查看: 1293|回复: 7
[allegro16.5][6层]Jetson_TX1_TX2_硬件开发资料(FMC+SATA+网口)pcb文件
发表于 2019-12-26 15:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 `  h0 Y# D7 @- A  p8 h( Q" F" a6 T. @2 R+ P4 T" t# O3 S6 s5 W6 X
: p  v/ N) d. a4 O1 A$ b
文件描述:
* _! r+ p" a* r! Y$ |. O' d" E' s' o( G# l' s$ l! r
1. 作品用途:Jetson_TX1_TX2_硬件开发资料
2. 软件版本:allegro16.5
3. 层数:6层
4. 用到的主要芯片:FMC+SATA+网口* ?3 ]) I4 B3 c, B
; {; M# O  u& z, U9 O+ K1 E  `1 Z! ~5. pcb尺寸:186.18*  170.18 mm
+ S  d/ J8 P0 z4 F6 r# T" A$ W2 M( I
作品截图如下:
1 q* l. u# D, a3 T  `, \) M. p2 N4 D8 O  ~4 S* n# z5 Y5 o" `. {
顶层截图:
* B8 R: Y, A0 ~, `. _1 i5 i3 L# a) \0 H" \
底层截图:
4 e: v# e* l" b2 J# M" q: W% ~8 ^3 M# k8 s: S9 I
, a3 X- C8 B; g# s8 K
; z% u5 q$ c+ P* }! Y6 f( p% F' g
# m  ]# W" p+ t9 S# \. ?5 n  H* L8 R
全层截图:
4 k$ f- ~: ^- B; Q# b! Y: g# S8 L) v0 I" s0 P+ U/ E' E& f
, t2 J+ a* a; ?* L
L1 ^+ r. p+ J: t" b# G5 i% G( f9 Q! B0 {6 ^0 T/ T' e& J- `1 G
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402C_0402-10NF,X7R,10%,25V,036-0019-000-036-0019-000,10NF10nFDISCRETE7C5; C6; C7; C8; C145; C204; C514
402C_0402-0.1UF,X7R,10%,16V,036-0014-000-0.1UF,036-0014-0000.1uFDISCRETE79C10; C11; C12; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C25; C26; C30; C39; C43; C44; C45; C48; C51; C54; C55; C56; C59; C61; C62; C66; C67; C68; C73; C79; C80; C82; C90; C92; C96; C98; C101; C102; C103; C104; C105; C108; C109; C115; C131; C136; C137; C149; C150; C151; C159; C160; C162; C175; C180; C181; C202; C203; C502; C504; C506; C507; C510; C512; C513; C515; C517; C518; C519; C523; C524; C525; C526; C530; C531; C533
402C_0402-1NF,X7R,10%,16V,036-0012-000-036-0012-000,1NF1nFDISCRETE4C29; C35; C46; C50
402C_0402-10NF,X5R,10%,16V,039-0024-000-039-0024-000,10NF10nFDISCRETE1C31
402C_0402-1NF,X5R,10%,16V,039-0023-000-039-0023-000,1NF1nFDISCRETE1C41
402C_0402-10PF,C0G,5%,50V,035-0011-000-035-0011-000,10PF10pFDISCRETE2C58; C60
402C_0402-1UF,X5R,10%,6.3V,039-0008-000-039-0008-000,1UF1uFDISCRETE13C93; C100; C114; C117; C124; C128; C135; C140; C141; C146; C155; C157; C535
402C_0402-150PF,C0G,5%,50V,035-0018-000-035-0018-000,150PF150pFDISCRETE3C97; C133; C161
402C_0402-100PF,C0G,5%,50V,035-0012-000-035-0012-000,100PF100pFDISCRETE2C134; C205
402C_0402-0.1UF,X5R,10%,6.3V,039-0007-000-0.1UF,039-0007-0000.1uFDISCRETE2C505; C516
402C_0402-4.7PF,C0G,0.25PF,50V,035-0031-000-035-0031-000,4.7PF4.7pFDISCRETE2C520; C521
402C_0402-12PF,C0G,5%,50V,035-0014-000-035-0014-000,12PF12pFDISCRETE4C522; C527; C528; C532
402R_0402-49.9K,1 %,62.5MW,195-0340-000-195-0340-000,49.9K49.9kDISCRETE1R1
402R_0402-10OHM,5 %,62.5MW,195-0483-000-10OHM,195-0483-00010ohmDISCRETE1R2
402R_0402-10K,5 %,62.5MW,195-0486-000-10K,195-0486-00010kDISCRETE44R3; R15; R16; R38; R43; R48; R92; R93; R96; R98; R117; R118; R148; R149; R155; R156; R157; R158; R172; R232; R233; R234; R236; R239; R240; R241; R246; R247; R248; R249; R254; R255; R259; R260; R273; R501; R504; R506; R509; R513; R522; R559; R570; R573
