查看: 228|回复: 0
[allegro16.3][6层]新岸线参考板(Telink7689+ALC3224+AP6210+usb)pcb文件
发表于 2019-12-31 16:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层]新岸线参考板(Telink7689+ALC3224+AP6210+usb)pcb文件
+ c) Q+ w6 L; S" _* W" H0 m
$ q$ e* c# |$ [文件描述:
( X: ]% C: d1 F2 l
  a) O" z) y) j6 p1 W8 O4 x" D" k1. 作品用途:新岸线参考板
' g- t$ S$ t& }2. 软件版本:allegro16.60 z% k* [( z; b( g5 j
3. 层数:6层: t" A  U8 [& B' P% f6 w/ {! F
4. 用到的主要芯片:Telink7689+ALC3224+AP6210+usb7 q( b+ q/ C1 J4 v, ^
5. pcb尺寸:3543.31*1181.1 MIL
" k' T1 y6 b: i2 J  H4 _7 `/ A3 G. |- X% u: d& N
作品截图如下:3 d( W1 @  e/ U5 \, i3 k; Q- d8 j
; A* ]/ k  Y+ d% W顶层截图:
) G6 Y) K8 Q3 G- R3 a 9 E/ j3 h' o/ v0 n( y
底层截图:0 V/ B# m- \5 I3 `
0 n" J( ~* W* V* ^
全层截图:4 V) p# M) {% k' g7 D( ^( y
8 M" d* d- p5 c3 `( V
5 R6 n) i4 b' U) _& D/ F9 Q
BOM:
; @6 ~/ |# T6 T, N' f. P( D2 a
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
AXE540124TCON40A_AXE540124T_AXE540124AXE540124IC2J2; J8
BGA80-0_65-0608U_RC5T619-BGA_BGA80-0_65-0608_RRC5T619_1003IC1U27
C0201CAP_C0201_100NF100nFIC61C1; C5; C6; C8; C9; C10; C11; C12; C13; C14; C16; C17; C18; C19; C21; C22; C23; C24; C25; C26; C27; C29; C30; C31; C32; C33; C34; C35; C37; C38; C39; C40; C41; C42; C45; C50; C51; C52; C53; C54; C55; C56; C58; C61; C63; C66; C68; C70; C140; C141; C144; C145; C146; C150; C187; C193; C197; C231; C242; C277; C285
C0201CAP_C0201_1.0UF1.0uFIC26C3; C15; C20; C46; C47; C48; C49; C65; C186; C190; C202; C247; C248; C249; C254; C255; C257; C258; C259; C260; C261; C262; C263; C264; C272; C284
C0201CAP_C0201_12PF12pFIC4C62; C69; C265; C266
C0201CAP_C0201_15PF15pFIC3C74; C75; C189
C0201CAP_C0201_10PF10pFIC1C183
C0201CAP_C0201_2.2PF2.2pFIC2C184; C185
C0402CAP_C0402_4.7UF4.7uFIC10C2; C28; C36; C133; C139; C162; C163; C188; C192; C253
C0603CAP NP_1_C0603_820PF820pFIC1C77
C0603CAP NP_1_C0603_10PF10pFIC1C78
C0603CAP_C0603_22UF22uFIC6C86; C235; C238; C239; C243; C246
C0603CAP NP_1_C0603_0.1UF/25V_20%0.1uF/25VIC1C113
DF14-2PDF57-2P_DF14-2P_DF14-2P-1.25HDF14-2P-1.25HIC1J5
DF14-2PDF57-2P_DF14-2P_DF14- 2P-1.25HDF14- 2P-1.25HIC1J9
FB0201BEAD_FB0201_0/120@100M0/120@100MIC6B1; B2; B3; B4; B5; B6
FBGA96-0_8-1014U_MT41J256M16RE_FBGA96-0_8-1014H5TQ4G63AFR-PBCIC2U2; U3
FBGA169-0_5-1216U_INAND_FBGA169-0_5-1216_SDIN7DSDIN7DP2-32GIC1U4
FBGA506-0_65-1717-7689U_TELINK7689_FBGA506-0_65-1717-Telink7689IC1U1
FH12-45P-20FH12-45S-0.5H_FH12-45P-20_FH12-FH12-45S-0.5HIC1J7
FH19S_12P_20CON12_FH19S_12P_20_FH19S-12S-0.FH19S-12S-0.5SHIC1J6
FH26-13SHEADER 7_6/SM_FH26-13S_FH26W-13FH26W-13S-0.3SHWIC1J3
IPEX-ECT818000071CON3_IPEX-ECT818000071_RF_SOCKERF_socketIC1J24
LED0805INDUCTOR/SM_LED0805_150MOHM@800150mOhm@800mAIC1L6
LQFP-64P-16EP952_LQFP-64P-16_EP952EP952IC1U9
MICROSD-9P-BJ_MICROSD_CPTFBT1-08GLBSINN4H0_TF-001IC1J1
MIPF2016DINDUCTOR_MIPF2016D_3.3UH3.3uHIC1L5
MOLEX105017-001J_USB-MINIB-SMD-5P_MOLEX105017-Micro_USB_SMDIC1J23
MPH2520INDUCTOR_MPH2520_1.0UH1.0uHIC6L12; L13; L14; L15; L16; L17
