作品名:[AD 10][3层]带DVB高频头接收功能的DVD板(ES8380+ZL10353+AM5888S)PCB源文件
( T' N/ u7 |3 f9 k5 F文件描述 1. 作品用途:带DVB高频头接收功能的DVD板 2. 软件版本:AD 10 3. 层数:3层板 4. 用到的主要芯片:ES8380+ZL10353+AM5888S 5. PCB尺寸:125mm*124.5mm ' K0 u2 v3 a* A( }* C
作品截图如下: 顶层截图: ! d% e6 M/ @. r
底层截图: 全层截图:
0 f: ~5 j3 g0 O( O' @叠层信息截图如下: : k5 v- `# a: i. r, K
BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C1, C133, C134 | c0603 | 3 | 10UF/16V | C2, C9, C28, C33, C44, C139 | CELA2.5-4 | 6 | 0.1UF | C3, C6, C7, C8, C10, C11, C26, C27, C29, C30, C31, C32, C34, C35, C36, C37, C38, C39, C40, C42, C45, C46, C47, C48, C49, C50, C51, C53, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C72, C73, C129, C130, C131, C138, C140, C141, C142, C183, C184, C191, C193, C194, C195, C196, C197, C198, C200, C201, C202, C203, C204, C208, C217, C218, C221, C229 | C0603 | 66 | 22PF | C4, C5, C89, C101, C114, C124, C137, C153, C215, C216 | C0603 | 10 | 680PF | C12, C14 | C0603 | 2 | 220UF/16V | C13 | CELA2.5-4 | 1 | 1000PF | C15, C21, C52, C74 | C0603 | 4 | 100PF | C16, C67, C164, C165, C167, C168, C169, C170, C171, C172, C173, C174, C175, C185, C186, C187, C188, C189, C190, C236, C237, C238, C240, C241, C1236 | C0603 | 25 | 0.022UF | C17 | C0603 | 1 | C | C18, C19 | C0603 | 2 | 4700PF | C20 | C0603 | 1 | 0.15UF | C22 | C0603 | 1 | 4.7uF | C24 | CELA2.5-4 | 1 | 1000UF/6.3V | C25 | CELA2.5-4 | 1 | 10UF | C65, C79, C88, C100, C111, C122, C136, C151 | CELA2.5-4 | 8 | 270pF | C66 | C0603 | 1 | 150nf | C68 | C0603 | 1 | 10nF | C69 | C0603 | 1 | 100UF | C71, C93, C105, C115, C125, C147, C154, C199, C207, C222, C228, C230 | CELA2.5-4 | 12 | 100UF/16V | C76, C77, C132, C143 | CELA2.5-4 | 4 | 220UF/16V | C80 | CAP-8.0-3.5 | 1 | 47UF/16V | C81 | CELA2.5-4 | 1 | 0.1 | C82 | C0603 | 1 | 0.01 | C83, C85 | C0603 | 2 | 0.1U | C84 | C0603 | 1 | 0.47UF | C86, C87 | C0603 | 2 | 33PF | C90, C97, C102 | C0603 | 3 | 82PF | C91, C98, C103 | C0603 | 3 | 330PF | C94, C106, C116, C126, C148, C155 | C0603 | 6 | 4.7nF | C95, C96, C107, C108, C117, C118, C127, C128, C149, C150, C156, C157 | C0603 | 12 | 470PF | C109, C110, C112, C113, C119, C120 | C0603 | 6 | 470uF/16V | C121 | CAP-8.0-3.5 | 1 | 220uF/16V | C123 | CELA2.5-6 | 1 | 10UF/25V | C135, C146, C227 | CELA2.5-4 | 3 | 10pF | C152, C213, C214 | C0603 | 3 | 103 | C159 | C0603 | 1 | 27pF | C163, C219, C220 | C0603 | 3 | 15pF | C176, C177, C178, C179, C180, C181, C182, C231, C232, C234, C235 | C0603 | 11 | 100P | C223 | C0603 | 1 | 220n | C224 | C0603 | 1 | 10P | C225, C226 | C0603 | 2 | 15pF(NC) | C239 | C0603 | 1 | CON5 | CN2, CON7 | CONS5 | 2 | CON7 | CON3 | CONS6 | 1 | 24PIN | CON4 | NZ24 | 1 | HEADER 4 | CON6 | cons5 | 1 | 6pin/2.0MM | CON8 | cons6 | 1 | RCA CN4 | CON11 | RCA-613D | 1 | MC4 | CON12 | OPTICAL | 1 | CN10 | CON13 | cons10 | 1 | cn7 | CON15 | cons7 | 1 | CON15 | CON16 | CONS15 | 1 | 1N4007 | D4 | DIOA12.5 | 1 | 7V | D5 | d1206 | 1 | 3.3V | D6 | d1206 | 1 | IN4148 | D16, D17, D18 | D1206 | 3 | 1N6263 | D21, D22, D23, D24, D25, D26, D27, D28, D29, D30, D31, D32 | d1206 | 12 | FB | FB1, L1, L3, L4, L8, L9, L29 | r0603 | 7 | L100MH/OPEN | FB2 | r0603 | 1 | 120 ohm@100MHz/200mA | FB8, FB9, FB10, FB11, FB12, FB13, FB14, FB15, FB16, FB18, L25, L30, L31, L32, L33, L39 | r0603 | 16 | 601 | FB20, FB21, FB22, FB23, FB24, FB25, FB26, FB27, FB28, FB31, FB32, FB33, FB34, FB35, FB36, FB37, FB38, FB39, FB40 | R0603 | 19 | ES8380 | IC100 | PQFP208 | 1 | 4Mx16 SDRAM (6ns) | IC101 | SOP54 | 1 | SDRAM 512KX16X2 (9ns)(open) | IC101B | SOP50 | 1 | 29LV800BE-90 | IC103 | TSOP48 | 1 | ZL10353 | IC104 | QFP64 | 1 | 74HCT374 | IC105 | SOP20 | 1 | 74F244 | IC106 | SOP20 | 1 | AM5888S | IC107 | BA5934FP | 1 | AT24C01A-10TC-2.7 | IC108 | SOP8 | 1 | 4558 | IC110, IC111, IC112 | SOP8 | 3 | RCA+SVIDEO | JK301 | S-VIDOB | 1 | 22UH | L2, L7, L12, L27 | r0603 | 4 | 10uH | L5, L6 | R0603 | 2 | 470nH | L10, L13, L16 | r0603 | 3 | 220nH | L11, L14, L17 | r0603 | 3 | 2.7UH | L18, L19, L20 | r0603 | 3 | 600OHM | L21, L22 | r0603 | 2 | 1UH | L23, L24 | r0603 | 2 | 120 ohm | L34 | r0603 | 1 | APM2301AAC | Q1 | SOT-23 | 1 | 2SK3018 | Q2, Q4 | 2SK3018 | 2 | 2N3904 | Q3, Q5, Q11, Q12, Q13, Q16, Q18, Q20, Q32, Q33, Q34, Q35 | NPN/PNP-ECB | 12 | 8550 | Q6, Q8 | NPN/PNP-ECB | 2 | SS8550D | Q9, Q10 | NPN/PNP-ECB | 2 | 8550 | Q14, Q15 | 8055TA | 2 | 2N3904 | Q17 | 8055TA | 1 | SST3904 | Q19 | NPN/PNP-ECB | 1 | 2N3906 | Q31 | NPN/PNP-ECB | 1 | 4.3K | R1, R2 | R06-12.5 | 2 | 4.7K | R4, R5, R6, R11, R15, R22, R23, R24, R32, R39, R57, R81, R154, R161, R198, R207, R220, R228, R235, R237, R246 | R0603 | 21 | 100K | R7, R10, R51, R90, R100, R111, R121, R128, R134, R147, R197 | R0603 | 11 | 10 | R8, R9, R17, R58, R64 | R0603 | 5 | 33 OHM | R12 | R0603 | 1 | 1K | R13, R14, R25, R72, R79, R122, R123, R187, R189, R236 | R0603 | 10 | 0 | R16, R30, R40, R41, R42, R44, R49, R53, R54, R131, R204 | R0603 | 11 | open | R18, R19, R43, R52, R55, R165, R166, R202, R203, R225, R226, R227, RL1, RL2 | R0603 | 14 | 33 | R20, R26, R27, R28, R78, R199, R224 | R0603 | 7 | 10K | R21, R45, R48, R50, R59, R65, R67, R84, R95, R105, R115, R129, R138, R151, R221 | R0603 | 15 | 15K | R29, R33, R34 | R0603 | 3 | 390 OHM 1% | R31 | R0603 | 1 | 47K | R35, R36, R80 | R0603 | 3 | 68K | R37 | R0603 | 1 | 680 | R60 | R0603 | 1 | 560 | R66 | R0603 | 1 | 12K | R68, R87 | R0603 | 2 | 24K | R69 | R0603 | 1 | 22K | R70, R75, R86 | R0603 | 3 | 56K | R71 | R0603 | 1 | 4.3K | R76 | R0603 | 1 | 3.3K | R77 | R0603 | 1 | 3K | R82 | R0603 | 1 | 1.2K | R83, R88 | R0603 | 2 | 20K | R85 | R0603 | 1 | 470 OHM | R89, R99, R109, R119, R133, R145, R230, R231, R232, R233 | R0603 | 10 | 75 OHM | R91, R98, R101, R108, R110, R117 | R0603 | 6 | 2K | R92, R102, R112, R124, R135, R148 | R0603 | 6 | 1.5K | R93, R94, R103, R104, R113, R114, R125, R126, R136, R137, R149, R150 | R0603 | 12 | 470 | R96, R106, R116, R130, R132, R139, R152 | R0603 | 7 | 6.8K | R118 | R0603 | 1 | 2.2K | R120 | R0603 | 1 | 1K(OPEN) | R127 | R0603 | 1 | 33R | R140, R186 | R0603 | 2 | 68R | R141, R142 | R0603 | 2 | 180R | R143 | R0603 | 1 | 0R | R144 | R0603 | 1 | 91R | R146 | R0603 | 1 | 0 OHM | R164 | R0603 | 1 | 100R | R188, R191, R196, R200, R206, R209, R210 | R0603 | 7 | 1OHM | R211 | 0805 | 1 | 75 | R238 | R0603 | 1 | 1K(NC) | R239 | R0603 | 1 | 1K(0OHM ) | R240 | R0603 | 1 | 0OHM(NC) | R243 | R0603 | 1 | 0OMHM(NC) | R244 | R0603 | 1 | NC(O0OHM) | R245 | R0603 | 1 | 33x4 | RB1, RB2, RB3 | ra | 3 | Reset | T30 | TP | 1 | ZW | TU1B | DVB-T-P | 1 | AMS1117-1.8(NC) | U10 | SOT-223 | 1 | 74F08 | U11 | SOP14 | 1 | LM809 | U12 | 8055ta | 1 | 74HC32 | U23 | SOP14 | 1 | 27M | Y1 | XTAL | 1 | 20.48MHZ | Y2 | XTAL | 1 |
* x" b( m Q! r1 p9 [! H0 s( u附件: PCB源文件如下: 0 f+ c; b- S6 t/ q6 v* x
