查看: 1368|回复: 10
[allegro16.6][8层]RK3326官方参考设计之一(RK3326+K4B4G1646Q)原理图和pcb文件
发表于 2019-12-31 13:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][4层]RK3326官方参考设计之一(RK3326+K4B4G1646Q)原理图和pcb文件
文件描述:
1. 作品用途:RK3326官方参考设计之一
2. 软件版本:allegro16.6
3. 层数:4层
4. 用到的主要芯片:RK3326+K4B4G1646Q
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
ANTPCB_44R00X11R00_DSRANT_1P1G_ANTPCB_44R00X11R00_DSRANT4411DRIC1ANT6100
ANT_JACKANT_1P2G_ANT_JACK_ANT_JACKANT_JACKIC1ANT6101
BAT3_2R54BATT3_BAT3_2R54_BAT3_2R54BAT3_2R54IC1BT2001
BGA169_18R00X14R00X1R20_2LINAND_EMMC_169_2L_BGA169_18R00XKLMAG2GEAC-B031IC1U4100
BGA418_14R00X14R00X1R24mcu_RK3326_BGA418_14R00X14R00X1RK3326IC1U1000
C0402CAP NP_C0402_100NF100nFIC110C1001; C1002; C1003; C1004; C1005; C1006; C1008; C1009; C1010; C1011; C1012; C1013; C1100; C1103; C1104; C1105; C1106; C1107; C1108; C1201; C1202; C1203; C1204; C1205; C1206; C1300; C1400; C1401; C1402; C1500; C1501; C1600; C1601; C1701; C1702; C1703; C1704; C1800; C1801; C1802; C2000; C2002; C2006; C2014; C2015; C2021; C2023; C2025; C2026; C2057; C2129; C2132; C2137; C2139; C2141; C2501; C3003; C3004; C3005; C3006; C3007; C3008; C3009; C3010; C3011; C3021; C3022; C3023; C3024; C3025; C3026; C3027; C4001; C4003; C4102; C4104; C4105; C4601; C4602; C4603; C4606; C4608; C4702; C4704; C4707; C5101; C6102; C6107; C7002; C7003; C7004; C7145; C7147; C7150; C7152; C7208; C7209; C7212; C7214; C7221; C7223; C7224; C9012; C9100; C9201; C9601; C9603; C9604; C9605; R2161
C0402CAP NP_C0402_4.7UF4.7uFIC10C1014; C1015; C1200; C4000; C4002; C4101; C4103; C4605; C4706; C6108
C0402CAP NP_C0402_2.2UF2.2uFIC7C1016; C2122; C2133; C2135; C2136; C2138; C2140
C0402CAP NP_C0402_22PF22pFIC6C1101; C1102; C2130; C2131; C6104; C6105
C0402CAP NP_C0402_100PF100pFIC2C2003; C3000
C0402CAP NP_C0402_1NF1nFIC18C2012; C2050; C3014; C3015; C3016; C3017; C3018; C7100; C7101; C7113; C7121; C7128; C7133; C7134; C7135; C7144; C7146; C9202
C0402CAP NP_C0402_47NF47nFIC1C2018
C0402CAP NP_C0402_1UF1uFIC30C2020; C2027; C2054; C2100; C2103; C2107; C2108; C2109; C2111; C2112; C2113; C2117; C2118; C2119; C2120; C2121; C2123; C2127; C2128; C2502; C4100; C4703; C4705; C6106; C7114; C7119; C7140; C9010; C9011; C9602
C0402CAP NP_C0402_10NF10nFIC6C3012; C3013; C7106; C7112; C7126; C7127
C0402CAP NP_C0402_8PF8pFIC3C4600; C4700; C4701
C0402CAP NP_C0402_27PF27pFIC1C6003
C0402CAP NP_C0402_47PF47pFIC1C6016
C0402CAP NP_C0402_3PF3pFIC1C6100
C0402CAP NP_C0402_DNPDNPIC1C6109
C0402CAP NP_C0402_330PF330pFIC4C7109; C7116; C7118; C7124
C0603CAP NP_C0603_22UF22uFIC8C1000; C1007; C2104; C2106; C2114; C2116; C2125; C2126
C0603CAP NP_C0603_10UF10uFIC20C2005; C2024; C2101; C2102; C2105; C2110; C2115; C2124; C2134; C2500; C3001; C3002; C3019; C3020; C4604; C4607; C5100; C6101; C9101; C9600
C0603CAP NP_C0603_1UF1uFIC5C2022; C7107; C7111; C7120; C7122
C0603CAP NP_C0603_100NF100nFIC2C7102; C7129
C0603CAP NP_C0603_2.2UF2.2uFIC4C7105; C7110; C7125; C7131
