查看: 2702|回复: 27
[allegro16.6][4层]RK3326 AI智能语音方案子(RK3326+K4B4G1646Q+KLMAG2GEAC-B031...
发表于 2020-1-2 14:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][4层]RK3326 AI智能语音方案子(RK3326+K4B4G1646Q+KLMAG2GEAC-B031)pcb文件
文件描述:
1. 作品用途:RK3326 AI智能语音方案
2. 软件版本:allegro16.6
3. 层数:4层
4. 用到的主要芯片:RK3326+K4B4G1646Q+KLMAG2GEAC-B031
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
ANTPCB_44R00X11R00_DSRANT_1P1G_ANTPCB_44R00X11R00_DSRANT4411DRIC1ANT6100
ANT_JACKANT_1P2G_ANT_JACK_ANT_JACKANT_JACKIC1ANT6101
BAT3_2R54BATT3_BAT3_2R54_BAT3_2R54BAT3_2R54IC1BT2001
BGA169_18R00X14R00X1R20_2LINAND_EMMC_169_2L_BGA169_18R00XKLMAG2GEAC-B031IC1U4100
BGA418_14R00X14R00X1R24mcu_RK3326_BGA418_14R00X14R00X1RK3326IC1U1000
C0402CAP NP_C0402_100NF100nFIC110C1001; C1002; C1003; C1004; C1005; C1006; C1008; C1009; C1010; C1011; C1012; C1013; C1100; C1103; C1104; C1105; C1106; C1107; C1108; C1201; C1202; C1203; C1204; C1205; C1206; C1300; C1400; C1401; C1402; C1500; C1501; C1600; C1601; C1701; C1702; C1703; C1704; C1800; C1801; C1802; C2000; C2002; C2006; C2014; C2015; C2021; C2023; C2025; C2026; C2057; C2129; C2132; C2137; C2139; C2141; C2501; C3003; C3004; C3005; C3006; C3007; C3008; C3009; C3010; C3011; C3021; C3022; C3023; C3024; C3025; C3026; C3027; C4001; C4003; C4102; C4104; C4105; C4601; C4602; C4603; C4606; C4608; C4702; C4704; C4707; C5101; C6102; C6107; C7002; C7003; C7004; C7145; C7147; C7150; C7152; C7208; C7209; C7212; C7214; C7221; C7223; C7224; C9012; C9100; C9201; C9601; C9603; C9604; C9605; R2161
C0402CAP NP_C0402_4.7UF4.7uFIC10C1014; C1015; C1200; C4000; C4002; C4101; C4103; C4605; C4706; C6108
C0402CAP NP_C0402_2.2UF2.2uFIC7C1016; C2122; C2133; C2135; C2136; C2138; C2140
C0402CAP NP_C0402_22PF22pFIC6C1101; C1102; C2130; C2131; C6104; C6105
C0402CAP NP_C0402_100PF100pFIC2C2003; C3000
C0402CAP NP_C0402_1NF1nFIC18C2012; C2050; C3014; C3015; C3016; C3017; C3018; C7100; C7101; C7113; C7121; C7128; C7133; C7134; C7135; C7144; C7146; C9202
C0402CAP NP_C0402_47NF47nFIC1C2018
C0402CAP NP_C0402_1UF1uFIC30C2020; C2027; C2054; C2100; C2103; C2107; C2108; C2109; C2111; C2112; C2113; C2117; C2118; C2119; C2120; C2121; C2123; C2127; C2128; C2502; C4100; C4703; C4705; C6106; C7114; C7119; C7140; C9010; C9011; C9602
C0402CAP NP_C0402_10NF10nFIC6C3012; C3013; C7106; C7112; C7126; C7127
C0402CAP NP_C0402_8PF8pFIC3C4600; C4700; C4701
C0402CAP NP_C0402_27PF27pFIC1C6003
C0402CAP NP_C0402_47PF47pFIC1C6016
C0402CAP NP_C0402_3PF3pFIC1C6100
C0402CAP NP_C0402_DNPDNPIC1C6109
C0402CAP NP_C0402_330PF330pFIC4C7109; C7116; C7118; C7124
C0603CAP NP_C0603_22UF22uFIC8C1000; C1007; C2104; C2106; C2114; C2116; C2125; C2126
