查看: 382|回复: 0
[allegro16.6][8层]一款不错的8层板(U7+U10+SW2)pcb文件
发表于 2019-12-28 10:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
. E" ]5 k* x! ^! ?# B- J5 J
文件描述:
1. 作品用途:一款不错的8层板
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:U7+U10+SW2
5. PCB尺寸:5678*5114 mil
5 I4 b1 p' v& K7 E. r
作品截图如下:
+ s( r( q3 V$ K& `
顶层截图:
. B8 y- E7 W4 g9 M5 {  N' p, Y: s
底层截图:
全层截图:
叠层阻抗信息:
; n+ c9 @. K  r8 A% w, j, F
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类别属性类型数量位号
8P4R0402RES ARRAY_8P4R0402_33R33RDISCRETE6RN13; RN14; RN15; RN16; RN17; RN18
8P4R0402RES ARRAY_8P4R0402_10K10KIC5RN19; RN20; RN21; RN22; RN23
ANTS3LCONN_UFL_0_ANTS3L_CONN_COAXIALCONN_CoaxialIC3J4; J5; J10
AUDIO5VAF5-1908_6_AUDIO5_CONN_HPCONN_HPIC1J15
AUDIO5VAF5-1908_6_AUDIO5_CONN_MICCONN_MICIC1J16
BATS4P75D150LRTC_1_BATS4P75D150L_CONN_BATCONN_BATIC1J3
BGA144P10BCM54220_1_BGA144P10_BCM54220B0BCM54220B0KFBGIC1U31
BGA153P5EMMC_V5_BGA153P5_MTFC8GACAEAM-1MTFC8GACAEAM-1M WTIC1U10
BGA541XPCIMX7D7DVM10SA_541BGA_V2_BGA54PCIMX7D7DVM10SA_541BGA_V2IC1U7
BGADDR96P8B90X1302G_DDR3_SDRAM_128MX16_3_BGADDR9MT41K256M16HA-125IC2U8; U9
C35X28CAP POL_2_C35X28__100UF100uFIC10C1; C198; C199; C202; C203; C204; C274; C275; C299; C438
C0402CAP NP_C0402__1UF1uFIC47C3; C20; C21; C22; C29; C58; C59; C61; C194; C220; C221; C276; C277; C308; C309; C310; C311; C313; C315; C316; C317; C318; C324; C326; C327; C329; C331; C333; C334; C336; C338; C340; C341; C342; C343; C345; C377; C382; C387; C392; C393; C411; C412; C414; C426; C427; C428
C0402CAP NP_C0402__220NF220nFIC97C5; C7; C11; C12; C13; C60; C63; C64; C66; C68; C69; C70; C71; C72; C74; C75; C78; C79; C80; C81; C82; C83; C84; C86; C88; C90; C92; C93; C94; C98; C101; C104; C107; C108; C110; C117; C118; C119; C122; C124; C125; C127; C129; C130; C142; C143; C144; C145; C146; C147; C149; C150; C151; C152; C153; C154; C155; C157; C158; C159; C160; C161; C162; C163; C165; C166; C167; C168; C169; C170; C171; C173; C174; C175; C176; C177; C178; C179; C190; C191; C192; C237; C241; C245; C265; C278; C279; C280; C284; C357; C376; C378; C380; C381; C388; C389; C408