C0603CAP NP_C0603_220NF220nFIC4C7108; C7115; C7117; C7123
C0603CAP NP_C0603_4.7UF4.7uFIC7C7207; C7210; C7211; C7220; C7222; C7225; C9200
C0805CAP NP_C0805_10UF10uFIC4C2001; C2019; C2036; C2052
C0805CAP NP_C0805_22UF22uFIC4C2004; C2010; C2016; C2017
C0805CAP NP_C0805_2.2UF2.2uFIC1C2051
CNN2_2R00_6R30X4R90X6R30_VJACK_1500_0_CNN2_2R00_6R30X4R90JACK_1500_2PIC3J2100; J7100; J7101
CNN30_1R00_FP05SL_VLCD_HITACHI_TX05D99VM1AAA_1_CNN30PIN FPC CONIC2J7201; J7202
CON2_1X2_5R08_DIPGND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATEIC2J9901; J9902
CON30F_2X15_0R40_OK_14F030_04OK-14GM030-04_CON30F_2X15_0R40_OK-14GM030-04IC1J4601
CON30M_2X15_0R40_V_SMTCMK-CB0077-FV1_2_CON30M_2X15_0RAXT530124IC1J4600
CRY2_6R90X1R40X1R30CRYSTAL_2P_1G_CRY2_6R90X1R40X1R32.768KHzIC1Y2100
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzIC1Y1100
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R8_126MHzIC1Y6100
DC3_DC_0007_5PDCJACK_3P_DC3_DC_0007_5P_DC-000DC-0007-5PIC1J2000
DO_214ACDIODE_DO_214AC_SS32SS32IC1D2001
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD54ESD5451NIC11D4100; D9100; ED2003; ED2100; ED2101; ED7000; ED7001; ED7002; ED7003; ED7200; ED7201
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD53ESD5341NIC1ED2500
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD_1ESD5471XIC7ED9100; ED9101; ED9102; ED9103; ED9104; ED9105; ED9106
F8050FUSE_F8050_JK-SMD200LJK-SMD200LIC1F2000
FBGA96_14R00X11R00X1R20DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QIC2U3000; U3001
FPC24L_1X24_0R50_DOWNOV2659_FPC24L_1X24_0R50_DOWN_OVOV2659IC1J4700
FPC30R_0R50_UPFPC_MIPI/LVDS_FPC30R_0R50_UP_3030PIN FPC CONIC1J5100
HOLE_C3R20_C6R00HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20IC4H9900; H9901; H9902; H9903
IND_111114_DIPINDUCTORS OF FERRITE_IND_11111415uHIC4L7104; L7105; L7106; L7107
IND_252010INDUCTORS OF FERRITE_IND_252010470nHIC5L2100; L2101; L2102; L2103; L2104
IND_303012INDUCTORS OF FERRITE_IND_3030124.7uHIC1L6102
IND_404030INDUCTORS OF FERRITE_IND_4040303.3uHIC1L2000
IND_606028INDUCTORS OF FERRITE_IND_6060283.3uHIC1L2001
IND_808040INDUCTORS OF FERRITE_IND_80804015uHIC4L7100; L7101; L7102; L7103
IR-SIR8B39IR_RECEIVE_1_IR-SIR8B39_OQSS-R1OQSS-R12IC1IR9200
L0402INDUCTOR_L0402_DNPDNPIC2L6100; L6101
L0603BEAD_L0603_180R-100M180R-100MIC2FB4600; FB4700
L0603DINDUCTOR COM_L0603D_90R-100M90R-100MIC1FB2500
LED0603LED_LED0603_LED_BLUELED_BlueIC1LED2001
LED0603LED_LED0603_LED_REDLED_REDIC2LED2003; LED9600
MARKMARK_MARK_MARKMARKIC6M9900; M9901; M9902; M9903; M9904; M9905
MD44_AP6XXXMODULE_AP6XXX_MD44_AP6XXX_AP621AP6212IC1U6100
MODULE-8AL3006_0_MODULE-8_TMD27723TMD27723IC1U9010
MSOP10_3R00X3R00X1R10SWITCH_FSUSB30MUX_MSOP10_3R00X3FSUSB30MUXIC1U9602
MTM-CCM_C_MTM-C_100UF/25V100uF/25VIC2CM7100; CM7101
PJ6_D3R50_PJ35106SY-P10PHONEJACK_6P_PJ6_D3R50_PJ35106SPJ35106SY-P10IC1J7000
QFN24_5R65X3R65X1R00_TCHARGER_BQ24133_QFN24_5R65X3R65BQ24133IC1U2001
QFN68_7R00X7R00X0R80_TRK809_QFN68_7R00X7R00X0R80_T_RKRK809IC1U2100
