作品名:[AD 10][2层]AM3354底板demo板(MP2012+DP83848I+SN74CB3T16210DGGR)PCB源文件 5 I, E: Z0 }/ @
文件描述 1. 作品用途:AM3354底板demo板 2. 软件版本:AD 10 3. 层数:2层板 4. 用到的主要芯片:MP2012+DP83848I+SN74CB3T16210DGGR 5. PCB尺寸:190mm*130mm
; P& w( i9 e3 x* P, w/ O作品截图如下: 顶层截图:
0 Z- F7 c; R# v& Y& W底层截图: 全层截图:
! C& t" K' w/ m$ `) k叠层信息截图如下: : K3 k0 F; F0 g& Y& Q: w
BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1.8V | BT1 | BATTERY2 | 1 | 47uF | C1, C2, C51 | 1210C | 3 | 10uF | C3, C9, C11, C13, C15, C19, C45 | C0805_M2013 | 7 | 0.1uF | C4, C10, C12, C14, C16, C49, C79, C80 | C0603_M1608 | 8 | 470nF | C5, C6, C7, C8 | C0603_M1608 | 4 | 4.7uF | C17, C23, C33, C35 | C0603_M1608 | 4 | 10pF | C18, C55, C56 | C0603_M1608 | 3 | 100nF | C20, C21, C32, C34, C36, C37, C38, C39, C40, C41, C42, C43, C44, C52 | C0603_M1608 | 14 | 1nF | C22, C53 | C0603_M1608 | 2 | 1uF | C24, C25, C26, C27, C28, C29, C30, C31 | C0603_M1608 | 8 | 18pF | C46, C47 | C0603_M1608 | 2 | 22uF | C48 | 1210C | 1 | 10uF | C50 | 1210C | 1 | 220pF | C75, C76 | C0603_M1608 | 2 | 470nF_NC | C77, C78 | C0603_M1608 | 2 | LED blue | D1, D2, D3, D4 | LED0603_M1608 | 4 | D Schottky | D5 | LED-0805 | 1 | D Schottky | D6 | DIODE-SK34A | 1 | SMBJ15A | D7 | DIODE-SK34A | 1 | CBG201209U151B/0805 | FB1, FB2 | 0805R | 2 | 150R@100Mhz | FB3, FB4 | 0805R | 2 | 3.5mm SJ3524 | J1, J2 | PHONE1 | 2 | LCD | J3 | FPC54 | 1 | D Connector 9 | J4, J11 | DB-9RA/M | 2 | CONN40X2 | J5, J6, J7 | CON80A_08_D | 3 | Jump | J8, J9, J16, J17, J23, J24, J25, J26 | SIP-3 | 8 | SD_CARD | J13 | SDCARD | 1 | RJ45 | J15 | RJ-45A12 | 1 | POWER | J18 | JACK-2.5MM_B | 1 | USB Device | J19 | USB-A | 1 | SW_2 | K2 | SWPB-4 | 1 | | K4, K5, K6, K7, K8, K9 | SWPB-4 | 6 | 3X3-smd_5% | L1 | L1212_M3X3 | 1 | 3.3uH | L2 | LSMD10X10 | 1 | LED RED | LED5, LED6 | LED0603_M1608 | 2 | Header 25X2 | P1 | CON2X50_1.27_SMT | 1 | CAN | P2 | 2PIN(200mil) | 1 | UART2 | P3 | IDC10S | 1 | I2C0 & I2C2 | P4 | IDC10S | 1 | UART4 | P5 | IDC10S | 1 | DS18B20 | P7 | DS18B20 | 1 | SPI0 | P8 | IDC10S | 1 | JTAG | P9 | IDC20S | 1 | SDIO_WIFI | P10 | IDC20S | 1 | PWM | P11 | 2PIN(200mil) | 1 | AD | P12 | IDC10S | 1 | USER IO | P13 | IDC10S | 1 | USB Device | P14 | USB/S | 1 | 9014 | Q1 | SOT23T | 1 | 10K | R1, R3, R7, R24, R25, R26, R27, R28, R29, R30, R31, R39, R40, R41, R42, R56, R57, R58, R59, R60, R61, R62, R63, R67, R68, R70, R71, R72, R84, R87, R111, R112, R115, R116, R117, R118, R119, R120, R121 | 0603R | 39 | 0R | R2, R20, R21, R22, R23, R32, R33, R34, R35, R38, R75, R80, R88, R89, R90 | 0603R | 15 | 300K | R4 | 0603R | 1 | 150K | R5 | 0603R | 1 | 0R_NC | R6, R13 | 0603R | 2 | 4.7K | R8, R14, R15, R109, R110, R122, R123, R124, R125, R126, R127 | 0603R | 11 | 22R | R9, R10, R11, R12, R69, R74, R85, R86 | 0603R | 8 | 100K | R16, R17, R18, R19, R49, R65, R73, R78 | 0603R | 8 | 10K_NC | R36, R107, R128, R129, R130 | 0603R | 5 | 1.5K | R37, R44 | 0603R | 2 | 2.2K | R43, R45, R46, R47, R76, R77, R79, R81 | 0603R | 8 | 4.87K | R48 | 0603R | 1 | 1K | R50, R51, R52, R53, R54 | 0603R | 5 | Res Tap | R55 | AD01 | 1 | 121K | R64 | 0603R | 1 | 39K | R66 | 0603R | 1 | 1K_NC | R82, R113, R114 | 0603R | 3 | 120K | R83 | 0603R | 1 | 1.2K | R91, R92 | 0603R | 2 | 4.7K_NC | R131 | 0603R | 1 | SW SMD-4 | S1 | SW_SMD4 | 1 | SPAKER | S3 | BELL | 1 | POWER | S10 | SWITCH_POWER | 1 | TLV320AIC3106 | U1 | S-PVQFN-48N(TLV320) | 1 | MP2104DJ | U2 | SOT23-5 | 1 | SN74CB3T16210DGGR | U3, U4, U7, U8 | SSOP-48-DGG | 4 | SN74AUP2G08 | U5 | SO_G8 | 1 | SN74LVC2G00 | U6 | SO_G8 | 1 | MAX3232E | U9, U11 | SO-16 | 2 | MCP2551 | U10 | SOIC-8N | 1 | DP83848I | U12 | LQFP-(NS)VBH48A | 1 | MP2012 | U13 | QFN6(3mmx3mm) | 1 | TPS2051bd | U18, U19 | SOIC-8N | 2 | X3225_20ppm | X1 | Crystals_3225 | 1 | 12M | X3 | Y7050 | 1 |
/ d( _( _0 h8 K; h附件: PCB源文件如下: 8 C4 R; n% {$ n4 W' |) n0 R
