作品名:[AD 10][2层]STM32开发板(STM32+TPD3E001DRYR+TPS73733DCQ+SMF05CT1G)原理图和PCB源文件 - X) S# L3 J: V! N4 L5 Z
文件描述 1. 作品用途:STM32开发板 2. 软件版本:AD 10 3. 层数:2层板 4. 用到的主要芯片:STM32+TPD3E001DRYR+TPS73733DCQ+SMF05CT1G 5. PCB尺寸:84mm*52mm 6 n4 t+ T7 F8 U$ W9 A; _
作品截图如下: 顶层截图: % v# \; S/ H( X
底层截图: 全层截图:
& ?! ~5 E! V; T# J叠层信息截图如下:
. S" _3 ~8 c; i% N$ }; SBOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 2.54mm | BT1 | XH2.54_1X2_L | 1 | 0.1uF/50V/X7R/0603 | C1, C6, C7, C8, C11, C20, C21, C24, C25, C26, C27, C28, C29, C31, C32, C36, C37, C38 | C0603 | 18 | NC/50V/X7R/0402 | C2, C3, C22, C23 | C0402 | 4 | 10uF/6.3V/X7R/0603 | C4, C9, C10, C13, C14, C16, C17, C18, C19, C34 | C0603 | 10 | 470PF/50V/X7R/0603 | C5 | C0603 | 1 | 33PF/50V/X7R/0603 | C12, C30, C33, C35 | C0603 | 4 | 100uF/6.3V/Tan_B | C15 | TAJ-B | 1 | 100pF/50V/X7R/0603 | C39 | C0603 | 1 | LED_GREEN/1206 | D1, D4, D5 | D1206 | 3 | PGB0010603MR | D2, D3 | F603-41X39 | 2 | LED_RED/1206 | D6 | D1206 | 1 | Comment | J1, J4 | SMA-ANT_DIP4 | 2 | MICRO-USB | J2 | MICRO_USB | 1 | 104350-1 | J3 | SS12D00 | 1 | XH2.54_1X4 | J5, J8 | XH2.54_1X4_L | 2 | 17*2_2.54 | J6, J9 | 2*17_34PIN-2.54mm | 2 | SIM_CARD | J7 | MICRO_SIM-T | 1 | XH2.54_1X5 | J10 | XH2.54_1X5_L | 1 | PH2.54_1X2 | J11 | 2PIN-2.54mm | 1 | BLM18KG221SN1D | L1 | SM-7351-IND-0603 | 1 | SPP2341S23RG | Q1 | MOS_GSD | 1 | SS9014/SOT23-3 | Q2, Q3, Q4 | SOT23_3-T | 3 | 0R/0603 | R1, R2 | R0603 | 2 | 0R/0402 | R3, R7 | R0402 | 2 | 1M(1%)/0603 | R4 | R0603 | 1 | 1K(1%)/0603 | R5, R10, R11, R18, R31, R32, R35 | R0603 | 7 | 1.66K(1%)/0603 | R6 | R0603 | 1 | 10K(1%)/0603 | R8, R9, R13, R14, R23, R25, R27, R36, R37 | R0603 | 9 | 47K(1%)/0603 | R12 | R0603 | 1 | 470K(1%)/0603 | R15 | R0603 | 1 | 22R/0603 | R16, R17, R19, R21, R22, R24, R26 | R0603 | 7 | 20K(1%)/0603 | R20 | R0603 | 1 | 560R/0603 | R28, R29, R34 | R0603 | 3 | 200K(1%)/0603 | R30 | R0603 | 1 | 100K(1%)/0603 | R33 | R0603 | 1 | KAN0631 | S1, S2 | SW/4.5*4.5*3.8 | 2 | STM32 | U1 | STM32_37*24 | 1 | TPD3E001DRYR | U2 | U_6_DRY | 1 | TP4055/SOT23-5 | U3 | SOT-23 | 1 | TPS73733DCQ/SOT223 | U4 | SOT223 | 1 | MFF2_VQFN8 | U5 | 1 | 1 | SMF05CT1G/SC88 | U6 | SC-88 | 1 | % h' V W+ ~# u l( f$ B
附件: 原理图和PCB源文件如下: 3 b: ` R1 N$ N, i9 m) W" f6 M
