查看: 487|回复: 3
[allegro16.6][12层]嵌入式3D 扫描仪机器视觉检查解决方案(AM572x+DDR3x4+TPS659...
发表于 2019-12-24 13:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
( {6 S: L9 b# B; g0 u. u
4 p  o& w6 q# s2 l$ Q
9 [! _. v: C7 ~6 P, \
[allegro16.6][12层]嵌入式3D 扫描仪机器视觉检查解决方案(AM572x+DDR3x4+TPS6590376ZWSR)原理图和pcb文件
/ _! P6 o; Z1 D9 n8 v% g
文件描述:
X! }# S: N5 o3 }4 l7 R# r& h  f$ Z1 q3 I6 `5 y
0 i$ e! k* m! w. C5 J# z- \$ d
1. 作品用途:嵌入式3D 扫描仪机器视觉检查解决方案
2. 软件版本:allegro16.6
3. 层数:12层
4. 用到的主要芯片:AM572x+DDR3x4+TPS6590376ZWSR
5. PCB尺寸:4430*4000mil
: I6 Q: E8 Z6 Z+ m5 _5 L% b5 k
3 |3 K/ ]. c6 F+ y- I! D/ ?6 w# d
作品截图如下:
% v# y( E) L9 r. C( G
& H  E7 a; [5 X, v+ q
顶层截图:
$ k5 q. ~. |0 D5 X1 y) b8 z4 n7 C$ [1 h* h6 K& @& U! a' D
底层截图:
# E, Q) m6 h# _2 {8 o- z2 |8 I+ Q7 Q) K( o* ]# F6 C% D1 t8 F
8 v2 k( z5 k! |/ v& U; X
  t8 b1 l8 [# s( h/ j* }/ I2 ]% t1 ?& p& E* n& C+ r6 f& h% ?6 z" a
全层截图:
9 D5 ~2 C4 j9 C( L% t5 P$ N) M, D" I2 l) h5 n( n) i( O/ c- Q; h7 P" s# V: e' o/ W/ h4 C# C
  R/ ^5 ]8 v& n) ~" E2 ~* @
2 A: O# `, X/ ^0 E
o. F. ]8 u. u; [1 ~6 o$ ^5 H0 O# J, ^0 b  h7 e$ q) p8 Y  y) k! D* G# W4 B* K
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
2XSONIC_TPD1E05U06_0_2XSON_TPD1E05U0TPD1E05U06IC8D12; D13; D14; D15; D16; D17; D18; D19
2XSONIC_TPD1E05U06_2XSON_TPD1E10B06TPD1E10B06IC5D34; D35; D36; D37; D42
201CAP_8.2NF_X5R_10V_10%_0201 _2018.2nF,10V,0201IC3C4; C13; C408
201CAP_0.1UF_X5R_6.3V_20% 0201 _200.1uF/201IC103C51; C55; C57; C58; C59; C60; C61; C62; C66; C67; C68; C69; C71; C72; C73; C74; C75; C76; C77; C82; C83; C84; C85; C86; C87; C95; C96; C98; C114; C115; C116; C117; C118; C119; C120; C121; C123; C124; C125; C126; C127; C128; C129; C132; C133; C134; C135; C136; C137; C138; C139; C140; C157; C158; C159; C160; C169; C170; C173; C174; C175; C176; C177; C178; C181; C182; C183; C184; C185; C186; C187; C188; C191; C192; C193; C194; C195; C196; C198; C199; C200; C201; C203; C204; C236; C243; C273; C421; C470; C482; C483; C484; C485; C486; C487; C488; C489; C490; C491; C492; C493; C498; C499
