Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
4PSO | SW PUSHBUTTON-SPST-2/SM_4PSO_KS | KST241GLFS | IC | 2 | SW2; SW3 |
8MSOP | TPS3707-DGNG_8MSOP_TPS3707-DGNG | TPS3707-DGNG | IC | 1 | U23 |
8SOIC | FDS3672_8SOIC_FDS3672 | FDS3672 | IC | 1 | Q1 |
10DGQ | TPS51100_10DGQ_TPS51100 | TPS51100 | IC | 1 | U1 |
12MM | BATTERY_12MM_12MM | 12MM | IC | 1 | BT5 |
16SMT | DFM-DIP-SW-8_16SMT_219-8MSTP | 219-8MSTP | IC | 1 | SW1 |
20PWP | TPS54316PWPG4_0_20PWP_TPS54316P | TPS54316PWPG4_0 | IC | 1 | U4 |
20PWP | TPS54310PWP_20PWP_TPS54310PWP | TPS54310PWP | IC | 1 | U17 |
25MILSQPOST | T POINT R_25MILSQPOST_T POINT R | T POINT R | IC | 32 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32 |
28PWP | TPS546_0_28PWP_TPS54615 | TPS54615 | IC | 1 | U7 |
28PWP | TPS546_0_28PWP_TPS54614 | TPS54614 | IC | 1 | U12 |
48TFBGA | DFM-XCF08P-FSG48C_48TFBGA_XCF16 | XCF16PFSG48C | IC | 2 | U8; U10 |
402 | CAP NP_0402_1000PF | 1000pF | DISCRETE | 4 | C11; C154; C163; C164 |
402 | CAP NP_0402_0.047UF | 0.047uF | DISCRETE | 6 | C16; C41; C45; C57; C63; C79 |
402 | CAP NP_0402_0.22UF | 0.22uF | IC | 7 | C174; C176; C184; C185; C191; C195; C200 |
402 | CAP NP_0402_0.1UF | 0.1uF | IC | 1 | C224 |
402 | R_0402_100 | 100 | DISCRETE | 79 | R29; R50; R56; R108; R155; R158; R163; R164; R165; R166; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R200; R201; R202; R203; R205; R206; R207; R208; R209; R210; R212; R215; R216; R218; R220; R221; R223; R224; R225; R226; R229; R230; R231; R232; R234; R236; R237; R238; R239; R240; R241; R242; R243; R245; R246; R247; R250; R251; R252; R253; R254 |
603 | CAP NP_0603_0.1UF | 0.1uF | DISCRETE | 146 | C9; C12; C13; C14; C15; C18; C19; C20; C24; C25; C26; C32; C36; C37; C42; C43; C44; C48; C49; C50; C54; C55; C56; C59; C60; C61; C62; C65; C66; C67; C69; C71; C72; C77; C78; C80; C82; C84; C86; C87; C88; C89; C92; C93; C95; C96; C101; C102; C104; C105; C106; C107; C108; C109; C111; C113; C115; C120; C121; C125; C127; C131; C133; C135; C139; C141; C143; C146; C148; C150; C152; C159; C161; C166; C170; C172; C178; C180; C182; C186; C187; C188; C189; C197; C198; C201; C203; C204; C205; C206; C207; C208; C209; C210; C212; C213; C214; C215; C216; C218; C219; C220; C221; C222; C225; C226; C227; C230; C231; C232; C233; C234; C235; C236; C237; C239; C240; C241; C242; C243; C245; C246; C248; C250; C251; C252; C253; C255; C257; C258; C259; C260; C261; C262; C263; C265; C266; C268; C271; C274; C275; C276; C277; C280; C281; C282 |
603 | CAP NP_0603_1UF | 1uF | DISCRETE | 2 | C10; C21 |
