查看: 472|回复: 1
[allegro16.3][6层]一块AM3352的板卡(FPC_FH28+SN74AVC32T245+TPS65105)pcb文件
发表于 2019-12-30 19:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
9 t8 N. B6 g. p+ G$ r
3 C: Q1 S. F8 p3 h6 z& a[allegro16.3][6层]一块AM3352的板卡(FPC_FH28+SN74AVC32T245+TPS65105)pcb文件: y  O1 W3 K) p; z
! u/ b! a' b/ n5 A& l0 j% v
* }' M' x8 y' X& j1 G* m: _; U" p
文件描述:% F8 u0 [) t& S  O3 q
0 ]) q8 ~$ n! A7 f8 \3 _5 Y1 ~+ y
& r& y( ^/ R- \  [/ D1 c8 S1. 作品用途:一块AM3352的板卡
! `# ~" P; _* R. d2. 软件版本:allegro16.32 ?( S# a5 S% j' A
3. 层数:6层+ h7 O8 j! n8 W% F3 x: V
4. 用到的主要芯片:FPC_FH28+SN74AVC32T245+TPS65105( L! I4 @4 a9 Z
5. pcb尺寸:6693*4330 MIL5 u5 m" n- U; l, G# \% M
  v4 m0 M" a/ \6 R4 n# E$ L2 t
9 [+ B8 p& \% J* `2 Q- P/ ?. c6 [( n作品截图如下:  Z4 x& ^7 e0 D8 a! a% C
9 _" O7 C8 T$ l4 k. B
' [' l* k0 E1 ]; \$ I2 j! t7 I
顶层截图:! A6 M7 E8 W9 e3 P- q
3 ], M# Y4 E2 y. u- Q1 ]
底层截图:1 i3 d; G" G5 Y
4 l9 l4 _+ e! `. b6 k4 h
/ I  \! S( |  s0 E. Q
3 D( ?6 v' W$ K; v# E% w
全层截图:
  l+ N+ p, Y% I9 f! C % m9 ?5 H# ~9 {# ~8 G1 }' o
# t$ P) _. z/ S3 H: n- Y
2 v4 X1 o: \. F% R6 i- a叠层阻抗信息如下:  T% m5 I6 y: q' ~
% m, g! w/ J, Q. M7 M
BOM:7 R- ^# \6 X! s) f
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
HEADER_5X1HEADER_5X1_HEADER_5X1_HEADER 5HEADER 5IC1J7
HEADER_10X2_THHEADER10X2_0.05INPITCH_MALE_HEAHeader_10x2_MaleIC3J1; J2; J3
SM-7351-CAP-04020.01UFCAPACITOR16V10%0402_SM-730.01uFIC20C1; C2; C3; C4; C5; C6; C31; C32; C33; C34; C35; C36; C37; C38; C43; C44; C45; C47; C54; C57
SM-7351-CAP-04026.8PFCAPACITOR50V10%SMD0402_SM-6.8pFIC1C8
SM-7351-CAP-04020.001UFCAPACITOR50V5%0402_SM-730.001uFIC1C10
SM-7351-CAP-04022200PFCAPACITOR50V10%SMD0402_SM2200pFIC1C11
SM-7351-CAP-04021UFCAPACITOR10V10%0402_SM-7351-1uFIC7C16; C19; C46; C53; C56; C60; C63
SM-7351-CAP-04020.1UFCAPACITOR50V10%0402_SM-7350.1uFIC11C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C39
SM-7351-CAP-040247NFCAPACITOR16V10%0402_SM-735147nFIC1C41
SM-7351-CAP-04020.1UFCAPACITOR16V10%0402_SM-7350.1uFIC10C48; C49; C50; C51; C52; C55; C64; C65; C66; C67
SM-7351-CAP-040215PFCAPACITOR50V10%SMD0402_SM-715pFIC2C58; C61
SM-7351-CAP-06030.22UFCAPACITOR50V10%0603_SM-730.22uFIC5C12; C13; C14; C15; C17
SM-7351-CAP-06034.7UFCAPACITOR16V10%0603_SM-7354.7uFIC4C18; C20; C40; C42
SM-7351-CAP-080522UFCAPACITOR16V10%0805_SM-735122uFIC2C7; C9
SM-7351-CAP-08052.2UF16V10%SMD0805_SM-7351-CAP-2.2uFIC2C59; C62
SM-7351-IND-0603FERRITEBEAD_300OHM500MA_SM-7351300OHM500mAIC2FB1; FB2
SM-7351-RES-040210KOHMRESISTOR1/16W0402_SM-735110KIC19R2; R4; R5; R9; R10; R33; R34; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R57; R60
SM-7351-RES-0402ZEROOHMRESISTOR1/16W0402_SM-7350IC13R6; R7; R8; R35; R36; R37; R52; R53; R56; R58; R59; R65; R68
SM-7351-RES-0402499KOHM1/16W1%SMD0402_SM-7351-R499KIC1R11
SM-7351-RES-0402430KOHM1/16W1%SMD0402_SM-7351-R430KIC1R12
SM-7351-RES-0402330KOHM1/16W1%SMD0402_SM-7351-R330KIC1R13
SM-7351-RES-040215KOHM1/16W1%SMD0402_SM-7351-RE15KIC1R14
