查看: 364|回复: 0
[allegro16.3][8层]飞思卡尔TWR-PXR40 开发板(MPXR4040VVU264+CON_2X10+MC9S08JM6...
发表于 2019-12-28 16:45 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][8层]飞思卡尔TWR-PXR40 开发板(MPXR4040VVU264+CON_2X10+MC9S08JM60CLD)pcb文件
+ e, o- b7 |8 U9 m5 p
7 G! @, P- ?% r
文件描述:
  j! r4 g4 k; P' C5 i
1. 作品用途:飞思卡尔TWR-PXR40 开发板
2. 软件版本:allegro16.3
3. 层数:8层
4. 用到的主要芯片:MPXR4040VVU264+CON_2X10+MC9S08JM60CLD
. k$ y; \2 f& T5. pcb尺寸:4665*3174  MIL
$ Q: W! z* p9 n
作品截图如下:
  D9 [7 U) \/ Z; l" g& P9 z8 W* ~9 {! K5 g
顶层截图:
底层截图:
+ ^7 L: s: s$ D, |' L8 [' T
全层截图:
& H' r( `2 ^6 ~; ~+ G% O! D- E
' u( k6 h; f! B% f
叠层阻抗信息如下:
) I8 T0 h3 s. x: j% _; w" W
8 f! y2 r- c' X
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UFDISCRETE7C7; C555; C557; C560; C561; C563; C564
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UFDISCRETE38C13; C15; C17; C503; C513; C515; C516; C517; C519; C520; C521; C523; C524; C526; C528; C529; C530; C532; C534; C535; C536; C537; C538; C539; C540; C542; C544; C546; C547; C548; C549; C550; C551; C553; C554; C556; C558; C562
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M18pFDISCRETE2C20; C21
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uFDISCRETE6C22; C23; C24; C25; C533; C545
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE16C1; C3; C4; C6; C8; C10; C11; C12; C14; C16; C18; C502; C505; C509; C511; C531
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM22pFDISCRETE1C2
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.252.2UFDISCRETE1C27
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965470PFDISCRETE2C506; C510
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE2C507; C512
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_11000PFDISCRETE1C518
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE15C5; C9; C19; C26; C500; C501; C504; C508; C514; C525; C527; C541; C543; C552; C559
CC1210MOT_CAP_CC1210_DISCRETE_2.7 MM_47UFDISCRETE1C522
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J11
CON3_TB_5_15X12P8MMTERMINAL_BAR3_CON3_TB_5_15X12P8CON 1x3IO2J9; J14
CON50_0P8MM_ERF8CONN_2X25_CON50_0P8MM_ERF8_IO_5CON 2X25IO1J7
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J2; J3
CON_USB_MINIABUSB_MINI_AB_SKT_CON_USB_MINIAB_USB_MINI_BIO1J5
DPAK_CASE_369C-01NPN_134_DPAK_CASE_369C-01_IC_2.NJD2873T4IC1Q2
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO8J8; J10; J12; J13; J17; J18; J19; J20
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO9J1; J21; J22; J23; J24; J25; J26; J27; J28
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3IO1J4
HDR216CONN_HDR_16X2_HDR216_IO_8.58 MMHDR_2X16IO4J31; J32; J33; J34
IND_0603BEAD_IND_0603_DISCRETE_0.95MM_1120OHMDISCRETE7L1; L2; L3; L4; L502; L503; L504
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L500; L501
JUMP2X7-6040HDR-2X7_JUMP2X7-6040_IO_8.38 MMHDR_2X7IO1J6
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRNIC2D1; D2
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D3
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC5D4; D5; D6; D7; D8
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1D9
LGA14_0P80_3X5_SH1MMA7450L_LGA14_0P80_3X5_SH1_IC_MMA7455LIC1U4
MSO8_MO-1872G125_MSO8_MO-187_IC_1.3MM_312-SN74LVC2G125IC1U2
NSOIC8_1P27_3P9X4P9SP485E_SOIC_8P_NSOIC8_1P27_3P9XSP3495IC1U510
PBGA416_1MM_27X27MMMPXR4040VVU264_PBGA_416P_PBGA41MPXR4040VVU264IC1U5
