查看: 512|回复: 1
[allegro16.3][4层]一款车联网PCB—M500_EVDO(MC850+STM32F103RDT6+USB)pcb文件
发表于 2019-12-24 17:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
) L5 k, k# B1 d. N& I5 k+ K! ]- h' L( s
文件描述:
5 s& m: K" Z9 A2 r
1. 作品用途:一款车联网PCB—M500_EVDO
2. 软件版本:allegro16.3
3. 层数:4层
4. 用到的主要芯片:MC850+STM32F103RDT6+USB
2 q: T5 ^! N" f9 s& P
0 b7 \; p3 O& }# V; {
作品截图如下:
. |7 h4 i' @0 H7 z4 ^2 I
顶层截图:
# c9 U5 z( c/ h4 a0 P
底层截图:
0 f) x0 D# m. |$ [" F  j* w% b4 u
3 Y0 l5 g& e3 F  {+ d) i& j  b
全层截图:
9 R2 I& R2 Z* q
3 a1 T- h) w) R# o
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
2PIN_2R0B2S_0_2PIN_2R0_JUMPERjumperIC1J5
12PIN_1R27CON12_12PIN_1R27_CON12CON12IC4J16; J18; M500_GPS0_J12; M500_GPS0_J13
20PIN_1R27_ACON20_20PIN_1R27_A_CON20CON20IC1J23
7343BCE_SMT_7343B_22UF/16V22UF/16VIC1M500_GPS0_C26
7343BCE_SMT_7343B_100UF100UFIC2M500_GPS0_C30; M500_GPS0_C44
C-0402CAP NP_C-0402_22PF22PFIC4C1; C2; C12; C13
C-0402CAP NP_C-0402_100NF100NFIC10C3; C4; C5; C6; C7; C8; C9; C10; C39; C46
C-0402CAP NP_C-0402_10NF10nFIC2C11; M500_GPS0_C24
C-0402CAP NP_C-0402_1UF1uFIC3C14; C15; M500_GPS0_C35
C-0402CAP NP_C-0402_NC/1.5PFNC/1.5pFIC2C16; C17
C-0402CAP NP_C-0402_100NF100nFIC8M500_GPS0_C23; M500_GPS0_C29; M500_GPS0_C31; M500_GPS0_C38; M500_GPS0_C39; M500_GPS0_C40; M500_GPS0_C43; M500_GPS0_C45
C-0402CAP NP_C-0402_NC/22PFNC/22pFIC2M500_GPS0_C25; M500_GPS0_C27
C-0402CAP NP_C-0402_4.7UF4.7uFIC2M500_GPS0_C34; M500_GPS0_C42
C-0402CAP NP_C-0402_33PF33pFIC1M500_GPS0_C36
C-0402CAP NP_C-0402_NC/100NFNC/100nFIC1M500_GPS0_C37
C-0402CAP NP_C-0402_15PF15pFIC1M500_GPS0_C47
C-0805CAP NP_C-0805_10UF/10V10UF/10VIC1C22
C-0805CAP NP_C-0805_1UF1UFIC1M500_GPS0_C32
C-0805CAP NP_C-0805_10UF10uFIC1M500_GPS0_C46
C-1812CAP NP_C-1812_100NF100NFIC1M500_GPS0_C33
D-0603LED_D-0603_LEDLEDIC3M500_GPS0_D1; M500_GPS0_D3; M500_GPS0_D7
D-1206DIODE 34/DPAK_5_D-1206_IN4148IN4148IC1D2
D-1206DIODE_2_D-1206_LMSZ5233BT1GLMSZ5233BT1GIC1M500_GPS0_D8
D-1206TVS_0_D-1206_DSK26DSK26IC4M500_GPS0_Z2; M500_GPS0_Z3; Z4; Z5
D_6R8_H_1R8BATTERY_D_6R8_H_1R8_3V3VIC1M500_GPS0_BT1
EMD2DIODE PIN_EMD2_RB751S-40RB751S-40IC1M500_GPS0_D5
GPS_25X25ANT_2_GPS_25X25_GPS_CONNGPS_CONNIC1M500_GPS0_ANT1
GSM_ANTCON2_GSM_ANT_EVDO_CONN1EVDO_CONN1IC1J10
L20QUECTEL-L20_L20_NEO_5QNEO_5QIC1M500_GPS0_U12
LGA14ADXL345_0_LGA14_ADXL345ADXL345IC1U4
LGA145MU270_LGA145_(S1+S2)_MC850MC850IC1U10
LQFP64_10X10STM32F103RCT6_1_LQFP64_10X10_STSTM32F103RDT6IC1U1
MICRO_SIM_CONN_ACON8_MICRO_SIM_CONN_A_CON8CON8IC1J14
MICRO_USBUSB_A/B_0_MICRO_USB_USBUSBIC1J2
OSCCC250X320X100AY4SMD_OSCCC250X320X100A_12MHZ12MHzIC1Y2
R-0402MOT_RES_R-0402_2.2K_-/+5%2.2KIC2M500_GPS0_R4; M500_GPS0_R79
R-0402R0603_R-0402_2.2K2.2KIC1M500_GPS0_R58
R-0402R0603_R-0402_470R470RIC3M500_GPS0_R61; R39; R41
R-0402R0603_R-0402_0R0RIC5M500_GPS0_R62; M500_GPS0_R72; R55; R83; R84
R-0402R0603_R-0402_10R10RIC1M500_GPS0_R63
R-0402R0603_R-0402_NC/0RNC/0RIC1M500_GPS0_R64
R-0402R0603_R-0402_NC/10KNC/10KIC2M500_GPS0_R65; M500_GPS0_R66
R-0402R0603_R-0402_NC/470RNC/470RIC1M500_GPS0_R67
