作品名:[AD 9][4层]用于数据存储的底板(LAN9514_QFN64+SP3232EEA+74HC245)原理图和PCB源文件 文件描述 1. 作品用途:用于数据存储的底板 2. 软件版本:AD 9 3. 层数:4层 4. 用到的主要芯片:LAN9514_QFN64+SP3232EEA+74HC245 5. PCB尺寸:272.2mm*246.6mm 作品截图如下: 顶层截图: 底层截图: 全层截图: 叠层信息截图如下: BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 25MHz | Y1 | Y1605 | 1 | RJ-45 | XS1 | RJ45 | 1 | 3_32PIN | XP2 | 9001-96ABC-LP | 1 | M7a | VD1 | 1N4148 | 1 | CAT1023JI-30 | U21 | SO-8 | 1 | TPS5450DDA | U18 | TPS5450 | 1 | TPS54331 | U17 | SOIC8 | 1 | TPD2E001DRL | U12, U13, U14 | drl5-12x40 | 3 | MIC2026-1YM | U10 | SOIC8 | 1 | LM393_SO-8 | U6 | SO-8 | 1 | LM75 | U5 | LM75_SOP | 1 | SN65HVD12(VP12) | U4 | SO-8 | 1 | 74HC245 | U3 | SN74HC245PW | 1 | SP3232EEA | U2 | SP3232EEA | 1 | LAN9514_QFN64 | U1 | QFN50P900X900X100-64N | 1 | SMBJ28A (LITTELFUSE) | TVS1 | TVS_Bi | 1 | Test Point-1x1 | TP1, TP2, TP3, TP4, TP5, TP11, TP12, TP13 | TP1-6040 | 8 | 11FB-05NL | T1 | 11FB_05NL | 1 | SK54B | SD2 | psm1 | 1 | B540C | SD1 | B540C | 1 | SW-PB | S3 | SW | 1 | SW | S2 | SW | 1 | HR911130C | RJ1 | HR911130C | 1 | 511 | R227, R228 | 0603_R | 2 | 332 | R225, R226 | 0603_R | 2 | 10 | R224 | 0603_R | 1 | 49.9 | R217, R218, R219, R220 | 0603_R | 4 | 331 | R216 | 0603_R | 1 | 1M | R213 | 0603_R | 1 | 10.0K | R206, R207, R208, R209, R210 | 0603_R | 5 | 12.4K | R204 | 0603_R | 1 | 12.0K | R202 | 0603_R | 1 | 4.7K | R201, R205, R211 | 0603_R | 3 | 0(DNP) | R163, R263 | 0805_R | 2 | 22R | R111, R112 | 0805_R | 2 | 680 | R107 | 0805_R | 1 | 200K | R106 | 0805_R | 1 | 100K | R105 | 0805_R | 1 | 10K | R103, R104, R121, R122 | 0805_R | 4 | 0R | R101 | 1206_R | 1 | RC0603FR-0775RL (YAGEO) | R65, R66 | 0603_R | 2 | RC0603FR-07120RL (YAGEO) | R62, R63, R64, R67 | 0603_R | 4 | 4.7K | R23, R32, R33, R34, R35, R36, R37, R38, R39, R40, R41, R42, R43, R44, R45, R46, R47, R48, R49, R50, R51, R52, R53, R54, R55, R56, R57, R58, R59, R60, R61, R91, R92, R93, R160, R162, R164, R165 | 0805_R | 38 | 33 | R21, R161 | 0805_R | 2 | 3.3K | R18 | R0805 | 1 | 10K | R17 | R0805 | 1 | 0.33 | R16 | R0805 | 1 | RC0603FR-073K3L (YAGEO) | R15 | 0805_R | 1 | 30K | R14 | R0805 | 1 | 68K | R12 | R0805 | 1 | 330K | R11 | R0805 | 1 | 1K | R8, R19 | R0805 | 2 | RC0603FR-07470RL (YAGEO) | R7 | 0603_R | 1 | 0 | R6, R215, R2012, R2014 | 