C0402CAP NP_C0402__100NF100nFIC93C6; C24; C28; C30; C37; C42; C46; C50; C52; C141; C181; C182; C184; C185; C186; C187; C196; C201; C206; C207; C208; C209; C210; C211; C212; C213; C216; C217; C222; C223; C227; C229; C230; C231; C240; C242; C246; C247; C248; C249; C250; C251; C253; C256; C258; C260; C262; C264; C266; C267; C268; C271; C300; C301; C302; C320; C322; C347; C348; C351; C352; C353; C359; C360; C361; C365; C367; C368; C379; C384; C385; C395; C396; C404; C405; C407; C409; C410; C415; C417; C419; C444; C446; C448; C450; C451; C453; C456; C457; C458; C459; C460; C461
C0402CAP NP_C0402__10NF10nFIC8C15; C18; C394; C429; C430; C431; C432; C433
C0402CAP NP_C0402__560PF560pFIC2C17; C19
C0402CAP NP_C0402__2.2UF2.2uFIC26C23; C26; C49; C67; C76; C77; C87; C89; C91; C95; C97; C100; C109; C111; C115; C116; C120; C126; C128; C131; C238; C254; C255; C356; C374; C452
C0402CAP NP_C0402__470NF470nFIC4C31; C112; C113; C114
C0402CAP NP_C0402_220NF220nFIC6C99; C136; C137; C138; C139; C140
C0402CAP NP_C0402__18PF18pFIC23C102; C103; C105; C106; C197; C243; C244; C349; C350; C366; C391; C397; C398; C399; C400; C401; C406; C420; C421; C422; C423; C434; C435
C0402CAP NP_C0402__56PF56pFIC2C281; C282
C0402CAP NP_C0402__1NF1nFIC3C283; C369; C370
C0402CAP NP_C0402__33NF33nFIC1C383
C0402CAP NP_C0402__10PF10pFIC2C402; C403
C0603CAP NP_C0603__22UF22uFIC31C8; C9; C14; C16; C32; C33; C34; C35; C38; C39; C40; C41; C44; C45; C54; C55; C65; C73; C85; C148; C156; C164; C172; C180; C215; C225; C263; C344; C346; C362; C390
C0603CAP NP_C0603__4.7UF4.7uFIC32C25; C27; C36; C43; C47; C48; C51; C53; C96; C183; C188; C189; C193; C200; C205; C226; C228; C232; C233; C235; C239; C269; C270; C272; C273; C298; C354; C355; C386; C445; C447; C449
C0603CAP NP_C0603__10UF10uFIC20C62; C121; C123; C214; C218; C219; C224; C252; C307; C319; C323; C325; C328; C330; C332; C335; C337; C358; C375; C413
C0603CAP NP_C0603__100NF100nFIC1C455
C0805CAP NP_C0805__22UF22uFIC11C2; C4; C10; C56; C57; C257; C259; C261; C363; C418; C439
C0805CAP NP_C0805__47UF47uFIC3C195; C321; C416
C0805CAP NP_C0805__2.2UF2.2uFIC1C454
CKS4B14X20W0504CHOKEWCM-2012-900TIC7L10; L40; L41; L59; L60; L61; L62
CON2B60X50P20CONN_HDR_2X1_CON2B60X50P20__CONCONN_BATINIC1J2
CONS120_8_2B413X73P5QSH060_CONS120_8_2B413X73P5__COCONN_EPDIC1J13
D0402DIODE_TVS_BIDIR_D0402__B72590D0B72590D0050H160IC6TVS1; TVS2; TVS3; TVS4; TVS5; TVS6
DB2M9_2DB9_DB2M9_2_CONN_CANCONN_CANIC1J19
DCJ140X90P3DC POWER JACK_1_DCJ140X90P3__COCONN_DCPOWERIC1J1
DCK5FNSN74LV1T126_DCK5FN_SN74LV1T126DSN74LV1T126DCKRIC1U39
DCU8P5RSN74LVC2G126_0_DCU8P5R_SN74LVC2SN74LVC2G126DCUTIC2U17; U19