MPH2520L_0_MPH2520_WPN252012H4R7MTWPN252012H4R7MTIC1L18
MSOP8RT9277_MSOP8_RT9277BGFRT9277BGFIC1U35
OSC4_2520Y_OSC_4PIN_OSC4_2520_26M26MIC1Y1
QFN44-0_9-1212L-P-AU_AP6XXX_WIFI_MODULE_QFN44-0_9-AP6210IC1U18
QFN48-0_4-0606L-PU_ALC3261AE_QFN48-0_4-0606L-P_AALC3224IC1U16
R0201RES_R0201_10K10KIC22R1; R10; R11; R72; R73; R74; R76; R78; R87; R88; R90; R128; R134; R146; R151; R177; R178; R179; R180; R181; R216; R217
R0201RES_R0201_100100IC2R2; R32
R0201RES_R0201_47K47KIC2R3; R66
R0201RES_R0201_10K,1%10K,1%IC2R4; R5
R0201RES_R0201_60.4,1%60.4,1%IC1R6
R0201RES_R0201_240,1%240,1%IC2R7; R8
R0201RES_R0201_100K100KIC8R9; R35; R52; R60; R64; R68; R102; R106
R0201RES_R0201_2222IC6R13; R29; R75; R77; R123; R145
R0201RES_R0201_1K1KIC6R14; R15; R16; R65; R215; R365
R0201RES_R0201_1M1MIC1R28
R0201RES_R0201_2.2K2.2KIC4R39; R40; R41; R42
R0201RES_R0201_4.7K4.7KIC7R43; R44; R45; R46; R48; R49; R50
R0201RES_R0201_100R100RIC1R47
R0201RES_R0201_00IC20R56; R57; R58; R59; R63; R69; R70; R79; R80; R81; R82; R83; R117; R131; R199; R213; R222; R225; R244; R301
R0201RES_R0201_8.2K,1%8.2K,1%IC2R61; R62
R0201RES_R0201_26.1K,1%26.1K,1%IC2R67; R103
R0201RES_R0201_680,1%680,1%IC1R96
R0201RES_R0201_75,1%75,1%IC1R97
R0201RES_R0201_10R10RIC1R129
R0201RES_R0201_6.04K,1%6.04K,1%IC1R214
R0402RES_R0402_00IC2R54; R245
R0603RES_R0603_00IC2R51; R53
R0603R0603_R0603_47K47KIC1R143
R0603R_0_R0603_309K,1%309K,1%IC1R190
R0603R_0_R0603_100K,1%100K,1%IC1R191
R0603R_0_R0603_82K,1%82K,1%IC1R193
R0805RES_R0805_0.02,1%0.02,1%IC2R182; R184
SC0402CAP_SC0402_10UF10uFIC17C4; C7; C87; C88; C112; C114; C115; C143; C147; C233; C234; C236; C237; C240; C241; C251; C252
SC0402CAP_SC0402_10NF10nFIC2C57; C59
SC0402CAP_SC0402_2.2UF2.2uFIC8C60; C142; C149; C153; C156; C159; C160; C244
SOD882-ESDTVS_SINGLE_SOD882-ESD_AOZ8231ADAOZ8231ADI-05IC3D10; D25; D26
SOD882DDIODE_SCHOTTKY_SOD882D_PMEG2020PMEG2020BELDIC1D6
SOD882DDIODE_SCHOTTKY_SOD882D_PMEG2010PMEG2010BELDIC1D7
SOT883BSS123_SOT883_2N7002BKM2N7002BKMIC4Q4; Q5; Q6; Q7
SOT-23MOSFET_P_SOT23_SOT-23_QM3001KQM3001KIC1Q3
SR0402X4RP8_SR0402X4_47K47KIC4RP1; RP2; RP3; RP4
SSW2P-2_34_6-BRBSW-4P_SSW2P-2_34_6-BRB_ST-1114AST-1114AIC1S1
STP30TP_D30_STP30_TP_D30TP_D30IC5GP12; SIF1_TX; SIF4_TX; VOL+; VOL-
STP40TP_D30_STP40_TP_D40TP_D40IC163V3; +VDC; GND1; GND3; GND4; GND5; GND6; RST; RXD; RXD1; SYS_32K; SYS_RST; TXD; TXD1; VBAT; VBUS_5V
TVS0402-ESDTVS_SINGLE_TVS0402-ESD_ES0402V0ES0402V014CTIC2D8; D9
USB_AUSB_A_1_USB_A_IO_USB-A-S-RAUSB-A-S-RAIO1J14
WDFN-6LRT9728_WDFN-6L_RT9728AGQWRT9728AGQWIC1U7
WDFN-6LRT9728_WDFN-6L_RT9728AHGQWRT9728AHGQWIC1U8
XTAL_2016X_CRYSTAL_4PIN_XTAL_2016_12M12MIC1X1
XTAL_3215CRYSTAL_1_XTAL_3215_32.768KHZ32.768KHzIC1X3
附件:
! D! h  @# \7 Z" ~PCB文件如下:
4 g/ E: g7 f( m$ p6 _
游客,如果您要查看本帖隐藏内容请回复
& J. u8 L/ I6 W7 N5 h+ [7 a1 S4 f! r3 i7 w* W; M" n
GMT+8, 2025-7-21 04:56 , Processed in 0.125000 second(s), 28 queries , Gzip On.
