作品名:[AD 9][2层]单向电能表设计(7805+78L05+78F0526)原理图和PCB源文件
' f! |9 {, B# f7 w4 e$ g4 o& n2 ^9 U6 f* B# d
文件描述
3 L" x6 z2 y3 X$ m t8 p8 @+ ]1. 作品用途:单向电能表设计 2. 软件版本:AD 9 3. 层数:2层 4. 用到的主要芯片:7805+78L05+78F0526 5. PCB尺寸:100mm*112mm : \9 L) E# [; l2 v* r: j6 k6 }
$ z4 v) u' Q, C% }作品截图如下: # Z$ s5 l- C$ e9 l% y
" V9 Y& W4 J3 `; O E R5 h
顶层截图: 底层截图: 全层截图: 叠层信息截图如下: BOM:
: R0 x2 V7 }3 fComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | LD4 | LED | 1 | | PTC3 | MZ4 | 1 | | S1, S11 | PAST2 | 2 | | SW2 | UPSW | 1 | 0.1uF | C1, C3, C4, C11, C12, C13, C15, C16, C25, C29, C56, C57, C59, C61, C62, C64, C65, C67, C69, C71, C72 | 0603C | 21 | 0.47uF | C2 | 0603C | 1 | 1K | R10, R11, R12, R13, R16, R19, R24, R25, R31, R34, R35, R36, R40, R47, R50, R51, R52, R53 | 0603 | 18 | 1N4007 | D1, D2, D3, D6, D7, D8, D9, D10, D11, D12 | LL4148 | 10 | 1N4148 | D4, D5 | LL4148 | 2 | 2K | R26, R33, R39 | 0603 | 3 | 2N5401 | Q6 | M6 | 1 | 2SA812 | Q2, Q3, Q4, Q7, Q10, Q11 | M6 | 6 | 2SC1623 | Q1, Q8, Q9 | M6 | 3 | 2SC1623 | Q14, Q15 | L6 | 2 | 2SC2001 | Q5 | M6 | 1 | 2.2K | R7 | 0603 | 1 | 3.3K | R6 | 0603 | 1 | 3.5795MHZ | CRY3 | XTAL11 | 1 | 3.6V | BAT1 | BAT3.6 | 1 | 4.7K | R17, R68, R73 | 0603 | 3 | 5.1k | R21, R66, R71 | 0603 | 3 | 8MHZ | CRY1 | XTAL11 | 1 | 10K | R2, R5, R8, R9, R27, R28, R29, R32, R55, R64, R69 | 0603 | 11 | 10K420 | GIA1 | SGIA | 1 | 10M | R75 | 0603 | 1 | 10nF | C9, C10, C19, C20 | 0603C | 4 | 10R | R37, R74 | 0603 | 2 | 10R | R44, R45 | 1206 | 2 | 10u/16v | C28 | 10U/16V | 1 | 20K | R23, R59, R62, R63 | 0603 | 4 | 20K510 | RV1 | 20K510 | 1 | 20R | R30 | AXIAL0.5 | 1 | 22pF | C5, C6, C7, C8, C26, C27 | 0603c | 6 | 30K | R22 | 0603 | 1 | 32.768KHz | CRY2 | 32768HZ | 1 | 33nF | C17, C18, C21, C22, C23, C24 | 0603C | 6 | 47R | R15, R18 | 0603 | 2 | 78F0526 | U1 | LCC52 | 1 | 78L05 | U8, U10 | TO-92 | 2 | 100 | R58 | 0603 | 1 | 100K | R1, R56, R57 | 0603 | 3 | 100R | R65, R70 | 0603 | 2 | 120K | R42, R43, R46, R48, R49 | 1206 | 5 | 220uF/35V | C63 | RB.2/.4 | 1 | 330K | R3 | 0603 | 1 | 470K | R14 | 0603 | 1 | 470u/25V | C70 | RB.2/.4 | 1 | 510R | R20, R38, R67 | 0603 | 3 | 560pF | C14 | 0603C | 1 | 620R | R4, R54 | 0603 | 2 | 680R | R72 | 0603 | 1 | 820R | R41 | 0603 | 1 | 1000u/35V | C66 | RB6.5/13MM | 1 | 1000uF/16V | C60 | RB.22/.51 | 1 | 7805 | U9 | 7805 | 1 | AT24C02 | U2 | SO-8 | 1 | BianCheng | SW1 | KEY1 | 1 | BL55070 | U5 | LCC44 | 1 | CON2 | DTP | sip2 | 1 | CON7 | J1 | sip7 | 1 | EL-1L7 | LD2 | LED | 1 | ESAM2605 | U3 | DIP8 | 1 | FM9038 | U6 | SBX-8035-F | 1 | HEADER 4X2 | J3 | IDC8 | 1 | HEADER 6X2 | J2 | IDC12 | 1 | JX-3065BG-4 | LD5 | JX-3065BG-4 | 1 | LCD-GWPS8258 | LCD300 | XHB4006QTPA | 1 | LED | LD1, LD3 | LED | 2 | LunXian | SW4 | KEY1 | 1 | P6KE12CA | TVS1 | P6KE6.8CA | 1 | P6KE12CA | TVS3 | TVS | 1 | P6KE18CA | TVS2 | LHL | 1 | P781B+ | OP1, OP2, OP3, OP4, OP5, OP8, OP9, OP10 | SOP4 | 8 | RN8209 | U11 | ADE7755 | 1 | RX8025 | U4 | SOJ-14 | 1 | SPMZ8(30-60) | PTC2 | MZ2 | 1 | TERMINAL | CTA-, CTA+, IA, IB | PAST3 | 4 | TERMINAL | P-, P+, T-, T+ | PAST1 | 4 | TESTPOINT | A0, B0, CK-, CK+, L, N | PAST1 | 6 | TET35I01-220F1 | T3 | TET35I01-220F1 | 1 | ZT3085LEEN | U7 | SO-8 | 1 | + @$ X' Z1 o( }2 \
附件: 原理图和PCB源文件如下:
# _; y5 U- I) Q5 q
& j2 u- ~: K+ P# _ |