603 | CAP NP_0603_0.01UF | 0.01uF | IC | 19 | C17; C22; C29; C30; C33; C34; C35; C46; C51; C52; C64; C73; C81; C90; C91; C97; C117; C118; C272 |
603 | CAP NP_0603_0.068UF | 0.068uF | IC | 4 | C38; C58; C94; C140 |
603 | CAP NP_0603_27PF | 27pF | DISCRETE | 8 | C123; C126; C128; C129; C132; C134; C137; C283 |
603 | CAP NP_0603_3900PF | 3900pF | IC | 1 | C136 |
603 | CAP NP_0603_100PF | 100pF | IC | 1 | C138 |
603 | CAP NP_0603_47NF | 47nF | IC | 1 | C144 |
603 | CAP NP_0603_33PF | 33pF | IC | 1 | C149 |
603 | CAP NP_0603_12PF | 12pF | DISCRETE | 2 | C168; C175 |
603 | CAP NP_0603_5.0PF | 5.0pF | IC | 2 | C177; C264 |
603 | CAP NP_0603_2700PF | 2700pF | IC | 1 | C286 |
603 | DFM-BEAD_0603_MI0603J680R-10 | MI0603J680R-10 | IC | 2 | F1; F2 |
603 | INDUCTOR_0603_MI0603J680R-10 | MI0603J680R-10 | IC | 3 | FB2; FB9; FB10 |
603 | R_0603_4.7K | 4.7K | DISCRETE | 46 | R1; R3; R15; R20; R22; R25; R26; R27; R28; R32; R35; R37; R45; R46; R47; R48; R51; R52; R54; R55; R57; R58; R60; R62; R72; R73; R76; R77; R82; R83; R84; R85; R86; R87; R93; R131; R134; R136; R142; R143; R154; R156; R157; R204; R257; R259 |
603 | R_0603_0 | 0 | DISCRETE | 15 | R2; R8; R12; R14; R18; R39; R53; R121; R124; R125; R126; R138; R151; R153; R263 |
603 | R_0603_NO POP | NO POP | IC | 6 | R5; R6; R7; R9; R16; R36 |
603 | R_0603_10K | 10K | DISCRETE | 13 | R10; R30; R31; R33; R102; R106; R107; R139; R141; R160; R248; R249; R261 |
603 | R_0603_NP | NP | DISCRETE | 24 | R11; R17; R38; R40; R49; R64; R65; R66; R68; R100; R101; R109; R111; R130; R133; R135; R137; R148; R152; R169; R211; R222; R260; R265 |
603 | R_0603_100K | 100k | DISCRETE | 2 | R13; R127 |
603 | R_0603_1K | 1K | DISCRETE | 17 | R19; R24; R59; R63; R67; R69; R70; R74; R75; R79; R81; R95; R140; R213; R219; R255; R256 |
603 | R_0603_51.1 | 51.1 | DISCRETE | 14 | R21; R23; R122; R123; R128; R132; R161; R162; R167; R185; R199; R217; R235; R244 |
603 | R_0603_22.1 | 22.1 | DISCRETE | 7 | R34; R44; R112; R114; R118; R119; R145 |
603 | R_0603_36 | 36 | DISCRETE | 8 | R71; R94; R96; R97; R98; R99; R105; R258 |
603 | R_0603_0.05 | 0.05 | DISCRETE | 6 | R88; R89; R90; R92; R214; R233 |
603 | R_0603_82.0K | 82.0k | IC | 1 | R103 |
603 | R_0603_3.74K | 3.74K | IC | 1 | R104 |
603 | R_0603_100 | 100 | IC | 1 | R113 |
603 | R_0603_432K | 432k | IC | 1 | R115 |
603 | R_0603_49.9K | 49.9k | IC | 1 | R116 |
603 | R_0603_20K | 20k | DISCRETE | 1 | R129 |
603 | R_0603_2.2K | 2.2k | DISCRETE | 6 | R144; R149; R159; R168; R227; R228 |
603 | R_0603_62 | 62 | IC | 3 | R146; R147; R150 |