201CAP_0.22UF_X5R_6.3V_20%_0201_200.22uF/201IC119C52; C56; C78; C88; C89; C161; C162; C165; C166; C167; C168; C171; C172; C266; C269; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C294; C296; C297; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310; C311; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C328; C329; C330; C331; C332; C333; C335; C336; C337; C338; C339; C340; C342; C343; C344; C345; C346; C347; C348; C349; C351; C352; C353; C354; C355; C356; C357; C358; C359; C360; C362; C363; C364; C365; C366; C367; C368; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386
201CAP_0.47UF_X5R_4V_20%_0201_201_0.47uF/201IC2C65; C79
201CAP_1.0UF_X5R_4V_20%_0201_201_11uF,4V,0201IC20C90; C91; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C164; C260; C471
402CAP_402_22PF22pFDISCRETE2C5; C409
402CAP_6.8NF_X7R_50V_10%_0805_402_.001uF,50VIC2C6; C410
402CAP_0.1UF_X7R_16V_10% 0402 _4020.1uf,16VDISCRETE72C15; C16; C30; C81; C94; C97; C99; C104; C105; C108; C110; C111; C207; C209; C211; C213; C215; C216; C222; C224; C225; C228; C230; C231; C239; C241; C242; C244; C247; C248; C252; C253; C258; C259; C262; C264; C270; C272; C274; C334; C388; C392; C398; C399; C405; C407; C412; C414; C415; C419; C422; C423; C424; C425; C426; C427; C428; C430; C433; C434; C441; C446; C447; C448; C449; C450; C451; C472; C473; C474; C475; C478
402CAP_2.2UF_X5R_6.3V_10%_0402_4022.2uF,6.3VIC21C17; C18; C19; C20; C21; C22; C24; C25; C26; C27; C28; C29; C63; C80; C92; C246; C255; C256; C267; C496; C500
402CAP_10PF_COG_50V_5%_0402_402_1010pF,50VIC2C31; C32
402CAP_4.7UF_X5R_6.3V_20%_0402_4024.7uF,6.3VIC18C33; C35; C37; C39; C41; C43; C45; C46; C48; C64; C70; C163; C179; C206; C221; C261; C265; C268
402CAP_18PF_COG_50V_5%_0402_402_1818pF,50VIC6C100; C101; C102; C103; C232; C233
402CAP_0.001_X7R_50V_10%_0402_402_.001uf,50VIC6C197; C237; C245; C390; C391; C429
402CAP_18PF_NPO_50V_5%_0402_402_1818pF,50VIC2C217; C218
402CAP_33PF_COG_50V_5%_0402_402_1818pF,50VIC2C235; C240
402CAP_0.1UF_X5R_6.3V_20% 0201 _400.1uf,16VIC1C263
402CAP_10PF_NPO_50V_5%_0402_402_1010pF,NPOIC1C400
402CAP_0.1UF_X7R_16V_10% 0402 _4_10.01uf,16VDISCRETE8C416; C417; C418; C420; C454; C455; C456; C457
402CAP_DNI_0402_402_CAP,DNI,0402CAP,DNI,0402IC1C435
402CAP_470PF_X7R_25V_10%_0402_402_470pF,6.3VIC1C443
402C_12PF/0402/50V_COG_0402_402_1212pF/0402/50VIC2C452; C453
402CAP_0.1UF_X7R_16V_10% 0402 _4_20.33uf,16VIC1C476
402CAP_1.0UF_X5R_4V_20%_0201_402_11uF,30V,0402IC1C495
