查看: 390|回复: 3
[allegro16.3][6层]finy2451核心板(s3c2443fbga+2片DDR+TF卡)pcb文件
发表于 2019-12-24 15:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
3 w: H. h( u+ ~, H8 B- W7 E* S
. O% C: N# x  {: }) D( h% w9 c
文件描述:
9 P( i6 H: O/ I0 a" w! T) ], C8 ~
$ J9 L" E# H; o3 R
1. 作品用途:finy2451核心板
2. 软件版本:allegro16.3
3. 层数:6层
4. 用到的主要芯片:s3c2443fbga+2片DDR+TF卡
5. PCB尺寸:2710.630 *1962.5910 mil
' L0 P( x. h; w
作品截图如下:
% v# y( E) L9 r. C( G/ @  M% A( c1 J' G: l8 R
顶层截图:
; E  d, E" i- b( \) X3 J3 v) o
底层截图:
# E, Q) m6 h# _2 {8 o- z2 |8 I+ Q7 Q
& n6 q0 ^4 q+ r* D, \# ?/ h- t4 J
  t8 b1 l8 [# s( h/ j* }/ I2 ]% t1 ?& p& E* n
: m+ T' j1 ^9 @* n
全层截图:
9 D5 ~2 C4 j9 C( L
% g1 U, Q) v3 n+ ~0 Q
( D" ^% }( \( d" _" R) T! \
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402CAPCAP_0402CAP_0.1UF0.1uFIC52C1; C3; C4; C15; C16; C17; C18; C22; C24; C25; C26; C27; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; CC1; CM2; CM4; CM5; CM6; CM7; CM8; CM9; CM10; CM11; CM12; CM13; CM14; CM15; CM16; CM17; CM18; CM19; CM20; CM23; CO1; CO2; CO3; CO6; CO10; CO14; CO17
0402CAPCAP_0402CAP_10NF(Y)10nF(Y)IC1C5
0402CAPCAP_0402CAP_22P22pIC2C6; C7
0402CAPCAP_0402CAP_15P15pIC4C8; C9; C10; C11
0402CAPCAP_0402CAP_1.8NF/5%1.8nF/5%IC1C13
0402CAPCAP_0402CAP_1NF1nFIC12C14; C23; C28; C43; CM1; CM3; CO4; CO7; CO9; CO11; CO12; CO15
0402CAPCAP_0402CAP_10NF10nFIC1C19
0402RESRES_0402RES_10K10KIC37R1; R12; R13; R14; R15; R17; R21; R33; R34; R44; R45; R46; R47; R48; R49; R53; R63; R64; R71; RC1; RC2; RC3; RC4; RC5; RC6; RD5; RD6; RM5; RM6; RM7; RM8; RM11; RM12; RM13; RM14; RO15; RO19
0402RESRES_0402RES_100K100KIC5R2; R27; RO1; RO8; RO11
0402RESRES_0402RES_1K1KIC12R3; R16; R24; R26; R28; R60; R61; RD1; RD2; RD3; RD4; RO2
0402RESRES_0402RES_330R330RIC1R4
0402RESRES_0402RES_10R10RIC1R5
0402RESRES_0402RES_100K(NC)100K(NC)IC2R6; R30
0402RESRES_0402RES_100R100RIC3R7; R55; R57
0402RESRES_0402RES_22K22KIC6R8; R9; R10; R11; RO10; RO16
0402RESRES_0402RES_4.7K4.7KIC6R18; R19; R20; R25; RO9; RO18
0402RESRES_0402RES_0R0RIC11R22; R58; R59; RJ1; RJ3; RO3; RO5; RO6; RO7; RO13; RO14
0402RESRES_0402RES_0R(NC)0R(NC)IC4R23; R29; RJ2; RJ4
0402RESRES_0402RES_51K51KIC2R31; RO20
0402RESRES_0402RES_0R(Y)0R(Y)IC1R32
0402RESRES_0402RES_0R(X)0R(X)IC2R35; R40
0402RESRES_0402RES_22R(Y)22R(Y)IC1R36
0402RESRES_0402RES_1M(X)1M(X)IC1R37
0402RESRES_0402RES_22R22RIC7R38; R39; R41; R43; R51; R54; R56
0402RESRES_0402RES_1M1MIC2R42; RO4
0402RESRES_0402RES_5M5MIC1R50
0402RESRES_0402RES_44.2R/1%44.2R/1%IC1R52
0402RESRES_0402RES_10K(NC)10K(NC)IC7R62; RM1; RM2; RM3; RM4; RM9; RM10
