查看: 296|回复: 0
[allegro16.5][4层]飞鼠遥控器(MKL16Z256VLH4+RDA5876A+USB)pcb文件
发表于 2019-12-28 16:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 wennne 于 2019-12-28 16:06 编辑 5 r4 V, K) z# m, |0 N, @" g
" i, ]5 O1 q$ Z# N
1 M* z7 S  _# X. h" }$ l. K
文件描述:
5 B$ N. v! h' g
1. 作品用途:飞鼠遥控器
2. 软件版本:allegro16.5
3. 层数:4层
4. 用到的主要芯片:MKL16Z256VLH4+RDA5876A+USB4% f# E3 `0 ]# x6 T0 e' O1 t" ^
5. pcb尺寸:11769.23*4721.55  MIL
3 f* @" @5 |" f7 X1 N0 v
作品截图如下:
0 e1 V. l. [  w. x
顶层截图:
底层截图:
  D4 W" ?. q" m$ g6 \
全层截图:
! F! L" N" m9 e0 ]% B( ^
2 D1 R5 N; j4 i8 _- @  y1 `* l, F; b
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
20279-001E-01ANT,I-PEX ANTENNA CONNECTOR_0_2MHF Coaxial CNIC1J301
CRY3225XTAL,CRY,24 MHZ_1,3225_CRY3225_26MHzIC1X301
DFN10_0P4_2X2IC,MAG3110,DFN10,MAGNETOMETER_DMAG3110FCR2IC1U201
DFN10_0P4_2X2MMIC,MMA8563FC,DFN10,ACC SENSOR_0MMA8653FCR1IC1U202
DOMECN,DOME_DOME_CN,DOMECN,DOMEIC36S402; S403; S404; S405; S406; S407; S408; S409; S410; S411; S412; S413; S415; S416; S417; S418; S419; S420; S421; S422; S423; S425; S426; S427; S428; S429; S431; S432; S433; S434; S435; S436; S441; S443; S444; S445
EM6022TMP_27_EM6022_EMC MICROPHONEEMC MICROPHONEIC1M101
ESD0402ESD,ES0402V014BT_2_ESD0402_ES04ES0402V014BTIC19ESD101; ESD102; ESD103; ESD401; ESD402; ESD403; ESD404; ESD405; ESD406; ESD407; ESD408; ESD409; ESD410; ESD411; ESD501; ESD502; ESD503; ESD504; ESD601
HDR_1P27_2X6CONN_HDR_9_HDR_1P27_2X6_IO_8.21HDR 2X6IO1J402
HDR_1P27_2X7CONN_HDR_5_HDR_1P27_2X7_IO_8.21HDR 2X7IO1J401
HDR_SMT_1P27_2X5CONN_HDR_5X2_HDR_SMT_1P27_2X5_IHDR 2X5IO2J101; J203
HSDL-4230LED,LTST-C194KRKT,LED0603,RED_HHIR305A318CPIC1D101
IND0402INDCT,SIG,2.7NH,0402,.17R/.3A_I3nHDISCRETE1L302
IND0402INDCT,SIG,2.7NH,0402,.17R/.3A_12.4nHDISCRETE1L303
IND0402INDCT,SIG,2.7NH,0402,.17R/.3A_22.7nH/NMDISCRETE2L304; L305
IND0603INDCT,PWR,2.5X2X1.2,1.12A,4.7UH4.7uHIC1L301
JAF00-06506-0100CON,JAF00-06506-0100,AUDIOJACK_Ear Phone JACKIC1J501
LQFP64_0P5_10X10MMIC,MKL16Z256VLH4,LQFP64,mcu_LQFMKL16Z256VLH4IC1U101
LTST-S110TMP_152527_LTST-S110_YELLOW LEDYELLOW LEDIC1D103
LTST-SDLEDTMP_20_LTST-SDLED_DLEDDLEDIC1D601
NTC301-BA1G-B160TSW,SKRTLAE010,SIDE TACT SW_7_NTNTC301-BA1G-B160TIC1SW601
PAD-SPARKGAPMDIOD,SCH,RB520CS-30T2_3_PAD-SPAPAD-SPARKGAPMIC36ESD413; ESD414; ESD415; ESD416; ESD417; ESD418; ESD419; ESD420; ESD421; ESD422; ESD423; ESD424; ESD425; ESD426; ESD427; ESD428; ESD429; ESD430; ESD431; ESD432; ESD433; ESD434; ESD435; ESD436; ESD437; ESD438; ESD439; ESD440; ESD441; ESD442; ESD443; ESD444; ESD445; ESD446; ESD447; ESD448
PAD_2X3MMPAD_6_PAD_2X3MM_MIC+MIC+IC1PAD501
PAD_2X3MMPAD_7_PAD_2X3MM_MIC-MIC-IC1PAD502
PAD_2X3MMPAD_4_PAD_2X3MM_GNDGNDIC2PAD601; PAD608
PAD_2X3MMPAD_5_PAD_2X3MM_WL_CHGWL_CHGIC1PAD602