C0603CAP NP_C0603_10UF10uFIC20C2005; C2024; C2101; C2102; C2105; C2110; C2115; C2124; C2134; C2500; C3001; C3002; C3019; C3020; C4604; C4607; C5100; C6101; C9101; C9600
C0603CAP NP_C0603_1UF1uFIC5C2022; C7107; C7111; C7120; C7122
C0603CAP NP_C0603_100NF100nFIC2C7102; C7129
C0603CAP NP_C0603_2.2UF2.2uFIC4C7105; C7110; C7125; C7131
C0603CAP NP_C0603_220NF220nFIC4C7108; C7115; C7117; C7123
C0603CAP NP_C0603_4.7UF4.7uFIC7C7207; C7210; C7211; C7220; C7222; C7225; C9200
C0805CAP NP_C0805_10UF10uFIC4C2001; C2019; C2036; C2052
C0805CAP NP_C0805_22UF22uFIC4C2004; C2010; C2016; C2017
C0805CAP NP_C0805_2.2UF2.2uFIC1C2051
CNN2_2R00_6R30X4R90X6R30_VJACK_1500_0_CNN2_2R00_6R30X4R90JACK_1500_2PIC3J2100; J7100; J7101
CNN30_1R00_FP05SL_VLCD_HITACHI_TX05D99VM1AAA_1_CNN30PIN FPC CONIC2J7201; J7202
CON2_1X2_5R08_DIPGND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATEIC2J9901; J9902
CON30F_2X15_0R40_OK_14F030_04OK-14GM030-04_CON30F_2X15_0R40_OK-14GM030-04IC1J4601
CON30M_2X15_0R40_V_SMTCMK-CB0077-FV1_2_CON30M_2X15_0RAXT530124IC1J4600
CRY2_6R90X1R40X1R30CRYSTAL_2P_1G_CRY2_6R90X1R40X1R32.768KHzIC1Y2100
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzIC1Y1100
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R8_126MHzIC1Y6100
DC3_DC_0007_5PDCJACK_3P_DC3_DC_0007_5P_DC-000DC-0007-5PIC1J2000
DO_214ACDIODE_DO_214AC_SS32SS32IC1D2001
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD54ESD5451NIC11D4100; D9100; ED2003; ED2100; ED2101; ED7000; ED7001; ED7002; ED7003; ED7200; ED7201
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD53ESD5341NIC1ED2500
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD_1ESD5471XIC7ED9100; ED9101; ED9102; ED9103; ED9104; ED9105; ED9106
F8050FUSE_F8050_JK-SMD200LJK-SMD200LIC1F2000
FBGA96_14R00X11R00X1R20DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QIC2U3000; U3001
FPC24L_1X24_0R50_DOWNOV2659_FPC24L_1X24_0R50_DOWN_OVOV2659IC1J4700
FPC30R_0R50_UPFPC_MIPI/LVDS_FPC30R_0R50_UP_3030PIN FPC CONIC1J5100
HOLE_C3R20_C6R00HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20IC4H9900; H9901; H9902; H9903
IND_111114_DIPINDUCTORS OF FERRITE_IND_11111415uHIC4L7104; L7105; L7106; L7107
IND_252010INDUCTORS OF FERRITE_IND_252010470nHIC5L2100; L2101; L2102; L2103; L2104
IND_303012INDUCTORS OF FERRITE_IND_3030124.7uHIC1L6102
IND_404030INDUCTORS OF FERRITE_IND_4040303.3uHIC1L2000
IND_606028INDUCTORS OF FERRITE_IND_6060283.3uHIC1L2001
IND_808040INDUCTORS OF FERRITE_IND_80804015uHIC4L7100; L7101; L7102; L7103
IR-SIR8B39IR_RECEIVE_1_IR-SIR8B39_OQSS-R1OQSS-R12IC1IR9200
L0402INDUCTOR_L0402_DNPDNPIC2L6100; L6101
