% N( n7 E( P8 B: X8 ^' B3 z
2 S7 w8 P7 I8 a4 j* Z- j. B[allegro16.6][6层]CPU H264 视频解码(Mozart_3s+RTL8211EG-VB-CG+K4B2G1646B)pcb文件 7 P' ^ e* J7 U3 G, P. I6 N, s
文件描述: 2 d6 y( q( l$ q
1. 作品用途:CPU H264 视频解码 2. 软件版本:allegro16.6 3. 层数:6层 4. 用到的主要芯片:Mozart_3s+RTL8211EG-VB-CG+K4B2G1646B 5. PCB尺寸:6692*5153 mil # \( X4 M' |9 A- b* b: t; f6 i
作品截图如下: _
$ {4 x: w! [3 `) e: ^4 Z顶层截图: 9 j% e; M% ~' m) \6 a! A# I- L2 f) V* b
底层截图:
/ T9 G. T% d" g) s( O# K: h% i2 a% B: Y9 l
全层截图:
2 j0 ^# ?5 S: d; O! T/ d8 W+ o
. x& d0 [, P, e$ O, L; a
+ q8 P7 ~3 K! N7 E1 {% y" j7 i5 e6 M# l1 h
" ]) ]$ _% T1 A; U6 Q6 x# G# z$ ~) M9 j
BOM: Bill of Material Report (Condensed) | | | | | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | 8P4R_0402 | 8P4R_0402 | 30 | DISCRETE | 31 | RN5; RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN20; RN21; RN22; RN23; RN24; RN25; RN26; RN39; RN40; RN41; RN42; RN43; RN44; RN45; RN46; RN47; RN48 | BGA0_8MM9X13-96 | BGA0_8MM9X13-96 | K4B2G1646B | IC | 2 | U11; U13 | BT_SCDM3R3224 | BT_SCDM3R3224 | 0.22F,3.3V,Gold-Cap | IC | 1 | BT1 | C0402 | C0402 | 0.1uF,16V | DISCRETE | 186 | C3; C9; C14; C15; C24; C29; C35; C36; C37; C38; C39; C46; C51; C57; C66; C68; C71; C73; C75; C84; C87; C88; C92; C103; C105; C106; C108; C109; C110; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C134; C137; C138; C140; C141; C144; C145; C146; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C212; C255; C256; C257; C258; C262; C263; C264; C265; C266; C269; C272; C273; C275; C276; C279; C280; C281; C282; C284; C286; C287; C292; C293; C295; C296; C297; C300; C302; C309; C310; C311; C312; C313; C314; C317; C318; C319; C320; C321; C325; C329; C331; C335; C336; C341; C342; C343; C345; C347; C349; C352; C356; C357; C358; C362; C363; C366; C369; C370; C371; C372; C375; C376; C377; C378; C379; C380; C385; C388; C392; C394; C396; C398; C405; C430; C431; C432; C433; C434; C435; C436; C437; C438; C439; C441; C442; C443; C445; C446; C448; C449; C450; C451; C452; C453; C464; C467; C468; C470; C471; C479; C512; C513; C514; C515; C536; C537; C550; C554; C556 | C0402 | C0402 | 0.01uF,50V | DISCRETE | 24 | C6; C13; C21; C25; C32; C33; C45; C49; C55; C60; C253; C334; C340; C344; C346; C351; C353; C386; C393; C395; C397; C417; C483; C557 | C0402 | C0402 | 100pF,16V | DISCRETE | 1 | C69 | C0402 | C0402 | 10pF,50V | DISCRETE | 5 | C70; C99; C101; C359; C360 | C0402 | C0402 | 1nF,50V | DISCRETE | 3 | C77; C170; C171 | C0402 | C0402 | xx_27pF,50V | DISCRETE | 1 | C97 | C0402 | C0402 | xx_10pF,50V | DISCRETE | 5 | C98; C247; C248; C251; C254 | C0402 | C0402 | 27pF,50V | DISCRETE | 2 | C100; C102 | C0402 | C0402 | xx_0.1uF,16V | DISCRETE | 3 | C107; C260; C261 | C0402 | C0402 | 22pF,50V | DISCRETE | 6 | C173; C174; C289; C290; C304; C305 | C0402 | C0402 | 220pF,50V | DISCRETE | 5 | C455; C456; C460; C465; C466 | C0603 | C0603 | 5.6nF,50V | IC | 5 | C4; C16; C20; C41; C53 | C0603 | C0603 | NC | IC | 5 | C5; C19; C28; C44; C52 | C0603 | C0603 | 10uF,6.3V | IC | 18 | C64; C82; C135; C136; C165; C166; C291; C337; C338; C373; C381; C382; C384; C387; C447; C463; C469; C534 | C0603 | C0603 | 1uF,16V | IC | 6 | C250; C348; C368; C389; C519; C560 | C0603 | C0603 | 0.1uF,16V | IC | 1 | C339 | C0603 | C0603 | 82nF | IC | 1 | C350 | C0603 | C0603 | 2.2nF,50V | IC | 1 | C383 | C0603 | C0603 | 12nF | IC | 1 | C390 | C0603 | C0603 | 0.15uF,16V | IC | 1 | C391 | C0603 | C0603 | 4.7uF,6.3V | IC | 1 | C480 | C0805 | C0805 | 4.7uF,16V | IC | 5 | C7; C17; C22; C42; C56 | C0805 | C0805 | 22uF,6.3V | IC | 27 | C111; C167; C316; C322; C330; C333; C440; C454; C505; C506; C507; C508; C520; C521; C522; C523; C524; C525; C526; C527; C528; C529; C530; C531; C532; C533; C535 | C0805 | C0805 | 1uF,25V | IC | 6 | C459; C461; C462; C551; C552; C553 | C1206 | C1206 | 22uF,16V | IC | 14 | C27; C61; C104; C283; C294; C298; C301; C303; C326; C361; C364; C365; C457; C458 | C1206 | C1206 | 1nF,2KV | IC | 2 | C185; C186 | CON1X2_2MM | CON1X2_2MM | CON1x2_2MM | IC | 5 | AUDIO_SEL1; J8; J19; USBID_SEL1; VIDEO_SEL1 | CON1X2_254 | CON1X2_254 | CON1X2_254 | IC | 1 | RS485 | CON1X3_2MM | CON1X3_2MM | CON1X3_2MM | IC | 2 | J11; J34 | CON1X3_254 | CON1X3_254 | CON1X3_254 | IC | 2 | J7; J17 | CON1X4_254 | CON1X4_254 | xx_CON1X4_254 | IC | 3 | J12; J14; J32 | CON2X5_254 | CON2X5_254 | CON2X5_254 | IC | 1 | J29 | CON2X12_254 | CON2X12_254 | xx_CON2X12_254 | IC | 1 | J16 | CON30_1MM | CON30_1MM | 3760-F30C | IC | 2 | J2; J28 | CONDIP1X2_125 | CONDIP1X2_125 | Wafer 1x2_125 | IC | 1 | J25 | CONDIP1X4_125 | CONDIP1X4_125 | Wafer 1x4_125 | IC | 2 | J26; J33 | DB9 | DB9 | xx_DB9_MALE | IC | 1 | COM1 | DB9 | DB9 | DB9_MALE | IC | 1 | COM2 | DIP08_300WA | DIP08_300WA | xx_MX25L3205D | IC | 1 | U8 | DIPSW_JS_606S_R | DIPSW_JS_606S_R | SWITCH_JS-606A-R | IC | 1 | PW_SW1 | FBGA484_MOZART_NOSKT | FBGA484_MOZART_NOSKT | Mozart_3s | IC | 1 | U1 | FPC14S_BL112_P05 | FPC14S_BL112_P05 | FPC,14x0.5mm,90D | IC | 1 | J24 | HOLE_C236D126 | HOLE_C236D126 | Mount_hole | IC | 7 | H2; H3; H4; H5; H6; H8; H9 | IC8SOIC | IC8SOIC | ISL3485EARZ | IC | 1 | U21 | IC8SSOP | IC8SSOP | PCF8563TS/5 | IC | 1 | U49 | IC28SSOP | IC28SSOP | ICL3243ECAZ-T | IC | 2 | UB1; UB2 | IC48TSOP | IC48TSOP | H27U1G8F2BTR-BC | IC | 2 | U18; U19 | IDECON2X10_254 | IDECON2X10_254 | Multi_ICE_10X2 | IC | 1 | ICE1 | IRDIP-IRM4838 | IRDIP-IRM4838 | IR RECEIVER,IRM3638N3 | IC | 1 | IRDA1 | L0402 | L0402 | FBM-11-100505-121T | IC | 4 | L22; L49; L50; L51 | L0603 | L0603 | MLB-160808-0010P-N1 | IC | 30 | L18; L40; L41; L43; L45; L46; L47; L48; L52; L53; L54; L55; L56; L58; L59; L60; L61; L73; L74; L75; L76; L82; L83; L84; L85; L86; L87; L88; L89; L90 | L0805 | L0805 | MLB-201209-0300P-N2 | IC | 4 | L16; L23; L62; L65 | L0805 | L0805 | GB201209D152TT | IC | 8 | L67; L68; L69; L70; L91; L92; L93; L94 | LED-SMD | LED-SMD | GREEN | IC | 13 | D4; D7; D11; D12; D13; D27; D28; D29; D30; D32; D33; D34; D35 | LED-SMD | LED-SMD | BLUE | IC | 1 | D8 | MF-NSMF050-2 | MF-NSMF050-2 | MF-NSMF050-2 | IC | 1 | F2 | MF-R250 | MF-R250 | MF-R250 | IC | 1 | F1 | MIC6MMP1_9MM | MIC6MMP1_9MM | MIC,OBO-06BP | IC | 1 | MIC1 | MJ-08 | MJ-08 | WTJ-035-05A | IC | 2 | LINE_IN1; LINE_OUT1 | MPDS006C_16P | MPDS006C_16P | SN74AVC4T245 | IC | 4 | U30; U31; U46; U48 | MSOP8-NS6642X | MSOP8-NS6642X | LTC6244CMS8 | IC | 1 | U33 | MSOP10_MD124 | MSOP10_MD124 | MD124/MSOP10 | IC | 1 | U10 | PCIE_36P | PCIE_36P | PCIe x1 Edge Connector | IC | 1 | J20 | PJ-25B | PJ-25B | DC-1R2000Q | IC | 1 | PJ1 | QFN28_5X5_P05 | QFN28_5X5_P05 | SSM2603 | IC | 1 | U40 | QFN32_5X5X0_9MM | QFN32_5X5X0_9MM | ADV7391 | IC | 1 | U37 | QFN40_6X6MM_P05 | QFN40_6X6MM_P05 | ADV7180 | IC | 1 | U29 | QFN64_9X9MM_P05 | QFN64_9X9MM_P05 | RTL8211EG-VB-CG | IC | 1 | U14 | QTH-030-01-L-D-A | QTH-030-01-L-D-A | QTH-030-04-LDA | IC | 2 | TOP1; TOP2 | Q_SOT23 | Q_SOT23 | BAT54 | DISCRETE | 3 | D15; D16; D31 | Q_SOT23 | Q_SOT23 | BAT54S | DISCRETE | 1 | D36 | Q_SOT23-5 | Q_SOT23-5 | xx_TPS77028 | IC | 1 | U39 | Q_SOT23BCE | Q_SOT23BCE | PMBT3904 | IC | 4 | Q9; Q13; Q15; Q21 | Q_SOT23BCE | Q_SOT23BCE | PMBT3906 | IC | 1 | Q14 | R0402 | R0402 | 2.7K | DISCRETE | 3 | R3; R530; R531 | R0402 | R0402 | 10K | DISCRETE | 4 | R9; R379; R381; R383 | R0402 | R0402 | 3.3K | DISCRETE | 2 | R15; R49 | R0402 | R0402 | 5.6K | DISCRETE | 3 | R28; R466; R469 | R0402 | R0402 | 22K | DISCRETE | 3 | R34; R456; R457 | R0402 | R0402 | 12K | DISCRETE | 1 | R50 | R0402 | R0402 | 47K | DISCRETE | 2 | R57; R465 | R0402 | R0402 | 6.49K,1% | DISCRETE | 1 | R63 | R0402 | R0402 | 0 | DISCRETE | 16 | R91; R96; R226; R227; R352; R372; R373; R506; R514; R515; R517; R526; R532; R533; R534; R538 | R0402 | R0402 | 1K,0.5% | DISCRETE | 2 | R120; R121 | R0402 | R0402 | 240,1% | DISCRETE | 3 | R122; R123; R130 | R0402 | R0402 | 1M | DISCRETE | 4 | R146; R330; R366; R382 | R0402 | R0402 | 22 | DISCRETE | 1 | R149 | R0402 | R0402 | 100 | DISCRETE | 4 | R255; R256; R258; R259 | R0402 | R0402 | 4.7K | DISCRETE | 15 | R257; R261; R263; R266; R267; R268; R278; R279; R281; R284; R385; R527; R528; R529; R535 | R0402 | R0402 | xx_4.7K | DISCRETE | 4 | R265; R277; R282; R285 | R0402 | R0402 | 2.49K,1% | DISCRETE | 1 | R305 | R0402 | R0402 | 220 | DISCRETE | 8 | R316; R317; R318; R319; R320; R321; R322; R323 | R0402 | R0402 | 43.2,1% | DISCRETE | 1 | R328 | R0402 | R0402 | 1K | DISCRETE | 2 | R334; R537 | R0402 | R0402 | 191,1% | DISCRETE | 1 | R339 | R0402 | R0402 | 475,1% | DISCRETE | 1 | R340 | R0402 | R0402 | 49.9,1% | DISCRETE | 4 | R341; R342; R345; R346 | R0402 | R0402 | 36 | DISCRETE | 1 | R357 | R0402 | R0402 | 47K,1% | DISCRETE | 1 | R377 | R0402 | R0402 | 5.6K,1% | DISCRETE | 1 | R380 | R0402 | R0402 | 10K,1% | DISCRETE | 2 | R384; R387 | R0402 | R0402 | 15K | DISCRETE | 2 | R470; R471 | R0402 | R0402 | xx_0 | DISCRETE | 1 | R513 | R0402 | R0402 | 470 | DISCRETE | 1 | R536 | R0603 | R0603 | 4.7K | DISCRETE | 24 | R8; R39; R65; R77; R102; R106; R111; R271; R295; R296; R301; R302; R307; R309; R331; R337; R361; R364; R395; R454; R455; R459; R467; R468 | R0603 | R0603 | 3.01K,1% | DISCRETE | 1 | R11 | R0603 | R0603 | 1.96K,1% | DISCRETE | 1 | R12 | R0603 | R0603 | 220 | DISCRETE | 5 | R14; R23; R62; R92; R461 | R0603 | R0603 | 10K,1% | DISCRETE | 2 | R18; R20 | R0603 | R0603 | 17.4K,1% | DISCRETE | 1 | R19 | R0603 | R0603 | 44.2K,1% | DISCRETE | 2 | R21; R45 | R0603 | R0603 | 510 | DISCRETE | 3 | R22; R64; R355 | R0603 | R0603 | 10K | DISCRETE | 6 | R25; R44; R360; R367; R392; R397 | R0603 | R0603 | 5.1K | DISCRETE | 1 | R26 | R0603 | R0603 | 680K | DISCRETE | 1 | R37 | R0603 | R0603 | 4.7K,1% | DISCRETE | 2 | R38; R46 | R0603 | R0603 | 100K | DISCRETE | 2 | R40; R458 | R0603 | R0603 | 20K | DISCRETE | 1 | R47 | R0603 | R0603 | 4.64K,1% | DISCRETE | 1 | R59 | R0603 | R0603 | 12K,1% | DISCRETE | 1 | R60 | R0603 | R0603 | 270K | DISCRETE | 1 | R94 | R0603 | R0603 | 560K | DISCRETE | 1 | R95 | R0603 | R0603 | 30 | DISCRETE | 16 | R107; R112; R343; R344; R350; R351; R362; R363; R389; R390; R391; R393; R394; R460; R462; R474 | R0603 | R0603 | 0 | DISCRETE | 26 | R242; R243; R244; R245; R253; R254; R264; R269; R270; R273; R283; R324; R329; R333; R347; R348; R447; R448; R510; R511; R512; R520; R522; R523; R524; R525 | R0603 | R0603 | xx_0 | DISCRETE | 8 | R247; R248; R249; R250; R251; R252; R451; R521 | R0603 | R0603 | 120 | DISCRETE | 1 | R287 | R0603 | R0603 | 39 | DISCRETE | 1 | R358 | R0603 | R0603 | 1.69K | DISCRETE | 1 | R365 | R0603 | R0603 | 220K | DISCRETE | 2 | R378; R386 | R0603 | R0603 | 510,1% | DISCRETE | 1 | R388 | R0603 | R0603 | 169 | DISCRETE | 1 | R396 | R0603 | R0603 | 75 | DISCRETE | 3 | R398; R399; R400 | R0603 | R0603 | 680 | DISCRETE | 1 | R463 | R0603 | R0603 | xx_30 | DISCRETE | 3 | R475; R518; R519 | R0603 | R0603 | 1K | DISCRETE | 1 | R508 | R0805 | R0805 | 0 | IC | 5 | R213; R449; R450; R452; R453 | R0805 | R0805 | 10 | IC | 1 | R374 | R1206 | R1206 | 0 | DISCRETE | 5 | R496; R497; R498; R499; R500 | RCA | RCA | RCA | IC | 2 | VIDEO_IN1; VIDEO_OUT1 | RESET-SW | RESET-SW | TS1102LA | IC | 1 | S1 | RJ45-GTC1111-02AL | RJ45-GTC1111-02AL | GTC1111-02AL | IC | 1 | RJ45 | SC70-6 | SC70-6 | AD5602 | IC | 2 | U34; U35 | SCD34 | SCD34 | SCD34 | DISCRETE | 2 | D1; D2 | SD-104G-TAA0-R | SD-104G-TAA0-R | SD Socket,104G-TAA0-R | IC | 2 | SD1; SD2 | SDSG740D | SDSG740D | 10uH | IC | 1 | L1 | SDSG740D | SDSG740D | 15uH | IC | 3 | L3; L4; L13 | SDSG740D | SDSG740D | 6.8uH | IC | 1 | L7 | SMD-EC8 | SMD-EC8 | 330uF/25V | IC | 1 | C1 | SMDCON1X6P1MM-CSI-1181-XXXX | SMDCON1X6P1MM-CSI-1181-XXXX | WAFER 1X6(CSI-1181-061R) | IC | 1 | J4 | SMDCON1X6P1MM-CSI-1181-XXXX | SMDCON1X6P1MM-CSI-1181-XXXX | WAFER 1X6(CSI-1182-061R) | IC | 1 | J5 | SMDL-EA-22AM03C02 | SMDL-EA-22AM03C02 | 2.2uH/2.35A/59mOhm | IC | 1 | L33 | SOP8_TH | SOP8_TH | NX7102 | IC | 5 | U2; U3; U4; U5; U6 | SOP16_400W | SOP16_400W | MX25L12845EMI-10G | IC | 1 | U9 | SOT23-5P | SOT23-5P | xx_TPS2051BDBV | IC | 1 | U25 | SOT26-6P | SOT26-6P | AP1511A | IC | 1 | U32 | SOT143 | SOT143 | PT7M7811 | IC | 1 | U7 | SOT-23 | SOT-23 | AIC1722A_18PU | IC | 2 | U28; U36 | SWSMD2X2_127 | SWSMD2X2_127 | SWSMD2X2_127 | IC | 1 | SW8 | TANT_B | TANT_B | 100uF,6.3V | IC | 5 | C214; C516; C517; C518; C555 | TANT_B | TANT_B | xx_100uF,6.3V | IC | 1 | C249 | TANT_D | TANT_D | 33uF,25V | IC | 7 | C8; C18; C23; C43; C54; C315; C444 | TP | TP | TP | IC | 20 | TP39; TP40; TP41; TP42; TP43; TP44; TP48; TP49; TP50; TP51; TP52; TP54; TP55; TP58; TP59; TP64; TP65; TP66; TP67; TP74 | TP | TP | T POINT R | IC | 1 | TP47 | TPDIPC55D35 | TPDIPC55D35 | T POINT R | IC | 2 | TP56; TP57 | TSSOP16_5X6_4P065 | TSSOP16_5X6_4P065 | PI6C557-03LE | IC | 1 | U26 | TSSOP20_6_5X6_4P0_65 | TSSOP20_6_5X6_4P0_65 | SN74HC541PWR | IC | 1 | U23 | USBDIP_ATYPE6P | USBDIP_ATYPE6P | USB_A_Dip | IC | 1 | USB1 | USBSMD_MUSB5 | USBSMD_MUSB5 | USB_MINI_AB | IC | 1 | USB2 | XTAL_X32 | XTAL_X32 | 24MHz | IC | 2 | OSC3; Y6 | XTAL_X32 | XTAL_X32 | xx_18.432MHz | IC | 1 | Y2 | XTAL_X32 | XTAL_X32 | 25MHz | IC | 3 | Y5; Y7; Y10 | XTAL_X32 | XTAL_X32 | 28.6363MHz | IC | 1 | Y11 | Y2 | Y2 | 32.768 KHz | IC | 1 | Y9 | 附件:pcb文件
8 N* P- l( W8 M3 o2 J0 h
( c, B" v: b0 c% R- o9 X r* R |