603 | R_0603_732 | 732 | IC | 1 | R262 |
603 | R_0603_49.9 | 49.9 | IC | 1 | R264 |
805 | INDUCTOR_0805_BLM21PG600SN1D | BLM21PG600SN1D | IC | 3 | FB3; FB7; FB8 |
1206 | CAP NP_1206_4.7UF | 4.7uF | IC | 2 | C142; C145 |
1206 | INDUCTOR_1206_HI1206T500R-10 | HI1206T500R-10 | IC | 5 | FB1; FB4; FB5; FB6; FB11 |
1206 | R_1206_0 | 0 | IC | 11 | R4; R41; R42; R43; R61; R78; R80; R91; R110; R117; R120 |
1210 | CAP NP_1210_10UF | 10uF | IC | 7 | C1; C5; C7; C39; C68; C99; C147 |
CONN38 | MICTOR19X2_CONN38_2-767004-2 | 2-767004-2 | IC | 2 | J8; J9 |
CUI_PJ-047BH | PJ1-022-SMT_CUI_PJ-047BH_CUI PJ | CUI PJ-047BH | IC | 1 | J12 |
HDR7X2 | HEADER 7X2/SM_HDR7X2_87832-1420 | 87832-1420 | IC | 1 | H1 |
JUMPER2 | HEADER 2_JUMPER2_TSW-102-05-F-S | TSW-102-05-F-S | IC | 4 | J4; J7; J10; J11 |
MOLEX_43045-0412 | CONN PWR 2X2-P_MOLEX_43045-0412 | Molex 43045-0412 | IC | 1 | J18 |
MOLEX_054819-0589 | UX50-MB-5ST_MOLEX_054819-0589_0 | 054819-0589 | IC | 1 | J1 |
OMRON_A6S-1104-H | SW SPST_OMRON_A6S-1104-H_SPST A | SPST A6S-1104-H | IC | 1 | SW4 |
OSC4PIN | EC2700TTS-50_0.000M_OSC4PIN_EC2 | EC2700TTS-50_0.000M | IC | 1 | U9 |
POWERDI123 | DIODE ZENER_POWERDI123_10V | 10V | IC | 1 | D8 |
SM_CM14_0805 | CHOKE CM14_SM_CM14_0805_DLW21HN | DLW21HN900SQ2L | IC | 1 | L10 |
SM_CONN_8397_BOARD | 7840-LVDS-DMD_SM_CONN_8397_BOAR | 7840-LVDS-DMD | IC | 2 | J13; J14 |
SM_CONN_MOLX_532611071 | HEADER 10/SM_SM_CONN_MOLX_53261 | 53261-1071 | IC | 2 | J3; J6 |
SM_DIO_SMA | DIODE SCHOTTKY_SM_DIO_SMA_10MQ0 | 10MQ060NPBF | IC | 4 | D4; D5; D6; D7 |
SM_DIO_SMA | DIODE TS_SM_DIO_SMA_DIODE TS | DIODE TS | IC | 1 | D13 |
SM_DO1813H | INDUCTOR_SM_DO1813H_1.2UH | 1.2uH | IC | 1 | L9 |
SM_DO3316H | INDUCTOR_SM_DO3316H_3.3UH | 3.3uH | IC | 2 | L2; L3 |
SM_DO3316P | INDUCTOR_SM_DO3316P_4.7UH | 4.7uH | IC | 1 | L1 |
SM_FF676 | XC5VLX30FF676_SM_FF676_XC5VLX30 | XC5VLX30FF676 | IC | 1 | U11 |
SM_FF1153 | XC5VLX50FF1153_13_SM_FF1153_XC5 | XC5VLX50FF1153 | IC | 1 | U5 |
SM_IND_DT1608C | INDUCTOR_SM_IND_DT1608C_22UH | 22uH | IC | 4 | L4; L5; L6; L7 |
SM_LED_0603 | LED_SM_LED_0603_SML-310MTT86 | SML-310MTT86 | IC | 7 | D1; D9; D10; D11; D12; D16; D17 |
SM_LED_0603 | LED_SM_LED_0603_SML-310VTT86 | SML-310VTT86 | IC | 2 | D2; D3 |
SM_LITTELFUSE_MRL | FUSE_SM_LITTELFUSE_MRL_FUSE | FUSE | IC | 1 | F5 |
SM_QSE_120 | QSE-060-01_SM_QSE_120_QSE-060-0 | QSE-060-01 | IC | 2 | J16; J17 |
SM_RP4X0603 | RESISTOR DIP 4 A-D_SM_RP4X0603_ | 47 | DISCRETE | 6 | RP5; RP6; RP7; RP8; RP9; RP10 |
SM_RP8X0603 | RSNETWORKX8_SM_RP8X0603_10 | 10 | DISCRETE | 4 | RN1; RN2; RN3; RN4 |