DFN8FRAO4447A_4_DFN8FR_AON3419AON3419IC3Q2; Q32; Q34
F1206FUSE_F1206__FUSEFUSEIC1F1
FPC2X12_0P4FPC15_6_FPC2X12_0P4_CONN_DSICONN_DSIIC1J30
FPC2X15_4P4_AFPC15_15_FPC2X15_4P4_A_CONN_CSICONN_CSIIC1J29
FPC14_2W23P5FPC14_FPC14_2W23P5_CONN_SMARTCACONN_SMARTCARDIC1J18
FPC50_2P5TF134-50RL-TAND_3_FPC50_2P5_CONCONN_LCDIC1J14
H2JTSW 2PTS-DROIT_1_H2J_CONN_JUMPECONN_JUMPERIC6J36; J37; J38; J39; J40; J41
H2X5MYHEADER5_2_H2X5MY_CONN_MFICONN_MFIIC1J20
H3JH1X3_H3J_HTMS-103-02-G-SHTMS-103-02-G-SIC1JP1
H4MCONN_HDR_4X1_H4M__CONN_SPEAKERCONN_SPEAKERIC1J17
H8MHDR1X8_H8M_CONN_MIKROBUSCONN_MikroBUSIC2J32; J33
HDMIS19_4P5CON20_0_HDMIS19_4P5_CONN_HDMICONN_HDMIIC1J9
HS2X4_2MZHEADER5_1_HS2X4_2MZ_CONN_ADCCONN_ADCIC1J22
HS2X5_2JZH10_SMT_0_HS2X5_2JZ_CONN_JTAGCONN_JTAGIC1J12
HS2X10_2JZHDR2X10_HS2X10_2JZ_CONN_TAMPERCONN_TAMPERIC1J31
L25X20PINDUCTOR_L25X20__1.5UH1.5uHIC4L3; L4; L5; L7
L25X20PINDUCTOR_L25X20__2.2UH2.2uHIC1L6
L66X66PINDUCTOR_L66X66__2.2UH2.2uHIC2L1; L2
L0402IND_L0402__120 OHM@100MHZ120 OHM@100MHZDISCRETE36L8; L11; L12; L13; L14; L15; L19; L20; L21; L22; L25; L26; L27; L28; L29; L30; L31; L39; L42; L43; L45; L46; L47; L48; L49; L50; L51; L52; L53; L57; L58; L63; L64; L65; L66; L68
L0402INDUCTOR_L0402_1NH1nHIC4L16; L17; L55; L56
L0805PINDUCTOR_L0805__4.7UH4.7uHIC2L44; L54
L1008PINDUCTOR_L1008__2.2UH2.2uHIC2L18; L67
LED0805LED_LED0805__GREENGreenIC4D1; D6; D9; D11
LED0805LED_LED0805__REDREDIC5D2; D7; D8; D10; D23
LED0805LED_LED0805__ORGORGIC1D5
LED0805LED_LED0805__LEDLEDIC2D12; D13
LFB0603_4_3TDK_FILTER_DEA20_1_LFB0603_4_3_LFB182G45SG9A272IC1FL1
LGA8IRMPL3115A2_LGA8IR_MPL3115A2MPL3115A2IC1U22
MHS230D134MGX_2_MHS230D134_MGXMGXIC4MG1; MG2; MG3; MG4
MODULE58_6P45LBEH5HMZPC_MODULE58_6P45_(S1+S2LBEH5HMZPC-TEMPIC1U16
PCIEMINIS52_2_2P8MINI PCIE_1_PCIEMINIS52_2_2P8_CCONN_PCIeIC1J8
QFN8_4_1FRTPS73701DRB_QFN8_4_1FR_TPS73701TPS73701DRBIC1U35
QFN24_1P5M9FGV0241AKLF_3_QFN24_1P5M_IC_PIPI6CFGL201BZDIEXIC1U42
QFN32_1P5HWM8960_QFN_33P_QFN32_1P5H__WM89WM8960CGEFL/VIC1U24
QFN48_1P5BPC32PF3000A1EP_QFN48_1P5B_PC32PPC32PF3000A1EPIC1U4
QFN72_1P5CSIL9022A_0_QFN72_1P5C_SII9022ACSiI9022ACNUIC1U13
QFNASY16P5RFXOS8700CQ_1_QFNASY16P5R_FXOS87FXOS8700CQR1IC1U21
QFNASY24P5MFXAS21002_0_QFNASY24P5M_FXAS210FXAS21002CQR1IC1U20
QFP48P5JFT2232D_2_QFP48P5J_FT2232DFT2232DIC1U18
R0402RES_R0402__1K1KIC13R1; R4; R134; R161; R162; R166; R167; R295; R296; R309; R310; R347; R623
