查看: 704342|回复: 27
[allegro16.6][6层]英特尔方案平板PCB共享(Z3735F_G+ALC5640+AXP288+RL_SM02BD_87...
发表于 2019-12-30 14:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层]英特尔方案平板PCB共享(Z3735F_G+ALC5640+AXP288+RL_SM02BD_8723BS+BCM43438+BCM4752IFBG)pcb文件
文件描述:
1. 作品用途:英特尔方案平板PCB共享
2. 软件版本:allegro16.6
3. 层数:6层
4. 用到的主要芯片: Z3735F_G+ALC5640+AXP288+RL_SM02BD_8723BS+BCM43438+BCM4752IFBG
5. PCB尺寸:118*67.03 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1X6_P8MM_WTB_ACES_50208CON6_WTB_MTG2_1X6_P8MM_WTB_ACESCON6_WTB_MTG2IC1J3500
2X20_P4MM_BTB_RCPT_DF40CCON40_RCPT_2X20_P4MM_BTB_RCPT_DCON40_RCPTIC1J9700
AFN_MAX2659MAX2659_0_AFN_MAX2659_MAX2659MAX2659IC1U17
ANT-IPEXANT_WFL-R-SMT_ANT-IPEX_WFL-R-SMWFL-R-SMTIC1ANT1
ANT-IPEXCON RF I-PEX MHF-20279_0_ANT-IPU.FL-R-SMTIC1CON14
ANT-WIFI-2ANT-WIFI-2_0_ANT-WIFI-2_ANT-WIFANT-WIFI-2IC1ANT2
BGA6_5MM_1P4_P974AVC1T45YZP_BGA6_5MM_1P4_P9_7474AVC1T45YZPIC1U9009
BGA8_P4MM_1P19SQ_P57H_12MILPADAK09911C_12MILPAD_BGA8_P4MM_1P1AK09911C_12MILPADIC1U8002
BGA49_P65_5SQ_1P3H_PAD12MILU_BCM4752IFBG_BGA49_P65_5SQ_1P3BCM4752IFBGIC1U18
BGA96_P8MM_9P1X14P1MT41K256M16_BGA96_P8MM_9P1X14P1MT41K256M16IC4U3005; U3006; U3101; U3102
BGA153_11P5X13_12MILPADKLM8G1WEMB_B031_0_BGA153_11P5X1KLM8G1WEMB_B031IC1U3501
BGA592_P65MM_17X17SOC_VLV2_CR_concept_CUST_WW3_BGSOC_VLV2_CR_CONCEPT_CUST_WW3IC1U1000
C0201CAPNP_DUP1_1_C0201_0.5PF0.5pFIC2C9739; C9742
C0201CAPNP_DUP1_1_C0201_10PF10pFIC2C9740; C9741
C0402CAP NP_C0402_0.1UF0.1uFIC7C196; C238; C239; C240; C246; C259; C321
C0402CAP NP_C0402_470PF470pFIC1C198
C0402CAP NP_C0402_22PF22pFIC1C299
C0402CAP NP_C0402_100NF100nFIC1C315
C0402CAP NP_C0402_1UF1uFIC2C319; C320
C0402CAPNP_DUP1_1_C0402_27PF27pFIC2C656; C657
C0402C 0402_0_C0402_10PF/50V_EC0.15010pF/50VIC1C908
C0402CAP NP_C0402_2PF2pFIC2C919; C920
C0402CAP NP_C0402_5.6PF5.6pFIC6C925; C941; C942; C943; C944; C945
C0402C0402_C0402_1UF1uFIC2C2507; C9710
C0402C0402_C0402_4.7UF4.7uFIC1C9711
C0402CAPNP_DUP1_1_C0402_1UF1uFIC7C9730; C9731; C9732; C9733; C9734; C9736; C9737
C0402CAPNP_DUP1_1_C0402_100NF100nFIC1C9735
C0402CAPNP_DUP1_1_C0402_2.2UF2.2uFIC2C9744; C9745
C0603CAP NP_C0603_10UF10uFIC5C71; C197; C247; C260; C318
C0603CAP NP_C0603_4.7UF4.7uFIC1C237
C0603CAP NP_1_C0603_10UF10uFIC1C305
C0603C0603_C0603_10UF10uFIC1C913
C0603C0603_C0603_1UF1uFIC2C2505; C2506
C0603CAPNP_DUP1_1_C0603_4.7UF4.7uFIC2C9738; C9743
C0603CAP_C0603_22UF_H35094-00122UFIC1C9747