L0603BEAD_L0603_180R-100M180R-100MIC2FB4600; FB4700
L0603DINDUCTOR COM_L0603D_90R-100M90R-100MIC1FB2500
LED0603LED_LED0603_LED_BLUELED_BlueIC1LED2001
LED0603LED_LED0603_LED_REDLED_REDIC2LED2003; LED9600
MARKMARK_MARK_MARKMARKIC6M9900; M9901; M9902; M9903; M9904; M9905
MD44_AP6XXXMODULE_AP6XXX_MD44_AP6XXX_AP621AP6212IC1U6100
MODULE-8AL3006_0_MODULE-8_TMD27723TMD27723IC1U9010
MSOP10_3R00X3R00X1R10SWITCH_FSUSB30MUX_MSOP10_3R00X3FSUSB30MUXIC1U9602
MTM-CCM_C_MTM-C_100UF/25V100uF/25VIC2CM7100; CM7101
PJ6_D3R50_PJ35106SY-P10PHONEJACK_6P_PJ6_D3R50_PJ35106SPJ35106SY-P10IC1J7000
QFN24_5R65X3R65X1R00_TCHARGER_BQ24133_QFN24_5R65X3R65BQ24133IC1U2001
QFN68_7R00X7R00X0R80_TRK809_QFN68_7R00X7R00X0R80_T_RKRK809IC1U2100
R0402RESISTOR_R0402_22R22RIC53R1102; R1730; R1800; R1801; R1802; R1803; R1804; R1805; R1806; R1809; R1810; R1811; R1812; R1813; R1814; R4103; R4601; R4700; R4701; R7006; R7007; R7200; R7201; R7202; R7203; R7204; R7205; R7206; R7207; R7208; R7209; R7210; R7211; R7212; R7220; R7221; R7222; R7223; R7224; R7225; R7226; R7227; R7228; R7229; R7230; R7231; R7232; R7233; R9100; R9200; R9202; R9604; R9605
R0402RESISTOR_R0402_0R0RDISCRETE90R1103; R1104; R1105; R1106; R1107; R1110; R1111; R1112; R1115; R1128; R1300; R1401; R1402; R1403; R1501; R1510; R1601; R1602; R1702; R1703; R1704; R1705; R1707; R1709; R1711; R1713; R1715; R1717; R1719; R1721; R1723; R1726; R1731; R1807; R1815; R2060; R2070; R2073; R2101; R2102; R2104; R2106; R2107; R2109; R2111; R2113; R2115; R2120; R2122; R2125; R2136; R2137; R2138; R2139; R2150; R2151; R2152; R4001; R4002; R4004; R4005; R4102; R4602; R4703; R6003; R6100; R6110; R6112; R6118; R6119; R6120; R6121; R6122; R6136; R7005; R7022; R7023; R7101; R7105; R7111; R7114; R7115; R7116; R7124; R7134; R7256; R9001; R9601; R9602; R9603
R0402RESISTOR_R0402_2.2K2.2KIC6R1108; R1109; R1603; R1604; R2124; R2126
R0402RESISTOR_R0402_150K150KIC2R1120; R6116
R0402RESISTOR_R0402_180K180KIC4R1121; R6113; R6115; R6117
R0402RESISTOR_R0402_133R133RIC1R1400
R0402RESISTOR_R0402_51K51KIC2R1500; R1502
R0402RESISTOR_R0402_2K2KIC4R1600; R1701; R2079; R9600
R0402RESISTOR_R0402_75K75KIC1R2001
R0402RESISTOR_R0402_DNPDNPIC4R2002; R7122; R7123; R7145
R0402RESISTOR_R0402_10K10KIC10R2007; R2071; R2129; R2131; R2502; R4100; R4101; R4600; R4702; R7109
R0402RESISTOR_R0402_1M1MIC2R2010; R2018
R0402RESISTOR_R0402_22K22KIC1R2011
R0402RESISTOR_R0402_1K1KIC6R2014; R3004; R3005; R3006; R3007; R7004
R0402RESISTOR_R0402_4.7K4.7KIC14R2015; R2016; R2040; R2041; R2505; R4000; R4003; R7108; R7120; R7127; R7128; R7144; R7149; R9201
R0402RESISTOR_R0402_220K220KIC2R2019; R2020
