查看: 247|回复: 0
[allegro16.3][4层]CY8C3866AXI-040+CS42L51+TSH-3756 pcb文件
发表于 2019-12-25 14:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 `  h0 Y# D7 @- A  p8 h( Q" F" a6 T. @
2 e/ J+ l# @2 B7 C3 m' Q8 B/ l) ~$ Z
文件描述:
# [0 i9 \# _: ?' B) w% ~7 R
! g: l- h" D; ^9 R
1. 软件版本:allegro16.3
2. 层数:4层
3. 用到的主要芯片:CY8C3866AXI-040+CS42L51+TSH-3756
4.pcb尺寸:5800*3165 MIL/ J! p9 `- A% l* @9 V, f
4 Y) V7 P! y5 j6 Y4 Z, P8 @/ ?( X/ C
作品截图如下:
1 q* l. u# D, a3 T  `, \) M. p2 N4 D8 O  ~4 S9 z3 |' ^; S* Q
顶层截图:
* B8 R: Y, A0 ~, `. _1 i
0 T* }9 M: h- V3 f# t! J# x' F
底层截图:
4 e: v# e* l" b2 J1 @) m3 C2 x# d$ r5 Q; A
; z% u5 q$ c+ P* }! Y6 f( p% F' g2 g* }. }; z) y. Z
全层截图:
4 k$ f- ~: ^- B; Q
1 q$ V4 {8 u8 G- g- A* J
% n/ l* ^9 G5 v' _. u" K' }
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
5_PIN_STARPOINTSTAR_POINTStar PointIC1SP1
C-0402CAP_C-0402_0.1UF0.1uFIC24C101; C107; C119; C128; C131; C133; C134; C136; C145; C158; C159; C160; C163; C164; C165; C167; C169; C171; C172; C173; C174; C175; C176; C179
C-0402CAP_C-0402_10NF10nFIC7C103; C109; C113; C115; C117; C123; C126
C-0402CAP_C-0402_3.3NF3.3nFIC2C104; C110
C-0402CAP_C-0402_22NF22nFIC2C124; C125
C-0402CAP_C-0402_1NF1nFIC2C137; C138
C-0402CAP_C-0402_12PF12pFIC2C177; C178
C-0603CAP_C-0603_1UF1uFIC7C120; C121; C129; C130; C135; C162; C168
C-0603CAP_C-0603_330PF330pFIC4C142; C143; C150; C151
C-0603CAP_C-0603_2.2UF2.2uFIC1C161
C-0603CAP_C-0603_2.2NF2.2nFIC1C166
C-0805CAP_C-0805_10UF10uFIC10C102; C105; C106; C108; C111; C112; C170; C180; C181; C182
C-0805CAP_C-0805_22UF22uFIC1C132
C-1206CAP_C-1206_47UF47uFIC3C114; C116; C157
C-1210CAP_C-1210_100UF100uFIC1C118
CAPAE-D10UFD_ELECT_10V100 uFIC1C148
CAPT3216CAP_0_CAPT3216_1UF1uFIC6C122; C127; C139; C140; C153; C155
CAPT3216CAP_0_CAPT3216_2.2UF2.2uFIC2C144; C149
CON-1X2_3-96MM1X2 HEADER_CON-1X2_3-96MM_1X2 H1X2 HeaderIC1P101
CON-2X5_1-27-SMDPSOC_3_PROG_HDR_CON-2X5_1-27-SMFTSH-105-01-L-DV-KIC1J107
CON-2X13M_2-0MM2X13 HEADER_2_CON-2X13M_2-0MM_22X13 HEADERIC1J108
CON-2X20FR_2-54MM2X20 HEADER_CON-2X20FR_2-54MM_22x20 HEADERIC1J109
CSB-10MMCSB_CIR_SCapSenseIC4B1; B2; B3; B4
CSS7ACAPSENSE LINEAR SLIDER 7 SEG A_CapSense Linear Slider 7 Seg AIC1CSS1
DO-214ACSCHOTTKYDIODE_1_DO-214AC_SM340ASM340AIC2D102; D111
IRM-SMD-3IRM_V538N7/TR1_IRM-SMD-3_IRM_V5IRM_V538_TR1IC1U103
JACK-EARPHONE-ACIPJ-3755B-PA6T-TR_0_JACK-EARPHONTSH-3756IC2J103; J104
JACK-MUSB-ABFMJACK-MINI-USB-AB_JACK-MUSB-ABFMJack-Mini-USB-ABIC1J102
JACK-SPDIF-TOTX147LTOTX147L_JACK-SPDIF-TOTX147L_TOTOTX147AL(F,T)IC1U104
L-0805INDUCTOR_L-0805_BEAD 2ABEAD 2AIC6L101; L102; L103; L104; L105; L106
LCD-SD1602X1X7_LCD_HDR_LCD-SD1602X_1X7 HEA1X7 HeaderIC1J106
LED-0805LED_0_LED-0805_LEDRLEDRIC4D101; D103; D104; D110
LED-0805LED_0_LED-0805_LEDGLEDGIC4D105; D106; D107; D108
MTG-250D126MH_MTG-250D126_GNDGNDIC4MH1; MH2; MH3; MH4
MTG-LED_105RD_110UMH_LED_105RD_110U_MTG-LED_105RD105RD_110U PADIC1MH6
MTG-LED_140R_140UMH_LED_140RD_140U_MTG-LED_140R_140RD_140U PADIC1MH5
OSC-2-5X3MM_DABCRYSTAL-2_0_OSC-2-5X3MM_DAB_24M24MHzIC1X102