402R_0402-0OHM,0.05 OHM,62.5MW,195-2655-000-0OHM,195-2655-0000ohmDISCRETE148R6; R12; R14; R17; R18; R20; R21; R23; R24; R25; R26; R28; R30; R31; R32; R33; R34; R35; R40; R41; R42; R45; R52; R56; R59; R66; R67; R68; R69; R71; R73; R74; R76; R79; R80; R81; R82; R84; R85; R86; R87; R89; R90; R91; R95; R100; R102; R103; R106; R107; R108; R109; R110; R111; R120; R122; R135; R142; R143; R145; R147; R150; R152; R165; R167; R168; R169; R173; R175; R176; R178; R181; R182; R186; R187; R189; R191; R192; R194; R197; R198; R202; R206; R207; R209; R218; R220; R222; R223; R224; R226; R229; R230; R231; R238; R253; R268; R269; R270; R304; R310; R311; R312; R313; R316; R317; R318; R319; R322; R342; R343; R348; R507; R508; R510; R511; R517; R518; R519; R526; R527; R528; R529; R530; R531; R532; R537; R539; R540; R541; R542; R545; R547; R551; R552; R553; R554; R555; R556; R557; R558; R560; R564; R569; R572; R585; R592; R593
402R_0402-100K,1 %,62.5MW,195-0005-000-100K,195-0005-000100kDISCRETE30R7; R49; R51; R62; R63; R78; R83; R94; R105; R112; R113; R114; R121; R127; R128; R132; R174; R177; R188; R190; R237; R272; R301; R314; R315; R324; R325; R544; R578; R580
402R_0402-681OHM,1 %,62.5MW,195-0403-000-195-0403-000,681OHM681ohmDISCRETE2R10; R44
402R_0402-75K,5 %,62.5MW,195-0634-000-195-0634-000,75K75kDISCRETE5R11; R37; R129; R514; R535
402R_0402-4.7K,5 %,62.5MW,195-0598-000-195-0598-000,4.7K4.7kDISCRETE6R13; R115; R131; R323; R548; R549
402R_0402-47K,5 %,62.5MW,195-0599-000-195-0599-000,47K47kDISCRETE37R19; R22; R27; R29; R36; R39; R77; R116; R144; R164; R196; R200; R205; R215; R228; R235; R242; R244; R257; R261; R262; R263; R266; R267; R271; R274; R306; R320; R503; R516; R520; R521; R523; R525; R543; R546; R591
402R_0402-20OHM,5 %,62.5MW,195-0533-000-195-0533-000,20OHM20ohmDISCRETE1R50
402R_0402-2.21K,1 %,62.5MW,195-0169-000-195-0169-000,2.21K2.21kDISCRETE1R53
402R_0402-16.2K,1 %,62.5MW,195-0105-000-16.2K,195-0105-00016.2kDISCRETE1R54
402R_0402-5.9K,1 %,62.5MW,195-0374-000-195-0374-000,5.9K5.9kDISCRETE1R55
402R_0402-330OHM,5 %,62.5MW,195-0569-000-195-0569-000,330OHM330ohmDISCRETE5R60; R101; R104; R146; R154
402R_0402-0OHM,0.01 OHM,0.125W,195-1691-000-0OHM,195-1691-0000ohmDISCRETE4R61; R97; R137; R305
402R_0402-20K,1 %,62.5MW,195-0150-000-195-0150-000,20K20kDISCRETE3R70; R119; R204
402R_0402-1M,5 %,62.5MW,195-0488-000-195-0488-000,1M1MDISCRETE27R72; R99; R136; R203; R252; R321; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R339; R340; R341; R344; R345; R346; R502; R505; R3238
402R_0402-10M,5 %,62.5MW,195-0489-000-10M,195-0489-00010MDISCRETE1R88
402R_0402-25.5K,1 %,62.5MW,195-0200-000-195-0200-000,25.5K25.5kDISCRETE1R123
402R_0402-10OHM,1 %,62.5MW,195-0001-000-10OHM,195-0001-00010ohmDISCRETE20R124; R139; R140; R153; R160; R170; R171; R179; R180; R199; R201; R208; R210; R213; R214; R589; R590; R594; R595; R596
402R_0402-1.8K,5 %,62.5MW,195-0528-000-1.8K,195-0528-0001.8kDISCRETE6R125; R349; R524; R538; R561; R574
402R_0402-680K,5 %,62.5MW,195-0628-000-195-0628-000,680K680kDISCRETE6R141; R151; R163; R185; R195; R211
402R_0402-1K,5 %,62.5MW,195-0485-000-195-0485-000,1K1kDISCRETE3R161; R217; R250
402R_0402-71.5K,1 %,62.5MW,195-0415-000-195-0415-000,71.5K71.5kDISCRETE1R162
402R_0402-21.5K,1 %,62.5MW,195-0165-000-195-0165-000,21.5K21.5kDISCRETE1R166
402R_0402-24.3K,1 %,62.5MW,195-0190-000-195-0190-000,24.3K24.3kDISCRETE1R212
