作品名:[AD 10][6层]BeagleBone Black开发板设计(TPS65217C+SN74LVC1G06DCK+TL5209)原理图和PCB源文件 文件描述 1. 作品用途:BeagleBone Black开发板设计 2. 软件版本:AD 10 3. 层数:6 层 4. 用到的主要芯片:TPS65217C+SN74LVC1G06DCK+TL5209 5. PCB尺寸:86.5mm*54.1mm 作品截图如下: 顶层截图: 底层截图: 全层截图: 叠层信息截图如下: BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10uF, 10V | C1, C2, C4, C7, C8, C9, C10, C11, C12, C13, C14, C15, C39, C40, C55, C62, C77, C95, C96, C118, C122, C126, C133, C153 | 805 | 24 | 0.1uf, 6V3 | C3, C20, C27, C28, C29, C30, C31, C33, C35, C36, C37, C38, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C56, C57, C58, C59, C60, C61, C63, C64, C65, C66, C67, C68, C69, C70, C71, C72, C73, C74, C75, C76, C78, C79, C80, C81, C82, C83, C84, C85, C86, C87, C88, C92, C93, C94, C97, C98, C99, C100, C101, C102, C103, C105, C106, C107, C108, C109, C110, C111, C112, C113, C114, C115, C116, C117, C119, C120, C121, C124, C127, C128, C129, C130, C131, C132, C135, C145, C147, C149, C150, C152, C154, C155, C158, C159 | 402 | 100 | 2.2uF, 6V3 | C16, C17, C18, C125, C144, C146, C148, C151 | 402 | 8 | 470pF, 50V | C19, C136 | 402 | 2 | 18pF, 50V | C21, C22, C25, C26 | 402 | 4 | 1uF, 10V | C24, C89, C90, C91, C104, C134 | 402 | 6 | 1nF, 50V | C32, C123 | 402 | 2 | 100uF, 6V3 | C34 | RD205SMD_250D | 1 | 15pF, DNI | C137, C138, C139, C140 | 402 | 4 | 0.022uF,10V | C141 | 402 | 1 | 30pF, 50V | C142, C143 | 402 | 2 | 47pF, 6.3V | C156, C157, C160, C161, C162, C163, C164, C165, C166, C167, C168, C169, C170, C171, C172, C173 | 402 | 16 | 598-8170-107F | D1, D2, D3, D4, D5 | LED_0603 | 5 | IP4283CZ10-TT | D6, D7 | TSSOP10 | 2 | RB751V40,115 | D8 | SOD323 | 1 | 150OHM800mA | FB1, FB2, FB3, FB4, FB5, FB7 | SM-7351-IND-0805 | 6 | 0.1 Ohm, 0805 | FB8 | SM-7351-IND-0805 | 1 | HEADER 6 | J1 | SIP6 | 1 | 2.2uH, 2.6A | L1, L2, L3 | 2520 | 3 | PJ-200A | P1 | CONN3-PWR-PJ102A | 1 | CTI JTAG,DNI | P2 | HEADER10X2_SMD | 1 | USB-A Conn. - 87520-xx1xx | P3 | USB_A_SH | 1 | mini USB-B | P4 | USB5MINI_4SHIELDED_SMD-5 | 1 | WE_7499010211A | P5 | RJ45-7499010211A | 1 | 10118241-001RLF | P6 | CONN19_HDMI | 1 | FEMALE HEADER 2x23 | P8, P9 | HEADER23X2 | 2 | MOLEX 502570-001 | P10 | SD-MICRO-SCHA5B0300 | 1 | DMC56404 | Q1, Q2 | SMINI6-F3-B | 2 | 100K, 1% | R1, R56, R65, R66, R67, R68, R76, R77, R78, R79, R80, R82, R83, R84, R85, R86, R87, R88, R89, R94, R95, R165 | 402 | 22 | 1.5K, 1% | R3, R4, R97, R112, R113, R114, R119, R146, R147 | 402 | 9 | 0R, 1% | R5, R6, R7, R8, R19, R20, R27, R49, R50, R51, R137, R142, R149, R159, R160, R161, R162 | 402 | 17 | 0R, 1%, DNI | R9 | 402 | 1 | 470K, 5% | R10 | 402 | 1 | 280K, 1% | R11 | 402 | 1 | 820, 5% | R12, R71, R72, R73, R74 | 402 | 5 | 10K, 1% | R14, R52, R53, R54, R96, R98, R100, R101, R102, R103, R104, R105, R106, R107, R108, R109, R110, R111, R115, R116, R117, R118, R135, R145, R148, R150, R151, R152, R153, R154, R155, R156, R157, R158 | 402 | 34 | 1M, 1% | R17 | 402 | 1 | 33, 0402 | R18, R21, R28, R45, R46, R47, R48, R167 | 402 | 8 | 49.9, 1% | R22, R120, R121, R122, R123 | 402 | 5 | 4.75K, 1% | R23, R24, R25, R26, R163, R164 | 402 | 6 | 100K, 1%, DNI | R55, R57, R59, R69, R81, R90, R91, R92, R93 | 402 | 9 | 100K, 1%,DNI | R58, R60, R61, R62, R63, R64, R70 | 402 | 7 | 100 | R75 | 402 | 1 | 240, 1% | R99 | 402 | 1 | 10, 1%,DNI | R124 | 402 | 1 | 100, 1% | R125, R126, R127, R128, R129, R131, R133, R134, R138, R139 | 402 | 10 | 470, 5% | R130, R132 | 402 | 2 | 0.1, 0805 | R136 | 805 | 1 | 0R, 1%,DNI | R140 | 402 | 1 | 1M, 1%,DNI | R141 | 402 | 1 | 10, 1% | R143 | 402 | 1 | 12.1K, 1% | R144 | 402 | 1 | 27K, 1% | R166 | 402 | 1 | PTC_RXEF010 | RT1 | POLYSW200-5638-310 | 1 | KMR231GLFS | S1, S2, S3 | SW4SMD_63X161LS | 3 | TPS65217C | U2 | U_48_RSL | 1 | SN74LVC1G06DCK | U3 | DCK5_2P15X1P4 | 1 | TL5209 | U4 | SO8-25X75 | 1 | IC_AM335X_ZCE_1 | U5 | AM33XX_15X15 | 1 | SN74LVC1G74DCTR | U6 | SOP8_DCT | 1 | 24LC32A | U7 | SOT23-5 | 1 | TPS2051 (DGN) | U8 | DGN-16X60 | 1 | TPD4S012 | U9, U10 | U_6_DRY | 2 | TDA19988 | U11 | QFN64S9X9P5 | 1 | MT41K256M16HA -125:E | U12 | BGA96_T9_P8_9X14 | 1 | eMMC, 2GB | U13 | BGA153_P14_P5_11P5X13 | 1 | LAN8710A | U14 | QFN32_5X5MM_EP3P3MM | 1 | SN74LVC2G241 | U15 | U_8_DCU | 1 | 32.768kHz | Y1 | XTAL4_126-216SMD | 1 | 24MHz | Y2 | XTAL150SMD_125X196 | 1 | 25.000MHz | Y3 | XTAL150SMD_125X196 | 1 | 24.576MHz | Y4 | OSC4_61X65LS_79X98SMD | 1 |
附件: 原理图和PCB源文件如下: . k2 U/ W* l% A0 K: t0 [
7 @& r* x% A5 [% b6 a; ] |
