查看: 254|回复: 0
[allegro16.3][8层]Cyclone_III_Edition CYCLONE III数据转换HSMC(DAC5672IPFBR+A...
发表于 2019-12-30 19:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
' u: }, ?, }/ P" v' u2 q$ l" Z
[allegro16.3][10层]Cyclone_III_Edition CYCLONE III数据转换HSMC(DAC5672IPFBR+AD9254+QTH_HSM)pcb文件
3 j3 H" Y% t4 r# A0 v. j3 b5 V" M. U  T
文件描述:6 |2 t6 V, p% [0 Q
! A& \6 |5 O8 i. t4 r1. 作品用途:Cyclone_III_Edition CYCLONE III数据转换HSMC! J  K4 B5 w1 r8 E' u" C
2. 软件版本:allegro16.3# H- I# T4 r; S% ]
3. 层数:10层" V. @( l+ P- D( e3 j, n) n  H
4. 用到的主要芯片:DAC5672IPFBR+AD9254+QTH_HSM
) Q$ T, `9 ^; A8 o' M5. pcb尺寸:3075*5500  MIL
- I7 I9 O! l; b3 `- C# I
2 Y, H$ X, P$ b! l& h4 r作品截图如下:
- d2 I- R% X' j5 b# P, a. L/ z. m: S$ `4 s. T  e
顶层截图:
- d1 [7 L9 T# f
9 B- v4 p: o5 Z: E  r+ z" U! |底层截图:
: R* ~7 N8 k- \: D! I# Q8 M+ ~0 [6 A3 C! u
" ~: R1 a5 G9 Y9 D3 A9 K全层截图:
8 b1 Y# @, o% }: o& N
. |1 w* A- E7 P5 P" y5 d7 m% Y8 M! ~6 e. g  g  ?, R9 ~( s
叠层阻抗信息如下:) ]2 k0 H- Y" s# g% }$ V& y
/ L/ Q* f- h+ V4 e4 P
BOM:
& h1 i& l7 P9 a
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_HeaderIC12J31; J32; J33; J34; J35; J38; J39; J40; J41; TP1; TP2; TP5
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2IC5J2; J6; J10; J11; J13
2X3VH2X3_2X3VH_2X3HEADER2x3HeaderIC5J3; J7; J15; J17; J23
603CAP_0603_0.1UF0.1ufIC45C1; C2; C3; C4; C5; C7; C9; C10; C11; C12; C13; C20; C21; C24; C25; C26; C27; C28; C30; C32; C33; C34; C35; C36; C43; C44; C49; C50; C53; C54; C55; C59; C61; C66; C70; C74; C77; C83; C86; C94; C96; C99; C101; C103; C105
603CAP_0603_5PF5pFIC2C6; C29
603CAP_0603_1.0NF1.0nFIC23C14; C15; C16; C17; C18; C22; C23; C37; C38; C39; C40; C41; C45; C46; C58; C65; C78; C87; C95; C100; C102; C104; C106
603CAP_0603_10PF10pfIC4C47; C48; C51; C52
603CAP_0603_0.47UF0.47ufIC4C56; C57; C63; C64
603CAP_0603_47P47pIC1C108
603RESISTOR_0402_0603_49.949.9IC8R1; R8; R10; R17; R19; R21; R22; R25
603RESISTOR_0402_0603_100100IC11R2; R11; R20; R24; R65; R66; R71; R72; R73; R74; R113
603RESISTOR_0402_0603_10K10KIC2R3; R12
603RESISTOR_0603_1.00K, 1%1.00K, 1%IC14R4; R6; R13; R15; R75; R76; R78; R85; R89; R95; R97; R101; R102; R103
603RESISTOR_0603_00IC2R5; R14
603RESISTOR_0603_33.2R, 1%33.2R, 1%IC4R7; R9; R16; R18
603RESISTOR_0603_2K2KIC2R23; R26
603RESISTOR_0402_0603_NL-49.9NL-49.9IC30R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56
603RESISTOR_0603_4.70K, 1%4.70K, 1%IC9R57; R58; R59; R60; R61; R62; R63; R64; R107
603RESISTOR_0603_47.5K 1%47.5K 1%IC4R67; R68; R69; R70
603RESISTOR_0603_576, 1%576, 1%IC1R82
603RESISTOR_0603_931, 1%931, 1%IC1R87
603RESISTOR_0603_2.05K 1%2.05K 1%IC1R93
603RESISTOR_0603_NL-1.00K, 1%NL-1.00K, 1%IC3R98; R99; R100
603RESISTOR_0402_0603_00IC6R104; R105; R109; R110; R111; R112
603RESISTOR_0603_10.0K, 1%10.0K, 1%IC2R106; R108
603RESISTOR_0402_0603_1K1KIC2R114; R115
603RESISTOR_0603_NL-0RNL-0RIC4R116; R118; R120; R122
603RESISTOR_0603_0R0RIC4R117; R119; R121; R123
805CAP_0805_10UF10uFIC11C8; C19; C31; C42; C60; C62; C67; C79; C88; C97; C98
805CAP_0805_1.0UF1.0ufIC10C73; C75; C76; C82; C84; C85; C91; C92; C93; C107
805INDUCTOR_0805_120OHM, 800MA120ohm, 800mAIC1L3
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uFIC5C68; C69; C72; C81; C90
FUSE_SMTFUSE_FUSE_SMT_FUSE_BLOCK_7AMPFuse_Block_7AMPIC3F1; F2; F3
KK81TRFMR TT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81IC6T1; T2; T3; T4; T6; T7
LFCSP48AD9254_LFCSP48_AD9254AD9254IC2U1; U2
LTC-S8LT1963_LTC-S8_LT1963LT1963IC3U6; U7; U8
M08AFIN1028_M08A_FIN1028FIN1028IC1U4
M08AFIN1027_M08A_FIN1027FIN1027IC1U15
RES_PACK_8RES_PACK_8_RES_PACK_8_00IC4RN1; RN2; RN3; RN4
SAMTEC_QTHDP120CUSTOMQTH_HSM_SAMTEC_QTHDP120CUSTOM_QQTH_HSMIC1J1
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515NIC4J19; J20; J21; J42
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GTIC8J4; J8; J12; J14; J25; J26; J28; J30
TQFP-48DAC5672IPFBR_1_TQFP-48_DAC5672IDAC5672IPFBRIC1U3
TSSOP8IS24C_TSSOP8_IS24C02BIS24C02BIC1U14
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054IC5U9; U10; U11; U12; U13
TSSOP-28AIC23_TSSOP-28_AIC23AIC23IC1U5
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006IC4R80; R83; R91; R94
WSL2010RESISTOR_WSL2010_00IC2R81; R92
附件:
( R' Q' R/ I4 n; ^5 SPCB文件如下:
6 R) d3 M8 ?5 {7 E0 b# P& x
游客,如果您要查看本帖隐藏内容请回复
: T. c7 l; W9 x) ~; }- z0 E. q& J. K0 D
GMT+8, 2025-7-21 01:18 , Processed in 0.125000 second(s), 28 queries , Gzip On.