CABLE_HOLDER_SV08MCABLE_HOLDER_CABLE_HOLDER_SV08MCABLE_HOLDERIC1J9900
CON-BTB-P0_4H1_5W4_1F-24P-OPCON24_RCPT_CAM_BYT_CR_CON-BTB-PCON24_RCPT_CAM_BYT_CRIC2J8504; J8505
CON-FPC-0_5-5P-OPCON6_0_CON-FPC-0_5-5P-OP_5PIN0.5PIN0.5IC1J6
CON-FPC-0_5-12PTOUCH_SCREEN_1_CON-FPC-0_5-12P_Touch_screenIC1J13
CON-FPC-0_5-40PLD089WU1_2_CON-FPC-0_5-40P_LD08LD089WU1IC1LCD4
CON-PAD-2_5-2PCON-SMT-1_0_CON-PAD-2_5-2P_CON-con-pad-2_5-2pIC1J9901
CON-PAD-2_5-2PCON-SMT-1_1_CON-PAD-2_5-2P_CON-con-pad-2_5-2pIC1J9902
CON-SMT-1_25-5PBATTERY_0_CON-SMT-1_25-5P_LI_3.LI_3.7VIC1BAT1
CRY-D3225CRYSTAL-4_0_CRY-D3225_26M-20PPM26M-20ppmIC1Y6
DFN5FIL_SAW-856561_DFN5_B9482(1575MB9482(1575MHz)IC2FIL1; FIL2
E0402SDIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRIC26CR3502; CR3503; CR3504; CR3505; CR3506; CR3507; CR3508; CR3509; CR7000; CR7001; CR7002; CR7003; CR7004; CR7005; CR7006; CR7007; CR7008; CR7009; CR7010; CR9401; CR9402; CR9403; CR9501; CR9502; CR9503; CR9504
E0402SDIODE BI-DIR TRIG_E0402S_ESD9B5ESD9B5VIC5ED26; ED27; ED28; ED29; ED30
FC135XTAL_0_FC135_32.768KHZ_G41053-032.768KHZIC1Y1001
HDMI-MINI-19P-CBS-B4501H-BELL-1HDMI CON G3168-0500XXXX-00_HDMIHDMI-MINI-19P-CBS-B4501H-BELLIC1J7
IND-4X4INDUCTOR_1_IND-4X4_4.7UH/1.5A4.7uH/1.5AIC1L19
IND-4X4L_LVS404018_IND-4X4_10UH10uHIC1L901
IR-LED-D3LED_6_IR-LED-D3_IR12-21C-TR8IR12-21C-TR8IC1D6
IRM-V538_TR1IR_RECEIVE_2_IRM-V538_TR1_IRM-VIRM-V538/TR1IC1IR1
L0201INDUCTOR_0_L0201_4.7NH4.7nHIC1L9510
L0201INDUCTOR_0_L0201_NC/4.7NHNC/4.7nHIC1L9511
L0402INDUCTOR_L0402_600R/100MHZ600R/100MHzIC2FB7015; FB7016
LCC6_P65MM_SQ2P05MM_NSWPM1481_LCC6_P65MM_SQ2P05MM_NS_WPM1481IC1Q2000
LCC10_P4MM_1P8X1P4AOZ6184_DPDT_LCC10_P4MM_1P8X1P4AOZ6184_DPDTIC1U9010
LCC12_NS_P5MM_SQ3MM_1P0HBMG160_LCC12_NS_P5MM_SQ3MM_1P0HBMG160IC1U8024
LCC14_P4MM_2P2SQ_BMC150BMC150_LCC14_P4MM_2P2SQ_BMC150_BMC150IC1U8003
LCC16_NS_P5MM_SQ3MM_1P01HKXCJK_1013_LCC16_NS_P5MM_SQ3MM_KXCJK_1013IC1U8001
LCC32_P5MM_5SQ_EP3P45TUSB1210_LCC32_P5MM_5SQ_EP3P45_TUSB1210IC1U9001
LCC44_P9MM_SQ12_1P6HRL_SM02BD_8723BS_LCC44_P9MM_SQ1RL_SM02BD_8723BSIC1U6206
LCC48_P4MM_SQ6MM_1P0HALC5640_VB_LCC48_P4MM_SQ6MM_1P0ALC5640_VBIC1U7001
LCC76_P4MM_SQ9P1MM_EP5P5AXP288_1P04_LCC76_P4MM_SQ9P1MM_AXP288_1P04IC1U2003
LED0603LED0603_LED0603_LED0603LED0603IC2CR24; CR25
LFB212G45CG7D227LFB212G45CG7D227_1_LFB212G45CG7LFB212G45CG7D227IC1U27
LGA10_0_65_3X3MMKXCJ9-1008_LGA10_0_65_3X3MM_KXCKXCJ9-1008IC1U225