402RES_10.1K_1/16W_1%_0402_402_10.10.2K,1%IC3R2; R13; R292
402RESISTOR_402_169K169KDISCRETE2R3; R9
402RES_12.1K_1/16W_1%_0402_402_45.45.3KDISCRETE2R4; R295
402RESISTOR_402_1.91K1.91KDISCRETE2R5; R296
402RES_20.5K_1/16W_1%_0402_402_20.20.5K,1%IC3R6; R11; R297
402RES_1K_1/16W_5%_0402_402_1K,5%1K,5%IC14R8; R70; R71; R72; R73; R90; R91; R99; R100; R116; R117; R273; R274; R303
402RES_10K_1/16W_1%_0402_402_10K,110K,1%IC56R10; R21; R22; R24; R26; R27; R37; R41; R42; R44; R46; R50; R51; R52; R56; R58; R74; R75; R76; R77; R93; R120; R180; R181; R182; R183; R187; R188; R190; R191; R192; R193; R194; R195; R196; R197; R205; R239; R260; R261; R262; R263; R264; R265; R272; R285; R287; R288; R313; R321; R335; R407; R419; R421; R424; R433
402RES_12.1K_1/16W_1%_0402_402_51.51.1KDISCRETE1R12
402RESISTOR_402_3.24K,1%3.24K,1%IC1R14
402RES_4.75K_1/16W_1%_0402_402_4.74.7KDISCRETE2R15; R33
402RES_2.2K_1/16W_1%_0402_402_2.2K2.2K,1%IC7R16; R17; R43; R212; R213; R391; R392
402RES_DNI_1/16W_1%_0402_402_2.2K,2.2K,1%IC2R18; R19
402RES_10K_1/16W_1%_0402_402_10K,D10K,DNIIC2R20; R405
402RES_10K_1/16W_1%_0402_402_10K_110K,1%,DNIIC9R23; R49; R200; R214; R247; R248; R411; R432; R434
402RES_DNI_1/16W_1%_0402_402_10K,110K,1%IC2R28; R189
402RES_0_1/16W_1%_0402_402_0,1%0,1%DISCRETE31R29; R30; R32; R39; R53; R57; R84; R85; R86; R87; R88; R89; R96; R111; R112; R113; R114; R115; R118; R123; R244; R249; R290; R291; R302; R384; R395; R412; R414; R416; R422
402RES_10K_1/16W_1%_0402_402_0,1%,0,1%,DNIIC2R31; R320
402RES_DNI_1/16W_1%_0402_402_DNI,0DNI,0402IC21R38; R40; R45; R47; R54; R94; R121; R237; R241; R242; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R311
402RES_100K_1/16W_1%_0402_402_100K100K,1%IC11R48; R101; R102; R103; R104; R219; R220; R221; R222; R286; R309
402RES_DNI_1/16W_1%_0402_402_0,1%,0,1%,DNIIC1R55
402RES_4.7K_1/16W_5%_0402_402_4.7K4.7KDISCRETE17R59; R62; R66; R204; R207; R209; R215; R216; R217; R218; R243; R333; R334; R389; R390; R398; R399
402RES_22_1/16W_5%_0402_402_22,5%22,5%DISCRETE44R61; R63; R64; R78; R79; R80; R81; R82; R83; R105; R106; R107; R108; R109; R110; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R152; R153; R223
402RES_220_1/16W_5%_0402_402_220,5220,5%IC5R68; R69; R97; R98; R417