PSOP-8LP3878MR-ADJ_PSOP-8_LP3878MR-ADLP3878MR-ADJIC2REG101; REG102
QFN-32CS42L51_3_QFN-32_CS42L51CS42L51IC1U102
R-0402RES_R-0402_10K10KIC4R101; R120; R154; R179
R-0402RES_R-0402_1.5K1.5KIC2R102; R111
R-0402RES_R-0402_100K100KIC4R104; R119; R125; R126
R-0402RES_R-0402_4.7K4.7KIC1R106
R-0402RES_R-0402_51.1K51.1KIC1R107
R-0402RES_R-0402_680 OHM680 ohmIC6R109; R146; R167; R171; R173; R175
R-0402RES_R-0402_1K1KIC1R113
R-0402RES_R-0402_2.2K2.2KIC1R117
R-0402RES_R-0402_39K39KIC9R121; R122; R129; R130; R135; R141; R142; R143; R144
R-0402RES_R-0402_30K30KIC8R123; R124; R127; R128; R133; R138; R139; R140
R-0402RES_R-0402_100 OHM100 ohmIC2R131; R145
R-0402RES_R-0402_47K47KIC2R136; R137
R-0402RES_R-0402_560 OHM560 ohmIC4R147; R148; R149; R150
R-0402RES_R-0402_47 OHM47 ohmIC1R153
R-0402RES_R-0402_560560IC5R162; R163; R164; R165; R166
R-0402RES_R-0402_0 OHM0 ohmIC9R168; R169; R172; R176; R177; R178; R188; R189; R196
R-0402RES_R-0402_7.15K OHM7.15K ohmIC1R174
R-0402RES_R-0402_22 OHM 1%22 ohm 1%IC2R193; R194
R-0402RES_R-0402_1M OHM1M ohmIC1R195
R-0603RES_R-0603_0 OHM0 ohmIC18R100; R118; R180; R181; R183; R184; R185; R190; R191; R197; R198; R199; R200; R201; R202; R203; R204; R207
R-0603RES_R-0603_16K16KIC1R103
R-0603RES_R-0603_2.05K2.05KIC1R108
R-0603RES_R-0603_806 OHM806 ohmIC1R112
R-0603RES_R-0603_270 OHM270 ohmIC1R114
R-0603RES_R-0603_49.9 OHM49.9 ohmIC4R115; R116; R182; R192
R-060310_080510 ohmIC1R132
R-0603RES_R-0603_2.7K OHM2.7K ohmIC1R170
R-0603RES_R-0603_953 OHM953 ohmIC2R186; R187
R-0805RES_R-0805_0 OHM0 ohmIC4R105; R110; R205; R206
SIP3HEADER 3_SIP3_HEADER 3HEADER 3IC1J101
SOIC-824AA512-I/SN_SOIC-8_24AA512-I/S24AA512-I/SNIC1U105
SOT-23ZVP3310/TO_0_SOT-23_AO3401AO3401IC2Q101; Q102
SW-TACT-6X6SW-BUTTON_SW-TACT-6X6_TACT SWTACT SWIC2SW101; SW102
TP1TEST_POINT_TP1_VBUSVBUSIC1TP101
TP1TEST_POINT_TP1_VSSAVSSaIC1TP102
TP1TEST_POINT_TP1_VSSDVSSdIC2TP103; TP104
TP1TEST_POINT_TP1_VSSCODECVSScodecIC1TP105
TP1TEST_POINT_TP1_VCC5VCC5IC1TP106
TP1TEST_POINT_TP1_VCCSYSVCCsysIC1TP107
TP1TEST_POINT_TP1_PSOC_CODEC_PWRPSOC_CODEC_PWRIC1TP108
TP1TEST_POINT_TP1_VDDCODECVDDcodecIC1TP109
TP1TEST_POINT_TP1_CODEC_MCLKCODEC_MCLKIC1TP110
TP1TEST_POINT_TP1_CODEC_RSTCODEC_RSTIC1TP111
TP1TEST_POINT_TP1_CODEC_SCLKCODEC_SCLKIC1TP112
TP1TEST_POINT_TP1_CODEC_LRCLKCODEC_LRCLKIC1TP113
TP1TEST_POINT_TP1_CODEC_SDTICODEC_SDTIIC1TP114
TP1TEST_POINT_TP1_CODEC_SDTOCODEC_SDTOIC1TP115
TP1TEST_POINT_TP1_PSOC_I2C_SCLPSOC_I2C_SCLIC1TP116
TP1TEST_POINT_TP1_PSOC_I2C_SDAPSOC_I2C_SDAIC1TP117
TP1TEST_POINT_TP1_DPDPIC1TP118
TP1TEST_POINT_TP1_DMDMIC1TP119
TP1TEST_POINT_TP1_PSOC_USB_SELPSOC_USB_SELIC1TP120
TQFP-100CY8C3TQFP100_TQFP-100_CY8C3866ACY8C3866AXI-040IC1U101
UMLP-10_1-8X1-4MMFSUSB30UMX_UMLP-10_1-8X1-4MM_FSFSUSB30UMXIC1U106
VR-PVG3APOT_0_VR-PVG3A_10K10KIC1VR101
XTL-11-5X4-8MM_DAB24MHZ_XTAL24 MHzIC1X101
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
6 K% f2 f, Q' S. N
GMT+8, 2025-7-21 05:45 , Processed in 0.125000 second(s), 28 queries , Gzip On.