R0402RESISTOR_R0402_22R22RIC53R1102; R1730; R1800; R1801; R1802; R1803; R1804; R1805; R1806; R1809; R1810; R1811; R1812; R1813; R1814; R4103; R4601; R4700; R4701; R7006; R7007; R7200; R7201; R7202; R7203; R7204; R7205; R7206; R7207; R7208; R7209; R7210; R7211; R7212; R7220; R7221; R7222; R7223; R7224; R7225; R7226; R7227; R7228; R7229; R7230; R7231; R7232; R7233; R9100; R9200; R9202; R9604; R9605
R0402RESISTOR_R0402_0R0RIC90R1103; R1104; R1105; R1106; R1107; R1110; R1111; R1112; R1115; R1128; R1300; R1401; R1402; R1403; R1501; R1510; R1601; R1602; R1702; R1703; R1704; R1705; R1707; R1709; R1711; R1713; R1715; R1717; R1719; R1721; R1723; R1726; R1731; R1807; R1815; R2060; R2070; R2073; R2101; R2102; R2104; R2106; R2107; R2109; R2111; R2113; R2115; R2120; R2122; R2125; R2136; R2137; R2138; R2139; R2150; R2151; R2152; R4001; R4002; R4004; R4005; R4102; R4602; R4703; R6003; R6100; R6110; R6112; R6118; R6119; R6120; R6121; R6122; R6136; R7005; R7022; R7023; R7101; R7105; R7111; R7114; R7115; R7116; R7124; R7134; R7256; R9001; R9601; R9602; R9603
R0402RESISTOR_R0402_2.2K2.2KIC6R1108; R1109; R1603; R1604; R2124; R2126
R0402RESISTOR_R0402_150K150KIC2R1120; R6116
R0402RESISTOR_R0402_180K180KIC4R1121; R6113; R6115; R6117
R0402RESISTOR_R0402_133R133RIC1R1400
R0402RESISTOR_R0402_51K51KIC2R1500; R1502
R0402RESISTOR_R0402_2K2KIC4R1600; R1701; R2079; R9600
R0402RESISTOR_R0402_75K75KIC1R2001
R0402RESISTOR_R0402_DNPDNPIC4R2002; R7122; R7123; R7145
R0402RESISTOR_R0402_10K10KIC10R2007; R2071; R2129; R2131; R2502; R4100; R4101; R4600; R4702; R7109
R0402RESISTOR_R0402_1M1MIC2R2010; R2018
R0402RESISTOR_R0402_22K22KIC1R2011
R0402RESISTOR_R0402_1K1KIC6R2014; R3004; R3005; R3006; R3007; R7004
R0402RESISTOR_R0402_4.7K4.7KIC14R2015; R2016; R2040; R2041; R2505; R4000; R4003; R7108; R7120; R7127; R7128; R7144; R7149; R9201
R0402RESISTOR_R0402_220K220KIC2R2019; R2020
R0402RESISTOR_R0402_27K27KIC3R2021; R2023; R2130
R0402RESISTOR_R0402_100K100KIC16R2022; R2088; R2128; R2504; R6108; R7103; R7113; R7118; R7119; R7121; R7125; R7126; R7142; R7143; R7250; R7251
R0402RESISTOR_R0402_10R10RIC2R2028; R7135
R0402RESISTOR_R0402_4.99K4.99KIC1R2033
R0402RESISTOR_R0402_30K30KIC1R2035
R0402RESISTOR_R0402_330R330RIC1R2036
R0402RESISTOR_R0402_100R100RIC4R2072; R2105; R2110; R2510
R0402RESISTOR_R0402_110K110KIC1R2112
R0402RESISTOR_R0402_120K120KIC2R2116; R6019
R0402RESISTOR_R0402_140K140KIC1R2118
R0402RESISTOR_R0402_20K20KIC1R2119
R0402RESISTOR_R0402_18K18KIC1R2503
R0402RESISTOR_R0402_240R240RIC2R3000; R3001
R0402RESISTOR_R0402_49.9R49.9RIC2R3002; R3003
R0402RESISTOR_R0402_150R150RIC1R6030
R0402RESISTOR_R0402_680R680RIC1R6050
R0402RESISTOR_R0402_68K68KIC2R6111; R6114
R0402RESISTOR_R0402_1.5K1.5KIC3R6130; R6132; R6134
R0402RESISTOR_R0402_1.8K1.8KIC3R6131; R6133; R6135
R0402RESISTOR_R0402_3.3R3.3RIC4R7102; R7104; R7110; R7117
R0603RESISTOR_R0603_2.2R2.2RIC2R2500; R2501
R0603RESISTOR_R0603_10R10RIC4R7100; R7106; R7107; R7112
