查看: 262|回复: 0
[allegro16.3][4层]一款车联网PCB—M500_GPS(NEO_5Q+AP9564+GM6603ATC3)pcb文件
发表于 2019-12-25 13:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 `  h0 Y# D7 @- A' @% ?' T! T% m9 [
文件描述:
) d1 E1 Z- j; R" }+ K- T
1. 作品用途:一款车联网PCB—M500_GPS
2. 软件版本:allegro16.3
3. 层数:4层
4. 用到的主要芯片:NEO_5Q+AP9564+GM6603ATC3
5.pcb尺寸:44.7*39.7mm
1 d3 u1 W% `+ S3 U
+ k. j) R4 l" q1 w4 W* L% q% g
作品截图如下:
1 q* l. u# D, a3 T  `, \
$ W$ E+ \. _# K+ Q' l) B* d: v
顶层截图:
0 ^; x, v2 N2 z0 R
底层截图:
4 e: v# e* l" b2 J+ ~8 V3 J: A. {4 W
8 y; c# {' T( \  t
全层截图:
4 k$ f- ~: ^- B; Q0 z% \4 j6 }/ b# n% B* m* ?8 \6 b1 @
  S  H7 J  X' H' |/ p# ^7 `! o5 [
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
8PIN_2R0CON8_8PIN_2R0_CON8CON8IC1J11
12PIN_1R27CON12_12PIN_1R27_CON12CON12IC2J12;J13
7343BCE_SMT_7343B_22UF/16V22UF/16VIC1C26
7343BCE_SMT_7343B_100UF100UFIC2C30;C44
C-0402CAP NP_C-0402_100NF100nFIC8C23;C29;C31;C38;C39;C40;C43;C45
C-0402CAP NP_C-0402_10NF10nFIC1C24
C-0402CAP NP_C-0402_NC/22PFNC/22pFIC2C25;C27
C-0402CAP NP_C-0402_4.7UF4.7uFIC1C34
C-0402CAP NP_C-0402_1UF1uFIC1C35
C-0402CAP NP_C-0402_33PF33pFIC1C36
C-0402CAP NP_C-0402_NC/100NFNC/100nFIC1C37
C-0805CAP NP_C-0805_1UF1UFIC1C32
C-1812CAP NP_C-1812_100NF100NFIC1C33
D-0603LED_D-0603_LEDLEDIC3D1;D3;D7
D-1206DIODE_2_D-1206_LMSZ5233BT1GLMSZ5233BT1GIC1D8
D-1206TVS_0_D-1206_DSK26DSK26IC2Z2;Z3
D_5R8_H_1R8BATTERY_D_5R8_H_1R8_3V3VIC1BT1
EMD2DIODE PIN_EMD2_RB751S-40RB751S-40IC1D5
GPS_25X25ANT_2_GPS_25X25_GPS_CONNGPS_CONNIC1ANT1
L20QUECTEL-L20_L20_NEO_5QNEO_5QIC1U12
R-0402MOT_RES_R-0402_2.2K_-/+5%2.2KIC2R4;R79
R-0402R0603_R-0402_2.2K2.2KIC1R58
R-0402R0603_R-0402_470R470RIC2R61;R67
R-0402R0603_R-0402_0R0RIC2R62;R72
R-0402R0603_R-0402_10R10RIC1R63
R-0402R0603_R-0402_NC/0RNC/0RIC1R64
R-0402R0603_R-0402_10K10KIC2R65;R75
R-0402R0603_R-0402_NC/10KNC/10KIC1R66
R-0402R0603_R-0402_100R100RIC2R68;R69
R-0402R0603_R-0402_402K402KIC1R70
R-0402R0603_R-0402_39K39KIC1R71
R-0402R0603_R-0402_100K100KIC1R73
R-0402R0603_R-0402_71.5K71.5KIC1R74
R-0402R_R-0402_820K820KIC1R76
R-0402R_R-0402_1K1kIC1R77
R-0402R0603_R-0402_110K110KIC1R78
R-0402MOT_RES_R-0402_100K_-/+5%100KIC4R80;R81;R82;R88
R-0402R_R-0402_220R220RIC1R89
R-0402R_R-0402_510R510RIC1R90
R-0603BEAD_0_R-0603_600R@100MHZ600R@100MHZIC1B1
SMATVS_1_SMA_SS34SS34IC1Z1
SMD_L_11R5X11X4L_SMT_SMD_L_11R5X11X4_33UH33UHIC1L2
SO8NMP24971_0_SO8N_MP2497_DN_LF_ZMP2497_DN_LF_ZIC1U14
SOIC-8IRF7204_0_SOIC-8_AP9564AP9564IC1U13
SOT25CON5_4_SOT25_AX6607AX6607IC1U15
SOT252LM1085_0_SOT252_GM6603ATC3GM6603ATC3IC1U17
SOT323L14C1/TO_2_SOT323_MUN5214T1GMUN5214T1GIC4Q15;Q18;Q20;Q23
SOT-23DIODE_0_SOT-23_RB715DRB715DIC1D4
SOT-23APM2301_SOT-23_IRLM6402IRLM6402IC4Q16;Q17;Q19;Q22
TEST0R8TP_TEST0R8_TPTPIC2GPS_RXD1;GPS_TXD1
TO-277ADIODE_0_TO-277A_S4PBS4PBIC1D6
附件:
pcb文件如下:
游客,如果您要查看本帖隐藏内容请回复
5 A* Y2 d7 x5 l. y
GMT+8, 2025-7-20 20:44 , Processed in 0.140625 second(s), 29 queries , Gzip On.