R0402RES_R0402__100K100KIC26R6; R8; R15; R18; R35; R75; R152; R153; R154; R155; R156; R254; R256; R280; R348; R354; R539; R547; R549; R550; R551; R561; R570; R584; R611; R614
R0402RES_R0402__10K10KDISCRETE89R9; R11; R28; R68; R87; R88; R89; R92; R93; R94; R97; R98; R99; R100; R101; R104; R105; R108; R135; R138; R139; R148; R165; R168; R169; R170; R225; R226; R228; R230; R232; R234; R236; R239; R241; R242; R244; R252; R253; R255; R257; R262; R263; R275; R282; R294; R327; R330; R331; R332; R333; R334; R335; R336; R351; R353; R361; R362; R363; R364; R367; R386; R387; R472; R477; R489; R490; R493; R498; R537; R543; R548; R553; R602; R603; R604; R609; R610; R612; R613; R615; R621; R622; R628; R630; R631; R636; R637; R640
R0402RES_R0402__75K75KIC1R10
R0402RES_R0402__12K712K7IC2R12; R16
R0402RES_R0402__24K24KIC2R13; R17
R0402RES_R0402__88K788K7IC1R14
R0402RES_R0402__470R470RIC14R19; R90; R91; R127; R128; R129; R157; R264; R266; R267; R268; R269; R270; R556
R0402RES_R0402__0R0RDISCRETE189R23; R30; R31; R32; R45; R46; R65; R69; R76; R85; R102; R117; R118; R119; R120; R124; R125; R136; R147; R163; R171; R172; R180; R181; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R243; R250; R251; R258; R261; R265; R281; R283; R284; R285; R299; R300; R301; R302; R303; R307; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R325; R326; R329; R339; R340; R341; R350; R352; R355; R365; R368; R369; R370; R371; R372; R373; R374; R375; R388; R389; R390; R391; R392; R393; R394; R395; R396; R397; R398; R399; R400; R401; R402; R403; R404; R405; R406; R407; R408; R409; R410; R411; R412; R413; R415; R416; R417; R419; R420; R421; R422; R423; R424; R425; R426; R427; R428; R429; R430; R431; R432; R433; R434; R435; R476; R478; R479; R480; R481; R482; R483; R484; R485; R486; R487; R488; R496; R497; R499; R500; R501; R502; R503; R504; R505; R506; R507; R508; R509; R510; R512; R514; R515; R516; R518; R519; R520; R521; R523; R524; R554; R555; R557; R558; R559; R560; R565; R566; R567; R568; R569; R571; R582; R583; R595; R596; R617; R618; R619; R620; R629; R632; R633; R641; R642; R643
R0402RES_R0402__47K47KIC6R27; R132; R142; R143; R249; R616
R0402RES_R0402__2K22K2IC14R33; R34; R59; R60; R61; R62; R63; R64; R107; R182; R491; R538; R580; R581
R0402RES_R0402__4.75M4.75MIC1R36
R0402RES_R0402__1M1MIC3R38; R164; R349
