查看: 682|回复: 0
[allegro16.6][4层]RK3326官方参考设计之三(RK3326+K3PE0E000E)原理图和pcb文件
发表于 2019-12-27 11:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
' r3 @. T7 L4 u
文件描述:
' G' h- b& O8 J8 i* K
1. 作品用途:RK3326官方参考设计之三
2. 软件版本:allegro16.6
3. 层数:4层
4. 用到的主要芯片:RK3326+K3PE0E000E
5. PCB尺寸:异形
) A9 @6 F0 x; g1 M/ L
作品截图如下:
8 B; Z- H- t8 e, x- b2 g# w8 \8 l
顶层截图:
/ Q- Z3 U% ~8 K7 M4 j
底层截图:
5 Z( j# w- g8 ^* ^
Z0 y5 A; I* K( B+ n
全层截图:
/ h+ C! x, E4 {2 E  v2 {* h& n: @
0 B8 d! v0 V: S) k* N
/ @: ~+ d# r0 ?' H) y
7 k  Y2 d/ k0 e3 W5 t7 Z( R.
* ^  E/ M6 u% k! ^! O
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
ANTPCB_44R00X11R00_DSRANT_1P1G_ANTPCB_44R00X11R00_DSRANT4411DRIC1ANT6100
ANT_JACKANT_1P2G_ANT_JACK_ANT_JACKANT_JACKIC1ANT6101
BAT3_2R54BATT3_BAT3_2R54_BAT3_2R54BAT3_2R54IC1BT2100
BGA14_1R59X1R59X0R57SENSOR_AK8963C_BGA14_1R59X1R59XAK8963CIC1U9002
BGA169_18R00X14R00X1R20_2LINAND_EMMC_169_2L_BGA169_18R00XKLMAG2GEAC-B031IC1U4100
BGA418_14R00X14R00X1R24mcu_RK3326_BGA418_14R00X14R00X1RK3326IC1U1000
C0402CAP NP_C0402_100NF100nFIC109C1001; C1002; C1003; C1004; C1005; C1006; C1008; C1009; C1010; C1011; C1012; C1013; C1100; C1103; C1104; C1105; C1106; C1107; C1108; C1201; C1202; C1203; C1204; C1205; C1206; C1300; C1400; C1401; C1402; C1500; C1501; C1600; C1601; C1701; C1702; C1703; C1704; C1800; C1801; C1802; C2000; C2005; C2007; C2009; C2012; C2016; C2136; C2137; C2138; C2139; C2140; C2501; C3500; C3501; C3504; C3507; C3510; C3511; C3512; C3513; C3516; C3517; C3518; C3519; C3520; C3523; C3524; C3525; C3526; C4001; C4003; C4102; C4104; C4105; C4601; C4602; C4603; C4606; C4608; C4702; C4704; C4707; C5101; C6102; C6107; C6111; C6113; C7001; C7002; C7003; C7004; C7009; C7010; C9000; C9002; C9004; C9100; C9301; C9303; C9305; C9601; C9603; C9604; C9605; C9606; C9608; C9715; C9716; C9824
C0402CAP NP_C0402_4.7UF4.7uFIC11C1014; C1015; C1200; C4000; C4002; C4101; C4103; C4605; C4706; C6108; C6112
C0402CAP NP_C0402_2.2UF2.2uFIC7C1016; C2127; C2128; C2131; C2133; C2134; C9705
C0402CAP NP_C0402_22PF22pFIC6C1101; C1102; C2132; C2135; C6104; C6105
C0402CAP NP_C0402_8PF8pFIC4C1700; C4600; C4700; C4701
C0402CAP NP_C0402_100PF100pFIC3C2006; C2013; C3506
C0402CAP NP_C0402_1UF1uFIC46C2018; C2101; C2102; C2105; C2108; C2109; C2111; C2115; C2116; C2117; C2118; C2119; C2120; C2123; C2129; C3515; C3522; C4100; C4703; C4705; C6106; C7000; C7006; C9602; C9700; C9701; C9702; C9703; C9711; C9712; C9713; C9800; C9801; C9802; C9803; C9804; C9805; C9806; C9807; C9808; C9809; C9810; C9811; C9812; C9813; C9814