402RES_12.1K_1/16W_1%_0402_402_12.12.1K,1%IC2R92; R119
402RES_100K_1/16W_1%_0402_402_10_1100K,1%,DNIIC3R95; R122; R310
402RES_1.87K_1/16W_1%_0402_402_1.81.87K,1%IC1R201
402RES_1M_1/16W_1%_0402_402_1M,1%1M,1%IC1R202
402RES_4.99K_1/16W_1%_0402_402_4.94.99K,1%IC1R203
402RES_9.09K_1/16W_1%_0402_402_8.28.25K,1%IC1R206
402RES_27_1/16W_1%_0402_402_0,1%0,1%IC2R210; R211
402RES_10_1/10W_5%_0402_402_10,5%10,5%IC7R224; R225; R227; R229; R230; R233; R289
402RES_20K_1/16W_1%_0402_402_20K,120K,1%IC6R226; R228; R231; R232; R234; R235
402RES_10K_1/16W_1%_0402_402_100K,100K,1%IC1R236
402RES_1K_1/16W_5%_0402_402_3.24K,3.24K,1%IC1R240
402RES_4.7K_1/16W_5%_0402_402_4._14.7K,DNIIC2R245; R246
402RES_33_1/16W_5%_0402_402_33,5%33,5%DISCRETE6R266; R267; R268; R269; R270; R271
402RES_240_1/16W_1%_0402_402_240,1240,1%IC4R275; R276; R277; R278
402RES_49.9K_1/16W_1%_0402_402_49.49.9,1%IC6R279; R280; R281; R282; R283; R284
402RES_12.1K_1/16W_1%_0402_402_25.25.5K,1%IC1R293
402RESISTOR_402_30K30KIC1R294
402RES_100K_1/16W_1%_0402_402_63.463.4K,1%IC1R298
402RES_1M_1/16W_1%_0402_402_0,1%0,1%IC11R299; R300; R331; R332; R385; R386; R387; R400; R401; R402; R403
402RES_100_1/10W_5%_0402_402_100,5100,5%IC1R308
402RES_DNI_1/16W_1%_0402_402_0,1%0,1%IC1R312
402RES_27_1/16W_1%_0402_402_27,1%,27,1%,DNIIC2R314; R315
402RES_0_1/16W_1%_0402_402_0,1%,DN0,1%,DNIIC2R316; R413
402RES_0_1/16W_1%_0402_402_0,DNI0,DNIIC3R317; R393; R394
402RES_DNI_1/16W_1%_0402_402_1.74K1.74KIC1R318
402RES_DNI_1/16W_1%_0402_402_2K2KIC1R319
402RES_DNI_1/16W_1%_0402_402_1.7_11.74K,DNIIC1R322
402RES_DNI_1/16W_1%_0402_402_2K,DN2K,DNIIC1R323
402RES_1K_1/16W_5%_0402_402_1K,5%,1K,5%,DNIIC1R328
402RES_20K_1/16W_1%_0402_402_16K16KIC1R329
402RES_10K_1/16W_1%_0402_402_90.9K90.9K,1%IC1R330
402RES_47_1/16W_1%_0402_402_47,1%47,1%IC48R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R365; R366; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R383
402RES_470_1/10W_5%_0402_402_154K,154K,1%IC1R396
402RES_470_1/10W_5%_0402_402_470K,470K,1%IC1R397
402RES_22.6K_1/16W_1%_0402_402_22.22.6K,1%IC1R404
402RES_10K_1/16W_1%_0402_402_47K,147K,1%IC2R408; R415
402RES_10K_1/16W_1%_0402_402_620K620KIC1R409
402RES_10K_1/16W_1%_0402_402_330K330KIC1R410
