查看: 400|回复: 2
[allegro16.6][8层]4片DDR,用来练手(816X_0_SKTBGA+4片DDR+ISL6535CRZ)pcb文件
发表于 2019-12-31 18:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
( r9 X. B4 A1 @& H( `9 h
- j* g3 z) V5 G& l4 ]/ V% b& z
文件描述:* u9 G% t) `" E5 j! q
* \6 o0 ^2 ?" H( ^1 @% F1. 作品用途:4片DDR,用来练手
* `% U, c4 d, g1 x9 ]2. 软件版本:allegro16.6, l3 o/ O- V% G# `2 T
3. 层数:8层* F# w6 c+ w- S+ ]
4. 用到的主要芯片:816X_0_SKTBGA+4片DDR+ISL6535CRZ
' z6 H2 C, a  }* O% Q5. pcb尺寸:50*75 MM
. ]& {5 ?2 L2 a; c# G6 y2 e; S; p: G0 g; b, T
作品截图如下:
& @+ [+ V7 B1 Z! M( t
4 n( \8 |, L7 `, B顶层截图:2 G. i1 _! P1 `# V
. [' F* x6 v3 A  r. k3 `
全层截图:8 S+ N- ~! u9 T
7 v8 q" B! M$ v
/ x$ J  \' A8 f3 aBOM:
5 p, g) ~9 N3 H& ~% A1 s
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA6X13-P8-12P75EDJ1108DBSE_0_BGA6X13-P8-12P75_MT41J128M8JP-125:GIC4U2; U3; U4; U5
C0402CAP NP_0_C0402_0.1UF0.1uFIC64C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C99; C100; C101; C102; C103; C104; C105; C106; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C121; C122; C123; C124; C125; C126; C127; C128; C151; C157; C158
C0402C_2_C0402_0.1UF0.1uFIC60C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81
C0402CAP NP_C0402_0.1UF/16V_YC10-0000.1uF/16VIC6C130; C135; C138; C144; C145; C147
C0402CAP NP_C0402_390PF/50V_YC10-001390pF/50VIC1C142
C0402CAP NP_C0402_1.5PF/50V_YC10-0011.5pF/50VIC1C146
C0402CAP NP_0_C0402_0.001UF0.001uFIC1C149
C0402CAP NP_0_C0402_1000PF1000pFIC1C152
C0402CAP NP_0_C0402_10PF10pFIC1C159
C0603CAP NP_C0603_1UF/25V_YC10-000321uF/25VIC2C136; C137
C0603CAP NP_C0603_3300PF/50V_YC10-003300pF/50VIC2C139; C148
C1206CAP POL_C1206_10UF/25V_YC10-00110uF/25VIC3C131; C132; C143
DRC-10TPS51200_DRC-10_TPS51200DRCTTPS51200DRCTIC1U7
L4040INDUCTOR_L4040_1UH/5A_YL10-00031uH/5AIC1L1
NSIP4CONN RCPT 4/SM_NSIP4_POWER CONPOWER CONIC1J1
QFN16ISL6535CRZ_QFN16_12V PWM_YU00-012V PWMIC1U6
R0402R_R0402_49.9R49.9RIC27R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27
R0402R0201_0_R0402_240R240RIC4R28; R29; R30; R31
R0402RES_V_R0402_510 OHM_YR10-00318-510 ohmIC1R33
R0402RES_V_R0402_10K_YR10-00066-10010KIC4R34; R35; R38; R42
R0402RES_V_R0402_11K8_YR10-00311-00011K8IC1R37
R0402RES_V_R0402_4K7_YR10-00091-1004K7IC1R40
R0402RES_V_R0402_120K_YR10-00154-100120KIC1R41
R0402R_R0402_10K10KIC3R45; R47; R49
R0402R_R0402_100K100KIC1R46
R0402R_R0402_10R10RIC1R48
R0603RES_V_R0603_2.2 OHM_YR10-00131-2.2 ohmIC2R32; R36
R0603RES_V_R0603_31K6_YR10-00241-10031K6IC1R39
R0603RES_V_R0603_2K2_YR10-00202-1002K2IC2R43; R44
SKTBGA-1031-37X37_C9212_P65MM816X_0_SKTBGA-1031-37X37_C9212_Controller ICIC1U1
SO8-MOSFETSI468DP-T1-GE3_6_SO8-MOSFET_30V30V/40A NChIC1Q1
SO8-MOSFETSI468DP-T1-GE3_6_SO8-MOSFET_3_130V/60A NChIC1Q2
SOD123MBR05030T1G_8_SOD123_30V/0A5_YD30V/0A5IC1D1
TC3216CAP_0_TC3216_33UF33uFIC8C82; C83; C84; C85; C98; C107; C120; C129
TC3216CAP_0_TC3216_10UF10uFIC1C150
TC3216CAP_0_TC3216_10UF/16V 10%10uF/16V 10%IC2C155; C156
TC3528CAP_0_TC3528_100UF/6.3V 10%100uF/6.3V 10%IC2C153; C154
TC7343CAP POL_TC7343_270UF/16V_YC20-0270uF/16VIC2C133; C134
TC7343CAP POL_TC7343_470UF/6.3V_YC20-470uF/6.3VIC2C140; C141
附件:( y. j2 M- {. v8 ?! Z
PCB文件如下:/ c3 a7 t( u( j& p6 g0 ]4 v
游客,如果您要查看本帖隐藏内容请回复
3 g8 i" p8 d' ?' i  v8 [' E* }) ^  [6 T- H' J
发表于 2023-2-9 14:08 | 只看该作者
发表于 2024-9-8 00:06 | 只看该作者
GMT+8, 2025-8-19 18:15 , Processed in 0.125000 second(s), 27 queries , Gzip On.