C0402CAP NP_C0402_27PF27pFIC2C2141; C2142
C0402CAP NP_C0402_1NF1nFIC6C3502; C3503; C3505; C3508; C3527; C9200
C0402CAP NP_C0402_3PF3pFIC1C6100
C0402CAP NP_C0402_18PF18pFIC1C6103
C0402CAP NP_C0402_DNPDNPIC1C6109
C0402CAP NP_C0402_680PF680pFIC2C7005; C7007
C0402CAP NP_C0402_220PF220pFIC1C7008
C0402CAP NP_C0402_12PF12pFIC2C9706; C9707
C0603CAP NP_C0603_22UF22uFIC13C1000; C1007; C2103; C2104; C2112; C2114; C9817; C9818; C9819; C9820; C9821; C9822; C9823
C0603CAP NP_C0603_10UF10uFIC22C2003; C2015; C2106; C2107; C2110; C2113; C2122; C2126; C2130; C2500; C3509; C3514; C3521; C4604; C4607; C5100; C6101; C9101; C9300; C9302; C9600; C9607
C0603CAP NP_C0603_4.7UF4.7uFIC2C6110; C9704
C0805CAP NP_C0805_10UF10uFIC5C2001; C2004; C2010; C2011; C9304
C0805CAP NP_C0805_22UF22uFIC12C2002; C2014; C2100; C2121; C2124; C2125; C9708; C9709; C9710; C9714; C9815; C9816
C0805CAP NP_C0805_2.2UF2.2uFIC2C2008; C2017
CON2M_1X2_2R00_V_P_DIPCON2_1X2_CON2M_1X2_2R00_V_P_DIPCON2M_1X2_2R00_V_P_DIPIC1J7001
CON2_1X2_5R08_DIPGND_GATE_CON2_1X2_5R08_DIP_GND_GND_GATEIC7J9901; J9902; J9903; J9904; J9905; J9906; J9907
CON6M_1X6_2R54_V_DIPCON6_1X6_CON6M_1X6_2R54_V_DIP_CCON6M_1X6_2R54_VIC1J2100
CON30M_2X15_0R40_V_SMTCMK-CB0077-FV1_2_CON30M_2X15_0RAXT530124IC1J4600
CON30M_2X15_2R54_V_DIPCON30_2X15_CON30M_2X15_2R54_V_DP101-2x15SGF01IC1J9301
CON40M_2X20_1R27_V_PCON40_2X20_CON40M_2X20_1R27_V_PB127S2GL240DTIC1J6101
CON40M_2X20_2R54_V_DIPHEADER 28X2_1_CON40M_2X20_2R54_GPIO_EXTIC1J9300
CRY2_6R90X1R40X1R30CRYSTAL_2P_1G_CRY2_6R90X1R40X1R32.768KHzIC1Y2100
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzIC2Y1100; Y9700
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R8_126MHzIC1Y6100
DC3_DC_0007_5PDCJACK_3P_DC3_DC_0007_5P_DC-000DC-0007-5PIC1J2000
DFN10_3R00X3R00X0R90SENSOR_MMA7660FC_DFN10_3R00X3R0MMA7660FCTIC1U9000
DO_214ACDIODE_DO_214AC_SS32SS32IC1D2000
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD54ESD5451NIC9D9100; ED2100; ED2101; ED7000; ED7001; ED7002; ED7003; ED7004; ED9200
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD53ESD5341NIC1ED2500
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD_1ESD5471XIC7ED9100; ED9101; ED9102; ED9103; ED9104; ED9105; ED9106
F8050FUSE_F8050_JK-SMD200LJK-SMD200LIC1F2000