R-0402R0603_R-0402_100R100RIC2M500_GPS0_R68; M500_GPS0_R69
R-0402R0603_R-0402_402K402KIC1M500_GPS0_R70
R-0402R0603_R-0402_39K39KIC1M500_GPS0_R71
R-0402R0603_R-0402_100K100KIC1M500_GPS0_R73
R-0402R0603_R-0402_71.5K71.5KIC1M500_GPS0_R74
R-0402R0603_R-0402_10K10KIC1M500_GPS0_R75
R-0402R_R-0402_820K820KIC1M500_GPS0_R76
R-0402R_R-0402_1K1kIC2M500_GPS0_R77; M500_GPS0_R83
R-0402R0603_R-0402_110K110KIC1M500_GPS0_R78
R-0402MOT_RES_R-0402_100K_-/+5%100KIC4M500_GPS0_R80; M500_GPS0_R81; M500_GPS0_R82; M500_GPS0_R88
R-0402R_R-0402_220R220RIC1M500_GPS0_R89
R-0402R_R-0402_510R510RIC1M500_GPS0_R90
R-0402R_R-0402_453K453kIC1M500_GPS0_R91
R-0402R_R-0402_100K100kIC1M500_GPS0_R92
R-0402R0603_R-0402_10K10kIC15R1; R3; R7; R8; R17; R18; R20; R23; R27; R29; R37; R45; R46; R51; R52
R-0402R0603_R-0402_510R510RIC1R2
R-0402R0603_R-0402_NC/4.7KNC/4.7KIC1R5
R-0402R0603_R-0402_4.7K4.7KIC17R6; R12; R13; R14; R15; R19; R22; R24; R26; R30; R31; R32; R33; R34; R35; R36; R42
R-0402R0603_R-0402_2.7K2.7KIC1R16
R-0402R0603_R-0402_1.5K1.5KIC2R21; R40
R-0402R0603_R-0402_2K2KIC2R25; R43
R-0402R0603_R-0402_1K1KIC1R28
R-0402R0603_R-0402_240R240RIC1R38
R-0402R0603_R-0402_680R680RIC1R44
R-0402R0603_R-0402_3.3K3.3KIC2R47; R53
R-0402R0603_R-0402_20K20KIC2R48; R54
R-0402MOT_RES_0_R-0402_10K10KIC2R49; R50
R-0603BEAD_0_R-0603_600R@100MHZ600R@100MHZIC1M500_GPS0_B1
R-1206L_SMT_R-1206_2.7UH2.7UHIC1M500_GPS0_L3
SMATVS_1_SMA_SS34SS34IC1M500_GPS0_Z1
SMD5032Y4SMD_SMD5032_8MHZ8MHzIC1Y1
SMD_L_11R5X11X4L_SMT_SMD_L_11R5X11X4_33UH33UHIC1M500_GPS0_L2
SO8NMP24971_0_SO8N_MP2497_DN_LF_ZMP2497_DN_LF_ZIC1M500_GPS0_U14
SOIC-8IRF7204_0_SOIC-8_AP9564AP9564IC1M500_GPS0_U13
SOIC-8WEN25Q64_4_SOIC-8W_EN25Q64EN25Q64IC1U3
SOIC-8MP24971_3_SOIC-8_LM317LLM317LIC1U7
SOIC-8MCP2551T-I/SN_0_SOIC-8_MCP2551MCP2551IC2U8; U9
SOT25CON5_4_SOT25_AX660733BAAX660733BAIC1M500_GPS0_U15
SOT25CON5_4_SOT25_AX3513BTAAX3513BTAIC1M500_GPS0_U16
SOT252LM1085_0_SOT252_GM6603ATC3GM6603ATC3IC1M500_GPS0_U17
SOT323L14C1/TO_2_SOT323_MUN5214T1GMUN5214T1GIC5M500_GPS0_Q18; M500_GPS0_Q20; M500_GPS0_Q21; M500_GPS0_Q23; Q18
SOT-23DIODE_0_SOT-23_RB715DRB715DIC1M500_GPS0_D4
SOT-23APM2301_SOT-23_IRLM6402IRLM6402IC4M500_GPS0_Q16; M500_GPS0_Q17; M500_GPS0_Q19; M500_GPS0_Q22
SOT-23PNP BCE_0_SOT-23_39063906IC3Q1; Q5; Q7
SOT-23L14C1/TO_0_SOT-23_39043904IC8Q2; Q3; Q4; Q6; Q8; Q9; Q11; Q13
SOT-23PNP BCE_0_SOT-23_2N29072N2907IC2Q10; Q12
SSOP20H340T_SSOP20_H340TH340TIC1U5
TEST0R8TP_TEST0R8_TPTPIC6CS1; M500_GPS0_GPS_RXD1; M500_GPS0_GPS_TXD1; SCLK1; SI1; SO1
TO-277ADIODE_0_TO-277A_S4PBS4PBIC1M500_GPS0_D6
TSSOP14CD4066_2_TSSOP14_CD4066CD4066IC1U2
TSSOP14LM339_TSSOP14_LM339LM339IC1U6
TSSOP16CD4052B/SO_0_TSSOP16_74HC405274HC4052IC1U17
USS_RF_IIANT_5_USS_RF_II_EVDO_C0NNEVDO_C0NNIC1J1
XLW003XCON24_0_XLW003X_CON23CON23IC1J17
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
" N$ s( k7 X( r7 f  {
! d% ?9 h0 n$ f0 k: b2 a" c
GMT+8, 2025-7-2 22:55 , Processed in 0.093750 second(s), 27 queries , Gzip On.