402R_0402-100OHM,5 %,62.5MW,195-0484-000-100OHM,195-0484-000100ohmDISCRETE3R216; R227; R300
402R_0402-61.9K,1 %,62.5MW,195-0385-000-195-0385-000,61.9K61.9kDISCRETE1R219
402R_0402-121K,1 %,62.5MW,195-0046-000-121K,195-0046-000121kDISCRETE1R251
402R_0402-22.1K,1 %,62.5MW,195-0170-000-195-0170-000,22.1K22.1kDISCRETE1R256
402R_0402-27.4K,1 %,62.5MW,195-0215-000-195-0215-000,27.4K27.4kDISCRETE1R302
402R_0402-10K,1 %,62.5MW,195-0004-000-10K,195-0004-00010kDISCRETE1R303
402R_0402-121OHM,1 %,62.5MW,195-0043-000-121OHM,195-0043-000121ohmDISCRETE1R307
402R_0402-1OHM,5 %,62.5MW,195-0482-000-195-0482-000,1OHM1ohmDISCRETE2R515; R536
402R_0402-200K,5 %,62.5MW,195-0537-000-195-0537-000,200K200kDISCRETE1R534
402R_0402-88.7K,1 %,62.5MW,195-0460-000-195-0460-000,88.7K88.7kDISCRETE1R550
402R_0402-499OHM,1 %,62.5MW,195-0338-000-195-0338-000,499OHM499ohmDISCRETE8R562; R566; R567; R575; R576; R581; R582; R586
402R_0402-3.3OHM,5 %,62.5MW,195-0567-000-195-0567-000,3.3OHM3.3ohmDISCRETE2R563; R565
402R_0402-5.6OHM,5 %,62.5MW,195-0609-000-195-0609-000,5.6OHM5.6ohmDISCRETE6R568; R571; R577; R579; R583; R584
402R_0402-32.4K,1 %,62.5MW,195-0250-000-195-0250-000,32.4K32.4kDISCRETE1R587
402R_0402-162K,1 %,62.5MW,195-0106-000-162K,195-0106-000162kDISCRETE1R588
402R_0402-75OHM,5 %,62.5MW,195-0631-000-195-0631-000,75OHM75ohmDISCRETE4R597; R598; R599; R600
0402_LARGEC_0402W-4.7UF,X5R,20%,4V,039-0145-000-039-0145-000,4.7UF4.7uFDISCRETE6C78; C89; C99; C110; C118; C132
0402_LARGEC_0402W-4.7UF,X5R,20%,6.3V,039-0188-000-039-0188-000,4.7UF4.7uFDISCRETE10C83; C84; C87; C91; C94; C95; C111; C112; C116; C123
603C_0603-0.1UF,X7R,10%,50V,036-0050-000-0.1UF,036-0050-0000.1uFDISCRETE5C3; C9; C32; C37; C167
603C_0603-10NF,X7R,10%,25V,036-0042-000-036-0042-000,10NF10nFDISCRETE3C28; C36; C65
603C_0603-1UF,X5R,10%,50V,039-0222-000-039-0222-000,1UF1uFDISCRETE11C38; C42; C49; C88; C106; C107; C119; C163; C164; C170; C529
603C_0603-100PF,C0G,5%,50V,035-0040-000-035-0040-000,100PF100pFDISCRETE1C47
603C_0603-10UF,X5R,20%,6.3V,039-0135-000-039-0135-000,10UF10uFDISCRETE4C74; C509; C511; C534
603C_0603-4.7UF,X5R,10%,6.3V,039-0037-000-039-0037-000,4.7UF4.7uFDISCRETE5C81; C120; C127; C152; C171
603C_0603-470PF,C0G,5%,50V,035-0056-000-035-0056-000,470PF470pFDISCRETE1C122
603C_0603-0.1UF,X7R,10%,25V,036-0043-000-0.1UF,036-0043-0000.1uFDISCRETE1C174
603C_0603-680PF,C0G,5%,50V,035-0060-000-035-0060-000,680PF680pFDISCRETE2C503; C508
603R_0603-0OHM,0.05 OHM,0.1W,195-2656-000-0OHM,195-2656-0000ohmDISCRETE9R8; R46; R47; R126; R130; R134; R183; R184; R221
603R_0603-47OHM,5 %,0.1W,195-1246-000-195-1246-000,47OHM47ohmDISCRETE2R57; R65
603R_0603-100OHM,5 %,0.1W,195-1134-000-100OHM,195-1134-000100ohmDISCRETE2R64; R308
603R_0603-36OHM,5 %,0.1W,195-1225-000-195-1225-000,36OHM36ohmDISCRETE1R75
603R_0603-10OHM,1 %,0.1W,195-0651-000-10OHM,195-0651-00010ohmDISCRETE2R159; R243
603R_0603-470OHM,5 %,0.1W,195-1247-000-195-1247-000,470OHM470ohmDISCRETE2R309; R347
603R_0603-3.3OHM,5 %,0.1W,195-1217-000-195-1217-000,3.3OHM3.3ohmDISCRETE2R512; R533
0603_LARGEC_0603W-10UF,X5R,20%,25V,032-0421-000-032-0421-000,10UF10uFDISCRETE4C2; C64; C166; C168
0603_LARGEC_0603W-10UF,X5R,20%,25V,032-0186-000-032-0186-000,10UF10uFDISCRETE6C52; C53; C75; C177; C178; C179