402RES_240_1/16W_1%_0402_402_499,1499,1%IC2R418; R423
402RES_10K_1/16W_1%_0402_402_40.2K40.2K,1%IC2R420; R425
402RES_10K_1/16W_1%_0402_402_DNIDNIIC2R429; R430
603CAP_10UF_X5R_6.3V_20%_0603_603_10uF,6.3VIC44C23; C50; C53; C54; C113; C122; C130; C131; C189; C190; C202; C208; C210; C212; C223; C226; C227; C238; C249; C254; C257; C271; C295; C312; C327; C341; C350; C361; C369; C387; C389; C393; C394; C395; C396; C397; C431; C432; C436; C437; C442; C481; C494; C497
603CAP_10UF_X5R_6.3V_20%_0603_60_110uF,DNIIC2C219; C234
603PROT_PESD0603_240_603_PESD0603-PESD0603-240IC4D8; D9; D10; D11
805CAP_0.1UF_X7R_25V_10% 0805_805_0.1uf,25V,0805IC3C1; C7; C401
805CAP_805_220PF,50V220pF,50VIC1C10
805CAP_820PF_X5R_50V_10%_0805_805_820pF,50VIC1C11
805CAP_15PF_NPO_50V_5%_0805_805_1515pF,50VIC1C12
805CAP_22UF_X5R_6.3V_20%_0805_805_22uF,6.3VIC3C93; C156; C180
805CAP_220PF_X7R_50V_10%_0402_805_220pF,50VIC2C109; C112
805FERRITE_180_800_0805_805_150OHM150OHM800mAIC7FB1; FB3; FB4; FB5; FB7; FB8; FB9
805RES_0_1/16W_1%_0402_805_0,1%,080,1%,0805IC2FB2; FB6
1206CAP_47UF_X5R_6.3V_20%_1206_120647uF,6.3V,1206IC14C34; C36; C38; C40; C42; C44; C47; C49; C205; C214; C220; C229; C250; C251
1206RES 0.002_1/2W_1%_0805_1206_.01.01,1206IC4R1; R7; R34; R35
1206RES 0.002_1/2W_1%_0805_1206_.02.02,1206IC1R36
1210CAP_4.7UF_X5R_50V_10%_LESR_12104.7uF,50V.LESRIC7C3; C14; C402; C438; C439; C440; C445
1210CAP_10UF_X5R_6.3V_20%_0603_12101uF,50VIC1C479
6032CAP_100UF_TANT_6.3V_3528-21_603100uF,10VIC8C2; C8; C9; C403; C404; C406; C411; C413
BATT2_78X492BATT_HOLD_BH501_BATT2_78X492_CRCR1220MFR FV,DNIIC1BAT1
BGA96_T9_P8_9X14MEM_DDR3L_256MBX16_0_BGA96_T9_P256MBx16 DDR3LIC4U23; U24; U25; U26
BGA153_P14_P5_11P5X13MEM_MNAND_1_BGA153_P14_P5_11P5XMEM_MNAND_4GBIC1U22
BGA169_N13_P8IC_TPS659039_8_BGA169_N13_P8_TPTPS6590376ZWSRIC1U5
CHOKE4_0805-2CHOKE_DLW21SN121HQ2_3_CHOKE4_08DLW21SN900HQ2IC4FL1; FL2; FL3; FL4
CN7699CONN_KEYSTONE_SCREW_7699_CN7699Keystone_screw_7699IC1J7
CNPJ-080BHCONN_PWRJACK_PJ-080BH_CNPJ-080BCUI-PJ-080BHIC1P1
CON2_49LSHDR_1X1_M_.1_CON2_49LS_2POS 1.22POS 1.25MMIC1J1
DDA-8IC_TPS54331,3A_0_DDA-8_TPS54531TPS54531DIC3U1; U3; U28
DFN8_2X3MMIC_MCP79410_DFN8_2X3MM_MCP79410MCP79410,TFDNIC1U6
DO221ACDIO_ZEN_DDZ9678-7_1.8V_DO221AC_SK54AFL-TPIC3D1; D2; D24
