[ allegro15.2][4层]监控960P CMOS SENSOR AR0130(2)(ILCC48+FPC40-5920)pcb文件 " |: m7 w& Z$ Q" B/ R- y" l' E
文件描述: 5 o- x- I/ m' P: Q$ e3 X
1. 作品用途:监控960P CMOS SENSOR AR0130(2) 2. 软件版本:allegro15.2 3. 层数:4层 4. 用到的主要芯片:ILCC48+FPC40-5920 5. PCB尺寸:38*38mm
; C+ o7 z2 j" ~2 M8 \, U C4 Q- A8 Y作品截图如下: * j0 \! K$ _* d8 [: R& }& Y) c+ F" v
顶层截图: 6 F$ D* _ O& _- }) E4 y! ?, U
底层截图: 7 E% E* j$ {' D, s4 C0 S6 n# O5 V
, A4 L* B3 Z( V) h0 k/ Y' l3 B
全层截图: : U" y+ M; K% _" l
# l- j( c1 L! f2 J% F; }
叠层阻抗信息:
0 O# O- x, G+ _: o9 CBOM: Bill of Material Report (Condensed) | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | FPC40-5920-40-0VT0R | FPC40-5920-40-0VT0R | | IC | 1 | J3 | HOLE_3 | HOLE_3 | | IC | 4 | M1; M2; M3; M4 | HSOD523 | HSOD523 | | IC | 2 | D1; D2 | ILCC48-P70-S0 | ILCC48-P70-S0 | | IC | 1 | U4 | LENS_SOCKET | LENS_SOCKET | | IC | 1 | OBJ1 | SC0402 | SC0402 | 33pF | DISCRETE | 26 | C2; C3; C5; C6; C8; C9; C11; C12; C14; C15; C18; C19; C20; C22; C24; C25; C26; C27; C29; C30; C31; C34; C35; C36; C38; C40 | SC0603 | SC0603 | 20pF | DISCRETE | 19 | C1; C4; C7; C10; C13; C16; C17; C21; C23; C28; C32; C37; C39; C41; C42; C43; C44; C45; C51 | SC1206 | SC1206 | 22uF | DISCRETE | 1 | C33 | SIP-2P-20 | SIP-2P-20 | | IC | 1 | J1 | SL0805 | SL0805 | 1uH | DISCRETE | 2 | LB1; LB2 | SOP8-50-150 | SOP8-50-150 | 24LC16B_SN | IC | 1 | U5 | SOT23 | SOT23 | PMOS-GSD | IC | 5 | Q1; Q2; Q3; Q4; Q5 | SOT23-6B | SOT23-6B | | IC | 2 | U1; U2 | SOT223-6A | SOT223-6A | | IC | 1 | U3 | SR0402 | SR0402 | | IC | 21 | R1; R3; R7; R8; R9; R10; R11; R12; R13; R14; R18; R19; R23; R24; R26; R28; R29; R30; R31; R32; R36 | SR0603 | SR0603 | 49.9 | DISCRETE | 13 | R2; R4; R5; R6; R16; R17; R20; R21; R22; R25; R33; R34; R35 | SR0805 | SR0805 | 0 | DISCRETE | 2 | R15; R27 | TP24-SMD | TP24-SMD | | IC | 7 | TP1; TP2; TP3; TP4; TP5; TP6; TP7 | WBC0104-49T | WBC0104-49T | | IC | 1 | J4 |
附件: pcb文件如下: . t& o1 F6 y% w5 R# J