R0402RES_R0402__22R22RDISCRETE47R39; R40; R41; R42; R43; R44; R112; R158; R160; R286; R287; R288; R289; R290; R291; R342; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453; R454; R455; R456; R457; R458; R459; R468; R469; R470; R471; R473; R474; R475
R0402RES_R0402__200R200RIC2R66; R70
R0402RES_R0402__470K470KIC2R67; R71
R0402RES_R0402__4K74K7IC36R80; R140; R141; R144; R145; R174; R175; R195; R196; R197; R199; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R272; R273; R276; R277; R278; R279; R540; R638; R639
R0402RES_R0402__240R240RIC5R81; R82; R83; R84; R86
R0402RES_R0402__33R33RDISCRETE25R95; R96; R106; R110; R111; R137; R151; R177; R178; R179; R337; R338; R356; R357; R358; R359; R360; R492; R590; R591; R592; R593; R597; R598; R601
R0402RES_R0402__5K15K1IC1R133
R0402RES_R0402__15K15KIC1R146
R0402RES_R0402__1K51K5IC2R159; R271
R0402RES_R0402__10R10RIC1R176
R0402RES_R0402__6K046K04IC1R274
R0402RES_R0402__52K352K3IC1R323
R0402RES_R0402__30K130K1IC1R324
R0402RES_R0402__49R949R9DISCRETE25R343; R344; R345; R346; R460; R461; R462; R463; R464; R465; R466; R467; R495; R525; R526; R527; R528; R529; R530; R531; R532; R533; R534; R535; R536
R0402RES_R0402__33K33KIC1R366
R0402RES_R0402__560R560RIC1R494
R0402RES_R0402__140R140RIC2R605; R607
R0402RES_R0402__75R75RIC2R606; R608
R0402RES_R0402__374K374KIC1R624
R0402RES_R0402__12K12KIC1R625
R0402RES_R0402__49.9R 1%49.9R 1%IC2R634; R635
R0603RES_R0603__30R30RIC1R626
R0805RES_R0805__60R460R4IC3R103; R245; R246
R1206RES_R1206__0R0RIC2R20; R24
RJ45_48F-01GY_P14_448F-01GY2DPL2NL_2_RJ45_48F-01GYCONN_RJ45IC1J27
RJ45_48F-01GY_P14_448F-01GY2DPL2NL_4_RJ45_48F-01GYCONN_RJ45IC1J28
SD11_6B280X180SD_CARD_1_SD11_6B280X180_CONN_SCONN_SDIC1J6
SIMCARD6B163X157SIM CARD_0_SIMCARD6B163X157_CONCONN_SIMIC1J7
SOD123DIODE_SCHTKY_0_SOD123__1N5819HW1N5819HW-7-FIC6D3; D4; D16; D20; D25; D26
SOD523ZDIODE_SOD523__MM5Z5V1ST1GMM5Z5V1ST1GIC1D17
SOIC8JAMC33901WEF_SOIC8JA_MC33901WEFMC33901WEFIC1U25
SOIC8JASP2526A-2_2_SOIC8JA_SP2526A-1ENSP2526A-1EN-LIC1U30
SOIC8JALM358_SOIC8JA_(S1+S2)_LMV358MXLMV358MXIC1U40
SOIC8JA24AA512-I/SN_SOIC8JA_24AA512-I/24AA512-I/SNIC1U41
SOIC8_1JGS25FL128S_SO_8_SOIC8_1JG__MX25LMX25L51245GZ2I-10GIC1U11
SOP8_1JART8070ZSP_1_SOP8_1JA_RT8070ZSPRT8070ZSPIC2U2; U3
SOT23_5TPS79912YZU_SOT23_5_ME6211C12M5ME6211C12M5GIC1U14
SOT23_5TPS79912YZU_SOT23_5_ME6211C18M5ME6211C18M5GIC1U33
SOT23_5TPS3808_6_SOT23_5_TLV73310PDBVTTLV73310PDBVTIC1U44
