Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2PIN_2R0 | B2S_0_2PIN_2R0_JUMPER | jumper | IC | 1 | J5 |
12PIN_1R27 | CON12_12PIN_1R27_CON12 | CON12 | IC | 4 | J16; J18; M400GPS1V5_J12; M400GPS1V5_J13 |
20PIN_1R27_A | CON20_20PIN_1R27_A_CON20 | CON20 | IC | 1 | J23 |
7343B | CE_SMT_7343B_22UF/16V | 22UF/16V | IC | 1 | M400GPS1V5_C26 |
7343C | CE_SMT_7343C_100UF | 100UF | IC | 2 | M400GPS1V5_C30; M400GPS1V5_C44 |
7343D | CE_SMT_7343D_470UF | 470UF | IC | 2 | C30; C31 |
ANT_522515_2R54 | CON2_ANT_522515_2R54_GSM_CONN1 | GSM_CONN1 | IC | 1 | J10 |
C-0402 | CAP NP_C-0402_22PF | 22PF | IC | 4 | C1; C2; C12; C13 |
C-0402 | CAP NP_C-0402_100NF | 100NF | IC | 15 | C3; C4; C5; C6; C7; C8; C9; C10; C46; M400GPS1V5_C29; M400GPS1V5_C31; M400GPS1V5_C38; M400GPS1V5_C40; M400GPS1V5_C43; M400GPS1V5_C45 |
C-0402 | CAP NP_C-0402_10NF | 10nF | IC | 1 | C11 |
C-0402 | CAP NP_C-0402_1UF | 1uF | IC | 4 | C14; C15; M400GPS1V5_C35; M400GPS1V5_C46 |
C-0402 | CAP NP_C-0402_NC/1.5PF | NC/1.5pF | IC | 2 | C16; C17 |
C-0402 | CAP NP_C-0402_0.01UF | 0.01uF | IC | 2 | C18; M400GPS1V5_C50 |
C-0402 | CAP NP_C-0402_4.7UF | 4.7uF | IC | 2 | M400GPS1V5_C34; M400GPS1V5_C47 |
C-0402 | CAP NP_C-0402_33PF | 33pF | IC | 2 | M400GPS1V5_C36; M400GPS1V5_C55 |
C-0402 | CAP NP_C-0402_NC/100NF | NC/100nF | IC | 2 | M400GPS1V5_C37; M400GPS1V5_C39 |
C-0402 | CAP NP_C-0402_22PF | 22pF | IC | 2 | M400GPS1V5_C48; M400GPS1V5_C52 |
C-0402 | CAP NP_C-0402_10PF | 10pF | IC | 1 | M400GPS1V5_C51 |
C-0805 | CAP NP_C-0805_10UF/10V | 10UF/10V | IC | 1 | C22 |
C-0805 | CAP NP_C-0805_1UF | 1UF | IC | 1 | M400GPS1V5_C32 |
C-1812 | CAP NP_C-1812_2.2UF | 2.2UF | IC | 1 | M400GPS1V5_C33 |
CABLE_PAD | B2S_CABLE_PAD_B2S | B2S | IC | 1 | M400GPS1V5_J7 |
D-0603 | LED_D-0603_LED | LED | IC | 3 | M400GPS1V5_D1; M400GPS1V5_D3; M400GPS1V5_D7 |
D-1206 | DIODE 34/DPAK_5_D-1206_IN4148 | IN4148 | IC | 1 | D2 |
D-1206 | DIODE_2_D-1206_LMSZ5233BT1G | LMSZ5233BT1G | IC | 1 | M400GPS1V5_D8 |
D-1206 | TVS_0_D-1206_DSK26 | DSK26 | IC | 3 | M400GPS1V5_Z3; Z4; Z5 |
D_6R8_H_1R8 | BATTERY_D_6R8_H_1R8_3V | 3V | IC | 1 | M400GPS1V5_BT1 |
EMD2 | DIODE PIN_EMD2_RB751S-40 | RB751S-40 | IC | 1 | M400GPS1V5_D5 |