FBGA220-14X14LP2_D220_FBGA220-14X14_K3PE0E00K3PE0E000EIC1U3500
FPC24L_1X24_0R50_DOWNOV2659_FPC24L_1X24_0R50_DOWN_OVOV2659IC1J4700
FPC30R_0R50_UPFPC_MIPI/LVDS_FPC30R_0R50_UP_3030PIN FPC CONIC1J5100
FR4_6R35X3R68X0R635CSM2512_FR4_6R35X3R68X0R635_CSMCSM2512 10mRIC1R2000
HOLE_C3R20_C6R00HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20IC4H9900; H9901; H9902; H9903
HSMT8_3R30X3R30X0R90MOSFET N 8L1_HSMT8_3R30X3R30X0RRQ3E130BNIC1Q2000
HSMT8_3R30X3R30X0R90MOSFET P 8L_1_HSMT8_3R30X3R30X0RQ3E120ATIC2Q2001; Q2002
IND_252010INDUCTORS OF FERRITE_IND_252010470nHIC5L2100; L2101; L2102; L2103; L2104
IND_303012INDUCTORS OF FERRITE_IND_3030124.7uHIC1L6102
IND_404030INDUCTORS OF FERRITE_IND_4040303.3uHIC2L2000; L2001
JTAG_ARMJTAG_ARM_JTAG_ARM_JTAG_ARMJTAG_ARMIC1J9601
L0402INDUCTOR_L0402_DNPDNPIC2L6100; L6101
L0603BEAD_L0603_180R-100M180R-100MIC2FB4600; FB4700
L0603BEAD_L0603_600R-100M600R-100MIC5FB7000; FB7001; FB9700; FB9800; FB9801
L0603DINDUCTOR COM_L0603D_90R-100M90R-100MIC1FB2500
LCD30_UG-2864HSWEG01OLED096_SSD1306_1_LCD30_UG-2864OLED096_SSD1306IC1LCD9700
LED0603LED_LED0603_LED_REDLED_REDIC2LED2000; LED9600
MARKMARK_MARK_MARKMARKIC6M9900; M9901; M9902; M9903; M9904; M9905
MD44_AP6XXXMODULE_AP6XXX_MD44_AP6XXX_AP621AP6212IC1U6100
MIC2_4020MIC_MIC2_4020_MIC-4020MIC-4020IC1MIC7000
MSOP10_3R00X3R00X1R10SWITCH_FSUSB30MUX_MSOP10_3R00X3FSUSB30MUXDISCRETE2U9602; U9603
MSOP10_3R00X3R00X1R10IN219_1_MSOP10_3R00X3R00X1R10_IINA226AIDGSTIC15U9800; U9801; U9802; U9803; U9804; U9805; U9806; U9807; U9808; U9809; U9810; U9811; U9812; U9813; U9814
PJ7_D3R50_PJ3536PHONEJACK_7P_PJ7_D3R50_PJ3536_PPJ-3536IC1J7000
QFN56_8R00X8R00X1R00CY7C68013A_0_QFN56_8R00X8R00X1RCY7C68013AIC1U9701
QFN68_7R00X7R00X0R80_TRK817_QFN68_7R00X7R00X0R80_T_RKRK817-1IC1U2100
R0402RESISTOR_R0402_22R22RDISCRETE23R1102; R1700; R1800; R1801; R1802; R1803; R1804; R1805; R1806; R1809; R1810; R1811; R1812; R1813; R1814; R4601; R4700; R4701; R7006; R7007; R9100; R9604; R9605
R0402RESISTOR_R0402_2.2K2.2KIC9R1108; R1109; R1113; R1114; R1603; R1604; R2010; R7000; R7009
R0402RESISTOR_R0402_0R0RIC62R1110; R1111; R1705; R1706; R1707; R1708; R1709; R1710; R1711; R1712; R1713; R1714; R1715; R1716; R1717; R1718; R1719; R1720; R1721; R1722; R1723; R1724; R1816; R2126; R2128; R2130; R2131; R2132; R2133; R2134; R2135; R4001; R4002; R4004; R4005; R4102; R4602; R4703; R6100; R6101; R6102; R6103; R6104; R6105; R6106; R6107; R6110; R6112; R6118; R6121; R6122; R7005; R9300; R9301; R9302; R9303; R9304; R9305; R9306; R9307; R9601; R9602
