Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
C1005 | CAPACITOR NON-POL_C1005_0.1UF | 0.1uF | IC | 2 | C102; C103 |
C1005 | CAP NP_C1005_0.01UF | 0.01uF | IC | 15 | C106; C109; C128; C130; C139; C141; C143; C149; C153; C157; C166; C170; C174; C178; C182 |
C1005 | CAP NP_C1005_0.1UF | 0.1uF | DISCRETE | 37 | C108; C119; C120; C122; C124; C127; C129; C134; C135; C138; C140; C142; C146; C147; C148; C150; C151; C152; C154; C155; C156; C158; C159; C160; C163; C164; C165; C167; C168; C169; C171; C172; C173; C175; C176; C177; C181 |
C1608 | CAP NP_C1608_2.2UF/16V | 2.2uF/16V | IC | 1 | C100 |
C1608 | CAP NP_C1608_1UF_NMT | 1uF_NMT | IC | 1 | C107 |
C1608 | CAP NP_C1608_22PF | 22pF | IC | 3 | C113; C121; C123 |
C1608 | CAP NP_C1608_1UF | 1uF | IC | 6 | C126; C131; C137; C145; C162; C180 |
C1608 | CAP NP_C1608_4700PF_NMT | 4700pF_NMT | IC | 1 | C132 |
C2012 | CAP NP_C2012_10UF/25V | 10uF/25V | IC | 12 | C104; C110; C114; C115; C116; C117; C118; C133; C136; C144; C161; C179 |
C2012 | CAP NP_C2012_22UF | 22uF | IC | 2 | C111; C112 |
C2012 | CAPACITOR NON-POL_C2012_10UF/25 | 10uF/25V | IC | 2 | C183; C184 |
CND-002-L-Z | CND-002-L-Z_CND-002-L-Z_B2P-VH( | B2P-VH(LF)(SN) | IC | 1 | CN100 |
CUTLAND35 | CUT_0_CUTLAND35_NB-1-3.0-S | NB-1-3.0-S | IC | 1 | JP100 |
DIP_10P_2R54_12R4X5R08 | CON10A_DIP_10P_2R54_12R4X5R08_A | A1-10PA-2.54DSA(71) | IC | 1 | CN102 |
F4532 | MINISMDC260F/16TR-ND_F4532_MINI | MINISMDC260F/16TR-ND | IC | 1 | F100 |
HK-3-G-T | T POINT R_1_HK-3-G-T_HK-3-G | HK-3-G | IC | 8 | TP100; TP101; TP102; TP103; TP104; TP105; TP106; TP107 |
HOLE_M3 | T POINT F_2_HOLE_M3_M3 | M3 | IC | 2 | H100; H101 |
L1608 | INDUCTOR_L1608_MPZ1608S221A | MPZ1608S221A | IC | 5 | FB100; FB101; FB102; FB103; FB104 |
LED1608 | LED_0_LED1608_SML-310MT | SML-310MT | IC | 4 | LED101; LED102; LED103; LED104 |
NFBGA-175 | TUSB1310AZAY_NFBGA-175_TUSB1310 | TUSB1310AZAY | IC | 1 | U105 |
PAD_C0R5 | T POINT R_PAD_C0R5_PAD | PAD | IC | 6 | PAD100; PAD101; PAD102; PAD103; PAD104; PAD105 |
R1005 | R_R1005_10 | 10 | IC | 2 | R100; R103 |
R1005 | RESISTOR_R1005_0_NMT | 0_NMT | IC | 1 | R101 |
R1005 | RESISTOR_R1005_0 | 0 | IC | 7 | R102; R104; R106; R115; R118; R120; R145 |
R1005 | RESISTOR_R1005_10K | 10k | IC | 7 | R105; R107; R127; R133; R134; R135; R144 |
R1005 | R_R1005_100K | 100K | IC | 2 | R108; R111 |
R1005 | R_R1005_22K | 22k | IC | 1 | R110 |
R1005 | RESISTOR_R1005_150 | 150 | IC | 2 | R112; R113 |
R1005 | RESISTOR_R1005_10K_NMT | 10k_NMT | IC | 1 | R132 |
R1005 | RESISTOR_R1005_4.7K | 4.7k | IC | 13 | R136; R139; R141; R143; R147; R149; R150; R151; R152; R153; R155; R157; R158 |
