Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
8P4R_0402 | RESAR_IS_4/SM_8P4R_0402_100K | 100K | IC | 2 | RN1; RN2 |
310_MODULE_V53_SMT | 310_MODULE_V50_13_310_MODULE_V5 | 310_Module_V50 | IC | 1 | U1 |
AN9520 | AN9520_AN9520_AN9520 | AN9520 | IC | 1 | T1 |
BATCON3_PAN25-03756-S103 | BATCON3_GYX_N95_4_BATCON3_PAN25 | PAN25-03756-S103 | IC | 1 | U2 |
BTB24_FIX_040 | OV5642_SZGZK_BTB24_FIX_040_AXK7 | AXK724145+OV5642_SZGZK | IC | 1 | J50 |
C0603 | CAP NP_C0603_0.1UF | 0.1uF | IC | 9 | C4; C23; C30; C32; C33; C35; C38; C39; C40 |
C0603 | CAP NP_C0603_1UF | 1uF | IC | 5 | C5; C20; C21; C90; C91 |
C0603 | CAP NP_C0603_10UF | 10uF | IC | 7 | C19; C29; C34; C47; C64; C65; C67 |
C0603 | CAP NP_C0603_33PF(NC) | 33pF(NC) | IC | 5 | C31; C74; C75; C76; C89 |
C0603 | CAPACITOR NON-POL_0_C0603_0.1UF | 0.1uF | IC | 2 | C48; C93 |
C0603 | CAP NP_C0603_1UF(NC) | 1uF(NC) | IC | 3 | C49; C57; C61 |
C0603 | CAP NP_C0603_0.22UF(NC) | 0.22uF(NC) | IC | 1 | C66 |
C0603 | CAP NP_C0603_33PF | 33pF | IC | 11 | C70; C73; C77; C78; C79; C80; C81; C82; C85; C86; C87 |
C0603 | CAP NP_C0603_0.01UF | 0.01uF | IC | 1 | C88 |
C0805 | CAP NP_C0805_22UF | 22uF | IC | 7 | C7; C50; C51; C52; C53; C54; C92 |
C1206 | RESISTOR_C1206_10 | 10 | IC | 1 | R51 |
CAMSTACK4PIN | CAMSTACK4PIN_0_CAMSTACK4PIN_CAM | CamStack4Pin | IC | 1 | J51 |
CON_MHFIII_20369 | SMA CON_1_CON_MHFIII_20369_MHFI | MHFIII_20369 | IC | 2 | J5; J6 |
CON_SIM_CAF99_06193 | SIM CARD_0_CON_SIM_CAF99_06193_ | CON_SIM_CARD | IC | 1 | J4 |
CON_TF_CAH11 | T-FLASH/PP_2_CON_TF_CAH11_CAH11 | CAH11-08163-S100 | IC | 1 | CN1 |
CON_ZIF24_050 | OV3640 CON_5_CON_ZIF24_050_ZIF2 | ZIF24_050_DT | IC | 1 | J7 |
C_TAN_B | CAP_C_TAN_B_100UF/6V_T491B107K0 | 100uF/6V | IC | 2 | C83; C84 |
C_TAN_V | CAP_C_TAN_V_1000UF/6V(NC)_T491B | 1000uF/6V(NC) | IC | 1 | C94 |
GPS_NEO6 | NEO-6_GPS_NEO6_NEO-6M | NEO-6M | IC | 1 | U19 |
HMC5883L | HMC5883L_0_HMC5883L_HMC5883L(NC | HMC5883L(NC) | IC | 1 | U27 |
JTAG9_100_F | SIP8_0_JTAG9_100_F_SIP9_P120(NC | sip9_p120(NC) | IC | 1 | U6 |
KEY_T_4P_S045 | KEY_TACT_KEY_T_4P_S045_KEY_TACT | Key_tact | IC | 3 | K1; K2; K3 |
L0603 | BLM18PG471SN1D_L0603_BEAD-1A-10 | Bead-1A-100ohm | IC | 1 | FB1 |
L0603 | BLM18PG471SN1D_1_L0603_BEAD-1A- | Bead-1A-100ohm | IC | 1 | FB4 |
L0603 | INDUCTOR_L0603_6.8NH(NC) | 6.8nH(NC) | IC | 2 | L2; L4 |
L0603 | INDUCTOR_L0603_27NH | 27nH | IC | 1 | L3 |
L0603 | INDUCTOR_L0603_NC | NC | IC | 2 | L5; L6 |
LED0603 | LED_LED0603_RED | RED | IC | 2 | LED1; LED2 |
LGA106_BGS2 | BGS2_LGA106_BGS2_BGS2 | BGS2 | IC | 1 | U15 |
MARK_100_300 | MARK_MARK_100_300_MARK(DNP) | Mark(DNP) | IC | 6 | FM1; FM2; FM3; FM4; FM5; FM6 |
MH_D500 | TEST_POINT_TH080_MH_D500_SREWHO | SrewHole9mm(DNP) | IC | 1 | MH15 |