PAD_2X3MMPAD_0_PAD_2X3MM_WL_CHG_ANT-WL_CHG_ANT-IC1PAD603
PAD_2X3MMPAD_3_PAD_2X3MM_WL_CHG_ANT+WL_CHG_ANT+IC1PAD604
PAD_2X3MMPAD_1_PAD_2X3MM_WL_CHG_ANT-WL_CHG_ANT-IC1PAD605
PAD_2X3MMPAD_2_PAD_2X3MM_WL_CHG_ANT+WL_CHG_ANT+IC1PAD606
PAD_2X3MMPAD_5_PAD_2X3MM_VBATVBATIC1PAD607
QFN24E_0P5_4X4MMIC,MPU-6050,QFN24,ACC/GYRO_QFN2MPU-6050IC1U204
QFN24_5X7X2IC,FXAS21000,QFN24,GYRO_0_QFN24FXAS21000CQR1IC1U203
QFN32_0P4_4X4MMIC,RDA5876A,QFN32,HCI BT_4_QFN3RDA5876AIC1U301
QFN32_0P5_5X5IC,WM8960,QFN32,CODEC_0_QFN32_0WM8960CGEFL/RV/NMIC1U501
RV0402RV,SDV1005E180C150NP,VARISTORS_SDV1005E180C150NPIC4RV801; RV802; RV803; RV804
SMB0603TMP_190357_SMB0603_120 OHM/2A@1120 OHM/2A@100MHzIC5FB101; FB102; FB104; FB301; FB501
SMC0402CAPC,X5R,0402,16V,10%,1UF_SMC041uF/16VIC6C102; C117; C220; C307; C601; C603
SMC0402CAPC,X7R,0402,16V,10%,0.1UF_SMC0.1uF/16VIC38C103; C104; C106; C107; C109; C110; C203; C204; C205; C206; C207; C209; C210; C212; C213; C214; C218; C221; C223; C224; C306; C308; C312; C315; C316; C401; C501; C502; C505; C516; C517; C521; C531; C533; C602; C604; C606; C608
SMC0402CAPC,NPO,0402,50V,10%,33PF_SMC033pF/50VIC1C112
SMC0402CAPC,X7R,0402,50V,10%,10NF_SMC010nF/50VIC4C116; C215; C217; C609
SMC0402CAPC,X7R,0402,50V,10%,2.2NF_SMC2.2nF/50VIC1C219
SMC0402CAPC,NPO,0402,50V,10%,10PF_SMC010pF/50VIC2C302; C310
SMC0402CAPC,NPO,0402,50V,10%, 1PF_SMC01pF/50VIC1C304
SMC0402CAPC,NPO,0402,50V,10%, 2PF_SMC02.7pF/50VIC1C305
SMC0402CAPC,NPO,0402,50V,10%, 8.2PF_SM8.2pF/50VIC1C309
SMC0402CAPC,X7R,0402,50V,10%,1NF_SMC041nF/50VIC1C311
SMC0402CAPC,NPO,0402,50V,10%,15PF_SMC015pF/50VIC6C507; C511; C518; C519; C522; C523
SMC0402CAPC,X7R,0402,16V,10%,0.1UF_S_10.1uF/16V/NMIC2C508; C510
SMC0402CAPC,NPO,0402,50V,10%,150PF_SMC150pF/50VIC2C514; C515
SMC0603CAPC,X5R,0603,10V,10%,4.7UF_SMC4.7uF/10VIC13C101; C105; C111; C201; C202; C211; C216; C503; C504; C506; C520; C532; C605
SMC0603CAPC,X5R,0603,6.3V,20%,22UF_SMC22uF/6.3VIC9C108; C222; C301; C313; C512; C513; C524; C607; C610
SMC0603CAPC,X5R,0603,16V,10%,2.2UF_SMC2.2uF/16V/NMIC1C509
SMR0402RESD,0402,5%,1/16W,10K_SMR0402_10KIC15R101; R108; R112; R113; R141; R148; R215; R225; R513; R514; R605; R607; R616; R623; R627
SMR0402RESD,0402,5%,1/16W,2.2K_SMR04022.2KIC5R102; R103; R105; R110; R523
SMR0402RESD,0402,5%,1/16W,1K_SMR0402_11KIC5R106; R107; R116; R213; R401
SMR0402RESD,0402,1%,1/16W,33K_SMR0402_33KIC1R114
SMR0402RESD,0402,1%,1/16W,9K_SMR0402_99KIC1R115
SMR0402RESD,0402,1%,1/16W,5.1K_SMR04025.1KIC2R117; R135
SMR0402RESD,0402,5%,1/16W,0_SMR0402_0/0/NMIC15R118; R119; R120; R121; R134; R140; R146; R150; R304; R305; R525; R526; R609; R610; R611
