作品名:[AD 9][2层] 1块芯片是(LPC2229B+ISP1160+IS61LV25616)的原理图和PCB源文件 , ?$ M0 l) s# Y' ^6 x* E1 ^
1 P0 i6 W; C' u3 d文件描述 1. 软件版本:AD 9 2. 层数:2层板 3. 用到的主要芯片:LPC2229B+ISP1160+IS61LV25616 4. PCB尺寸:130.6mm*88.7mm
1 Q9 H% t' ~1 Y, D$ _作品截图如下: 顶层截图:
) z4 w6 S3 c4 V& Z( I! J8 i底层截图:
& Q' C* k% C5 t9 E- R全层截图:
* I0 j6 o3 T7 |9 Q. [叠层信息截图如下: ! M- e+ D1 j1 ]) L2 b7 H! {" u4 ~
BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 3.6V | BT1 | BATT | 1 | 104 | C1, C2, C3, C5, C8, C11, C12, C13, C14, C15, C19, C20, C21, C22, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C50 | 0603 | 36 | 15P | C4 | 0603 | 1 | 22P | C6, C7, C9, C10 | 0603 | 4 | 220uF10V | C16 | RBB | 1 | 47 | C17, C18 | 0603 | 2 | 22uF16V | C44, C46, C47, C48, C49, C51 | RBB | 6 | 220uF25V | C45 | RBA | 1 | DIO123 | D1 | SOT-23 | 1 | LED | D2 | RAD0.1 | 1 | DIODE | D3 | DIODE0.4C | 1 | RCA_PO | G3, G4, G5, G6 | A1B | 4 | HEADER 22 | JP1 | SIP22 | 1 | HEADER 10X2 | JP2 | IDC20 | 1 | HEADER 15 | JP3 | SD_CARD | 1 | HEADER 4 | JP4, JP7, JP9 | SIP4 | 3 | HEADER 10 | JP5 | SIP10 | 1 | POWER2 | JP6 | POWER2 | 1 | HEADER 6 | JP8 | FLAT_USB | 1 | HEADER 9 | JP10 | SIP9 | 1 | K2X1B | K1 | KEY0.2B | 1 | NTA4151P | Q1, Q2, Q3 | SO-F3/Y.7R | 3 | 10K | R1 | VR5 | 1 | 10K | R2, R3, R4, R5, R6, R7, R9, R10, R11, R12, R17, R18, R19, R20, R21, R22, R23, R42, R43, R44, R49, R50, R58 | 0603 | 23 | 1K | R8, R51 | 0603 | 2 | 100 | R13, R14 | 0603 | 2 | 47K | R15, R16 | 0603 | 2 | 1M | R24 | 0603 | 1 | 470 | R25, R26, R28, R29, R30, R31, R32, R33, R34, R35, R36, R37, R38, R39, R45, R46, R47, R57, R59, R60, R61, R62, R63, R64 | 0603 | 24 | 30 1W | R27 | AXIAL0.6 | 1 | 0 | R40, R41 | AXIAL0.4 | 2 | 2K7 | R48 | 0603 | 1 | 2 | R52 | AXIAL0.4 | 1 | 18 | R53, R54 | 0603 | 2 | 15K | R55, R56 | 0603 | 2 | 11.0592MHz | TXL1 | CRYSTL1B | 1 | 6MHz | TXL2 | CRYSTL1B | 1 | 32.768KHz | TXL3 | CRYSTL2B | 1 | SPX1117 | U1, U3 | SOT223 | 2 | ISP1160 | U2 | QFP-64B | 1 | LPC2229B | U4 | TQFP-144 | 1 | 8563T | U5 | SO-8 | 1 | 24WCXX | U6 | SO-8 | 1 | 74HC125 | U7 | SO-14 | 1 | CAT809 | U8 | SOT-23 | 1 | IS61LV25616 | U9 | TSOP-II | 1 | 7805B | U10 | TO-126 | 1 |
- v* q* q0 \3 x: q( H$ p附件: 原理图和PCB源文件如下:
|, W3 M+ [, @- p/ C0 j$ x |