R0402RESISTOR_R0402_133R133RIC1R1400
R0402RESISTOR_R0402_51K51KIC2R1500; R1502
R0402RESISTOR_R0402_2K2KIC4R1600; R1701; R9202; R9600
R0402RESISTOR_R0402_DNPDNPIC2R1817; R2005
R0402RESISTOR_R0402_5.1K5.1KIC1R2001
R0402RESISTOR_R0402_10K10KIC29R2003; R2006; R2007; R2009; R2013; R2127; R2129; R2502; R3500; R3501; R3502; R3503; R3504; R3507; R3508; R4100; R4101; R4600; R4702; R7011; R9200; R9606; R9607; R9608; R9609; R9610; R9703; R9708; R9709
R0402RESISTOR_R0402_53.6K53.6KIC1R2004
R0402RESISTOR_R0402_75K75KIC1R2008
R0402RESISTOR_R0402_100K100KIC6R2011; R6108; R7002; R7003; R7010; R9702
R0402RESISTOR_R0402_1K1KIC4R2012; R2014; R7004; R9704
R0402RESISTOR_R0402_220K220KIC3R2015; R2017; R6109
R0402RESISTOR_R0402_470K470KIC1R2016
R0402RESISTOR_R0402_100R100RIC6R2018; R2105; R2111; R7001; R7008; R9201
R0402RESISTOR_R0402_68K68KIC3R2113; R6111; R6114
R0402RESISTOR_R0402_120K120KIC1R2116
R0402RESISTOR_R0402_18K18KIC1R2503
R0402RESISTOR_R0402_240R240RIC2R3505; R3506
R0402RESISTOR_R0402_49.9R49.9RIC2R3509; R3511
R0402RESISTOR_R0402_13K13KIC1R3510
R0402RESISTOR_R0402_4.7K4.7KIC2R4000; R4003
R0402RESISTOR_R0402_10R10RIC1R4103
R0402RESISTOR_R0402_180K180KIC3R6113; R6115; R6117
R0402RESISTOR_R0402_150K150KIC1R6116
R0402RESISTOR_R0402_3.3K3.3KIC1R9203
R0402RESISTOR_R0402_6.8K6.8KIC1R9204
R0402RESISTOR_R0402_15K15KIC1R9205
R0402RESISTOR_R0402_910K910KIC1R9706
R0603RESISTOR_R0603_0.1R0.1RIC23R1103; R1104; R1105; R1106; R1107; R1112; R1300; R1402; R1403; R1501; R1602; R1704; R1726; R1807; R1815; R2117; R2118; R2119; R2120; R3512; R6119; R6120; R9603
R0603RESISTOR_R0603_1R1RIC4R1401; R1601; R1702; R1703
R0603RESISTOR_R0603_0.05R0.05RIC9R2100; R2101; R2104; R2106; R2107; R2110; R2112; R2114; R2115
R0603RESISTOR_R0603_2.2R2.2RIC2R2500; R2501
R0805RESISTOR_R0805_0.02R0.02RIC4R2102; R2103; R2108; R2109
R0805RESISTOR_R0805_0.01R0.01RIC2R2121; R2124
R1210RESISTOR_R1210_2R2RIC1R2002
RADIATOR_38R00X38R00X10R00CON2_2_RADIATOR_38R00X38R00X10RRadiatorIC1J9900
RP4_0408RESISTOR 4PACK_RP4_0408_2.2K2.2KIC6R9700; R9701; R9705; R9707; R9710; R9711
SMTSO_M2_C3R6_C6R0_L5R0SMTSO_SMTSO_M2_C3R6_C6R0_L5R0_SSMTSO2050CTJIC2SMTSO9000; SMTSO9001
SMTSO_M3_C4R1_C6R0_L10R0SMTSO_SMTSO_M3_C4R1_C6R0_L10R0_SMTSO30100CTJIC7SMTSO9002; SMTSO9003; SMTSO9004; SMTSO9005; SMTSO9006; SMTSO9007; SMTSO9008
