本帖最后由 Sapir_BI 于 2020-1-3 14:54 编辑 5 i% B- A" K$ I/ l
# T' g( ?' N/ k" r! S
作品名:[AD 10][4层] 开发板(S3C2410A+74LVC14+MAX3232)原理图、PCB源文件
3 T5 ~* k8 S5 i& x3 i
: Q7 p S" R) M8 K+ s9 F% ^文件描述
( |4 z- Z+ ^" q5 G0 Y1. 作品用途:开发板( M% L3 t( S0 G& Z0 D3 c# n1 R
2. 软件版本:AD 10
) _) Y# U( N7 v3. 层数:4层板6 a7 f: K @7 P
4. 用到的主要芯片:S3C2410A+74LVC14+MAX32327 E3 X* h b- _1 S* b/ K, O% u# r" M
5. PCB尺寸:120mm*78mm
8 R7 r" Q2 r ^3 Q* k" f
1 X9 |0 b) O/ B2 m7 R, T& ^作品截图如下:
+ E$ Z0 K, [. ^: W- n J6 t8 x顶层截图:$ Z+ ]; r6 [4 D- c) |" J
5 Z/ C2 _2 a# k5 U& @底层截图:
: q1 y' I' W! i2 X4 l. _
# G7 V% H) q3 j全层截图:' U% Z2 \: x# B# \* v6 x( W
1 [5 b. E- c- l6 S F$ b$ d/ L' Y叠层信息截图如下:6 A ?3 P" i3 q5 u, h2 |" k: r
3 ]" J# X9 x5 ZBOM:
: I8 @7 F) Z# W E" z$ MComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10uF/16V | C1, C2, C3, C4, C6, C7, C8, C9, C10, C11, C12, C72, C74, C76, C77, C78, C79, C80 | A型钽电容 | 18 | 100nF | C5, C13, C14, C15, C16, C23, C27, C29, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C45, C46, C47, C49, C50, C53, C54, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C65, C66, C67, C68, C69, C70, C71, C95, C99, C100 | 0603A | 46 | 22pF | C19, C20, C21, C22 | 0603A | 4 | 1nF | C24, C25 | 0603A | 2 | 1uF/16V | C26 | A型钽电容 | 1 | 10nF/2KV(Unload) | C28, C30 | 1206A | 2 | 0.027uF(Unload) | C31, C32 | 1206A | 2 | 100uF/16V | C81, C82, C83, C85, C86 | D型钽电容 | 5 | 1uF | C87, C88, C89, C90, C91, C92 | 0805A | 6 | 560pF | C93 | 0603A | 1 | 10nF/2KV | C94 | 1206A | 1 | +5V | CN1 | DCJACK | 1 | HEADER 80X2 | CON1, CON2 | IDC80F2.0 | 2 | 0.4V/1a/30V | D1, D2 | SOD123 | 2 | 1N4148 | D5 | SOT-23D | 1 | miniSMDC150 | F1 | FU4532 | 1 | JTAG | J1 | HD20 | 1 | PWREN | JP1 | OP0603 | 1 | OM0 | JP2 | SIP2 | 1 | nBATT_FLT | JP3 | 0805A | 1 | NCON | JP4 | 0603A | 1 | LADDR24/25 | JP5 | OP0603 | 1 | LADDR25/26 | JP6 | OP0603 | 1 | FB/120 | L1, L2 | 0805A | 2 | GREEN | LED1, LED2, LED3, LED4 | LED_0805S | 4 | POWER | LED5 | LED_0805S | 1 | 0 | R9, R10, R11, R12, R15, R53, R56, R57, R58, R59, R60 | 0603A | 11 | 2.2K, 1% | R14 | 0603A | 1 | 1K, 1% | R16 | 0603A | 1 | 10K | R17, R27 | 0603A | 2 | 4.7K | R18, R28, R29, R30, R31, R32, R33, R34, R35, R36, R44, R45, R54, R55 | 0603A | 14 | 22 | R19, R41, R42, R43 | 0603A | 4 | 1M | R20 | 0603A | 1 | 1K | R21, R23, R24, R25, R26, R37, R38, R39, R40 | 0603A | 9 | 470 | R22 | 0603A | 1 | 75 | R46, R47, R48 | 0603A | 3 | 8R, 1% | R49, R50 | 0603A | 2 | 100, 1% | R51 | 0603A | 1 | 4.99K, 1% | R52 | 0603A | 1 | RJ45-LED | RJ1 | RJ45L | 1 | 10K | RP1 | RP4 | 1 | 22 | RP5 | RP4 | 1 | RESET | S1 | SW6X6-SMD | 1 | EINT11 | S2 | SMDSW4X4 | 1 | EINT14 | S3 | SMDSW4X4 | 1 | EINT15 | S4 | SMDSW4X4 | 1 | EINT19 | S5 | SMDSW4X4 | 1 | nRSTOUT | TP1 | TEST5028 | 1 | VIN1 | TP4 | TEST5028 | 1 | PWMDAC | TP5 | TEST5028 | 1 | S3C2410A | U1 | FBGA272 | 1 | SPX1117M3-3.3 | U2 | SOT-223A | 1 | SPX1117M3 | U3 | SOT-223A | 1 | 74LVC14 | U5 | SO14 | 1 | MAX3232 | U6 | SO16 | 1 | 74LVC32 | U7, U8 | SO14 | 2 | CS8900A-CQ3 | U9 | LQFP100 | 1 | H16106SN | U10 | 10/100TRAN | 1 | K4S561632(32MB) | U11, U12 | TSOPII54 | 2 | K9XXX08 | U13 | TSOP48 | 1 | Terminal | UART1 | DB9F | 1 | 10K | W1 | VR4 | 1 | 12MHz | Y1 | S49 | 1 | 32.768KHz | Y2 | EC0.1 | 1 | 20.0MHz | Y3 | S49 | 1 | 附件:
6 |5 N1 P9 [) l1 F原理图和PCB源文件如下:' l3 n; |9 N' @+ L
* n+ w- ], u t& f: q$ E8 F
0 d# Y2 O3 I. J9 ^