MIC-4020_SMD-P2_4MIC_AMS_O40S42_EC1_1_MIC-4020_SMIC_AMS_O40S42_EC1IC1U7200
PJ-B2318S-BELLPJ381-2_0_PJ-B2318S-BELL_PJ-B23pj-b2318s-bellIC1J11
R0402RESISTOR_R0402_NC/10KNC/10KIC1R60
R0402R_0_R0402_0R/NP0R/NPIC1R67
R0402RES 1B_R0402_NC/120KNC/120KIC1R124
R0402RES 1B_R0402_NC/0RNC/0RIC1R125
R0402R_R0402_2.2K2.2KIC6R183; R184; R187; R188; R1032; R1037
R0402RESISTOR_0_R0402_1K1KIC1R194
R0402RESISTOR_0_R0402_0R0RIC1R195
R0402R_R0402_NC/10KNC/10KIC2R199; R200
R0402R_R0402_NC/100KNC/100KIC2R201; R202
R0402R_R0402_0R0RIC2R203; R206
R0402RESISTOR_R0402_10K10KIC1R205
R0402RESISTOR_R0402_NC/4K7NC/4K7IC1R278
R0402R_4_R0402_NC/4.7KNC/4.7KIC1R340
R0402R_4_R0402_0R0RIC1R341
R0402R_4_R0402_47K47KIC1R344
R0402R_0_R0402_0R0RIC1R455
R0402R_R0402_10K10KIC9R942; R1076; R1077; R1078; R1079; R1080; R9743; R9775; R9843
R0402RES 1B_R0402_0R0RIC2R1228; R1229
R0402R_R0402_100K100KIC2R9742; R9774
R0402RESISTOR_0_R0402_330K330KIC1R9772
R0402RESISTOR_0_R0402_43K43KIC1R9773
R0402R_0_R0402_22R22RIC1R9834
R0402R_0_R0402_10K10KIC2R9835; R9836
R0402R_R0402_NC/0RNC/0RIC1R9842
R0603RES 1B_R0603_0R0RIC1R126
R0603RESISTOR_0_R0603_2R2RIC1R193
R0603RESISTOR_R0603_10R10RIC1R204
R0603R_R0603_00IC1R886
R0805R0805_R0805_1.5_1%1.5IC1R914
SHIELD-PTC0703B-5PTEST_1_SHIELD-PTC0703B-5P_SHIELSHIELDIC21T8; T9; T10; T11; T12; T13; T14; T15; T16; T17; T18; T19; T20; T21; T22; T23; T24; T25; T26; T27; T28
SHUNT_0402SHUNT_LOCAL_SHUNT_0402_SHUNT_LOSHUNT_LOCALIC22SH1000; SH1002; SH1003; SH1004; SH2001; SH2010; SH2013; SH2016; SH2019; SH3502; SH6201; SH7000; SH7001; SH8000; SH8001; SH8202; SH8204; SH8500; SH8501; SH8502; SH9000; SH9001
SHUNT_0402SHUNT_LOCAL#1_SHUNT_0402_SHUNT_SHUNT_LOCALIC2SH3500; SH3501
SHUNT_0603SHUNT_LOCAL_SHUNT_0603_SHUNT_LOSHUNT_LOCALIC10SH1001; SH2000; SH2002; SH2011; SH2012; SH2014; SH2017; SH2018; SH2020; SH8200
SHUNT_BOTTOM_P4XP6SHUNT_BYT_CR_MRD_SHUNT_BOTTOM_PSHUNT_BYT_CR_MRDIC1SH2005
SHUNT_L4-SIG_PWR_P4XP6SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_PSHUNT_BYT_CR_MRDIC5SH2003; SH2004; SH2006; SH2007; SH2008
SLP2510P8ESD SPE6V8UD DFN-10_0_SLP2510P8SPE6V8UDFN10RGBIC2U24; U214
SMC0201CAP_SMC0201_1UF_C83410-0131UFIC10C1007; C1008; C1009; C1010; C1020; C1028; C1037; C1042; C1045; C1047
SMC0402C0402_SMC0402_1PF1pFIC1C252
SMC0402C0402_SMC0402_470PF470pFIC1C253
SMC0402C0402_SMC0402_NCNCIC2C254; C255
SMC0402CAP NP_SMC0402_333333IC1C256
SMC0402CAP NP_SMC0402_1UF1uFIC9C257; C262; C263; C9712; C9713; C9714; C9715; C9716; C9717