R0402RESISTOR_R0402_27K27KIC3R2021; R2023; R2130
R0402RESISTOR_R0402_100K100KIC16R2022; R2088; R2128; R2504; R6108; R7103; R7113; R7118; R7119; R7121; R7125; R7126; R7142; R7143; R7250; R7251
R0402RESISTOR_R0402_10R10RIC2R2028; R7135
R0402RESISTOR_R0402_4.99K4.99KIC1R2033
R0402RESISTOR_R0402_30K30KIC1R2035
R0402RESISTOR_R0402_330R330RIC1R2036
R0402RESISTOR_R0402_100R100RIC4R2072; R2105; R2110; R2510
R0402RESISTOR_R0402_110K110KIC1R2112
R0402RESISTOR_R0402_120K120KIC2R2116; R6019
R0402RESISTOR_R0402_140K140KIC1R2118
R0402RESISTOR_R0402_20K20KIC1R2119
R0402RESISTOR_R0402_18K18KIC1R2503
R0402RESISTOR_R0402_240R240RIC2R3000; R3001
R0402RESISTOR_R0402_49.9R49.9RIC2R3002; R3003
R0402RESISTOR_R0402_150R150RIC1R6030
R0402RESISTOR_R0402_680R680RIC1R6050
R0402RESISTOR_R0402_68K68KIC2R6111; R6114
R0402RESISTOR_R0402_1.5K1.5KIC3R6130; R6132; R6134
R0402RESISTOR_R0402_1.8K1.8KIC3R6131; R6133; R6135
R0402RESISTOR_R0402_3.3R3.3RIC4R7102; R7104; R7110; R7117
R0603RESISTOR_R0603_2.2R2.2RIC2R2500; R2501
R0603RESISTOR_R0603_10R10RIC4R7100; R7106; R7107; R7112
R0805RESISTOR_R0805_330NH330nHIC1L6004
R0805RESISTOR_R0805_0.01R0.01RIC1R2061
R0805RESISTOR_R0805_0.02R0.02RIC8R2100; R2103; R2108; R2114; R2167; R7131; R7136; R9606
R0805RESISTOR_R0805_0R0RIC2R7129; R7130
R1206RESISTOR_R1206_0.01R0.01RIC5R2008; R2017; R2057; R2090; R2515
R1210RESISTOR_R1210_2R2RIC1R2050
SMT2_6R00X3R50X4R20SW PUSHBUTTON_SMT2_6R00X3R50X4RMaskromIC1SW4100
SMTSO_M3_C4R1_C6R0_L10R0SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJIC4SMTSO9900; SMTSO9901; SMTSO9906; SMTSO9907
SOD_323DIODE_SOD_323_B5819WSB5819WSIC1D2003
SOD_323DIODE_SOD_323_1N4148WS1N4148WSIC1D4101
SOP8_5R00X4R00X1R75SECURE_ATSHA204A_SOP8_5R00X4R00ATSHA204A-SSHDA-TIC1U7200
SOT_23MOSFET N_SOT_23_WNM3003-3/TRWNM3003-3/TRIC2Q2000; Q2001
SOT_23MOSFET P_SOT_23_WPM3407-3/TRWPM3407-3/TRIC1Q2002
SOT_23MOSFET N_SOT_23_WNM2016-3/TRWNM2016-3/TRIC1Q2500
SOT_23ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FIC2U2500; U9601
SOT_23_5SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACIC1U2507
SOT_23_6DCDC_SY8113_SOT_23_6_SY8113BSY8113BIC1U2000
SOT_89_3LDO_PT5108_1_SOT_89_3_SGM2203-5SGM2203-5.0IC1U2002
SOT_323MOSFET N_SOT_323_2SK30182SK3018IC4Q6100; Q6101; Q6102; Q7201
SOT_323MOSFET N_SOT_323_WNM6002-3/TRWNM6002-3/TRIC1Q7100
SSOP28_10R20X5R30X2R00INTERFACE_FT232RL_SSOP28_10R20XFT232RLIC1U9600
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_PWRPWRONIC1SW2000
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_RECRecoveryIC1SW2005
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_RESRESETIC1SW2100