SM_SDR0403 | INDUCTOR_SM_SDR0403_4.7UH | 4.7uH | IC | 1 | L8 |
SM_SN74_SOP8 | SN74AVC2T45DCU_SM_SN74_SOP8_SN7 | SN74AVC2T45DCU - NO POP | IC | 2 | U2; U6 |
SM_SODIMM_59354 | SODIMM-200_SM_SODIMM_59354_SODI | SODIMM-200 | IC | 1 | J15 |
SM_SOT523_3 | DIODE_DUAL_CK_AAJ_SM_SOT523_3_B | BAV170T-7-F | IC | 1 | D15 |
SM_SOT553-5_2 | TPD2E001DRLR_SM_SOT553-5_2_TPD2 | TPD2E001DRLR | IC | 1 | D14 |
SM_TI_DRC10 | TPS61081_SM_TI_DRC10_TPS61081 | TPS61081 | IC | 1 | U16 |
SM_TI_ZKE96 | SN74CB3Q32245_SM_TI_ZKE96_SN74C | SN74CB3q32245 | IC | 1 | U20 |
SM_TPQF128_CYPRESS | CY7C68013_128_SM_TPQF128_CYPRES | CY7C68013A_128 | IC | 1 | U18 |
SM_TSOP28_468 | AT45DB642D_SM_TSOP28_468_AT45DB | AT45DB642D - NO POP | IC | 1 | U3 |
SM_TSSOP8_174 | EPROM 24LC256_SM_TSSOP8_174_EPR | EPROM 24LC128 | IC | 1 | U19 |
SM_XTAL_275X200 | CRYSTAL_SM_XTAL_275X200_24.000M | 24.000MHz | IC | 1 | Y5 |
SOT23 | MMBTH69L_SOT23_MMBT2369LT1G | MMBT2369LT1G | IC | 1 | Q5 |
SOT23-5 | TPS2400_SOT23-5_TPS2400 | TPS2400 | IC | 1 | U15 |
SOT23-5 | SN74AUP1G00DBVR_SOT23-5_SN74AUP | SN74AUP1G00DBVR | IC | 1 | U22 |
TANT_A | CAP POL_TANT_A_10UF | 10uF | DISCRETE | 6 | C23; C27; C28; C53; C228; C229 |
TANT_B | CAP POL_TANT_B_33UF | 33uF | IC | 18 | C2; C3; C4; C6; C112; C153; C155; C162; C167; C171; C181; C183; C190; C192; C194; C199; C211; C217 |
TANT_B | CAP POL_TANT_B_47UF | 47uF | IC | 25 | C8; C31; C74; C75; C76; C83; C156; C157; C158; C160; C165; C169; C173; C179; C193; C196; C202; C223; C249; C267; C269; C270; C273; C278; C279 |
TANT_B | CAP POL_TANT_B_10UF | 10uF | DISCRETE | 6 | C110; C122; C238; C247; C254; C256 |
TANT_C | CAP POL_TANT_C_4.7UF | 4.7uF | DISCRETE | 4 | C116; C119; C124; C130 |
TANT_C | CAP POL_TANT_C_222UF | 222uF | IC | 1 | C151 |
TANT_C | CAP POL_TANT_C_NO-POP | NO-POP | IC | 1 | C285 |
TANT_D | CAP POL_TANT_D_680UF | 680uF | IC | 3 | C40; C85; C103 |
TANT_D | CAP POL_TANT_D_100UF | 100uF | IC | 4 | C47; C70; C98; C287 |
TANT_D | CAP POL_TANT_D_470UF | 470uF | IC | 1 | C100 |
TANT_D | CAP POL_TANT_D_330UF | 330uF | DISCRETE | 2 | C114; C284 |
TANT_D | CAP POL_TANT_D_NO-POP | NO-POP | IC | 1 | C244 |
TH_CONN_3POS_100 | CON3_TH_CONN_3POS_100_CON3 | CON3 | IO | 1 | J5 |
TH_HEADER_5X3 | HEADER 5X3_TH_HEADER_5X3_HEADER | HEADER 5x3 | IC | 1 | J2 |
TH_MTH_140D250P | MOUNT_HOLE_TH_MTH_140D250P_MOUN | MOUNT_HOLE | IC | 4 | MT1; MT2; MT3; MT4 |
TQFP80 | DAD2000_0_TQFP80_DAD2000_0 | DAD2000_0 | IC | 2 | U13; U14 |
TSSOP16 | SN74CB3T3253_TSSOP16_SN74CB3T32 | SN74CB3T3253 | IC | 1 | U21 |
附件:
