查看: 363|回复: 1
[allegro16.3][2层]HI3520DV2 PCB源文件(LQFP256+NVP6114+网口)原理图和pcb文件
发表于 2019-12-30 14:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 s8484ww 于 2019-12-30 14:36 编辑 3 a3 v* ^: p& H, v
% O: x9 b0 |4 p% ?2 F9 A; J
+ e, o- b7 |8 U9 m5 p* H& r% x5 Q! L6 g! d) ~$ N& w
文件描述:
) `/ m( d5 P: \" }3 j' B8 i
1. 作品用途:HI3520DV2 PCB源文件
2. 软件版本:allegro16.3
3. 层数:2层
4. 用到的主要芯片:LQFP256+NVP6114+网口* U0 r3 O1 K- O% q) y! {
5. pcb尺寸:162.69*118.87 MM
! o% J5 Y6 {6 l5 ?7 \: G
作品截图如下:
  D9 [7 U) \/ Z
! R3 B/ e+ K5 t/ I( `8 J( ^! Q' ]" j
顶层截图:
底层截图:
3 p8 \3 b' b( Z4 A2 P4 O
全层截图:
1 F: e/ m! X- b8 ^; n  Y' j
叠层阻抗信息:
8 T0 h3 s. x: j% _; w" W
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BAT_UPRIGHTBAT_UPRIGHTIC1U4
BGA96-32-1609GBGA96-32-1609GIC1U10
DB9-2RMDB9-2RMIC1J14
DB15-2RFDB15-2RFIC1J5
DB15-3RF-ADB15-3RF-A17HE_R13150_73HC2IC1J12
HOLE160-8STARHOLE160-8STARIC4M1; M2; M3; M4
HSC0402HSC0402100NFIC4C19; C20; C21; C22
HSC0603HSC06034.7uFDISCRETE2C216; C217
HSOD323AHSOD323AIC1D25
HSX2-0302HSX2-03020.03MHZIC2X1; X3
ID-BOARDID-BOARDIC6ID1; ID2; ID3; ID4; ID5; ID6
IDC20-DTM1-AIDC20-DTM1-AIC1J11
LQFP256-040-2828LH-SQ7_7MMLQFP256-040-2828LH-SQ7_7MMIC1U8
MJ8-RLYMJ8-RLYIC1J13
PWC0103-M-CPWC0103-M-CIC1J8
QFN76-040-0909-NVP6114QFN76-040-0909-NVP6114IC1U9
SATA7-MSATA7-MIC2J9; J10
SC0402SC040233pFDISCRETE148C2; C10; C15; C23; C24; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C46; C47; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C140; C141; C142; C152; C153; C160; C161; C162; C163; C164; C165; C184; C185; C187; C188; C192; C210; C211; C212; C213; C214; C215; C236; C237; C238; C239; C240; C241; C242; C246; C252; C253; C264; C265; C266; C267; C268; C270; C271; C272; C273; C275; C276; C277; C278; C289; C290; C495; C496; C657
SC0603SC060320pFDISCRETE81C7; C8; C9; C12; C13; C16; C17; C25; C26; C29; C43; C44; C45; C48; C49; C87; C88; C89; C110; C139; C143; C144; C145; C146; C149; C150; C151; C154; C155; C156; C157; C158; C159; C167; C168; C169; C170; C171; C179; C180; C181; C182; C198; C199; C200; C201; C202; C203; C204; C205; C206; C207; C208; C209; C218; C219; C220; C243; C244; C245; C248; C249; C250; C251; C255; C256; C261; C263; C269; C274; C281; C282; C284; C285; C287; C288; C293; C294; C295; C296; C656
SC0805SC08051uFDISCRETE3C42; C194; C195
SC1206SC120622uFDISCRETE9C11; C14; C18; C28; C147; C148; C178; C189; C286
SC1210SC1210IC1C292
SD0805-LEDSD0805-LEDLEDIC3D5; D23; D24
SD1714DSD1714DIC1D20
SD2723SD2723DIODEDISCRETE1D18
SEN3-100CSEN3-100CIC1D17