TF9_CKT01_009DTFCARD_SOCKET_TF9_CKT01_009D_TFTF-CKT01-009DIC1J9100
TP_0R50TP_TP_0R50_TP_0.5TP_0.5IC2TP2101; TP2105
TP_0R70TP_TP_0R70_TP_0.7TP_0.7IC59TP2001; TP4600; TP4601; TP4602; TP4603; TP4604; TP4605; TP4606; TP4607; TP4608; TP4609; TP4610; TP4611; TP4612; TP4613; TP4614; TP4620; TP4700; TP4701; TP4702; TP4703; TP4704; TP4705; TP4706; TP4707; TP4708; TP4709; TP4710; TP4711; TP4712; TP4713; TP4714; TP4715; TP4716; TP5100; TP5101; TP5102; TP5103; TP5104; TP5105; TP5106; TP5107; TP5108; TP5109; TP5110; TP5111; TP5112; TP5113; TP5114; TP5115; TP5116; TP5117; TP9100; TP9101; TP9102; TP9103; TP9104; TP9105; TP9106
TSOP48_18R40X12R10X1R20NANDFLASH_TSOP48_TSOP48_18R40X1H27UBG8T2DTR-BCIC1U4000
TSSOP28_9R70X4R40X1R20_TTPA3110_TSSOP28_9R70X4R40X1R20_TPA3110IC1U7100
USB20MICRO5_MU05_10MGF_TUSB20_MICRO_USB20MICRO5_MU05_10USB20_microIC2J2500; J9600
附件:
Pcb文件
游客,如果您要查看本帖隐藏内容请回复
2 y' g4 a- [) G- `5 G
7 r) O( y1 K" s# L
推荐
发表于 2024-12-21 15:52 | 只看该作者
学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习
    2025-8-15 15:39
  • 签到天数: 50 天
    [LV.5]常住居民I
    推荐
    发表于 2025-3-27 23:06 | 只看该作者
    ]RK3326 AI智能语音方案子(RK3326+K4B4G1646Q+KLMAG2GEAC-B031... [[url=]修改[/url]]
    ) k' F) b% r" M6 p7 M# h( Y: G
    + }. l2 }( h4 K( s
    " [) S8 h7 \4 J; _) z9 Q
    . b6 h' z  k& Z' J' o
    2 k( |4 _- m; q: I$ q: n: K& u
    ; I/ f# E. H/ {7 U2 V4 e
    9 X0 k+ A) s' r/ ^. B1 m0 I( W
    : c# `: L9 D$ N% Q1 `; J9 K' g) m: z$ l3 H
    2025-8-17 15:01
  • 签到天数: 569 天
    [LV.9]以坛为家II
    推荐
    发表于 2020-7-15 17:28 | 只看该作者
    楼主把这个文件整成16.6版的吧
    0 p- i3 ]3 u2 c" Q# ?
    发表于 2020-7-8 23:08 | 只看该作者
    消灭零回复,我要看看资料
    2 g4 z: J' `# T0 I+ P
    2025-8-17 15:01
  • 签到天数: 569 天
    [LV.9]以坛为家II
    发表于 2020-7-15 15:42 | 只看该作者
    学习,学习,再学习。
    2025-8-17 15:01
  • 签到天数: 569 天
    [LV.9]以坛为家II
    发表于 2020-7-15 15:44 | 只看该作者
    版本高。sp16.6打不开
    2024-8-26 15:16
    发表于 2020-7-15 20:51 | 只看该作者
    还不错,感谢楼主无私分享
    - Y) ?5 @$ X4 B# S% _5 z1 W
    发表于 2020-10-14 11:11 | 只看该作者
    感谢楼主分享资料
    : b$ p6 [0 w" l6 m2 `$ r  T# |- R5 ^
    2023-10-16 15:32
    发表于 2020-10-14 23:09 | 只看该作者
    谢谢楼主分享。
    2023-10-16 15:32
    发表于 2020-10-14 23:10 | 只看该作者
    下来看看先。
    2023-10-16 15:32
    发表于 2020-10-14 23:13 | 只看该作者
    不错,谢谢楼主。
    15#
    发表于 2021-12-8 07:14 | 只看该作者
    支持!感谢分享
    & a# _' f; k+ ]3 g
    ( E6 K) X% w2 R" O* _/ Z( K
    2023-3-17 15:08
  • 签到天数: 191 天
    [LV.7]常住居民III
    16#
    发表于 2021-12-8 10:50 | 只看该作者
    谢谢楼主分享
    17#
    发表于 2022-7-17 19:39 | 只看该作者
    看看 有原理图嚒
    GMT+8, 2025-8-17 21:22 , Processed in 0.187500 second(s), 29 queries , Gzip On.
