Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2DC-S028-C01 | 2DC-S028-C01 | 2dc-s028-c01 | IC | 1 | DC_IN1 |
7PINBAT | 7PINBAT | 7pinbat | IC | 1 | BATT1 |
A2001WV-2P | A2001WV-2P | a2001wv-2p | DISCRETE | 1 | SATA_PWR1 |
BVY_27X25_1170P_01-04 | BVY_27X25_1170P_01-04 | bvy_27x25_1170p_01-04 | IC | 1 | U1 |
CON-PCIE-MINI-CARD-4MM-NUT | CON-PCIE-MINI-CARD-4MM-NUT | con-pcie-mini-card-4mm-nut | IC | 1 | MSATA1 |
CON_FLAT_SODIMM_DDR3_STD | CON_FLAT_SODIMM_DDR3_STD | con_flat_sodimm_ddr3_std | IC | 1 | J1 |
CRYSMD6D9X1D4_4P | CRYSMD6D9X1D4_4P | crysmd6d9x1d4_4p | IC | 1 | Y2 |
CT3528 | CT3528 | | IC | 3 | C341; C369; C385 |
DIP_CNTR-FAN_1X3 | DIP_CNTR-FAN_1X3 | dip_cntr-fan_1x3 | IC | 1 | CPU_FAN1 |
FPC2P-1_25MM | FPC2P-1_25MM | fpc2p-1_25mm | IC | 1 | RTC1 |
FPC-4PIN-1_25MM | FPC-4PIN-1_25MM | fpc-4pin-1_25mm | IC | 5 | COM1; COM2; ID_USB1; RF_USB1; SPK1 |
FPC-5PIN-1_0MM-HOPELINK | FPC-5PIN-1_0MM-HOPELINK | fpc-5pin-1_0mm-hopelink | IC | 2 | CAM_USB1; CAM_USB2 |
FPC-6PIN-0_5MM | FPC-6PIN-0_5MM | fpc-6pin-0_5mm | IC | 1 | TP_USB1 |
FPC-12PIN-1_0MM-HOPELINK | FPC-12PIN-1_0MM-HOPELINK | fpc-12pin-1_0mm-hopelink | IC | 1 | SW1 |
FUSE1812 | FUSE1812 | fuse1812 | DISCRETE | 2 | F2; F3 |
HDMI-H2-02A-A-A0 | HDMI-H2-02A-A-A0 | hdmi-h2-02a-a-a0 | IC | 1 | HDMI1 |
HOLE180_120 | HOLE180_120 | hole180_120 | IC | 3 | PCIE_H1; PCIE_H2; SATA_H1 |
IO-40P-1MM | IO-40P-1MM | io-40p-1mm | IC | 2 | EDP1; LVDS1 |
L0603 | L0603 | l0603 | DISCRETE | 3 | L1; L2; L3 |
LCC10_SLP10 | LCC10_SLP10 | lcc10_slp10 | IC | 5 | TVS3; TVS4; TVS5; TVS6; TVS7 |
LQFP48 | LQFP48 | | IC | 1 | U3 |
LQFP128-0_4-16X16X1_6MM | LQFP128-0_4-16X16X1_6MM | lqfp128-0_4-16x16x1_6mm | IC | 1 | U21 |
MARK | MARK | mark | IC | 6 | FD1; FD2; FD3; FD4; FD5; FD6 |
MH250_1-C106D106N | MH250_1-C106D106N | mh250_1-c106d106n | IC | 5 | H1; H2; H3; H4; H5 |
MINIPCIE_HALF_L | MINIPCIE_HALF_L | minipcie_half_l | IC | 1 | MPCIE1 |
PJ-JA6341 | PJ-JA6341 | pj-ja6341 | IC | 1 | AUD1 |
POWERPAK3D0X3D0-SO8 | POWERPAK3D0X3D0-SO8 | powerpak3d0x3d0-so8 | IC | 21 | PQ1; PQ2; PQ3; PQ4; PQ5; PQ7; PQ8; PQ9; PQ10; PQ11; PQ12; PQ13; PQ14; PQ15; PQ16; PQ17; PQ18; PQ19; PQ20; PQ21; PQ22 |
PQFP14-3_6X3_6MM | PQFP14-3_6X3_6MM | pqfp14-3_6x3_6mm | IC | 2 | PU2; PU7 |
QFN24-TPS51125 | QFN24-TPS51125 | qfn24-tps51125 | IC | 1 | PU1 |
QFN40 | QFN40 | qfn40 | IC | 1 | PU9 |
QFN48_0R4_6X6_EP | QFN48_0R4_6X6_EP | qfn48_0r4_6x6_ep | IC | 1 | U7 |
QFN50P500X500X100-29N | QFN50P500X500X100-29N | qfn50p500x500x100-29n | IC | 1 | U22 |
QFN68_8X8P04 | QFN68_8X8P04 | qfn68_8x8p04 | IC | 1 | U26 |
RF-SMT-CONN | RF-SMT-CONN | rf-smt-conn | IC | 2 | ANT1; ANT2 |
RJ45-HLJ-6041SL-88A | RJ45-HLJ-6041SL-88A | rj45-hlj-6041sl-88a | IC | 1 | LAN1 |
R_2512 | R_2512 | r_2512 | IC | 2 | R404; R422 |
SATA7-TF | SATA7-TF | sata7-tf | IC | 1 | SATA1 |
SHORT_PAD | SHORT_PAD | short_pad | IC | 16 | SP1; SP2; SP3; SP4; SP6; SP10; SP11; SP12; SP13; SP14; SP15; SP16; SP17; SP18; SP19; SP22 |
SIM-SPPN08-X0-1X80_UPDATE | SIM-SPPN08-X0-1X80_UPDATE | sim-sppn08-x0-1x80_update | IC | 1 | SIM1 |