SMR0402RESD,0402,5%,1/16W,0_SMR0402_0_0IC26R122; R123; R124; R125; R126; R132; R136; R139; R149; R151; R207; R209; R212; R217; R218; R303; R501; R502; R503; R509; R512; R519; R520; R521; R524; R618
SMR0402RESD,0402,1%,1/16W,20.0K_SMR04020.0KIC2R127; R131
SMR0402RESD,0402,5%,1/16W,1.5M_SMR04021.5MIC1R130
SMR0402RESD,0402,1%,1/16W,100.0K_SMR04100IC1R133
SMR0402RESD,0402,1%,1/16W,100.0K_SMR_1100.0KIC4R137; R138; R142; R145
SMR0402RESD,0402,5%,1/16W,100K_SMR0402100KIC11R203; R204; R604; R606; R608; R612; R615; R617; R622; R624; R626
SMR0402RESD,0402,5%,1/16W,4.7K_SMR04024.7KIC1R221
SMR0402RESD,0402,1%,1/16W,1K_SMR0402_11KIC4R504; R508; R510; R511
SMR0402RESD,0402,1%,1/16W,1K_SMR0402_21K/NMIC2R505; R507
SMR0402RESD,0402,1%,1/16W,10.0K_SMR04010.0K/NMIC1R506
SMR0402RESD,0402,1%,1/16W,300_SMR0402_300IC4R515; R516; R518; R522
SMR0402RESD,0402,5%,1/16W,2.2K_SMR04_12.2K/NMIC1R517
SMR0402RESD,0402,1%,1/16W,1.6K_SMR04021.6KIC1R601
SMR0402RESD,0402,1%,1/16W,200_SMR0402_200IC2R602; R603
SMR0402RESD,0402,1%,1/16W,44.2K_SMR04042.2K/NMIC1R613
SMR0402RESD,0402,1%,1/16W,44.2K_SMR0_173.2K/NMIC1R614
SMR0603RESD,0603,1%,1/10W,5.1_SMR0603_5.1RIC1R104
SMR0603RESD,0603,5%,1/10W,0_SMR0603_0/0/NMIC4R143; R144; R147; R625
SMR0603RESD,0603,1%,1/10W,47_SMR0603_447IC1R208
SOD523DIOD,SW,1N4148,SOD523,75V,125MA1N4148WTIC24D104; D401; D402; D403; D404; D405; D406; D407; D408; D409; D410; D411; D412; D413; D414; D415; D416; D417; D418; D501; D502; D604; D605; D606
SOD523DIOD,SW,1N4148,SOD523,75V,125_11N4148WT/NMIC1D608
SOD-123TMP_11_SOD-123_IC_RB051M-2YRB051M-2YIC3D201; D602; D603
SOT23XSTR,MMBT3904,SOT23,NPN_SOT23_MMMBT3904IC5Q101; Q102; Q103; Q108; Q201
SOT23XSTR,MMBT3906,SOT23,PNP_SOT23_MMMBT3906IC4Q105; Q502; Q602; Q603
SOT23XSTR,AO3415,SOT23,PMOS_SOT23_AOAO3415IC3Q106; Q107; Q605
SOT23XSTR,AO3415,SOT23,PMOS_SOT23__1AO3415/NMIC1Q109
SOT23XSTR,MMBT3904,SOT23,NPN_SOT23_1MMBT3904/NMIC1Q501
SOT23IC,ASM1117,SOT223,1_0.8V 1A LDOUM15333S/NMIC1U205
SOT23-5TMP_101743_SOT23-5_CE6230B33MCE6230B33MIC1U602
SOT25IC,TP4054,SOT25,LINEAR CHGER_SOTP4054IC1U601
SOT523_312XSTR,2N7002T,SOT523,NMOS_SOT5232N7002T-7-FIC5Q104; Q601; Q604; Q606; Q607
TP20TP20_TP20_TP20TP20IC10TP201; TP202; TP203; TP305; TP306; TP307; TP308; TP309; TP310; TP311
TP40-DIPTP40_TP40-DIP_TP40TP40IC9TP103; TP104; TP106; TP107; TP108; TP109; TP111; TP112; TP113
USB_5F_0P65_TH_105017-0001CN,MOLEX MICRO USB 1050170001_UMICRO USBIC1J602
W12503-S160501ACN,W12503-S160501A,1.25MM/3 PINW12503-S160501AIC1J603
XF2M-1015-1ACN,91500 32PIN,0_4.5MM FPC CN_XXF2M-1015-1AIC1J201
Z4FC1B1301781MEC,Z4TL2B1241675,VIBRATOR_1_Z4VIBRATORIC1M201
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
# T5 Q% [+ u! P  n( ]
GMT+8, 2025-7-21 01:06 , Processed in 0.140625 second(s), 28 queries , Gzip On.