0603_LARGEC_0603W-22UF,X5R,20%,6.3V,039-0223-000-039-0223-000,22UF22uFDISCRETE2C138; C139
0603_LARGEC_0603W-4.7UF,X5R,10%,35V,032-0193-000-032-0193-000,4.7UF4.7uFDISCRETE1C201
805C_0805LP-22UF,X5R,20%,16V,032-0195-000-032-0195-000,22UF22uFDISCRETE5C69; C70; C71; C148; C154
805C_0805-22UF,X5R,20%,35V,032-0213-000-032-0213-000,22UF22uFDISCRETE1C77
805C_0805-4.7UF,X7R,10%,10V,036-0128-000-036-0128-000,4.7UF4.7uFDISCRETE1C147
805C_0805-1UF,X7R,10%,25V,036-0117-000-036-0117-000,1UF1uFDISCRETE1C153
805C_0805-0.47UF,X7R,10%,50V,036-0129-000-0.47UF,036-0129-0000.47uFDISCRETE1C176
805C_0805-4.7UF,X5R,10%,25V,039-0205-000-039-0205-000,4.7UF4.7uFDISCRETE1C501
1206C_1206-22UF,X5R,10%,25V,039-0213-000-039-0213-000,22UF22uFDISCRETE3C1; C13; C165
1206C_1206-22UF,X5R,10%,16V,039-0158-000-039-0158-000,22UF22uFDISCRETE2C33; C34
1206C_1206-100UF,X5R,20%,6.3V,039-0148-000-039-0148-000,100UF100uFDISCRETE7C113; C121; C156; C158; C536; C537; C538
1206C_1206-4.7UF,X5R,10%,25V,039-0093-000-039-0093-000,4.7UF4.7uFDISCRETE2C129; C130
1206R_1206-0OHM,0.05 OHM,0.25W,195-1635-000-0OHM,195-1635-0000ohmDISCRETE5F1; F2; F3; F4; F5
1206R_1206-0OHM,0.005 OHM,0.5W,195-1768-000-0OHM,195-1768-0000ohmDISCRETE1R264
1206R_SENSE_1206-0.007OHM,1%,0.5W,[ ],215-0064-000-0.007OHM,215-0064-0000.007ohmDISCRETE1RS1
4520MMC_1808-1NF,X7R,10%,2000V,032-0166-000-032-0166-000,1NF1nFDISCRETE1C27
BGA_0004_P040_008X008U_SW_LOAD_BGA04-TPS22915BYFPR,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1834-000-115-1834-000IC5U17; U19; U20; U24; U26
BGA_0010_P050_013X020_MARK_A3U_SW_ANA_SPDT_BGA10-TS5A22362YZPR,SWITCH - ANALOG,115-1461-000-115-1461-000IC1U8
CAP_SMD_048X048C_POL_SMD_D48-80000UF,SUPERCAP,-1%,3.3V@60DEGC,100OHM,[ ],[ ]@105DEGC,[ ],060-0002-000-060-0002-000,80000UF80000uFDISCRETE1C72
CAP_SMD_066X066C_POL_SMD_D60-330UF,AL-POLYMER,20%,6.3V@105DEGC,0.01OHM,[ ],3.9A@105DEGC,100KHZ,042-0138-000-042-0138-000,330UF330uFDISCRETE1C40
CAP_SMD_066X066C_POL_SMD_D60-56UF,ALE,20%,25V@105DEGC,0.03OHM,9.999UH,2.8A@105DEGC,100KHZ,032-0240-000-032-0240-000,56UF56uFDISCRETE6C125; C126; C169; C172; C173; C200
CAP_SMD_3528C_POL_SMD_3528-33UF,TA-POLYMER,20%,16V@105DEGC,0.045OHM,0PH,1.291A@-3.1DEGC,[ ],032-0468-000-032-0468-000,33UF33uFDISCRETE1C57
CAP_SMD_3528C_POL_SMD_3528-220UF,TA-POLYMER,20%,6.3V@105DEGC,0.045OHM,[ ],1.7A@45DEGC,100KHZ,041-0177-000-041-0177-000,220UF220uFDISCRETE7C63; C76; C85; C86; C142; C143; C144
CON_DCPWR_JACK_006_TH_RA_100X130CON_PWR_JACK_CON_6PIN-2DC-G213-B51,FEMALE,4.7MM,90,YES,NO,YES,NO,NO,20V,10A,065-0400-000-065-0400-000IO1J25
CON_FMC_050X008_BGA_ST_M_P013CON_CVM_CVM10_CAR-CON_CVB_1_0,MALE,1.27MM,90,N/A,YES,N/A,NO,NO,240V,1.8A,080-1276-000-080-1276-000IO1J13
CON_FTSH_002X007_SMD_ST_M_P013HDR_2X7_NORM-FTSH-107-01-L-DV-K-P-TR,MALE,1.27MM,0,YES,YES,NO,350.0 V,1.75 A,080-1345-000-080-1345-000IO1J14
CON_HDMI_019_SMD_RA_F_CCON_HDMI_HDMI_A_LONG-CON_HDMI_A-LONG,FEMALE,0.5MM,90,YES,N/A,N/A,YES,YES,N/A,N/A,080-0420-000-080-0420-000IO1J16
CON_HDR_001X002_TH_ST_M_P025HDR_1X2_NORM-HDR_1M2,MALE,2.54MM,0,NO,NO,NO,250V,3A,074-0117-000-074-0117-000IO6J3; J4; J6; J8; J9; J11