SMC0402CAP NP_SMC0402_0.1UF0.1uFIC4C258; C264; C900; C901
SMC0402CAP NP_SMC0402_47PF47pFIC1C261
SMC0402CAP NP_SMC0402_103103IC1C265
SMC0402CAP_SMC0402_0.1UF_H34935-0010.1UFIC33C1001; C1002; C3025; C3026; C3045; C3047; C3114; C3115; C3116; C3117; C3512; C3513; C3518; C3520; C6213; C6217; C6222; C7007; C7017; C7019; C7022; C7024; C7027; C7029; C7031; C8006; C8007; C8121; C8124; C9108; C9117; C9168; C9169
SMC0402CAP_SMC0402_27PF_H34861-00127PFIC2C1003; C1004
SMC0402CAP_SMC0402_18PF_H34859-00118PFIC2C1005; C1006
SMC0402CAP_SMC0402_1.0UF_H35088-0011.0UFIC52C1012; C1013; C1014; C1027; C1029; C1030; C1031; C1033; C1034; C1035; C1036; C1038; C1039; C1040; C1041; C1043; C1044; C1048; C1049; C1050; C1051; C1052; C1053; C1054; C1055; C1056; C1100; C1101; C2053; C2054; C2059; C3006; C3007; C3010; C3011; C3048; C3049; C3050; C3051; C3100; C3101; C3102; C3103; C3104; C3108; C3109; C3112; C7016; C8002; C8003; C8004; C8005
SMC0402CAP_SMC0402_1.0UF_H35227-0011.0UFIC1C2026
SMC0402CAP#1_SMC0402_0.1UF_H34935-0010.1UFIC9C3501; C9580; C9581; C9582; C9583; C9584; C9585; C9586; C9587
SMC0402CAP_SMC0402_0.001UF_H34875-0010.001UFIC8C3521; C3522; C3523; C3524; C3525; C3526; C3527; C8240
SMC0402CAP_SMC0402_2.2UF_H35090-0012.2UFIC7C7000; C7018; C7023; C7025; C9109; C9110; C9111
SMC0402CAP#1_SMC0402_2.2UF_H35090-0012.2UFIC2C7003; C7004
SMC0402CAP#3_SMC0402_2.2UF_H35090-0012.2UFIC2C7005; C7006
SMC0402CAP#1_SMC0402_1.0UF_H35088-0011.0UFIC3C7013; C7079; C7080
SMC0402CAP_SMC0402_68PF_H34870-00168PFIC2C7015; C7082
SMC0402CAP_SMC0402_47PF_H34865-00147PFIC4C7033; C7034; C7077; C7078
SMC0402CAP_SMC0402_100PF_H34871-001100PFIC1C7081
SMC0402CAP_SMC0402_0.1UF_H34940-0010.1UFIC4C7106; C7107; C7111; C9001
SMC0402CAP_SMC0402_4700PF_H34922-0014700PFIC2C7108; C7109
SMC0402CAP_SMC0402_2.2UF_H35094-0012.2UFIC1C9400
SMC0402_27X47CAP_ALTSIZE_SMC0402_27X47_4.7UF4.7UFIC13C2058; C3005; C3113; C3118; C3500; C3514; C3517; C6218; C7001; C7002; C7028; C7030; C7032
SMC0402_27X47CAP_ALTSIZE_SMC0402_27X47_10UF_10UFIC2C6210; C6214
SMC0603_36HCAP_ALTSIZE_SMC0603_36H_4.7UF_H4.7UFIC1C2004
SMC0603_36HCAP_SMC0603_36H_4.7UF_H35096-004.7UFIC16C2009; C2016; C2023; C2027; C2028; C2030; C2031; C2032; C2033; C2035; C2036; C2037; C2038; C2039; C2046; C2056
SMC0603_36HCAP_ALTSIZE_SMC0603_36H_4.7UF_14.7UFIC5C2044; C2045; C2047; C2060; C9746
