作品名:[AD 10][2层]AT24C8+EP2C5Q208+PCF8563_原理图和PCB源文件
9 |- M2 \$ t4 M Q文件描述 1. 作品用途:AT24C8+EP2C5Q208+PCF8563_原理图和PCB源文件 2. 软件版本:AD 10 3. 层数:2层板 4. 用到的主要芯片:AT24C8+EP2C5Q208+PCF8563 5. PCB尺寸:137mm*103.5mm
/ A6 v* k+ m4 s" F4 s作品截图如下: 顶层截图:
+ T- M* k; m2 `2 ^, |
3 b) H4 K" q+ ?% Z) k底层截图: 全层截图:
, J# q/ I( f+ K/ z% T" P" k叠层信息截图如下: 2 N: [* |2 h6 O' _4 \
BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | U2 | ams1117_adj | AMS1117_ADJ | 1 | BUZZER | BEEP | BUZZ-.28/.46 | 1 | 0.1uf | C36, C37, C38 | 0603C | 3 | 15pf | C39 | 0603C | 1 | 0.1u | C40, C44, C45, C46, C47, C48, C49, C50, C51, C53, C54, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C65, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87, C88, C89, C90 | 0603C | 47 | 0.01u | C41, C42 | 0603C | 2 | 33p | C95, C96 | 0603C | 2 | 1u | C97 | 0603C | 1 | 0.001u | C103 | 0603C | 1 | Cap Pol1 | CF2, CF3, CF4, CF5 | CAP-A | 4 | DB9 | com | DB-9RA/F | 1 | Cap Pol1 | CY3, CY4, CY5 | RB-220T | 3 | 10u | CYF1 | CAP-A | 1 | LED2 | DH1, DH2, DH3, DH4, Hpw_led, LED1, LED2, link1, rx1, Spw_led, tx1, usb_led1 | LED-0603 | 12 | | DIS1, DIS2 | LN3461 | 2 | | EPCS, JTAG | IDC-10-B | 2 | DAC | J2 | SIP6 | 1 | SWITCH | key0, key1, key2, key3 | KEY_2 | 4 | 100mh | L1, L5 | 0805 | 2 | 600ohm@100mhz | L2, L3 | 0805C | 2 | 10mh | L4 | 0805 | 1 | LCD12864 | LCD_1 | sip20 | 1 | lcd1602 | LCD_2 | sip16 | 1 | 4*220 | PR1, RP1, RP2, RP6 | PZ-4-0.5 | 4 | 4*10K | PR2, RP8 | PZ-4-0.5 | 2 | +5v | pw_in | pw_in | 1 | 8850 | Q1 | SOT-23 | 1 | 8550 | Q2, Q3, Q4, Q5, Q6, Q7, Q8, Q9 | SOT-23 | 8 | 220 | R37, R52, R53, R54, R55, R56, R57, R58, R59, R60, R61, R62 | 0603R | 12 | 10k | R63, R64, R65, R66, R67, R68, R69, R70, R71, R72, R73, R74, R75, R76, R77, R78 | 0603R | 16 | 5.1k | R79, R80, R81, R82, R83, R84 | 0603R | 6 | 470 | R85 | 0603R | 1 | 1k | R86, R87, R88, R89, R90, R91, R92, R93, R94, R95, R96, R97 | 0603R | 12 | 2k | R98 | 0603R | 1 | 30 | R99 | 0603R | 1 | 33 | R100, R101 | 0603R | 2 | 100 | R102, R103, R104, R105, R106, R107, R108 | 0603R | 7 | 27k | R109 | 0603R | 1 | 49R9(10.8k) | R110, R111 | 0603R | 2 | 24R9(5.2k) | R112, R113, R114, R115 | 0603R | 4 | 0 | R116, R117 | 0603R | 2 | | reset | KEY_2 | 1 | PTC0001-01(RJ45) | RJ45 | RJ45 | 1 | 4*1K | RP3, RP4, RP5, RP7 | PZ-4-0.5 | 4 | 10k | RW2 | VR-5 | 1 | | SP/2 | sps_2 | 1 | AMS1117 | U1 | AMS1117_3.3 | 1 | EP2C5Q208 | U3 | EP2C5Q208 | 1 | EPCS1 | U4 | EPCS1 | 1 | JS28F640_FLASH | U5 | JS28F640 | 1 | HY57V641620_SDRAM | U6 | HY57V641620 | 1 | AT24C8 | U10 | at24c08 | 1 | PCF8563 | U12 | PCF8563 | 1 | tl431 | U13 | TL431 | 1 | TLC5620 | U14 | TLC5620 | 1 | TLC549cd | U15 | TLC549CD | 1 | MAX3232ACPE16 | U16 | TSSOP-16 | 1 | RTl8019AS | U20 | RTl8019AS | 1 | CP2102 | U21 | CP2102 | 1 | USB_UART | USB_UART | USB_UART | 1 | VGA port | VGA | DB-15FLC | 1 | 50MHZ | X1 | x1 | 1 | 20Mhz | Y1 | XTAL-D | 1 | 32.768k | Y2 | SIP2 | 1 | , O4 J2 I" W9 A( {0 c& ]" |% t
附件: 原理图和PCB源文件如下: + k4 K& n9 S9 v0 B) N# v
