作品名:[AD 19][2 层]带有人体感应、灰尘检测、温湿度、空气质量检测的控制板设计(R5F212B8SNFP+ULN2003A+4N25)原理图和PCB源文件 文件描述 1. 作品用途:带有人体感应、灰尘检测、温湿度、空气质量检测的控制板设计 2. 软件版本:AD 19 3. 层数:2 层 4. 用到的主要芯片:R5F212B8SNFP+ULN2003A+4N25 5. PCB尺寸:190mm*100mm 作品截图如下: 顶层截图: 底层截图: 全层截图: 叠层信息截图如下: BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10MHz | Y1 | XTAL1-3 | 1 | 1117-3.3V | U10 | SOT-223-1117 | 1 | 7815 | U9 | 78**_W | 1 | 4N25 | U4, U5, U6, U8 | DIP6C | 4 | ULN2003A | U2 | SOJ-16 | 1 | R5F212B8SNFP | U1 | LQFP64 | 1 | P6KE200A | TVS1 | DO_15 | 1 | EE22 | T1 | E22077 | 1 | 14D471 | RV2 | RV-14mm | 1 | 10K/0603 | R72 | 0603R | 1 | 330R/1206 | R71 | 1206R | 1 | 390K-0805 | R70 | 0805R | 1 | 1K/0805 | R68, R69, R73 | 0805R | 3 | 220R/1206 | R66, R67 | 1206R | 2 | 51R/1206 | R65 | 1206R | 1 | 150K/1W | R63 | R5.5 | 1 | 2.2K | R61 | 0603R | 1 | 4.3K/1206 | R60 | 1206R | 1 | 27R | R58, R62 | 1206R | 2 | Res2 | R52, R55 | AXIAL-0.4 | 2 | 0R | R49 | 1206R | 1 | 5.1K | R47 | 0603R | 1 | 2K | R32, R33, R34, R64 | 0603R | 4 | 4.7K | R23 | 0603R | 1 | 1K | R16, R39, R40, R41, R46, R59 | 0603R | 6 | 100K | R15 | 0603R | 1 | 33R | R14, R21, R22 | 1206R | 3 | 10R | R12, R19, R20, R56 | 0603R | 4 | 100R/1W NP | R3, R4, R7, R8 | RAD0.7 - L | 4 | 10K | R1, R2, R5, R6, R10, R17, R18, R36, R37, R38, R45, R48, R50, R51, R53, R54, R57 | 0603R | 17 | RED 0805LED | LED8 | 0805LED | 1 | RED | LED1, LED2, LED3, LED4, LED5, LED6, LED7 | 0805LEDC | 7 | 3.3UH/2A | L2 | L.5 | 1 | 30mH/0.3A | L1 | UU10 | 1 | G5NB-1A | K1, K2, K3, K4 | G5NB-1A | 4 | logo | Jointech1 | SHANGBIAO-5 | 1 | 2.54 单排插针 | J17, J18 | HDR1X5 | 2 | XP4-VH-A | J16 | XP4-VH-A | 1 | HX25003-7A | J14 | HX25003-7A | 1 | HX25003-3A | J11, J12, J13 | DP-3 | 3 | | J10 | XP7-VH-A | 1 | HX25003-4A | J9 | HX25003-4A | 1 | HX25003-5A | J8 | HX25003-5A | 1 | 2.54mm*4 W | J7 | DP-4-W | 1 | 2.54mm*4PIN 插针 | J6 | HX25003-4A | 1 | HX25003-6A | J5 | HX25003-6A | 1 | XP3-VH-A | J1, J2, J3, J4, J15 | XP3-VH-A | 5 | 4-IC(TNY278P) | IC5 | DIP-8C | 1 | TL431 | IC4 | TL431 | 1 | PC817A | IC3 | SOP4 | 1 | LM358 | IC2 | SO-8 | 1 | 10A/250VAC | F1 | FUSE_B | 1 | ULCE1005A015FR | | 0603C | 1 | ULCE1012A015FR | ESD1, ESD2, ESD3 | 0603C | 3 | 100uF/25V | EC11 | RB2.5/6.3MM | 1 | 220uF/16V | EC10 | RB2.5/6.3MM | 1 | 680UF/16V | EC8, EC9 | RB5/10MM | 2 | 22UF/450V | EC7 | RB4.6/13.2 | 1 | 470UF/35V | EC6 | RB5/10MM | 1 | 100uF/16V NP | EC2, EC3, EC4 | RB2.5/6.3MM | 3 | FR107 | D23 | DO_41 | 1 | SB3100 | D22 | DO-201 | 1 | KBP307 | D21 | KBP2 | 1 | HER203 | D20 | DO_15 | 1 | Photo Sen | D19 | PIN2 | 1 | LL4148 | D13, D14, D15 | SOD123 | 3 | M7 | D2, D4, D6, D7, D8, D9, D10, D11, D12 | M7 | 9 | 0.1uF K AC275V C.6 19*6*12MM | CX1 | C.6 | 1 | 0.1uF | C30 | 0805C | 1 | 100pF | C29 | 0805c | 1 | 0.1UF/50V | C28 | 0805C | 1 | 0.1UF/50V | C27 | 0603C | 1 | 103-630V/CBB | C26 | C.4C | 1 | 1uF | C24 | 0805C | 1 | 1000PF/100V | C23, C25 | 0805C | 2 | 2.2nF 1600VAC | C22 | C.6 | 1 | 0.1uF NP | C20, C21 | 0603C | 2 | 10uF | C12 | 0805c | 1 | 4.7uF | C8, C19 | 0805C | 2 | 0.1uF | C5, C6, C7, C10, C16, C17, C18, C31, C32, C33, C34 | 0603C | 11 | 103/AC630V NP | C2, C3, C9, C11 | C.4 | 4 | 20pF | C1, C4 | 0603C | 2 | TP1 | +24V | TESTPOINT-S-1P-A | 1 | TP2 | +5V, +15V | TESTPOINT-S-1P-A | 2 | TP3 | +3.3V, DAC_OUT1 | TESTPOINT-S-1P-A | 2 |
附件: 原理图和PCB源文件如下:
6 R1 m# H5 G! q |
