Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
201 | CAP_0201_0.1UF | 0.1uF | DISCRETE | 47 | C137; C161; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C175; C176; C177; C178; C180; C181; C182; C184; C185; C186; C187; C188; C189; C193; C194; C198; C199; C200; C201; C202; C203; C204; C205; C206; C207; C208; C216; C218; C232; C233; C235; C314; C315; C316; C318 |
201 | CAP_0201_1UF | 1uF | DISCRETE | 16 | C138; C142; C144; C145; C146; C147; C150; C151; C154; C155; C162; C183; C196; C211; C234; C327 |
364A2795 | CONN_COAX_2POS_2P_4SH_364A2795_ | JK BNCx2 | IC | 2 | J1; J2 |
402 | CAP_0402_2000PF | 2000pF | IC | 2 | C5; C7 |
402 | CAP_0402_DNE | DNE | IC | 1 | C8 |
402 | CAP_0402_0.1UF | 0.1uF | DISCRETE | 25 | C11; C12; C13; C14; C18; C20; C21; C22; C23; C26; C27; C29; C31; C33; C34; C35; C36; C70; C105; C148; C157; C197; C214; C322; C329 |
402 | CAP_0402_4.7UF | 4.7uF | DISCRETE | 20 | C129; C130; C131; C132; C134; C135; C136; C139; C140; C141; C143; C149; C152; C153; C156; C158; C159; C160; C195; C210 |
402 | CAP_0402_1UF | 1uF | DISCRETE | 1 | C217 |
402 | RES_0402_0 | 0 | DISCRETE | 89 | R1; R2; R3; R4; R5; R7; R8; R9; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R64; R65; R66; R67; R68; R69; R70; R71; R74; R75; R76; R77; R78; R79; R80; R81; R83; R85; R86; R87; R88; R89; R90; R119; R120; R121; R122; R126; R127; R128; R142; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161; R162; R163; R164; R171; R172; R173; R174; R184 |
402 | RES_0402_DNE | DNE | IC | 1 | R24 |
402 | RES_0402_1.87K | 1.87K | IC | 4 | R27; R202; R203; R204 |
402 | RES_0402_3.40K | 3.40K | IC | 2 | R28; R201 |
402 | RES_0402_1.50K | 1.50K | IC | 1 | R33 |
402 | RES_0402_1.00K | 1.00K | IC | 2 | R37; R195 |
402 | RES_0402_75.0 | 75 | DISCRETE | 24 | R91; R92; R93; R95; R96; R97; R98; R99; R100; R101; R103; R104; R105; R106; R107; R109; R110; R111; R112; R113; R115; R116; R117; R118 |
402 | RES_0402_37.4 | 37.4 | DISCRETE | 4 | R94; R102; R108; R114 |
402 | RES_0402_10K | 10K | DISCRETE | 21 | R124; R125; R133; R134; R135; R136; R138; R139; R212; R214; R216; R219; R220; R225; R228; R232; R233; R235; R236; R237; R238 |
402 | RES_0402_33 | 33 | DISCRETE | 14 | R129; R130; R131; R140; R141; R143; R165; R167; R168; R169; R170; R183; R207; R208 |
402 | RES_0402_10.0K | 10.0K | IC | 3 | R132; R205; R206 |
402 | RES_0402_1.0K | 1.0K | DISCRETE | 10 | R137; R175; R177; R179; R181; R218; R221; R222; R223; R224 |
0402_ENG | RES_0402_ENG_10.0 | 10 | DISCRETE | 2 | R10; R12 |
603 | CAP_0603_1000PF | 1000pF | IC | 2 | C4; C6 |
603 | CAP_0603_1UF | 1uF | IC | 8 | C59; C61; C62; C64; C65; C67; C68; C71 |
603 | CAP_0603_470PF | 470pF | IC | 4 | C60; C63; C66; C69 |
603 | CAP_0603_10UF | 10uF | DISCRETE | 8 | C163; C174; C179; C192; C209; C213; C319; C320 |
