU3TSOP48
FLASH_512KBU4, U5PLCC32
HY57V641620HGT-7/KM416S4020BU6, U7TSOP54
MAX232U8, U9, U10, U11, U12SO-16
AC101TFU13TQFP80
H1102U14H1102
CON14U19FKV14SN
KS24C641U20DIP8
附件:' a% H- T5 o& o* _
原理图和PCB源文件如下:/ K5 \9 f: g; A2 E/ A
游客,如果您要查看本帖隐藏内容请回复
7 L6 \' E. P0 G+ B/ g
7 u$ q: g1 P6 O: w
GMT+8, 2025-7-21 05:52 , Processed in 0.125000 second(s), 28 queries , Gzip On.