SM-7351-RES-040256KOHM1/16W5%SMD0402_SM-7351-RE56KIC2R15; R19
SM-7351-RES-0402750KOHM1/16W1%SMD0402_SM-7351-R750KIC1R16
SM-7351-RES-0402680KOHM1/16W1%SMD0402_SM-7351-R680KIC1R17
SM-7351-RES-0402130KOHM1/16W1%SMD0402_SM-7351-R130KIC1R18
SM-7351-RES-0402220OHM1/10W1%SMD0402_SM-7351-RE220IC1R20
SM-7351-RES-040262OHMRESISTOR1/16W0402_SM-7351-62IC2R21; R31
SM-7351-RES-040269.8OHMRESISTOR1/16W0402_SM-73569.8IC1R23
SM-7351-RES-040240.2OHMRESISTOR1/16W0402_SM-73540.2IC1R24
SM-7351-RES-0402237OHMRESISTOR1/16W0402_SM-7351237IC1R25
SM-7351-RES-0402165OHMRESISTOR1/16W0402_SM-7351165IC1R27
SM-7351-RES-040264.9OHMRESISTOR1/16W0402_SM-73564.9IC1R28
SM-7351-RES-040282.5OHMRESISTOR1/16W0402_SM-73582.5IC1R29
SM-7351-RES-0402240OHMRESISTOR1/16W0402_SM-7351240IC1R30
SM-7351-RES-04022.2KOHMRESISTOR1/16W0402_SM-7352.2KIC7R49; R50; R51; R72; R73; R74; R75
SM-7351-RES-0402100OHM1/16W1%SMD0402_SM-7351-RE100IC2R54; R55
SM-7351-RES-0402100KOHMRESISTOR1/16W0402_SM-735100KIC2R61; R62
SM-7351-RES-040251KOHM1/16W1%SMD0402_SM-7351-RE51KIC1R66
SM-7351-RES-040230.1KOHM1/16W1%SMD0402_SM-7351-30.1KIC2R67; R71
SM-7351-RES-040237.4KOHM1/16W1%SMD0402_SM-7351-37.4KIC1R70
SM-7351-RES-0603ZEROOHMRESISTOR1/16W0603_SM-7350IC6R1; R3; R32; R63; R64; R69
SM-7351-RES-0603198OHMRESISTOR0.15W0603_SM-7351198IC1R22
SM-7351-RES-06031.0OHMRESISTOR1/10W0603_SM-73511IC1R38
SM-7351-RES_040225OHMRESISTOR1/16W0402_SM-7351-25IC1R26
SM_BGA_P8_6X16SN74AVC32T245_SM_BGA_P8_6X16_SNSN74AVC32T245IC1U4
SM_CON_FH28-60S-0_5SHCONN_FPC_FH28_60PIN_SM_CON_FH28FPC_FH28_60pinIC1J4
SM_CON_FH28_50S-0_5SHCONN_FPC_FH28_50PIN_SM_CON_FH28FPC_FH28_50pinIC1J8
SM_CON_SM02B_BHSS-1CONN_SM02B-BHSS_SM_CON_SM02B_BHSM02B-BHSS-1IC1J5
SM_DIO_CASE_457-04DIODE1A20V_SCHOTTKY_SM_DIO_CASEMBRM120LIC1D1
SM_IND_LQH32CN4.7UHINDUCTOR20%450MASMD_SM_IND4.7uHIC1L1
SM_LED_0805LED_GREEN_SM_LED_0805_GREEN LEDGreen LEDIC1D3
SM_RPAK_EXB-2HV33OHMX8_1/16W5%SMD_SM_RPAK_EXB-33x8DISCRETE6RP1; RP2; RP3; RP4; RP5; RP7
SM_SOT23_BCENPN_FMMT458_SM_SOT23_BCE_FMMT45FMMT458TAIC1Q1
SM_SOT323-3DIODE200MA30V_SCHOTTKY_SM_SOT32BAT54SIC1D2
SOIC_8CAT24C256W_SOIC_8_CAT24C256WCAT24C256WIC1U1
TH_HDR_4P_RACONN_4X1DAWARRESTSC_TH_HDR_4P_RHeader4x1_RAIC2J6; J9
TH_TP_5002TESTPOINTTHROUGHHOLE_TH_TP_5002TPIC1TP3
TP_SMD1MMCIRCLETESTPOINT_SMD1MMCIRCLE_TP_SMD1MTP1mmIC2TP1; TP2
UFBGA-7X7-P65MMMXT244_UFBGA49_UFBGA-7X7-P65MM_mxt224IC1U9
U_5_DCKSN74LVC1G07_U_5_DCK_SN74LVC1G07SN74LVC1G07IC2U2; U7
U_6_DBVTPS79301_U_6_DBV_TPS79301TPS79301IC2U11; U12
U_8_DCTTXS0102_U_8_DCT_TXS0102TXS0102IC2U6; U10
U_10_DRCTPS61081DRC_U_10_DRC_TPS61081DRTPS61081DRCIC1U5
U_20_PWTLC59108IPW_U_20_PW_TLC59108TLC59108IC1U8
U_24_PWTPS65105PWP_U_24_PW_TPS65105TPS65105IC1U3
VLCF5020T4.7UHINDUCTOR30%1.7ASMD_VLCF5024.7uHIC1L2
附件:
6 v/ m, l$ X& Q, \) aPCB文件如下:
0 b6 J- p1 ^5 }* i% D9 A3 F
游客,如果您要查看本帖隐藏内容请回复
; p& y! F* c' H) D  z9 G' [& \- D
; Y" F8 I  l. D- C
GMT+8, 2025-7-28 02:41 , Processed in 0.125000 second(s), 27 queries , Gzip On.