SMC0603_HI_VALUECAP_SMC0603_HI_VALUE_10UF_H352010UFIC11C2003; C2006; C2007; C2010; C2011; C2012; C2013; C2017; C2019; C2021; C2052
SMC0603_HI_VALUECAP_SMC0603_HI_VALUE_22UF_H352122UFIC12C2005; C2008; C2015; C2018; C2020; C2022; C2043; C2061; C2062; C2063; C2064; C7020
SMCR_1P0XP6_FBP02CESD9X7V_SMCR_1P0XP6_FBP02C_ESD9ESD9X7V-2T/RIC1CR9400
SMCR_SC79DIODE_SMCR_SC79_BAP63-02_H11513BAP63-02IC2CR9500; CR9507
SMF0402_1P15XP65_P65HFERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZEIC8FB7000; FB7001; FB7003; FB7004; FB7011; FB7012; FB7013; FB7014
SMF0402_1P15XP65_P65HFERRITE_ALTSIZE_SMF0402_1P15X_1FERRITE_ALTSIZEIC6FB7005; FB7006; FB7007; FB7008; FB7009; FB7010
SML2520_1P0HIND_ALTSIZE_SML2520_1P0H_4.7UH_4.7UHIC1L6200
SML2520_1P2HIND_ALTSIZE_SML2520_1P2H_1.0UH_1.0UHIC8L2000; L2001; L2002; L2003; L2004; L2005; L2006; L2007
SML_4P_43X53_CM_P35HCHOKE_4PIN_ALT_SML_4P_43X53_CM_80OHM_100MHZIC2L9000; L9507
SML_4P_43X53_CM_P35HCHOKE_4PIN_ALT_SML_4P_43X53_C_180OHM_100MHZIC3L9506; L9508; L9509
SMR0402FB0402_SMR0402_600R@100MHZ600R@100MHzIC1FB7
SMR0402L0402_SMR0402_0R0RIC1L14
SMR0402L0402_SMR0402_6.8NH6.8nHIC2L15; L16
SMR0402R0201_SMR0402_0R_5%0RIC2R267; R268
SMR0402R_SMR0402_00IC11R269; R270; R271; R272; R273; R274; R978; R980; R981; R982; R9765
SMR0402R_SMR0402_100K100KIC3R275; R561; R726
SMR0402R_SMR0402_10K10KIC2R557; R9767
SMR0402R_SMR0402_1M1MIC1R565
SMR0402RES#1_SMR0402_51_A93549-00751IC5R1002; R1003; R1004; R1005; R1048
SMR0402RES_SMR0402_162_A93548-636162IC1R1011
SMR0402RES_SMR0402_29.4_A93548-60729.4IC1R1012
SMR0402RES_SMR0402_23.2_A93548-54123.2IC1R1013
SMR0402RES_SMR0402_150_A93548-005150IC2R1016; R1017
SMR0402RES_SMR0402_402_A93548-032402IC1R1018
SMR0402RES_SMR0402_49.9_A93548-04549.9IC4R1020; R1021; R1022; R1028
SMR0402RES_SMR0402_45.3_A93548-06945.3IC1R1027
SMR0402RES_SMR0402_10K_A93549-02310KIC8R1029; R2008; R3503; R3504; R3505; R7009; R9005; R9578
SMR0402RES_SMR0402_4.02K_A93548-2544.02KIC1R1030
SMR0402RES#1_SMR0402_1M_A93549-0281MIC1R1031
SMR0402RES#1_SMR0402_10MEGOHM_A93549-010MEGOHMIC1R1033
SMR0402RES_SMR0402_51_A93549-00751IC3R1034; R1035; R1036
SMR0402RES#1_SMR0402_0_A93549-0010IC24R1038; R1042; R1043; R1049; R3502; R3507; R3508; R3509; R3510; R3511; R3512; R3513; R3514; R3515; R3516; R3517; R6286; R8246; R8413; R8414; R8415; R8418; R9000; R9841
SMR0402RES#1_SMR0402_1.24K_A93548-1081.24KIC3R1044; R1045; R3012
SMR0402RES_SMR0402_20K_A93549-03620KIC2R1046; R1047