CON_HDR_001X003_TH_ST_M_P025_CHDR_1X3_NORM-HDR_1X3,MALE,2.54MM,0,YES,NO,NO,500V,3A,074-0011-000-074-0011-000IO1J24
CON_HDR_001X006_TH_ST_M_P025HDR_1X6_NORM-HDR_1X6,MALE,2.54MM,0,YES,NO,NO,450V,3.0A,074-0050-000-074-0050-000IO1J17
CON_HDR_002X010_TH_ST_M_P025_SHRHDR_2X10_SHR_JTAG1-HDR_2X10,MALE,2.54MM,0,N/A,YES,NO,1000 V,3 A,074-0152-000-074-0152-000IO1J7
CON_HDR_002X015_TH_ST_M_P025HDR_2X15_NORM-HDR_2M15,MALE,2.54MM,0,NO,NO,NO,500V,3A,074-0110-000-074-0110-000IO1J26
CON_MINIPEX_067_SMT_RA_M22199230_4_SMD67_KEYE-2199230_4,FEMALE,0.5MM,90,YES,NO,NO,NO,NO,300.0 V,0.5 A,080-1243-000-080-1243-000IO1J18
CON_MISC_004_TH_ST_M_P013_WTBCON_B2W_1X4_TH-50275-00471-003,MALE,1.25MM,0,YES,YES,NO,NO,N/A,NA,NA,064-0267-000-064-0267-000IO1J15
CON_MISC_010_SMD_RA_F_P008_WTBHDR_1X10_MNT2-50208-01001-001,RECEPTACLE,0.8MM,90,YES,N/A,NO,N/A,N/A,080-0791-000-080-0791-000IO1J27
CON_MJ08_012_TH_RA_2LEDCON_RJ45_TH_RA_SHLD-CON_RJ45_LED,FEMALE,40MIL,90,NO,YES,YES,YES,YES,N/A,N/A,065-0014-000-065-0014-000IO1J5
CON_PEX_064_SMT_STCON_PCI_EXPRESS_PHY-X4-CON_PCIEXP_X4_MB,FEMALE,1MM,0,YES,YES,NO,NO,NO,50V,1.1A,065-0362-000-065-0362-000IO1J2
CON_QSH_060_SMT_ST_P005CON_B2B_60_F_NORM-QSH-030-01-L-D-A-K-TR,FEMALE,0.5MM,0,YES,YES,NO,NO,N/A,125.0 V,1.0 A,080-1344-000-080-1344-000IO1J10
CON_QSH_120_SMT_ST_P005CON_B2B_120_F_NORM-CON_QSH_SMT_2X60_P050,FEMALE,0.5MM,0,YES,YES,NO,NO,NO,NA,NA,080-1346-000-080-1346-000IO2J22; J23
CON_SATA_022_SMT_RA_F_P013CON_SATA_SMT22_2GND-1735284-4,RECEPTACLE,1.27MM,0,YES,YES,NO,NO,NO,NA,NA,080-1347-000-080-1347-000IO1J1
CON_SD_012_SMD_RACON_SD_SOCKET_PUSH_IN_OUT-SD_SOCKET,N/A,N/A,90,YES,N/A,N/A,YES,YES,250VAC,0.5A,220-0030-000-220-0030-000IO1J12
CON_TSM_002X020_SMD_ST_M_P025HDR_2X20_TSM40-TSM-120-01-S-DV-P-TR,MALE,2.54MM,0,YES,NO,NO,NA,NA,080-1348-000-080-1348-000IO1J21
CON_USB_005_SMD_RA_F_074X056CON_USB_MICRO_AB_SMD5-PUBGT0-05FLBS1NN4H0,RECEPTACLE,0.65MM,90,YES,YES,NO,NO,YES,100.0 V,1.8 A,080-1264-000-080-1264-000IO1J20
CON_USB_009_TH_RA_138X165CON_USB3_TYPEA_11PIN-UEA11123-4HK1-4H,FEMALE,2MM,90,YES,NO,YES,NO,YES,5V,0.5A,065-0399-000-065-0399-000IO1J19
DFET_003_SMD_010X006_BQ_FET_N_ENH_DFN1006-DMN26D0UFB4,20V,999MOHM@10V / 3000MOHM@4.5V / 4000MOHM@2.5V,0.14A,0.805A,10V,0.35W,999NC@10V / 999NC@4.5V BDISCRETE1Q505
DFET_003_SMD_010X006_BQ_NPN_DFN1006-MMBT3904LP-7,40V,0.3V,0.2A,9999A,6V,0.25W,300-0869-000-300-0869-000DISCRETE1Q507
DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-MDV3604URH,-30V,-1000MOHM@10V / -1000MOHM@4.5V / -1000MOHM@2.5V,-12.6A,-32A,25V,3.4W,[ ]@10V / [ ]@4.5V / [BDISCRETE3Q1; Q3; Q30
DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AM7321P,-20V,-1000MOHM@10V / 14MOHM@4.5V / 19MOHM@2.5V,-13A,-50A,8V,3.5W,[ ]@10V / [ ]@4.5V / [ ]@2.5V,300-BDISCRETE1Q19
DFET_SMD_056X052_VIASQ_FET_N_ENH_WPAK_DUAL_COPAD-SIZ918DT-T1-GE3,30V / 30V,12MOHM,3.7MOHM@10V / 14.5MOHM,4.5MOHM@4.5V / -1000MOHM,-1000MOHM@2.5V,14BDISCRETE2Q23; Q29
DFN04_P065_010X010_T005X005U_VREG_RP114X_DFN-TLV73312PDQNR,LOW DROP OUT/FIXED,0.45V@0.3A,1.2V..1.2V,1.4%,0MV,5.5V,0.3A,0.4W,315-0934-000-0MV,315-0934-0000mVIC2U13; U27
DFN06_P050_015X010_CU_BUF_FXLP34_SC70_34L6-SN74AUP1T34DRYR,TRANSLATOR,115-1283-000-115-1283-000IC1U15