0402RESRES_0402RES_33R33RIC6R65; R66; R67; R68; R69; R70
0603CAPCAPCE_0603CAP_2.2UF/10V2.2uF/10vIC3C12; CO18; CO19
0603INDRES_FB_0603IND_600OHM/100M600ohm/100MIC7FB1; FB2; FBC1; FBO1; FBO2; FBO3; FBO4
0603LEDDLED_0603LEDD_REDLEDREDLEDIC3LEDD1; LEDD4; LEE1
0603LEDDLED_0603LEDD_GREENLEDGreenLEDIC1LEDD2
0603LEDDLED_0603LEDD_YELLOW/BLUELEDyellow/blueLEDIC1LEDD3
0603RESRES_0603RES_0R(NC)0R(NC)IC1RO12
0805CAPCAPCE_0805CAP_10UF/10V10uF/10VIC11C2; C20; C21; C29; CM21; CM22; CM24; CO5; CO8; CO13; CO16
0805RESRES_0805RES_10R10RIC1RO17
CY015X7MMCRY_STAL3PIN_CY015X7MM_32.768KH32.768KHzIC1X3
FBGA380E0MM65S3C2443FBGA_FBGA380E0MM65_S3C24s3c2443fbgaIC1U1
LL34DIODE_LL34_SS14SS14IC2D1; DO2
PBZ_42X39MMTPO_PBZ_42X39MM_PBZ_42X39MMpbz_42x39mmIC1PBZ1
QF84BGAK4T51163QI_QF84BGA_K4T51163QEK4T51163QEIC2UM1; UM2
SA4028HSWPUSH_SA4028H_NRESETnRESETIC1SW1
SCO32CRY_OSCILLATOR_SCO32_48MH48MHIC1X1
SCO32CRY_CPX3225_SCO32_12MHZ12MHzIC1X2
SOCK2MM0THP4X2ACON4X2A_SOCK2MM0THP4X2A_CON4X2Acon4x2aIC1JTAG1
SOCK2MM0THP15X2ACON15X2A_SOCK2MM0THP15X2A_CON15con15x2aIC1J1
SOP8E1MM27F7MM62SWITCH-4_SOP8E1MM27F7MM62_SWITCSWITCH-4IC1SW2
SOT23V5PINTPS6226X_BL8563_SOT23V5PIN_BL85BL8563_33PRAIC1UO1
SOT23V5PINXC6221BXX_SOT23V5PIN_6221B182MR6221B182MRIC1UO3
SOT23V6PINRT9011_MGPJ6_SOT23V6PIN_RT9011_rt9011_mgpj6IC1UO6
SOT23V123BAT54C_SOT23V123_BAT54Cbat54cIC1DO1
SOT23V123AO3401PMOS_SOT23V123_AO3401AO3401IC1MOS1
SOT23V123SOT23NPN_SOT23V123_MMBT3904MMBT3904IC3QO1; VT1; VT2
SOT23V123XC6206_TOREX_SOT23V123_TOREX_XCtorex_xc6206_1.2VIC1UO2
SOT143V4PINMAX811_SOT143V4PIN_APB97APB97IC1IC1
TF14X15V9PTFCARD9P_TF14X15V9P_TFCARD9Ptfcard9pIC1TF1
TH2MM0_2X3_162PINBORD_162PIN_TH2MM0_2X3_162PIN_Bbord_162pinIC1BORD1
TP1MM0TPO_TP1MM0_SADDR13SADDR13IC1TP1
TP1MM0TPO_TP1MM0_PWR_ENPWR_ENIC1TP2
TP1MM0TPO_TP1MM0_VDD3V3VDD3V3IC2TP3; TP7
TP1MM0TPO_TP1MM0_VDD1V2VDD1V2IC1TP4
TP1MM0TPO_TP1MM0_VDD1V8VDD1V8IC1TP5
TP1MM0TPO_TP1MM0_VDD1V3VDD1V3IC1TP6
TSOP48E0MM5Z21MMK9F2G08U0B_TSOP48E0MM5Z21MM_K9FK9F2G08U0DIC1U2
WDFN_6L2X2RT8010_WDFN_6L2X2_RT8010ART8010AIC2UO4; UO5
XR3030LINDUCTOR_XR3030L_3.3UH/2A3.3uH/2AIC2LO1; LO2
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
" B; \. l- U  |) C( u
    2025-7-3 15:26
  • 签到天数: 553 天
    [LV.9]以坛为家II
    发表于 2021-2-23 12:16 | 只看该作者
    下载学习,经验9 }, k* a/ l% i. x
    0 k! M- U4 N+ L
    7 b/ L+ H8 k3 G: g3 E3 c
    擦汗
    2021-9-2 15:13
  • 签到天数: 344 天
    [LV.8]以坛为家I
    发表于 2021-3-2 15:24 | 只看该作者
    下载学习一下,
    GMT+8, 2025-7-5 18:49 , Processed in 0.125000 second(s), 27 queries , Gzip On.