L20 | QUECTEL-L20_L20_NEO_7M | NEO_7M | IC | 1 | M400GPS1V5_U12 |
LGA14 | ADXL345_0_LGA14_ADXL345 | ADXL345 | IC | 1 | U4 |
LQFP64_10X10 | STM32F103RCT6_1_LQFP64_10X10_ST | STM32F103RDT6 | IC | 1 | U1 |
M35 | M35_1_M35_M35 | M35 | IC | 1 | U10 |
MICRO_SIM_CONN | CON12_MICRO_SIM_CONN_CON12 | CON12 | IC | 1 | J14 |
OSCCC250X320X100A | Y4SMD_OSCCC250X320X100A_12MHZ | 12MHz | IC | 1 | Y2 |
R-0402 | MOT_RES_R-0402_2.2K_-/+5% | 2.2K | IC | 2 | M400GPS1V5_R4; M400GPS1V5_R79 |
R-0402 | R0603_R-0402_2.2K | 2.2K | IC | 1 | M400GPS1V5_R58 |
R-0402 | R0603_R-0402_470R | 470R | IC | 3 | M400GPS1V5_R61; R39; R41 |
R-0402 | R0603_R-0402_NC/10R | NC/10R | IC | 1 | M400GPS1V5_R63 |
R-0402 | R0603_R-0402_0R | 0R | IC | 4 | M400GPS1V5_R64; M400GPS1V5_R72; M400GPS1V5_R95; R55 |
R-0402 | R0603_R-0402_NC/10K | NC/10K | IC | 2 | M400GPS1V5_R65; M400GPS1V5_R66 |
R-0402 | R0603_R-0402_NC/470R | NC/470R | IC | 1 | M400GPS1V5_R67 |
R-0402 | R0603_R-0402_1K | 1K | IC | 4 | M400GPS1V5_R68; M400GPS1V5_R69; R4; R28 |
R-0402 | R0603_R-0402_402K | 402K | IC | 1 | M400GPS1V5_R70 |
R-0402 | R0603_R-0402_39K | 39K | IC | 1 | M400GPS1V5_R71 |
R-0402 | R0603_R-0402_100K | 100K | IC | 1 | M400GPS1V5_R73 |
R-0402 | R0603_R-0402_71.5K | 71.5K | IC | 1 | M400GPS1V5_R74 |
R-0402 | R0603_R-0402_10K | 10K | IC | 1 | M400GPS1V5_R75 |
R-0402 | R_R-0402_820K | 820K | IC | 1 | M400GPS1V5_R76 |
R-0402 | R_R-0402_1K | 1k | IC | 2 | M400GPS1V5_R77; M400GPS1V5_R81 |
R-0402 | R0603_R-0402_110K | 110K | IC | 1 | M400GPS1V5_R78 |
R-0402 | MOT_RES_R-0402_100K_-/+5% | 100K | IC | 3 | M400GPS1V5_R80; M400GPS1V5_R82; M400GPS1V5_R88 |
R-0402 | R_R-0402_220R 1% | 220R 1% | IC | 1 | M400GPS1V5_R89 |
R-0402 | R_R-0402_510R 1% | 510R 1% | IC | 1 | M400GPS1V5_R90 |
R-0402 | R0603_R-0402_10K | 10k | IC | 15 | R1; R3; R7; R8; R17; R18; R20; R23; R27; R29; R37; R45; R46; R51; R52 |
R-0402 | R0603_R-0402_510R | 510R | IC | 1 | R2 |
R-0402 | R0603_R-0402_47K | 47K | IC | 1 | R5 |
R-0402 | R0603_R-0402_4.7K | 4.7K | IC | 17 | R6; R12; R13; R14; R15; R19; R22; R24; R26; R30; R31; R32; R33; R34; R35; R36; R42 |
R-0402 | R0603_R-0402_2.7K | 2.7K | IC | 1 | R16 |
R-0402 | R0603_R-0402_1.5K | 1.5K | IC | 2 | R21; R40 |
R-0402 | R0603_R-0402_2K | 2K | IC | 2 | R25; R43 |