SOT23_6TRUSBLC6_0_SOT23_6TR_USBLC6-2SC6YUSBLC6-2SC6YIC2U27; U28
SOT23_6TRTPS3808_SOT23_6TR_TPS3808G30DBVTPS3808G30DBVTIC1U37
SOT23_123BAT54S_0_SOT23_123__BAT54SBAT54SIC1D22
SOT23_123MOSFET_N_0_SOT23_123_2N70022N7002IC8Q5; Q7; Q16; Q22; Q25; Q29; Q30; Q31
SOT23_123MOSFET_P_0_SOT23_123_AO3407AAO3407AIC5Q6; Q10; Q13; Q21; Q24
SOT23_123MM3904_2_SOT23_123_MMBT3904MMBT3904IC1Q8
SOT23_1232N1132_1_SOT23_123_MMBT2907MMBT2907IC1Q17
SOT23_123MOSFET_N_0_SOT23_123_DMN2005K-7DMN2005K-7IC1Q36
SOT323BAT54A_SOT323__BAT54ABAT54AIC3D14; D15; D24
SOT363_6BCM8576BS_2_SOT363_6_BCM857BSBCM857BSIC1Q35
SSOP8CRNT3H1101W0FHK_4_SSOP8CR_TXS0102TXS0102DCURIC1U45
SW5B87X45SSW3_RA_SLIDE_0_SW5B87X45S__SS-1SS-12D01VG2-566IC1SW1
SWS4B60SSW PUSHBUTTON_0_SWS4B60S_B3S-10B3S-1000IC4S1; S2; S3; S4
SWS4JVSW DIP-2/SM_SWS4JV_GDH02S04GDH02S04IC1SW3
SWS16JVSW_DIP_8_SWS16JV__DSHP08TSGERDSHP08TSGERIC1SW2
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107__TP30tp30IC8TP58; TP60; TP61; TP62; TP63; TP64; TP65; TP66
TP15TESTLOOP_TP15__TP30tp30IC12TP15; TP16; TP17; TP18; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47
TP30TESTLOOP_TP30__TP30tp30IC52TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP39; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP75
TSOP12P5RTPS3808_4_TSOP12P5R_AAT1239ITP-AAT1239ITP-1-T1IC1U43
TSOP48P5K_AMT29F32G08CBADB_1_TSOP48P5K_A_MMT29F32G08CBADBIC1U12
TSSOP16FATSC2046IPWR_TSSOP16FA_TSC2046IPTSC2046IPWRIC1U23
TSSOP16FA74LV595_0_TSSOP16FA_74LV595PW74LV595PWIC1U38
TSSOP38P5ACM2020_TSSOP38P5A_CM2020-00TRCM2020-00TRIC1U15
TSSOP48P5GSN74AVC16T245DGG_0_TSSOP48P5G_SSN74AVC16T245DGGRIC1U36
USB4_4ASUSB_A_USB4_4AS_CONN_USBCONN_USBIC1J26
USBMICRO5_6AUSB_MICRO_0_USBMICRO5_6A__CONN_CONN_USBIC1J11
USBMICRO5_6AUSB_MICRO_1_USBMICRO5_6A__CONN_CONN_USBIC1J25
X2S32X15CRYSTAL_4_X2S32X15_CM7V-T1ACM7V-T1AIC1Y1
X2S50X32CRYSTAL_4_X2S50X32_5XBB240002025XBB24000202TF50Q3IC1Y2
X2S50X32CRYSTAL_0_X2S50X32_5XBB250002025XBB25000202TF40Q3IC1Y8
X2S115X5CRYSTAL_5_X2S115X5_7D06000202BT7D06000202BTAF70Q3IC1Y4
X4S32X25SG615/SM_X4S32X25_32.768KHZ32.768KHzIC3X1; X2; X3
X4S32X25SG615/SM_X4S32X25_24MHZ24MHzIC1X4
X4S32X25CRYSTAL13_X4S32X25_DISCRETE_25M25MHZDISCRETE1Y3
附件:; [# y; o$ t* V1 o: H# Q1 J
pcb文件. m6 G3 H, ~; I  C7 {$ W
游客,如果您要查看本帖隐藏内容请回复
( ?5 R- t! E, V
GMT+8, 2025-7-20 20:22 , Processed in 0.156250 second(s), 28 queries , Gzip On.
