作品名:[AD 10][2层]ADUC7026开发板(ADUC7026-7027+74HC573+7805)PCB源文件
0 b2 X1 ?7 \: s: T1 _# T文件描述 1. 作品用途:ADUC7026开发板 2. 软件版本:AD 10 3. 层数:2层板 4. 用到的主要芯片:ADUC7026-7027+74HC573+7805 5. PCB尺寸:137.5mm*90mm 6 }2 ^* }' g5 v; i
作品截图如下: 顶层截图:
- `- y8 m9 F% z4 a, u) E" @7 y+ |底层截图: 全层截图:
0 {# y9 j3 |! p6 v+ Y8 J" r叠层信息截图如下:
1 W) e3 b& {8 J' J+ TBOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 100uF | C26 | C2220 | 1 | 10K | R16 | 0603 | 1 | 10uH | L1 | AXIAL0.3 | 1 | 1117-3.3 | U7 | SOT-223 | 1 | 32.768K | Y1 | XTAL2 | 1 | 4.7K | R17 | 0603 | 1 | 7805 | U8 | DPAK | 1 | ADUC7026-7027 | U2 | ADuC7026-7027 | 1 | CON3 | J9 | SIP3 | 1 | ISP | J10 | SIP3 | 1 | JTAG | JP5 | IDC20-H | 1 | MAX232 | U1 | SOP-16 | 1 | POT2 | RW1 | VR-5 | 1 | RESET | S5 | K-4 | 1 | RS-232接口 | J1 | DB-9/F | 1 | 12 | C24, C25 | 0603 | 2 | 62256 | U5, U6 | 62256 | 2 | 74HC573 | U3, U4 | SOP-20 | 2 | 0.47 | C1, C2, C3 | 0603 | 3 | 100K | R1, R2, R3 | 0603 | 3 | 10uF | C4, C5, C6, C7 | C1206 | 4 | 1u | C13, C14, C15, C16 | 0603 | 4 | HEADER 20X2 | JP1, JP2, JP3, JP4 | IDC40 | 4 | SW-PB | S1, S2, S3, S4 | K-4 | 4 | CON20 | J2, J3, J4, J5, J6, J7 | SIP20 | 6 | LED | LED1, LED2, LED3, LED4, LED5, LED6, LED7, LED8, LED9, LED10 | D0805 | 10 | 1K | R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15 | 0603 | 12 | 0.1 | C8, C9, C10, C11, C12, C17, C18, C19, C20, C21, C22, C23, C27, C28, C29, C30, C31 | 0603 | 17 |
/ F) R- N: T3 ^& w' ]5 i附件: PCB源文件如下: / i1 r8 u. j- Q) @
; D- ]/ J9 M) K3 l; S; {