DRC10-11X33PWR_TPS74801_SON_DRC10-11X33_TPTPS74801IC1U16
DRC10-11X33IC_TPS51200_10S0N_DRC10-11X33_TTPS51200_10SONIC1U27
DRC10-11X33PWR_TPS2560_DRC_0_DRC10-11X33_TTPS2561DRCIC2U29; U30
ESATA-USB_COMBO_RACONN_11P_ESATA_ESATA-USB_COMBO_eSATAIC1P6
FLT3SMD_0805-2FLT_HIFREQ_.47UF_FLT3SMD_0805-2FLT_HIFREQ_.47UFIC6L10; L11; L12; L21; L22; L24
FU250_200X400SMDFUSE_4A_QUICK_FU250_200X400SMD_5A_SlowBlowIC1F1
HDMI-SMT-W-FLANGEHDMI-RA-19_0_HDMI-SMT-W-FLANGE_HDMI-RA-19-TYPEAIC1P11
HDR2X30SMD_FX18-60P-0P8SVCONN_30X2_5.27MM_HDR2X30SMD_FX1CONN_30x2_0.8IC4P16; P17; P18; P19
HEADER10X2_SMDHDR_JTAG_20P_HEADER10X2_SMD_2020 Pin JTAGIC1P4
IND130_160X175IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIC7L3; L4; L5; L6; L7; L8; L9
IND130_208X216INDUCTOR_IND130_208X216_4.7UH4.7uHDISCRETE2L1; L16
IND130_208X216INDUCTOR_IND130_208X216_3.3UH,73.3uH,7AIC1L2
IND_0805FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIC8L13; L14; L15; L17; L18; L19; L20; L23
JACK5-472X551-SJ1-3524NGCONN_STEREO_3.5MM_1SW_JACK5-472SJ1-3524NGIC2P8; P9
LED_603LED_LTST_C150GKT_LED_603_DISCRELTST-C191KFKTDISCRETE6D3; D4; D5; D6; D7; D41
MTGH200C102D_PLTESTPOINT_MTGH200C102D_PL_MOUNTMOUNT_HOLEIC1MH5
MTGH250C125D_PLTESTPOINT_MTGH250C125D_PL_MOUNTMOUNT_HOLEIC4MH1; MH2; MH3; MH4
OSC4_87-146SMD_126X197-1CRYS_24MHZ_2PIN_OSC4_87-146SMD_24MHzIC1Y7
QFN20S4X4P5-2IC_SN75LVCP412A_1_QFN20S4X4P5-2SN75LVCP412AIC1U33
QFN24S_2X4P4IC_TPD12S016_QFN24S_2X4P4_TPD12TPD12S016 24UQFNIC1U21
QFN32IC_CDCM9102RHBR_0_QFN32_CDCM910CDCM9102RHBRIC1U7
QFN32IC_TLV320AIC3104_5_QFN32_TLV320TLV320AIC3104IC1U18
QFN48IC_KSZ9031RNX_QFN48_9_QFN48_KSZKSZ9031RNXIC2U14; U15
RJ45_2X1_XFRM_LEDCONN_RJ45_DUAL_GIGABIT_1_RJ45_2LPJG17561BGNL Dual RJ45 10/100/1000IC1P5
SC70TRN_BSS138_0_SC70_BSS138BSS138IC1Q6
SC70-5IC_SN74LVC1G08_DCK_SC70-5_SN74LSN74LVC1G08DCKIC1U10
SC70-5IC_SN74LVC1G06DCK_SC70-5_SN74LVSN74LVC1G06DCKIC1U42
SC70-6IC_SN74LVC1G11_DRY_SC70-6_SN74LSN74LVC1G11DBVIC1U9
SC75TRN_NTA4153N_SC75_NTA4153NNTA4153NIC1Q5
SD-MICRO-SCHA5B0300MICROSD_CONN_0_SD-MICRO-SCHA5B0SCHA5B0200IC1P12
SIP2HDR_1X1_M_.1_SIP2_HDR_1X1_M_.1,HDR_1x1_M_.1,DNIIC1J5
SIP3HDR_1X3_0.1_SIP3_HDR_1X3HDR_1x3IC3J3; J4; J6
SIP6HDR_5X2_M_2.1_SIP6_HDR_6X1_M_.1HDR_6x1_M_.1,DNIIC2P2; P3