R-0402 | R0603_R-0402_240R | 240R | IC | 1 | R38 |
R-0402 | R0603_R-0402_680R | 680R | IC | 1 | R44 |
R-0402 | R0603_R-0402_3.3K | 3.3K | IC | 2 | R47; R53 |
R-0402 | R0603_R-0402_20K | 20K | IC | 2 | R48; R54 |
R-0402 | MOT_RES_0_R-0402_10K | 10K | IC | 2 | R49; R50 |
R-0402 | R_R-0402_0R | 0R | IC | 2 | R56; R57 |
R-0402 | R0603_R-0402_100R | 100R | IC | 2 | R59; R60 |
R-0603 | INDUCTOR_R-0603_100NH | 100nH | IC | 1 | M400GPS1V5_L3 |
SMA | TVS_1_SMA_SS34 | SS34 | IC | 1 | M400GPS1V5_Z1 |
SMD5032 | Y4SMD_SMD5032_8MHZ | 8MHz | IC | 1 | Y1 |
SMD_L_11R5X11X4 | L_SMT_SMD_L_11R5X11X4_33UH | 33UH | IC | 1 | M400GPS1V5_L2 |
SO8N | MP24971_0_SO8N_MP2497_DN_LF_Z | MP2497_DN_LF_Z | IC | 1 | M400GPS1V5_U14 |
SOIC-8 | IRF7204_0_SOIC-8_AP9564 | AP9564 | IC | 1 | M400GPS1V5_U13 |
SOIC-8W | EN25Q64_4_SOIC-8W_EN25Q64 | EN25Q64 | IC | 1 | U3 |
SOIC-8 | MP24971_3_SOIC-8_LM317L | LM317L | IC | 1 | U7 |
SOIC-8 | MCP2551T-I/SN_0_SOIC-8_MCP2551 | MCP2551 | IC | 2 | U8; U9 |
SOT25 | CON5_4_SOT25_ME621133M5G | ME621133M5G | IC | 2 | M400GPS1V5_U15; M400GPS1V5_U18 |
SOT252 | LM1085_0_SOT252_GM6603ATC3 | GM6603ATC3 | IC | 1 | M400GPS1V5_U17 |
SOT323 | L14C1/TO_2_SOT323_MUN5214T1G | MUN5214T1G | IC | 7 | M400GPS1V5_Q15; M400GPS1V5_Q18; M400GPS1V5_Q20; M400GPS1V5_Q21; M400GPS1V5_Q23; Q14; Q15 |
SOT-23 | DIODE_0_SOT-23_RB715F | RB715F | IC | 1 | M400GPS1V5_D4 |
SOT-23 | APM2301_SOT-23_MT2305 | MT2305 | IC | 3 | M400GPS1V5_Q16; M400GPS1V5_Q19; M400GPS1V5_Q22 |
SOT-23 | PNP BCE_0_SOT-23_3906 | 3906 | IC | 3 | Q1; Q5; Q7 |
SOT-23 | L14C1/TO_0_SOT-23_3904 | 3904 | IC | 8 | Q2; Q3; Q4; Q6; Q8; Q9; Q11; Q13 |
SOT-23 | PNP BCE_0_SOT-23_2N2907 | 2N2907 | IC | 2 | Q10; Q12 |
SSOP20 | H340T_SSOP20_H340T | H340T | IC | 1 | U5 |
TEST0R8 | TP_TEST0R8_TP | TP | IC | 8 | CS1; GSM_RXD1; GSM_TXD1; M400GPS1V5_GPS_RXD1; M400GPS1V5_GPS_TXD1; SCLK1; SI1; SO1 |
TEST_1R00 | TP_TEST_1R00_TP | TP | IC | 5 | GND; TP1; TP2; TP3; TP4 |
TO-277A | DIODE_0_TO-277A_S4PB | S4PB | IC | 2 | M400GPS1V5_D6; M400GPS1V5_D9 |
TSSOP14 | CD4066_2_TSSOP14_CD4066 | CD4066 | IC | 1 | U2 |
TSSOP14 | LM339_TSSOP14_LM339 | LM339 | IC | 1 | U6 |
TSSOP16 | CD4052B/SO_0_TSSOP16_74HC4052 | 74HC4052 | IC | 1 | U17 |