MH_T4D6_D170 | TEST_POINT_TH080_MH_T4D6_D170_S | SrewHole9mm(DNP) | IC | 7 | MH1; MH2; MH4; MH5; MH6; MH7; MH8 |
MIC_DIP2_D6 | MICROPHONE_0_MIC_DIP2_D6_MIC(NC | MIC(NC) | IC | 1 | MK1 |
MINI_USB_10P | MC58_2_MINI_USB_10P_UAF0410376- | UAF0410376-S100 | IC | 1 | J1 |
MLF8_065 | MIC5060_MLF8_065_MIC5060 | MIC5060 | IC | 1 | U52 |
MS5561-C | MS5561-C_MS5561-C_MS5561-C(NC) | MS5561-C(NC) | IC | 1 | U25 |
MSOP8_065 | LM4890_MSOP8_065_LM4890 | LM4890 | IC | 1 | U9 |
PJ_327E | EARJACK_PJK510_1_PJ_327E_PJ-327 | PJ-327E | IC | 1 | U8 |
R0603 | RESISTOR_R0603_1K | 1K | IC | 7 | R6; R45; R85; R86; R87; R96; R97 |
R0603 | RESISTOR_R0603_10K | 10K | IC | 4 | R7; R8; R9; R38 |
R0603 | R_0_R0603_680OHM | 680ohm | IC | 1 | R10 |
R0603 | RESISTOR_R0603_0(NC)_RC0402FR-0 | 0(NC) | IC | 2 | R14; R15 |
R0603 | RESISTOR_R0603_20K_RC0402FR-071 | 20K | IC | 2 | R22; R24 |
R0603 | RESISTOR_R0603_47K_RC0402FR-071 | 47K | IC | 1 | R23 |
R0603 | RESISTOR_R0603_10K_RC0402FR-071 | 10K | IC | 2 | R25; R91 |
R0603 | RESISTOR_R0603_100K | 100K | IC | 12 | R34; R42; R44; R55; R56; R66; R67; R88; R93; R95; R99; R101 |
R0603 | RESISTOR_R0603_470 | 470 | IC | 1 | R35 |
R0603 | RESISTOR_R0603_2.2K | 2.2K | IC | 2 | R36; R37 |
R0603 | RESISTOR_R0603_5.6K | 5.6K | IC | 1 | R39 |
R0603 | RESISTOR_R0603_4.7K | 4.7K | IC | 1 | R40 |
R0603 | RESISTOR_R0603_10K(NC) | 10K(NC) | IC | 2 | R41; R60 |
R0603 | RESISTOR_R0603_0 | 0 | IC | 2 | R61; R106 |
R0603 | RESISTOR_R0603_100K_RC0402FR-07 | 100K | IC | 2 | R89; R100 |
R0603 | RESISTOR_R0603_0_RC0402FR-07100 | 0 | IC | 2 | R90; R92 |
R0603 | RESISTOR_R0603_150K | 150K | IC | 1 | R94 |
R0603 | RESISTOR_R0603_49.9K_RC0402FR-0 | 49.9K | IC | 1 | R102 |
R0603 | R_0_R0603_100K | 100K | IC | 1 | R104 |
R0603 | R_R0603_100K | 100K | IC | 1 | R105 |
RECEIVER_2P | SPEAKER_RECEIVER_2P_RECEIVER | Receiver | IC | 1 | J2 |
RECEIVER_2P_TMP | SPEAKER_RECEIVER_2P_TMP_RECEIVE | Receiver | IC | 1 | J10 |
SIP3_254 | SIP3_SIP3_254_SIP3 | SIP3 | IC | 1 | J52 |
SO8_127 | NTMS4807N_SO8_127_NTMS4807N | NTMS4807N | IC | 1 | U53 |
SOT23-5 | MIC5219_0_SOT23-5_XC6221B302MR | XC6221B302MR | IC | 1 | U12 |
SOT23-6 | RT9361_0_SOT23-6_RT9361B(NC) | RT9361B(NC) | IC | 1 | U23 |
SOT-25 | RT9701_SOT-25_RT9701CB | RT9701CB | IC | 1 | U14 |
SREWHOLE350_D180 | TEST_POINT_TH080_SREWHOLE350_D1 | SrewHole350_D180 | IC | 6 | MH9; MH10; MH11; MH12; MH13; MH14 |
TLD-Y04083D-139 | MOTOR_1_TLD-Y04083D-139_TLD-Y04 | TLD-Y04083D-139 | IC | 1 | M1 |
TVS0603 | DIODE ZENER1_4_TVS0603_VPORT060 | VPORT0603100MV05(NC) | IC | 1 | B1 |
WDFN10_050 | RT9502_WDFN10_050_RT9502 | RT9502 | IC | 1 | U5 |
ZIF4_P100 | ZIF4_0_ZIF4_P100_ZIF4+FPC+FLASH | ZIF4+FPC+Flash(NC) | IC | 1 | J9 |
ZIF45_050_R1 | ZIF45+KDK3P2LCD_ZIF45_050_R1_ZI | ZIF45+KDK3p2LCD | IC | 1 | U50 |