SMR0402RES_SMR0402_240_A93548-504240IC4R3000; R3011; R3101; R3102
SMR0402RES_SMR0402_0R_A93548-5040RIC4R3001; R3003; R3004; R3005
SMR0402RES#1_SMR0402_75K_A93549-17275KIC1R7001
SMR0402RES#1_SMR0402_2.2K_A93549-0172.2KIC2R7007; R7049
SMR0402RES#1_SMR0402_45.3_A93548-06945.3IC1R7011
SMR0402RES#2_SMR0402_23.2_A93548-54123.2IC2R7014; R7015
SMR0402RES#1_SMR0402_220_A93549-011220IC5R7062; R7063; R7065; R9003; R9004
SMR0402RES_SMR0402_2.2K_A93549-0172.2KIC3R7066; R7067; R9103
SMR0402RES#1_SMR0402_100K_A93549-027100KIC1R8248
SMR0402RES#1_SMR0402_NC/47K_A93549-001NC/47KIC1R8416
SMR0402RES#1_SMR0402_NC/2K_A93549-001NC/2KIC1R8417
SMR0402RES#2_SMR0402_100K_A93549-027100KIC2R8430; R8431
SMR0402RES_SMR0402_100K_A93549-027100KIC2R8432; R9576
SMR0402RES#1_SMR0402_0R_A93549-0110RIC4R9006; R9007; R9844; R9845
SMR0402RES_SMR0402_680_A93549-097680IC8R9520; R9521; R9522; R9523; R9524; R9525; R9526; R9527
SMR0402R_SMR0402_NC/0NC/0IC2R9766; R9840
SMR0402RES#1_SMR0402_0R_A93548-0690RIC1R9784
SMR0402SHUNT_LOCAL_SMR0402_SHUNT_LOCALSHUNT_LOCALIC1SH6203
SMR0805_24HRES_ALTSIZE_SMR0805_24H_NC/0_H2NC/0IC1R4015
SMR1206_P71W_P75H_PMRRES_PMR_SMR1206_P71W_P75H_PMR_00.01IC1R2009
SMRT0402_27X47THERMISTOR_SMRT0402_27X47_10K_D10KIC1RT2000
SMRT0402_27X47THERMISTOR#1_SMRT0402_27X47_10K10KIC1RT2001
SMY_4P_2P15X2P65_P8HOSC_TCXO_ALT_SMY_4P_2P15X2P65_P26MHZIC1Y6200
SMY_4P_79X98_PAD37X39_24HXTAL_4PIN_SMY_4P_79X98_PAD37X3925.0MHZIC1Y1000
SOD123DIODE_0_SOD123_1N58191N5819IC2D10; D903
SOD123D_1N5819HW_SOD123_1N5819HW1N5819HWIC1D902
SOP8-50-210MX25U1635E_0_SOP8-50-210_MX25U1MX25U1635EIC1U3500
SOT2340852_1_SOT23_39043904IC1Q10
SOT23MOSFET P_SOT23_VIC1121VIC1121IC3Q30; Q31; Q34
SOT23NPN_0_SOT23_VIC1221VIC1221IC1Q35
SOT23MOSFET N_SOT23_VIC1221VIC1221IC2Q91; Q8405
SOT23_5DS8008_4_SOT23_5_NC/ME6211-33NC/ME6211-33IC1U42
SOT23_574LVC1G126_SOT23_5_74LVC1G126_G74LVC1G126IC1U7002
SOT23_6_1P295HLP3211_0_SOT23_6_1P295H_LP3211_LP3211IC1U2005
SOT25LPW5206H_SOT25_DS9715ABGDS9715ABGIC1U19
SOT26U_MP3202_SOT26_MT9201MT9201IC1U902
SOT26G5121_1_SOT26_MT3608MT3608IC1U2006
SOT523MOSFET_N_SOT523_CJ1012CJ1012IC2Q5; Q55
SOT523MOSFET_N_SOT523_2SK30192SK3019IC5Q54; Q56; Q57; Q60; Q74
SOT523MOSFET_N_SOT523_NC/2SK3019NC/2SK3019IC2Q58; Q59
SWI-INT-1100AAGS-AIR-1LS77C2DE_T_0_SWI-INT-1100AAGS-ALS77C2DE_TIC3SW7000; SW7001; SW7002
T-1_0TEST_0_T-1_0_TESTTESTIC18T58; T59; T60; T61; T62; T63; T64; T65; T66; T67; T68; T70; T71; T72; T73; T74; T225; T226