0603_R | 4 | 3.16K | R5 | 0603_R | 1 | 10K | R4 | 0603_R | 1 | RC0603FR-07470RL (YAGEO) | R3, R13 | 0805_R | 2 | 68K | R2 | 0805_R | 1 | 330K | R1 | 0805_R | 1 | ACM3225-601-2P-X (TDK) | LP1, LP2 | ACM3225-601-2P-X (TDK) | 2 | Green | LED201, LED204, LED205 | 0603LED | 3 | LED | LED3 | 1206(DIO) | 1 | LED | LED1, LED2 | 1206D | 2 | ACM3225-601-2P-X (TDK) | L201, L202, L203 | ACM3225_adj | 3 | 0 | L23 | 1206_L | 1 | BEAD | L11, L12, L13 | 0805_L | 3 | DNP | L7 | 1206_L | 1 | BEAD | L6, L10, L31, L32 | 1206_L | 4 | 6.8uH | L4 | LS1010 | 1 | 15uH | L2 | LS1212 | 1 | 1LS0405-01 | L1 | 1LS0405-01-PF | 1 | 2xUSB | J8 | USBX2 | 1 | 1x10 | J7 | HDR1X10 | 1 | 1x6 | J6 | HDR1X6 | 1 | JUMP | J4 | HDR1*2 | 1 | D Connector 9 | J3 | DSUB1.385-2H9 | 1 | SATA | J1 | SATA_PORT | 1 | 2.0 Amp/0.05 DCR | FB1, FB2, FB3, FB4 | 1206L | 4 | JK60-065 (金瑞电子) | F1 | RM0.2 | 1 | SMBJ36CA | D5, D6 | SMBJ*CA | 2 | CONN SOCKET 60x2/SM | CN1, CN2 | COREConnector | 2 | 10uF | CC13, CC21, CC23, CC24 | 3528-T(B) | 4 | T491A106K016AT (KEMET) | CC11, CC12, CC22 | 7343-T(D) | 3 | 10uF/16V | CC7, CC8 | 3528-T(B) | 2 | 47uF/16V | CC5, CC6 | 7343T | 2 | 47uF/16V | CC2, CC3 | 7343-T(D) | 2 | 220uF/50V | CC1 | CE203480 | 1 | 100uF/10V | C240, C242 | 7343T | 2 | 1.0uF | C238 | C0805 | 1 | 0.022uF | C233 | 0603_C | 1 | 33pF | C229, C230 | 0603_C | 2 | 0.01uF | C220 | 0603_C | 1 | 1.0uF | C212 | 0603_C | 1 | 4.7uF | C201, C211 | C0805 | 2 | 104 | C80, C81, C82, C83, C84 | 0805_C | 5 | CC0603KRX7R9BB104 (YAGEO) | C61, C62 | 0603_C | 2 | 15pF | C34, C35, C36, C37 | 0603_C | 4 | Cap | C26, C27, C28, C85 | 0805_C | 4 | 10uF/25V | C25 | 1206_C | 1 | 0.1uF | C21, C22, C23, C24, C202, C203, C204, C205, C206, C207, C208, C209, C210, C213, C214, C215, C216, C217, C218, C264, C265 | 0603_C | 21 | CC0603KRX7R9BB104 (YAGEO) | C16, C41, C43, C44, C46, C47, C63, C91, C101 | 0805_C | 9 | 47pF | C15 | C0805 | 1 | 1000p | C14 | C0805 | 1 | 0.1u | C12 | C0805 | 1 | 0.01u | C11 | C0805 | 1 | 0.1u | C7, C8, C134 | 0805_C | 3 | CC0603KRX7R9BB103 (YAGEO) | C4 | 0603_R | 1 | CC0603KRX7R9BB103 (YAGEO) | C3, C13 | 0805_C | 2 | 103 | C1, C2, C6, C17 | C0805 | 4 |
6 D, z8 T( n, l, S; v- h5 G2 @
附件: 原理图和PCB源文件如下:
& | ?) f5 Y/ @4 b2 D9 U2 l
$ D8 y5 Y6 W, U6 t; p0 N% t$ q2 h |