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015KDISCRETE1R504
RC0402_25RES_RC0402_25_DISCRETE_470-3033270DISCRETE6R1; R18; R21; R24; R28; R31
RC0402_25RES_RC0402_25_DISCRETE_470-755510KDISCRETE6R3; R7; R8; R9; R11; R19
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE27R10; R27; R29; R30; R32; R500; R502; R506; R509; R510; R511; R512; R513; R516; R518; R519; R520; R521; R522; R523; R524; R525; R526; R527; R530; R533; R535
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0KDISCRETE1R12
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99KDISCRETE1R13
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE1R15
RC0402_25RES_RC0402_25_DISCRETE_470-7616510KDISCRETE1R26
RC0402_25RES_RC0402_25_DISCRETE_470-79971MDISCRETE1R34
RC0402_25RES_RC0402_25_DISCRETE_470-306412DISCRETE1R36
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2KDISCRETE1R503
RC0402_25RES_RC0402_25_DISCRETE_470-312810MDISCRETE1R514
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE2R515; R517
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE13R5; R6; R14; R16; R20; R22; R23; R25; R33; R505; R507; R508; R531
RC0603_OVRES_RC0603_OV_DISCRETE_470-7551330DISCRETE1R17
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110KDISCRETE1R528
RC0603_OVRES_RC0603_OV_DISCRETE_470-7539120DISCRETE2R529; R534
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE1R35
RC0805_OVRES_RC0805_OV_DISCRETE_470-30521.2KDISCRETE2R532; R536
RC1206_3P4X1P8LVK_4P_RC1206_3P4X1P8_DISCRETE_0.01OHMDISCRETE3R2; R4; R501
RC2512RES_RC2512_DISCRETE_470-80344_11DISCRETE1R37
RCA_8REZ_1P27_SMRES_ISO16_D_RCA_8REZ_1P27_SM_DI10KDISCRETE1RN500
SC70-5_AONE_AND_SC70-5_A_IC_1.1MM_312-7NC7SZ08P5XIC1U509
SC70_6LEADNC7WP14_SC70_6LEAD_IC_1.1MM_312NC7WZ04P6XIC1U3
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D501
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U501
SO8_1P27_4X5TJA1051T_SO_8P_SO8_1P27_4X5_IC_TJA1051T/3IC1U508
SO1474-125_14P_SO14_IC_1.75MM_312-7SN74LV125IC3U502; U505; U507
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q1
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U500
SOT416TRAN_NPN_RES_SOT416_IC_0.95MM_4PDTC115TIC1Q500
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC1D500
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC2U503; U504
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW2; SW3; SW4
SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTIC1SW1
TESTPOINT_35MILTEST PAD_TESTPOINT_35MIL_IC_0.135 MILIC2TP14; TP21
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO6TP3; TP4; TP5; TP6; TP7; TP10
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO2TP12; TP20
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020IO4TP11; TP15; TP16; TP18
TPAD_040TESTLOOP_TPAD_040_IO_0.1MM_211-TPAD_040IO7TP1; TP2; TP8; TP9; TP13; TP17; TP19
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM_21TESTLOOP_BLACKIO2TP_GND1; TP_GND2
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60 MMC9S08JM60CLDIC1U506
TSSOP1474LVC125_TSSOP14_IC_1.2MM_312-774LVC125IC1U1
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y500
XTLOSC4_3P2X2P5MM_SMXTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I40MHzIC1Y1
附件:
PCB文件如下:
9 p4 D: ]" p5 u  J4 K8 `; b' T
游客,如果您要查看本帖隐藏内容请回复
0 L5 W* V" K. K  D5 O
GMT+8, 2025-7-21 01:07 , Processed in 0.125000 second(s), 29 queries , Gzip On.