603 | CAP_0603_20PF | 20pF | IC | 2 | C190; C191 |
603 | R_0603_150 | 150 | IC | 5 | R6; R176; R178; R180; R182 |
603 | RES_0603_100K | 100K | DISCRETE | 4 | R11; R13; R20; R21 |
603 | RES_0603_110K | 110K | DISCRETE | 1 | R14 |
603 | RES_0603_40.2K | 40.2K | DISCRETE | 1 | R15 |
603 | RES_0603_240K | 240K | DISCRETE | 1 | R16 |
603 | RES_0603_30.1K | 30.1K | DISCRETE | 1 | R17 |
603 | RES_0603_10.7K | 10.7K | DISCRETE | 1 | R18 |
603 | RES_0603_10.0K | 10.0K | DISCRETE | 1 | R19 |
603 | RES_0603_12.7K | 12.7K | DISCRETE | 1 | R22 |
603 | RES_0603_60.4K | 60.4K | DISCRETE | 1 | R23 |
603 | RES_0603_49.9 | 49.9 | IC | 8 | R62; R63; R72; R73; R82; R84; R123; R166 |
603 | RES_0603_100 | 100 | DISCRETE | 1 | R226 |
603 | RES_0603_0 | 0 | IC | 2 | R332; R333 |
805 | CAP_0805_22UF | 22uF | DISCRETE | 2 | C16; C19 |
1210 | CAP_1210_22UF | 22uF | DISCRETE | 2 | C9; C10 |
222092-1 | BNC-RIGHT_ANGLE_4P_ENG_222092-1 | JK BNC | IC | 1 | J4 |
BGA_366P_0-80MM_17-0X17-0MM | CX25930_366P_ENG_BGA_366P_0-80M | CX25930-31Z | IC | 1 | U8 |
BNC7T-J-P-GN-ST-EM1 | CONN_COAX_5_BNC7T-J-P-GN-ST-EM1 | JK BNC | IO | 8 | J11; J12; J13; J14; J15; J16; J17; J18 |
CASED | CAP_POL_CASED_100UF | 100uF | DISCRETE | 3 | C15; C17; C321 |
CC0402 | SMD_BEAD_FB_CC0402_120 OHM@100M | 120 Ohm@100MHz | IC | 19 | FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20; FB21; FB43; FB51; FB52; FB53; FB54; FB56; FB57; FB58; FB59 |
HC49-USM | CRYSTAL_HC49-USM_27.0MHZ | 27.0MHz | IC | 1 | Y1 |
HDR1X1 | TEST_POINT_SHORT_HDR1X1_HDR 1X1 | HDR 1x1 | IC | 7 | TP1; TP2; TP3; TP4; TP5; TP6; TP7 |
HDR1X2 | SMALL_JMP2_HDR1X2_HDR 2X1 | HDR 2x1 | IO | 2 | JP1; JP8 |
HDR1X4 | HDR_4_M_HDR1X4_HDR 4X1 | HDR 4x1 | IO | 1 | J32 |
HDR1X7 | HDRP_7X1_HDR1X7_HDR 7X1 | HDR 7X1 | IC | 1 | P2 |
HDR_2X50F_2-00MM_100-3X4-0MM | HDR_2X50_F_HDR_2X50F_2-00MM_100 | SKT 50x2 | IO | 2 | J29; J30 |
IND_2P_8-10MM_10-1X10-1MM | IND_IND_2P_8-10MM_10-1X10-1MM_6 | 6.8uH | DISCRETE | 2 | L2; L3 |
L0402 | IND_L0402_4.7NH | 4.7nH | DISCRETE | 4 | L14; L16; L19; L21 |
L0402 | IND_L0402_5.6NH | 5.6nH | DISCRETE | 4 | L15; L17; L18; L20 |
QSOP_16P_0-64MM_5-0X4-0MM | PI3B3257_16P_QSOP_16P_0-64MM_5- | 3B3257A | IC | 1 | U18 |
R200_323_158_36_120_OFFSET | FUSE_R200_323_158_36_120_OFFSET | 72V_0.50A | IC | 1 | F4 |
SC70-5 | 74LVC1G17_SC70-5_LVC1G17 | LVC1G17 | IC | 1 | U21 |
SML-310 | LED_SML-310_GRN | GRN | IC | 5 | D5; D6; D7; D8; D9 |
SOT23-5_0-95MM | OP_SOT23_GATE_B_SOT23-5_0-95MM_ | AD8605 | IC | 1 | U22 |
SOT23CBE | BJT_NPN_SOT23CBE_MMBT3904 | MMBT3904 | IC | 4 | Q1; Q2; Q3; Q4 |
SOT_8P_0-65MM_2-9X1-6MM | MP1494_8P_SOT_8P_0-65MM_2-9X1-6 | MP1495 | IC | 2 | U2; U3 |
TH250RD125_A | TOOLING_HOLE_1P_TH250RD125_A_TH | TH250RD125 | IC | 2 | TH1; TH2 |
TV25RD15 | TEST_VIA_TV25RD15_TV25RD15 | TV25RD15 | IC | 3 | TV2; TV3; TV9 |