DFN06_P065_020X020_T016X010_CPOWER_SW2_SON7_R-RT9728AHGQW,POWER SWITCH,115-1581-000-115-1581-000IC1U502
DFN08_P050_030X020_T016X016U_MEM_EE_I2C_DFN08-1MHZ,1.7V..3.6V,AT24C02D-MAHM-T,174-0159-000-174-0159-000IC1U11
DFN10_P050_030X030_T027X018_VIASU_OPENVREG_TYPE0_DFN10-APW8805,BUCK,1PH,1MHZ,NONE,0.6V..6V,1%,0.8V,6V,3A,1.429W,315-0832-000-0.8V,315-0832-0000.8VIC1U9
DIODE_SMD_010X060D_ESD_NORM-AOZ8231ADI-12,1 LINE,BI-DIRECTIONAL,12V,0.1UA,13V,20V@1A,14PF,090-0150-000-090-0150-000DISCRETE1D17
DIODE_SMD_025X013D_ESD_MICROSMP-MSP5.0A-M3/89A,1 LINE,UNI-DIRECTIONAL,5V,100UA,6.4V,9.2V@16.3A,9.999NF,090-0233-000-090-0233-000DISCRETE1D11
DIODE_SMD_SOD523_BD_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000DISCRETE3D12; D16; D31
DIODE_SMD_SOD923D_ESD_SOD923-ESD9X5.0ST5G,1 LINE,UNI-DIRECTIONAL,5V,1UA,6.2V,12.3V@8.7A,65PF,090-0134-000-090-0134-000DISCRETE11D2; D3; D4; D6; D14; D15; D19; D20; D21; D27; D30
DIODE_SMD_SOD923D_ESD_SOD923-ESD7951ST5G,1 LINE,BI-DIRECTIONAL,5V,1UA,5.4V,12.9V@1A,0.9PF,091-0074-000-091-0074-000DISCRETE4D28; D29; D32; D33
DIODE_SMD_TO277AD_SCHOTTKY_3PIN_AA_SMPC-TO277A,1 PAIR - COMMON CATHODE,100V,150A,0.88V@5A,5A,090-0043-000-090-0043-000DISCRETE1D1
IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[ ],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmDISCRETE6L1; L3; L4; L5; L10; L13
IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-12OHM,[ ],[ ],0.1A,0.7OHM,[ ],102-0015-000-102-0015-000,12OHM12ohmDISCRETE4L501; L503; L504; L506
IND_NONRKO_SMD_012X010_BL_CMF_4P_SMDB_012X010-80OHM,FERRITE,25%,0.1A,1.5OHM,DLP11TB800UL2,102-0023-000-102-0023-000,80OHM80ohmDISCRETE2L11; L12
IND_NONRKO_SMD_044X041L_SMD_045_041-1UH,[ ],20%,5A,8.5A,0.027OHM,[ ]@[ ],[ ],[ ],131-0832-000-131-0832-000,1UH1uHDISCRETE1L6
IND_NONRKO_SMD_065X069L_SMD_6X6-2.2UH,[ ],20%,8A,16A,0.0136OHM,[ ]@[ ],[ ],[ ],131-0352-000-131-0352-000,2.2UH2.2uHDISCRETE1L8
IND_NONRKO_SMD_073X066L_SMD_073X066-1UH,CARBONYL POWDER,20%,11A,22A,0.01OHM,[ ]@[ ],[ ],[ ],130-0776-000-130-0776-000,1UH1uHDISCRETE2L7; L16
IND_NONRKO_SMD_076X076L_7_6X7_6-2.2UH,ALLOY CORE,20%,10A,10A,0.0132OHM,[ ]@[ ],[ ],0DECIBEL,130-0436-000-130-0436-000,2.2UH2.2uHDISCRETE1L2
IND_NONRKO_SMD_078X072L_SMD_8X7-2.2UH,[ ],20%,6A,8A,0.018OHM,[ ]@[ ],[ ],[ ],131-0604-000-131-0604-000,2.2UH2.2uHDISCRETE1L9
IND_NONRKO_SMD_088X084L_SMD_9X8-1UH,[ ],20%,13A,15A,0.0043OHM,[ ]@[ ],[ ],[ ],131-0653-000-131-0653-000,1UH1uHDISCRETE1L15
IND_SMD_0402L_0402-1NH,[ ],30%,[ ],0.3A,0.12OHM,8@-1MHZ,10GHZ,[ ],130-0074-000-130-0074-000,1NH1nHDISCRETE2L502; L505
IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[ ],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmDISCRETE8LB1; LB2; LB3; LB4; LB5; LB6; LB7; LB8
IND_SMD_0402L_BEAD_0402-30OHM,FERRITE,25%,[ ],2A,0.1OHM,[ ],N/A,N/A,100-0165-000-100-0165-000,30OHM30ohmDISCRETE1LB9
IND_SMD_0603L_BEAD_0603-220OHM,FERRITE,25%,[ ],2.5A,0.05OHM,[ ],N/A,N/A,100-0160-000-100-0160-000,220OHM220ohmDISCRETE2LB10; LB11
IND_SMD_0603L_BEAD_0603-30OHM,FERRITE,33.33%,[ ],5A,0.01OHM,[ ],N/A,N/A,100-0026-000-100-0026-000,30OHM30ohmDISCRETE7LB12; LB13; LB14; LB15; LB16; LB17; LB18
LED_SMD_0402_STLED_0402-LTST-C281KRKT-5A,5V,80MA,2.3V,30MA,RED,092-0090-000-092-0090-000DISCRETE2CR5; CR6