SF6127SF6127SSQ4DISCRETE1F1
SIP5-98SIP5-98IC3J6; J18; J19
SIP-1PSIP-1PIC4J15; J20; J21; J22
SIP-3PSIP-3PIC1J1
SIP-4P-200SIP-4P-200IC1J23
SL0402SL0402IC10LB1; LB2; LB3; LB10; LB11; LB13; LB14; LB15; LB16; LB18
SL0603SL0603IC1LB19
SL0805SL08051uHDISCRETE7LB5; LB6; LB7; LB9; LB12; LB17; LB22
SL1210SL121010uHDISCRETE2LB20; LB21
SL2828SL2828IC3L2; L3; L4
SOP8-26-118SOP8-26-118IC1U16
SOP8-50-150SOP8-50-150IC1U6
SOP8-50-173SOP8-50-173IC1U7
SOP8H-50-154CSOP8H-50-154CIC1U17
SOP10-20-124ASOP10-20-124AIC3U14; U15; U18
SOP16-26-208-255SOP16-26-208-255IC1U11
SOP38-20-173ASOP38-20-173AIC1U3
SOT23SOT23IC9D1; D2; D3; D4; D9; D10; D11; D21; D22
SOT23-6LSOT23-6LIC2U19; U21
SOT23BSOT23BIC1U2
SOT-DPAKSOT-DPAKIC1U1
SR0402SR0402IC122R1; R2; R3; R5; R6; R7; R8; R9; R11; R12; R13; R18; R19; R23; R24; R25; R26; R27; R28; R32; R33; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R51; R52; R53; R54; R55; R56; R57; R58; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R90; R91; R92; R95; R96; R97; R100; R104; R123; R124; R127; R128; R132; R134; R135; R136; R137; R138; R141; R142; R146; R149; R158; R164; R165; R166; R167; R168; R174; R175; R177; R178; R179; R186; R188; R189; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R202; R204; R213; R217; R219
SR0603SR0603IC71R10; R14; R15; R16; R17; R20; R21; R22; R34; R35; R50; R59; R60; R89; R93; R98; R99; R101; R102; R103; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R125; R126; R129; R130; R131; R133; R144; R145; R147; R150; R151; R152; R153; R154; R155; R156; R157; R169; R180; R181; R182; R183; R184; R187; R190; R201; R206; R207; R208; R209; R282; R474; R476
SR0805SR08050DISCRETE1R94
SR1206SR1206IC3R143; R148; R159
SR2512SR2512IC3R29; R30; R31
SRN8-0804SRN8-0804IC9RN1; RN2; RN3; RN4; RN5; RN6; RN7; RN8; RN9
SSW-PUSHSSW-PUSHTC-108IC1S1
STC3528STC352810uFDISCRETE8C111; C113; C114; C115; C191; C279; C280; C283
STC7343STC7343100UFIC9C1; C3; C4; C5; C6; C27; C196; C197; C247
STFM16-50-285STFM16-50-285IC1T1
SX2-1205SX2-120525MHzIC2X2; X4
TP24-SMDTP24-SMDIC27TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27
TSOT23-8TSOT23-8IC3U12; U13; U20
USB4-200-1907USB4-200-1907IC2J2; J7
VAF2VAF2IC3J3; J4; J17
WBC0109-20RAWBC0109-20RAIC1J16
WSOP8_MX25L3206EWSOP8_MX25L3206EIC1U5
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
0 o+ l5 S, K6 s$ U* z( \, w) H. ~
    郁闷
    2020-11-24 15:01
    发表于 2020-11-24 15:03 | 只看该作者
    没有威望啊
    GMT+8, 2025-7-8 06:13 , Processed in 0.125000 second(s), 27 queries , Gzip On.