R1005 | RESISTOR_R1005_4.7K_NMT | 4.7k_NMT | IC | 7 | R137; R140; R142; R146; R148; R154; R156 |
R1005 | R_R1005_0_NMT | 0_NMT | IC | 3 | R159; R160; R161 |
R1608 | R_R1608_120K | 120K | IC | 1 | R109 |
R1608 | RESISTOR_R1608_100 | 100 | IC | 1 | R114 |
R1608 | RESISTOR_R1608_90.9K_1% | 90.9k_1% | IC | 3 | R116; R128; R130 |
R1608 | RESISTOR_R1608_680K_1% | 680k_1% | IC | 1 | R117 |
R1608 | RESISTOR_R1608_150K_1% | 150k_1% | IC | 1 | R119 |
R1608 | RESISTOR_R1608_470K_1% | 470k_1% | IC | 2 | R121; R123 |
R1608 | RESISTOR_R1608_180K_1% | 180k_1% | IC | 1 | R122 |
R1608 | RESISTOR_R1608_390K_1% | 390k_1% | IC | 1 | R124 |
R1608 | RESISTOR_R1608_1M | 1M | IC | 1 | R125 |
R1608 | RESISTOR_R1608_90.9K_1%_NMT | 90.9k_1%_NMT | IC | 1 | R126 |
R1608 | RESISTOR_R1608_1M_NMT | 1M_NMT | IC | 1 | R129 |
R1608 | RESISTOR_R1608_28.7K_1% | 28.7k_1% | IC | 1 | R131 |
R1608 | RESISTOR_R1608_330 | 330 | IC | 1 | R138 |
SIP_2P_2R54_4R78X2R54 | CON2_SIP_2P_2R54_4R78X2R54_A2-2 | A2-2PA-2.54DSA(71)_NMT | IC | 1 | J101 |
SIP_2P_2R54_4R78X2R54 | CON2_SIP_2P_2R54_4R78X2R54_A2_1 | A2-2PA-2.54DSA(71) | IC | 1 | J103 |
SIP_3P_2R54_7R6X2R8 | CON3_SIP_3P_2R54_7R6X2R8_XG8S-0 | XG8S-0331 | IC | 3 | J100; J102; J104 |
SMD_6R1X3R7 | SW PUSHBUTTON-SPST_0_SMD_6R1X3R | SKQYAAE010 | IC | 1 | SW100 |
SMD_ALCAP_6R3X5R8 | CAP POL_SMD_ALCAP_6R3X5R8_47UF/ | 47uF/25V | IC | 1 | C105 |
SMD_ALCAP_8X10 | CAP POL_SMD_ALCAP_8X10_150UF/25 | 150uF/25V | IC | 1 | C101 |
SMD_ALCAP_8X10 | POSCAP_SMD_ALCAP_8X10_150UF/25V | 150uF/25V_ALUM | IC | 1 | C125 |
SMD_ASP-134488-01 | ASP-134488-01_SMD_ASP-134488-01 | ASP-134488-01 | IC | 1 | CN103 |
SMD_IND_7R1X6R8 | INDUCTOR_SMD_IND_7R1X6R8_HCM070 | HCM0703-2R2-R_2.2uH | IC | 1 | L101 |
SMD_IND_8R0X4R0 | INDUCTOR_SMD_IND_8R0X4R0_NR8040 | NR8040T220M_22uH | IC | 1 | L100 |
SMD_OSC_5X3R2 | FCX-05_SMD_OSC_5X3R2_ECS-400-20 | ECS-400-20-30B-AEM-TR | IC | 1 | X100 |
SMT3 | TR-3_0_SMT3_DTD113ZK | DTD113ZK | IC | 2 | Q100; Q102 |
SOD-128 | DIODE TVS_1_SOD-128_PTVS12VP1UP | PTVS12VP1UP | IC | 1 | D100 |
SOIC-8 | RT7250AZSP_SOIC-8_RT7250AZSP | RT7250AZSP | IC | 1 | U100 |
SOT-3 | TPD2EUSB30DRTR_2_SOT-3_TPD2EUSB | TPD2EUSB30DRTR | IC | 3 | U103; U104; U106 |
SOT-23 | 2SC2713_0_SOT-23_BC856ALT1 | BC856ALT1 | IC | 1 | Q101 |
SOT-23-6 | TPS3808_2_SOT-23-6_TPS3808G18DB | TPS3808G18DBV | IC | 1 | U101 |
SOT-23-6 | TPS2552DBVT_SOT-23-6_TPS2552DBV | TPS2552DBVT | IC | 1 | U107 |
USB-A | 1932258-1_0_USB-A_1932258-1 | 1932258-1 | IC | 1 | CN101 |
WFQFN-16 | TPS65000RTE_WFQFN-16_TPS65000RT | TPS65000RTE | IC | 1 | U102 |
