作品名:[AD 9][2层] Freescale智能车(LMV358+BTN7975+LM1117-5)原理图和PCB源文件
4 z4 p1 C4 u, m文件描述 1. 作品用途:Freescale智能车 2. 软件版本:AD 9 3. 层数:2层板 4. 用到的主要芯片:LMV358+BTN7975+LM1117-5 5. PCB尺寸:155mm*79mm
' b+ W5 i/ x3 H; H8 U作品截图如下: 顶层截图: ; r, k& w& z; R! O( E. j
底层截图: 8 m0 j$ W v( l
全层截图:
( l% y8 c4 L8 O+ z: K叠层信息截图如下:
3 t& F$ l; ?+ q8 z) {& w7 NBOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Header 3X2A | 6V, AVCC, DVCC | H3X2A | 3 | R-ADJ | ADJ1, J0, J1, J2, J3 | ADJ-2-SMD | 5 | BMSW | BMSW1, BMSW2 | BMSW | 2 | BTN7975 | BTS1, BTS2 | BTN7975 | 2 | Cap Pol1 | C1 | SMD-1000uf | 1 | Cap | C2, C11, C12, C13, C18, C20, C24, C28, C32 | 0805C | 9 | Cap Pol1 | C3, C8, C15 | SMD-100uf | 3 | Cap Pol1 | C4, C6, C9, C10, C16 | DIODE-47uf-C | 5 | Cap Pol1 | C5, C7, C14, C17 | DIODE-100UF-B | 4 | Cap | C21, C30 | DIP-C | 2 | Cap | C22, C27, C31, C34 | 0603 | 4 | 470nf | C23, C26 | 0805C | 2 | 磁珠 | CB1 | 0805R | 1 | LED0 | D2, D4 | LED-2.5mm | 2 | Header 3 | DJ, P-BMQ1, PP | HEADER3 | 3 | Header 2 | GHG | HDR1X2 | 1 | 1插针 | H0, H1, H2, H3, O0, O1, O2, O3 | HEADER1 | 8 | Inductor | L0, L1, L2, L3 | H2 | 4 | LED1 | LED2 | LED-2.5mm | 1 | LMV358_1 | LMV0 | SO-8_OPA2350 | 1 | LMV358_2 | LMV1 | SO-8_OPA2350 | 1 | LQ_80_V21 | LQ_XSV1 | LQ_80_V21 | 1 | Header 2 | PJ | H2 | 1 | Header 2 | POWER1, ZLDJ | POWER-插座 | 2 | Header 4 | PT0~3, SCI | H4 | 2 | Res2 | R3, R4, R5, R7, R8, R9, R10, R11, R12, R13, R14, R15, R16, R17, R18, R20, R21, R22, R80, R81, R82, R83 | 0805R | 22 | 10K | RESPACKET1 | RESPACKET | 1 | SW-SPDT | S1 | 妞子开关 | 1 | SW-SPST | S4, S5 | 自锁开关 | 2 | LM1117-5 | U1, U2, U3, U4 | LM1117 | 4 | 2 H# j/ L# l; b2 |
附件: 原理图和PCB源文件如下:
4 [+ B( s# B$ _
! l7 X$ A! n/ l! G- c; @ |