SMC0402 | SMC0402 | smc0402 | IC | 277 | C1; C2; C3; C4; C5; C6; C7; C8; C9; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C28; C29; C30; C39; C40; C41; C42; C43; C44; C45; C46; C47; C49; C50; C52; C53; C54; C56; C57; C58; C61; C62; C63; C67; C70; C71; C72; C73; C74; C86; C90; C94; C96; C97; C99; C100; C101; C102; C103; C104; C105; C106; C108; C109; C110; C111; C112; C113; C114; C115; C117; C118; C121; C124; C125; C126; C127; C128; C131; C132; C133; C134; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C153; C154; C161; C162; C167; C168; C169; C174; C176; C179; C186; C187; C188; C192; C197; C200; C204; C215; C218; C223; C225; C226; C228; C229; C230; C232; C234; C238; C239; C245; C246; C249; C250; C251; C252; C253; C254; C255; C256; C258; C259; C262; C263; C264; C265; C266; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C281; C285; C286; C287; C291; C292; C293; C296; C298; C300; C305; C306; C307; C308; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C327; C328; C329; C330; C331; C332; C334; C336; C337; C338; C340; C342; C344; C345; C346; C347; C349; C351; C362; C365; C366; C367; C370; C373; C374; C388; C391; C394; C396; C397; C398; C399; C400; C402; C441; C443; C444; C474; C475; C476; C806; C807; C808; C809; C810; C811; C812; C813; C815; C816; C817; C818; C819; C820; C821; C822; C823; C824; C825; C826; C827; C828; C829; C830; C831; C832; C833; C834; C841; C842; C843; C844; C845; C846; C847; C848; C849; C850; C851; C854; C857; C859; C862; C864; C865; C866; C867; C868; C869; C870 |
SMC0603 | SMC0603 | smc0603 | DISCRETE | 39 | C91; C120; C170; C171; C172; C175; C180; C189; C214; C233; C237; C240; C241; C244; C261; C299; C301; C302; C303; C304; C360; C363; C364; C371; C372; C375; C378; C379; C383; C403; C472; C852; C853; C855; C856; C858; C860; C861; C863 |
SMC0805 | SMC0805 | smc0805 | DISCRETE | 81 | C27; C31; C32; C33; C34; C35; C36; C37; C38; C48; C51; C64; C65; C66; C68; C69; C95; C98; C107; C123; C129; C130; C135; C151; C152; C155; C156; C157; C158; C159; C160; C173; C183; C185; C194; C196; C199; C202; C203; C206; C207; C209; C210; C212; C217; C219; C221; C222; C224; C227; C231; C235; C282; C283; C284; C290; C294; C295; C297; C326; C348; C350; C355; C356; C384; C386; C387; C389; C390; C392; C393; C395; C401; C404; C405; C406; C407; C408; C417; C418; C419 |
SMC1206 | SMC1206 | smc1206 | IC | 22 | C116; C177; C178; C190; C191; C193; C198; C211; C213; C216; C242; C243; C257; C260; C335; C361; C368; C376; C377; C380; C381; C382 |
SMC7343 | SMC7343 | smc7343 | DISCRETE | 14 | C181; C182; C184; C195; C201; C220; C247; C248; C267; C268; C333; C339; C343; C872 |
SMD_LED_0805 | SMD_LED_0805 | smd_led_0805 | IC | 2 | LED2; LED3 |
SMF0603 | SMF0603 | smf0603 | DISCRETE | 9 | FB2; FB3; FB5; FB6; FB9; FB10; FB17; FB18; FB40 |
SMF0805 | SMF0805 | smf0805 | IC | 6 | FB25; FB26; FB37; FB39; FB41; FB42 |
SMPI_0603 | SMPI_0603 | smpi_0603 | IC | 8 | PL2; PL3; PL4; PL5; PL6; PL7; PL8; PL12 |