LED_SMD_0603_STLED_0603-LED_SMD_0603,5V,60MA,2.35V,25MA,GREEN,092-0073-000-092-0073-000DISCRETE4CR1; CR2; CR3; CR4
LTPT28C49PLABTESTPOINT_B28-LABTESTPOINTIO30TP7; TP8; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP501; TP502; TP503; TP504
LTPT35C49PLABTESTPOINT_PIN-LABTESTPOINTIO6TP2; TP3; TP4; TP5; TP6; TP9
MEC_HOLE_PEM_NTH_430PMEC_STANDOFF2_SMD-STANDOFF_M3.0X3.0MM,320-0965-000-320-0965-000IO1MEC10
MEC_HOLE_PTH_599C_INT422C_B701C320PMOUNTING_HOLE_X1-P1963_MOUNTING_HOLE_3.2IO4MEC3; MEC4; MEC5; MEC6
MEC_HOLE_PTH_599C_INT422C_B701C320PMOUNTING_HOLE_X1-MECH_MOD_HOLESIO7MEC7; MEC8; MEC9; MEC11; MEC12; MEC15; MEC16
MTH_MB_C300NP156_NEWMOUNTING_HOLE_BRDMNT-MB_MOUNTING_HOLEIO4MEC1; MEC2; MEC13; MEC14
MULTI_CAP_TH_D080P035_D100P050C_POL_COMBI_TH_D80_D100-330UF,AL-POLYMER,20%,16V@105DEGC,0.007OHM,[ ],6.1A@105DEGC,100KHZ,041-0065-000-041-0065-000,330UF330uFDISCRETE2C4; C24
MULTI_SMD_SOT669_LFPAK_BQ_FET_N_ENH_LFPAK-CSD17506Q5A,30V,4.1MOHM@10V / 5.4MOHM@4.5V / -1000MOHM@2.5V,24A,155A,20V,3.2W,[ ]@10V / [ ]@4.5V / [ ]@2.5V,BDISCRETE1Q4
QFN008Q_P050_0016X0016U_I2C_PCA9306_QFN8-PCA9306AMUTCG,LEVEL SHIFTER,115-0785-000-115-0785-000IC1U501
QFN016Q_P065_0047_T022X022U_PWRMTR_INA3221_QFN16-INA3221AIRGVR,-9999V..9999V,-9999V..9999V,9999A,MONITOR,115-1066-000-115-1066-000IC2U10; U18
QFN020R_P050_0045X0035_T031X021_VIASU_LEVSHFT_TXB0108_QFN20-TXB0108RGYR,LEVEL SHIFTER,115-1921-000-115-1921-000IC2U7; U22
RES_04_SMD_015X032R_SENSE_4PIN_R_SENSE_4PIN-0.01OHM,1%,1W,[ ],215-0142-000-0.01OHM,215-0142-0000.01ohmDISCRETE4R58; R133; R138; R193
RES_04_SMD_015X032R_SENSE_4PIN_R_SENSE_4PIN-0.005OHM,1%,1W,[ ],215-0164-000-0.005OHM,215-0164-0000.005ohmDISCRETE1R225
RES_04_SMD_32X016_BR_SENSE_4PIN_R_SENSE_4PIN-0.02OHM,1%,1W,[ ],215-0168-000-0.02OHM,215-0168-0000.02ohmDISCRETE1R265
SC70_5U_BUF_OD_SC70_5-74LVC1G07GW/SN74LVC1G07DCKRE4,BUFFER - OPEN DRAIN,115-0138-000-115-0138-000IC1U1
SC70_6Q_FET_N_ENH_SOT363-NTJD4001N,30V,1500MOHM@10V / 1500MOHM@4.5V / 1500MOHM@2.5V,0.25A,0.25A,20V,0.272W,[ ]@10V / [ ]@4.5V / [ ]@BDISCRETE1Q506
SC70_6U_BUF_OD_SC70_6-NC7WZ07,BUFFER - OPEN DRAIN,115-1012-000-115-1012-000IC2U2; U3
SO08_048X038_T030X026U_VREG_APL5910_SOP8-APL5932AKAI,ULTRA LOW DROP OUT,0.23V@3A,[ ]..5.5V,1.5%,[ ],6V,3A,2W,315-0808-000-315-0808-000,[ ][ ]IC1U23
SOT23D_3PIN_AA_SOT23-BAT54ALT1,1 PAIR - COMMON ANODE,30V,0.6A,0.8V@0.1A,0.2A,091-0004-000-091-0004-000DISCRETE1D7
SOT23D_ZENER_SOT23-BZX84C24LT1G,25.6V,[ ],0.9V@10MA,[ ],090-0178-000-090-0178-000DISCRETE1D13
SOT23Q_FET_N_ENH_SOT23_1G1D1S-FDV301N,25V,-1000MOHM@10V / 4000MOHM@4.5V / -1000MOHM@2.5V,0.22A,0.5A,8V,0.35W,[ ]@10V / [ ]@4.5V / [BDISCRETE19Q2; Q5; Q7; Q10; Q15; Q16; Q21; Q22; Q24; Q25; Q26; Q27; Q28; Q33; Q37; Q39; Q503; Q504; Q508
SOT23Q_FET_N_ENH_SOT23_1G1D1S-NTR4003NT1G,30V,-1000MOHM@10V / 1500MOHM@4.5V / -1000MOHM@2.5V,[ ],1.7A,20V,0.83W,[ ]@10V / [ ]@4.5V BDISCRETE7Q6; Q8; Q9; Q11; Q12; Q34; Q35
SOT23Q_PNP_SOT23_1B1C1E-MMBT4403,40V,[ ],0.6A,0.6A,5V,0.225W,305-0002-000-305-0002-000DISCRETE1Q14
SOT23Q_NPN_SOT23_1B1C1E-MMBT2222ALT1,40V,[ ],0.6A,[ ],6V,0.3W,305-0008-000-305-0008-000DISCRETE2Q18; Q32