SIP6HEADER 6_SIP6_HDR_6X1_M_.1HDR_6x1_M_.1IC1P10
SKTBGA-ZKK-6334-P760IC_AM572X_BGA_36_SKTBGA-ZKK-633AM572xIC1U11
SMINI6-F3-BTRN_DMC56404_SMINI6-F3-B_DMC564DMC56404IC2Q3; Q4
SO8-25X75PWR_TLV70233DBV_0_SO8-25X75_TL5TL5209IC1U32
SOIC_8MEM_24WC256_0_SOIC_8_MEM_24WC25MEM_24WC256_8SOICIC1U8
SOT3_DRT_1P0XP8MMIC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRIC11D25; D26; D27; D28; D29; D30; D31; D32; D33; D38; D40
SOT23-3TRN_1_SOT23-3_TRN_2N2907TRN_2N2907IC2Q8; Q9
SOT23-3MA735/TO_0_SOT23-3_TLVH431TLVH431IC2U35; U43
SOT23-5PWR_TPS7018DBV_SOT23_5_SOT23-5_TPS77018DBVIC1U19
SOT23-6PWR_TPS3808G09DBVR_SOT23_0_SOT2TPS_3808G09IC2U12; U13
SOT223-1IRF5210S/SM_0_SOT223-1_FDT434PFDT434PIC2Q1; Q2
SOT563IC_TMP102AIDRL_SOT563_SOT563_TMTMP102AIDRLTIC1U4
SOT-23BSS138/SOT_0_SOT-23_BSS138/SOTBSS138/SOTIC1Q7
SW4_EVQF004RSW PUSH_TH_SW4_EVQF004R_SW PUSHSW PUSH_THIC2S1; S2
TP1-8040TESTPT1_TP1-8040_TESTPT1TESTPT1IC1TP4
TP30C12DTP_TP30C12D_TPTPIC12TP5; TP6; TP7; TP8; TP9; TP13; TP16; TP17; TP18; TP19; TP20; TP21
TQFN28S_3P5X5P5P5IC_PI2DBS212ZHE_TQFN_9_TQFN28S_PI2DBS212_TQFNIC1U31
USB5_FCI-10103594CONN_MINI-USB-AB_1_USB5_FCI-101Micro USB-BIC1P7
USB9RA_2SHIELDEDCONN_USB3_3.0_A_USB9RA_2SHIELDECONN_USB3.0_AIC1P13
USB18RA_4SHIELDEDCONN_USB3_3.0_A_DUAL_USB18RA_4SGSB311231HRIC1P15
U_5_DRLIC_TPD2E001DRL_U_5_DRL_TPD2E001TPD2E001DRLIC4D20; D21; D22; D23
U_8_DCUIC_SN74LVC2G241_1_U_8_DCU_SN74LSN74LVC2G241IC1U20
U_8_DCUIC_SN74LVC2G132DCU_U_8_DCU_SN74SN74LVC2G132DCUIC1U34
VQFN64S9X9P5IC_TUSB8041_2_VQFN64S9X9P5_TUSBTUSB8041IC1U17
WSON-8TPS22965DSG_1_WSON-8_TPS22965DSTPS22965DSGIC1U2
XTAL2_6X3P5_SMDCRYS_20MHZ_12.5PF_2P_3.2X1.5_XT20MHz,SMDIC1Y2
XTAL4_3P2X2P5_SMDCRYS_22.5792MHZ_7PF_4P_3.2X2.5_22.5792MHZIC1Y3
XTAL4_3P2X2P5_SMDCRYS_25MHZ_8PF_4P_3.2X2.5_XTAL425MHz,8pFIC1Y8
XTAL4_3P2X2P5_SMDCRYS_24MHZ_SCC_XTAL4_3P2X2P5_SM16.384MHzIC1Y9
XTAL_3P2X5SMDCRYS_25MHZ_18PF_2P_5.0X3.2_XTAL25MHzIC2Y5; Y6
XTAL_CFS-206CRYS_32_768KHZ_SMD_XTAL_CFS-206CFS206-32.768KDZBIC1Y1
附件:
' J/ T: p% ^+ ?, }( ^pcb文件和原理图- f0 d# {3 \( |8 K# [' {4 _4 k
游客,如果您要查看本帖隐藏内容请回复
& |7 X) `2 J; ?/ Y8 c) Y
发表于 2023-3-14 10:14 | 只看该作者
thank you share
发表于 2024-5-31 09:35 | 只看该作者
学习下,谢谢
GMT+8, 2025-6-22 18:46 , Processed in 0.093750 second(s), 27 queries , Gzip On.