SMR0402 | SMR0402 | smr0402 | DISCRETE | 420 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R98; R102; R103; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R154; R157; R158; R161; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R189; R190; R191; R196; R197; R198; R199; R200; R201; R202; R203; R204; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R238; R239; R240; R241; R242; R243; R244; R245; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R272; R273; R274; R275; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R287; R288; R289; R290; R291; R292; R293; R294; R295; R296; R297; R300; R301; R304; R307; R308; R309; R310; R313; R314; R315; R316; R317; R318; R319; R320; R321; R322; R323; R324; R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R365; R366; R367; R368; R369; R370; R371; R372; R373; R374; R376; R377; R378; R380; R381; R383; R384; R385; R396; R397; R398; R403; R405; R406; R407; R408; R409; R410; R411; R412; R413; R415; R416; R417; R418; R419; R420; R421; R423; R424; R425; R426; R427; R428; R429; R430; R431; R432; R433; R434; R435; R436; R437; R438; R443; R484; R485; R486; R489; R526; R527; R531; R535; R545; R551; R552; R688; R689; R690; R691; R692; R693; R694; R695; R696; R697; R698; R699; R730; R731; R732; R740; R741; R742; R743; R744; R745; R746; R747; R752; R753; R754; R755; RT1; RT2 |
SMR0603 | SMR0603 | smr0603 | DISCRETE | 4 | R224; R237; R687; R700 |
SO8_PWP | SO8_PWP | so8_pwp | IC | 2 | PQ6; PQ25 |
SOCKET8-FLASH | SOCKET8-FLASH | socket8-flash | IC | 2 | U2; U28 |
SOD123 | SOD123 | sod123 | IC | 12 | D1; D3; D7; D8; D11; D12; PD1; PD2; PD3; PD4; PD5; PD6 |
SOD323 | SOD323 | sod323 | DISCRETE | 4 | D15; PZ2; PZ3; PZ4 |
SOP8-1_27-5X6X1_75MM | SOP8-1_27-5X6X1_75MM | sop8-1_27-5x6x1_75mm | IC | 5 | PQ34; PQ35; PQ37; U15; U31 |
SOP8-1_27-DS9025 | SOP8-1_27-DS9025 | sop8-1_27-ds9025 | IC | 6 | PU6; PU8; PU10; PU11; PU12; U48 |
SOT23 | SOT23 | sot23 | IC | 20 | D13; D14; Q1; Q2; Q3; Q4; Q5; Q6; Q9; Q13; Q16; Q17; Q18; Q19; Q25; Q26; Q31; Q35; Q37; Q46 |
SOT23_5 | SOT23_5 | sot23_5 | IC | 2 | U9; U11 |
SOT363 | SOT363 | sot363 | IC | 13 | Q12; Q27; Q29; Q32; Q34; Q36; Q38; Q39; Q40; Q41; Q42; U4; U19 |
SSOP28-25P6X278 | SSOP28-25P6X278 | ssop28-25p6x278 | IC | 2 | U13; U16 |
SSOP28-26-209 | SSOP28-26-209 | ssop28-26-209 | IC | 1 | U51 |
SSOP28-L | SSOP28-L | | IC | 1 | CU1 |
STPI3015 | STPI3015 | stpi3015 | IC | 1 | PL1 |
TEST20 | TEST20 | test20 | DISCRETE | 26 | SUSCLK1; TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25 |
TRAN_24PIN_1MM | TRAN_24PIN_1MM | tran_24pin_1mm | IC | 1 | U8 |
T_FLASH_CARD_01 | T_FLASH_CARD_01 | t_flash_card_01 | IC | 1 | TF1 |
USB2_FOXCONN_CHENBAN | USB2_FOXCONN_CHENBAN | usb2_foxconn_chenban | IC | 1 | USB3 |
USB3_FOXCONN_CHENBAN | USB3_FOXCONN_CHENBAN | usb3_foxconn_chenban | IC | 1 | USB1 |
WIFI-BT-BL-8723RB1 | WIFI-BT-BL-8723RB1 | wifi-bt-bl-8723rb1 | IC | 1 | WIFI_BT1 |
XTAL3225-4 | XTAL3225-4 | xtal3225-4 | IC | 6 | Y1; Y3; Y4; Y5; Y6; Y7 |