TCXO_KT2016_2X1D6_0D8KT2016A26000ACW18TLG_BRCM_0_TCXKT2016A26000ACW18NANIC1Y5
TESTPAD_C16TESTPAD_CIR_TESTPAD_C16_C16C16IC13TP1026; TP1027; TP1028; TP1040; TP1041; TP1042; TP1043; TP1100; TP1101; TP8000; TP8401; TP9000; TP9001
TESTPAD_C16TESTPAD_CIR#1_TESTPAD_C16_C16C16IC11TP6200; TP6201; TP6202; TP6203; TP6204; TP6205; TP6206; TP6207; TP6208; TP6209; TP6210
TESTPAD_C20TP_1_TESTPAD_C20_TESTPAD_C20TESTPAD_C20IC1TP46
TESTPAD_C20TESTPAD_CIR#2_TESTPAD_C20_C20C20IC3TP6401; TP6402; TP6403
TESTPAD_C40TESTPAD_CIR#2_TESTPAD_C40_C40C40IC36TP9701; TP9702; TP9703; TP9704; TP9705; TP9707; TP9721; TP9722; TP9723; TP9724; TP9725; TP9726; TP9727; TP9728; TP9729; TP9730; TP9731; TP9732; TP9733; TP9734; TP9735; TP9736; TP9737; TP9738; TP9748; TP9749; TP9750; TP9751; TP9754; TP9755; TP9756; TP9757; TP9758; TP9759; TP9760; TP9763
TESTPAD_C40TESTPAD_CIR#1_TESTPAD_C40_C40C40IC3TP9706; TP9708; TP9709
TESTPAD_C40TESTPAD_CIR_TESTPAD_C40_C40C40IC2TP9752; TP9753
TF-CARDCON12_MICROSD_MTG4_3_TF-CARD_COCON12_MICROSD_MTG4IC1J3501
USB-5P-MICRO-DIP-BELL-1MINI USB_0_USB-5P-MICRO-DIP-BELUSBIC1U10
WLBGA60-0_4-5_35X3_35-BCM43438BCM43438_0_WLBGA60-0_4-5_35X3_3BCM43438IC1U26
附件:
0 a) a9 E  a% q$ l7 ypcb文件
5 ?1 L5 `. r+ b0 X, Y  s3 l0 [/ S9 x
游客,如果您要查看本帖隐藏内容请回复
- Z" x$ ~& y# O
    2023-7-20 15:22
    推荐
    发表于 2023-12-23 11:50 | 只看该作者
    学习
    3 a4 i1 y2 V4 Y% i* h
    慵懒
    2021-11-19 15:18
    推荐
    发表于 2021-11-19 10:01 | 只看该作者
    看起来很牛逼的样子 ,而且没有用AXP,不知道时序咋样
    7 _8 V; \- v8 r- H! A( O' }3 \% x9 q1 v  n# ]8 u
    奋斗
    2020-4-7 15:56
    推荐
    发表于 2020-4-17 16:37 | 只看该作者
    亏了,打不开,楼主能不能帮忙转成PADS的,谢谢
    发表于 2020-4-1 01:33 | 只看该作者
    奋斗
    2020-4-7 15:56
    发表于 2020-4-17 16:29 | 只看该作者
    学习一下哦
    发表于 2020-4-20 14:36 | 只看该作者
    学习一下哦
    发表于 2020-4-21 09:03 | 只看该作者
    感谢分享
    “来自电巢APP”
    奋斗
    2025-6-9 15:24
  • 签到天数: 337 天
    [LV.8]以坛为家I
    发表于 2020-7-24 10:31 | 只看该作者
    谢谢大大分享
    2020-12-9 15:49
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2020-11-9 09:55 | 只看该作者
    ALC5640ALC5640ALC5640
    / m, [7 O' Z0 F* i& _
    2024-8-26 15:16
    13#
    发表于 2020-12-10 08:53 | 只看该作者
    下载看看怎样
    2 B. K7 h- w9 h- `! i
    2022-5-7 15:10
    15#
    发表于 2021-2-23 11:47 | 只看该作者
    谢谢分享,谢谢分享
    ) |5 r5 [# H2 p/ ~# q7 [" n8 E% E
    GMT+8, 2025-7-19 13:23 , Processed in 0.203125 second(s), 29 queries , Gzip On.