R0805RESISTOR_R0805_330NH330nHIC1L6004
R0805RESISTOR_R0805_0.01R0.01RIC1R2061
R0805RESISTOR_R0805_0.02R0.02RIC8R2100; R2103; R2108; R2114; R2167; R7131; R7136; R9606
R0805RESISTOR_R0805_0R0RIC2R7129; R7130
R1206RESISTOR_R1206_0.01R0.01RIC5R2008; R2017; R2057; R2090; R2515
R1210RESISTOR_R1210_2R2RIC1R2050
SMT2_6R00X3R50X4R20SW PUSHBUTTON_SMT2_6R00X3R50X4RMaskromIC1SW4100
SMTSO_M3_C4R1_C6R0_L10R0SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJIC4SMTSO9900; SMTSO9901; SMTSO9906; SMTSO9907
SOD_323DIODE_SOD_323_B5819WSB5819WSIC1D2003
SOD_323DIODE_SOD_323_1N4148WS1N4148WSIC1D4101
SOP8_5R00X4R00X1R75SECURE_ATSHA204A_SOP8_5R00X4R00ATSHA204A-SSHDA-TIC1U7200
SOT_23MOSFET N_SOT_23_WNM3003-3/TRWNM3003-3/TRIC2Q2000; Q2001
SOT_23MOSFET P_SOT_23_WPM3407-3/TRWPM3407-3/TRIC1Q2002
SOT_23MOSFET N_SOT_23_WNM2016-3/TRWNM2016-3/TRIC1Q2500
SOT_23ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FIC2U2500; U9601
SOT_23_5SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACIC1U2507
SOT_23_6DCDC_SY8113_SOT_23_6_SY8113BSY8113BIC1U2000
SOT_89_3LDO_PT5108_1_SOT_89_3_SGM2203-5SGM2203-5.0IC1U2002
SOT_323MOSFET N_SOT_323_2SK30182SK3018IC4Q6100; Q6101; Q6102; Q7201
SOT_323MOSFET N_SOT_323_WNM6002-3/TRWNM6002-3/TRIC1Q7100
SSOP28_10R20X5R30X2R00INTERFACE_FT232RL_SSOP28_10R20XFT232RLIC1U9600
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_PWRPWRONIC1SW2000
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_RECRecoveryIC1SW2005
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_RESRESETIC1SW2100
TF9_CKT01_009DTFCARD_SOCKET_TF9_CKT01_009D_TFTF-CKT01-009DIC1J9100
TP_0R50TP_TP_0R50_TP_0.5TP_0.5IC2TP2101; TP2105
TP_0R70TP_TP_0R70_TP_0.7TP_0.7IC59TP2001; TP4600; TP4601; TP4602; TP4603; TP4604; TP4605; TP4606; TP4607; TP4608; TP4609; TP4610; TP4611; TP4612; TP4613; TP4614; TP4620; TP4700; TP4701; TP4702; TP4703; TP4704; TP4705; TP4706; TP4707; TP4708; TP4709; TP4710; TP4711; TP4712; TP4713; TP4714; TP4715; TP4716; TP5100; TP5101; TP5102; TP5103; TP5104; TP5105; TP5106; TP5107; TP5108; TP5109; TP5110; TP5111; TP5112; TP5113; TP5114; TP5115; TP5116; TP5117; TP9100; TP9101; TP9102; TP9103; TP9104; TP9105; TP9106
TSOP48_18R40X12R10X1R20NANDFLASH_TSOP48_TSOP48_18R40X1H27UBG8T2DTR-BCIC1U4000
TSSOP28_9R70X4R40X1R20_TTPA3110_TSSOP28_9R70X4R40X1R20_TPA3110IC1U7100
USB20MICRO5_MU05_10MGF_TUSB20_MICRO_USB20MICRO5_MU05_10USB20_microIC2J2500; J9600
附件:6 x! a) N; `. B
原理图和pcb文件& w. ~. i) e: x, P
游客,如果您要查看本帖隐藏内容请回复
, C$ b% H7 B- l' \- I6 t# y( o/ t
发表于 2020-9-15 18:50 | 只看该作者
感谢楼主分享资料!!!!
发表于 2020-9-15 20:00 | 只看该作者
感谢楼主分享资料!!!
发表于 2021-11-8 12:12 | 只看该作者
感谢,感谢,找了很久
, Z# F/ s, T# v# l( D
发表于 2022-7-17 19:40 | 只看该作者
感谢,感谢,找了很久& `
发表于 2024-6-6 15:06 | 只看该作者
感谢楼主分享,学习了
“来自电巢APP”
    郁闷
    2023-4-27 15:48
  • 签到天数: 5 天
    [LV.2]偶尔看看I
    发表于 2024-6-10 21:16 | 只看该作者
    感谢,分享学习
    发表于 2025-6-5 18:05 | 只看该作者
    谢谢楼主分享
    GMT+8, 2025-6-15 07:06 , Processed in 0.109375 second(s), 27 queries , Gzip On.