SOT23Q_FET_P_ENH_SOT23_1G1D1S-SI2305CDS,-8V,35MOHM@10V / 35MOHM@4.5V / 35MOHM@2.5V,-5.8A,-10A,8V,1.7W,[ ]@10V / [ ]@4.5V / [ ]@2.5VBDISCRETE1Q20
SOT23_5U_POWER_SW_SOT23_5B-APL3511CBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-0836-000-115-0836-000IC2U21; U25
SOT23_5U_POWER_SW_SOT23_5C-APL3511DBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1238-000-115-1238-000IC1U503
SOT23_6D_ESD_DIFFPAIR_SOT23_6-AZC199-04S,2 DIFFPAIR,UNI-DIRECTIONAL,5V,1UA,6V,11V@6A,1.7PF,091-0053-000-091-0053-000IO3D503; D506; D507
SOT23_6Q_FET_N_ENH_SOT23_6D_1G1D1S-AO6800,30V,-1000MOHM@10V / 75MOHM@4.5V / 115MOHM@2.5V,3.4A,20A,12V,1.15W,[ ]@10V / [ ]@4.5V / [ ]@BDISCRETE3Q17; Q38; Q501
SOT23_6U_RST_TPS3808_SOT23-6-TPS3808G01DBVR,RESET,115-2045-000-115-2045-000IC1U32
SOT323D_3PIN_CC_SOT323-BAS70W-05,1 PAIR - COMMON CATHODE,70V,0.1A,1V@0.1A,70MA,091-0023-000A-091-0023-000DISCRETE1CR501
SOT323D_3PIN_CC_SOT323-BAT54CW,1 PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0022-000A-091-0022-000DISCRETE2D5; D18
SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V / 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VBDISCRETE6Q13; Q31; Q36; Q40; Q502; Q509
SOT553D_ESD_SOT553-NZQA6V8AXV5T1G,4 LINE,UNI-DIRECTIONAL,4.3V,1UA,6.47V,13V@1.6A,9.5PF,091-0083-000-091-0083-000IC6D22; D23; D24; D25; D26; D34
SW_04_SMD_ST_1XONOFF_072X040SW_SPST_PB_SMD_4-DTSMW67N,N/A,N/A,0,YES,N/A,N/A,12V,50MA,280-0060-000-280-0060-000IO4S1; S2; S3; S4
TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-AZ1045-04F,2 DIFFPAIR,UNI-DIRECTIONAL,5V,1.5UA,6V,12V@3.5A,0.65PF,091-0054-000-091-0054-000IO4D8; D10; D501; D502
TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E05U06,2 DIFFPAIR,UNI-DIRECTIONAL,5.5V,10UA,6V,10V@1A,0.5PF,090-0231-000-090-0231-000IO3D9; D504; D505
XFMR_SMD_24_151X071TR_ENET_MAGCOM_SOP24-M3295NL,1:1,1500V(RMS),0HZ..100MHZ,50OHM..50OHM,295-0036-000-1:1,295-0036-000
1:01
DISCRETE1T1
XSOP08_P065_030X028U_LEVSHFT_3STATE_SSOP8-SN74LVC2T45,LEVEL SHIFTER,115-0340-000-115-0340-000IC4U5; U6; U12; U14
XSOP08_P065_030X030U_I2C_PCA9515A_MSOP8-PCA9515ADP,LEVEL SHIFTER,115-0401-000-115-0401-000IC1U30
XSOP10_P050_030X030U_DCDC_BOOST_LM3481_MSOP10-LM3481MMX/NOPB,SEPIC,1PH,1MHZ,NONE,2.97V..48V,1.5%,1.275V,48V,1A,[ ],315-0763-000-1.275V,315-0763-0A1.275VIC1U4
XSOP10_P050_030X030U_SWREG_TPS53015_XSOP10-TPS53015,BUCK,1PH,500KHZ,NONE,0.77V..7V,1%,0.773V,28V,10A,50W,316-0314-000-0.773V,316-0314-0000.773VIC2U16; U31
XSOP24_P065_079X045U_I2C_EXP_TCA9539_TSOP24-TCA9539PWR,I/O EXPANDER,115-0674-000-115-0674-000IC2U28; U29
XTAL_SMD_4_032X025OSC_4PIN_SMD_32X25-ASHEK-32.768KHZ-L-T,32.768KHZ,25PPM,5PPM,-1PPM,15PF,086-0143-000A-086-0143-000,32.768KHZ32.768KHzDISCRETE1Y501
附件:
原理图和PCB文件如下:
3 Z) r/ \: N. k# w
游客,如果您要查看本帖隐藏内容请回复
, W/ m; Q2 ?5 L5 N
发表于 2021-6-26 02:48 | 只看该作者
thank you so much for sharing the pcb file+ f8 A  n: @9 t. u5 |8 e
发表于 2022-3-7 08:30 | 只看该作者
谢谢分享,
“来自电巢APP”
发表于 2023-7-20 10:07 | 只看该作者
谢谢分享,学习一下
    无聊
    2021-12-20 15:47
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2025-1-4 20:34 | 只看该作者
    谢谢分享,就是东西太贵了% x8 q' {/ t# k. }' L6 o
    0 d) |+ V0 @9 H" f3 R6 T
    发表于 2025-1-6 00:22 | 只看该作者
    感谢楼主的分享,很实用
    GMT+8, 2025-8-18 13:35 , Processed in 0.156250 second(s), 27 queries , Gzip On.