SOD_323DIODE_SOD_323_B5819WSB5819WSIC3D2001; D9700; D9701
SOP8_6R20X5R00X1R75EEPROM_AT24C16_SOP8_6R20X5R00X1AT24C64N-10SI-2.7IC1U9700
SOT_23NPN_SOT_23_S8050S8050IC1Q2003
SOT_23MOSFET P_SOT_23_WPM2341-3/TRWPM2341-3/TRIC1Q7000
SOT_23ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FIC2U2500; U9601
SOT_23_5LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-33IC2U9702; U9815
SOT_23_6DCDC_SY8113_SOT_23_6_SY8113BSY8113BIC2U2000; U2001
SOT_323MOSFET N_SOT_323_2SK30182SK3018IC2Q6100; Q6101
SSOP28_10R20X5R30X2R00INTERFACE_FT232RL_SSOP28_10R20XFT232RLIC1U9600
SW3_KCD1-11-3P-WBR-11C-11P6KCD1-11-3P-WIC1S2000
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_RESRESETIC1SW2100
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_POWPOWERIC1SW2101
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_MASMaskromIC1SW4100
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_VOLVOL+/RECOVERYIC1SW9200
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_V_1VOL-IC1SW9201
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_HOMHOMEIC1SW9202
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_MENMENUIC1SW9203
SW5_6R20X6R20X2R50KEY_5PIN_SW5_6R20X6R20X2R50_ESCESCIC1SW9204
TF9_CKT01_009DTFCARD_SOCKET_TF9_CKT01_009D_TFTF-CKT01-009DIC1J9100
TP_0R70TP_TP_0R70_TP_0.7TP_0.7IC76TP1500; TP1600; TP1601; TP2100; TP2101; TP4600; TP4601; TP4602; TP4603; TP4604; TP4605; TP4606; TP4607; TP4608; TP4609; TP4610; TP4611; TP4612; TP4613; TP4614; TP4615; TP4616; TP4617; TP4618; TP4619; TP4700; TP4701; TP4702; TP4703; TP4704; TP4705; TP4706; TP4707; TP4708; TP4709; TP4710; TP4711; TP4712; TP4713; TP4714; TP4715; TP4716; TP4717; TP4718; TP4719; TP5100; TP5101; TP5102; TP5103; TP5104; TP5105; TP5106; TP5107; TP5108; TP5109; TP5110; TP5111; TP5112; TP5113; TP5114; TP5115; TP5116; TP5117; TP6100; TP6101; TP6102; TP6103; TP6104; TP9100; TP9101; TP9102; TP9103; TP9104; TP9105; TP9106; TP9300
TSOP48_18R40X12R10X1R20NANDFLASH_TSOP48_TSOP48_18R40X1H27UBG8T2DTR-BCIC1U4000
USB20MICRO5_MU05_10MGF_TUSB20_MICRO_USB20MICRO5_MU05_10USB20_microIC1J2500
USB20MIN5_USB_M5_03_002USB20_MINI_USB20MIN5_USB_M5_03_USB20_miniIC2J9600; J9700
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
! N6 P( g* [  q4 K4 e+ l
8 r3 N0 P1 |. B& \7 Q4 I
GMT+8, 2025-7-20 20:29 , Processed in 0.156250 second(s), 28 queries , Gzip On.
