查看: 284|回复: 0
[allegro16.3][4层]SD5115参考板(SD5115+DDR+网口)原理图和pcb文件
发表于 2019-12-23 16:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
  L7 ^0 T% |4 ]. O6 r: R
文件描述:
- y' ~. m! U. D8 R
1. 作品用途:SD5115参考板
2. 软件版本:allegro16.3
3. 层数:4层
4. 用到的主要芯片:SD5115+DDR+网口
5. PCB尺寸:2.992*5.374mm
" n$ ~5 a3 ^7 j$ G6 D) y
: E, |" |9 F: L3 k3 ~0 g
作品截图如下:
+ x, ]) P# K. ^) S( O
顶层截图:
9 `, N) V4 d* p! M+ v
底层截图:
( i8 l) e) O- _) e! l
# b/ b/ z- O& t0 X4 ]4 e! T' y% J
全层截图:
/ q! y! g3 j7 I. H6 s& U
; D( o1 K8 i) J6 l3 r* D# v
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA620-26-3434SD5115_BGA620-26-3434_SD5115SD5115IC1U1
CAPE_6D3PI_2D5_2DPC_P_CAPE_6D3PI_2D5_2DP_0.47UF0.47uFDISCRETE1C188
CAPE_10PI_5D_2DPC_P_CAPE_10PI_5D_2DP_22UF22uFDISCRETE1C190
CAPE_10PI_5D_2DPC_P_CAPE_10PI_5D_2DP_1000UF1000uFDISCRETE1C309
CC0402C_NP_CC0402_0.1UF0.1uFDISCRETE119C1; C2; C4; C6; C7; C9; C10; C15; C16; C17; C20; C22; C24; C26; C28; C30; C32; C34; C36; C44; C45; C48; C56; C59; C61; C62; C63; C64; C65; C66; C68; C70; C71; C73; C74; C75; C76; C78; C82; C83; C84; C87; C88; C89; C92; C93; C94; C96; C98; C99; C103; C104; C106; C108; C111; C112; C113; C115; C117; C118; C119; C120; C121; C126; C130; C131; C132; C133; C136; C137; C138; C141; C142; C143; C144; C145; C146; C149; C150; C171; C174; C175; C177; C178; C179; C199; C200; C201; C202; C203; C210; C211; C212; C213; C214; C224; C225; C226; C227; C241; C242; C282; C284; C286; C303; C305; C307; C311; C322; C329; C330; C336; C343; C344; C1176; C1487; C1493; C1495; C1497
CC0402C_NP_CC0402_1UF1uFDISCRETE13C8; C67; C69; C81; C95; C102; C105; C109; C110; C128; C283; C1175; C1486
CC0402C_NP_CC0402_@0.1UF@0.1uFIC2C12; C14
CC0402C_NP_CC0402_@10NF@10nFIC1C13
CC0402C_NP_CC0402_10NF10nFDISCRETE42C21; C23; C25; C27; C29; C31; C33; C35; C55; C57; C58; C79; C80; C86; C91; C101; C122; C123; C124; C125; C134; C135; C139; C140; C285; C304; C306; C308; C317; C318; C321; C327; C328; C332; C335; C341; C342; C398; C768; C1177; C1488; C1496
CC0402C_NP_CC0402_22PF22pFDISCRETE1C38
CC0402C_NP_CC0402_20PF20pFDISCRETE2C49; C50
CC0402C_NP_CC0402_DISCRETE_@15PF@15pFDISCRETE2C51; C52
CC0402C_NP_CC0402_1NF1nFDISCRETE1C127
CC0402C_NP_CC0402_0.01UF0.01uFDISCRETE4C147; C148; C151; C154
CC0402C_NP_CC0402_22NF22nFDISCRETE1C186
CC0402C_NP_CC0402_820PF820pFDISCRETE1C192
CC0402C_NP_CC0402_0.033UF0.033uFDISCRETE1C197
CC0402C_NP_CC0402_4PF4pFDISCRETE1C198
CC0402C_NP_CC0402_#10NF#10nFIC1C292
CC0402C_NP_CC0402_#100PF#100pFIC2C295; C296
CC0402C_NP_CC0402_DISCRETE_#2700PF#2700pFDISCRETE1C297
CC0402C_NP_CC0402_100PF100pFDISCRETE4C319; C331; C333; C345
CC0402C_NP_CC0402_3.3NF3.3nFDISCRETE2C323; C337
CC0603C_NP_CC0603_10UF10uFDISCRETE24C3; C5; C18; C19; C60; C72; C77; C85; C90; C97; C100; C107; C114; C116; C129; C170; C324; C325; C326; C338; C339; C340; C1174; C1494
CC0603C_NP_CC0603_@10UF@10uFIC2C11; C37
CC0603C_NP_CC0603_4.7UF4.7uFDISCRETE5C169; C173; C176; C180; C181
CC0603C_NP_CC0603_1UF1uFDISCRETE1C182
CC0603CAP NP_CC0603_10UF10uFDISCRETE1C223
CC0603CAP_NP_CC0603_DISCRETE_#1000PF#1000pFDISCRETE1C293
CC0603CAP_NP_CC0603_DISCRETE_#0.022UF#0.022uFDISCRETE1C299
CC0603C_NP_CC0603_470PF470pFDISCRETE1C363
CC0805C_CC0805_DISCRETE_#0.1UF 100V#0.1uF 100VDISCRETE3C40; C163; C165
CC0805C_NP_CC0805_DISCRETE_22NF22nFDISCRETE2C41; C42
CC0805CAP NON POLAR 0_CC0805_#1000P 1#1000p 100VIC1C166
CC0805C_NP_CC0805_0.01UF0.01uFDISCRETE1C189
CC0805C_NP_CC0805_22NF22nFDISCRETE2C194; C195
CC0805CAP_NP_CC0805_DISCRETE_#4.7NF 1#4.7nF 100VDISCRETE1C289
CC0805CAP_NP_CC0805_DISCRETE_#10UF#10uFDISCRETE1C298
CC1206CAP_NP_CC1206_DISCRETE_1000PF 21000pF 2KVDISCRETE4C155; C156; C157; C204
CC1206C_NP_CC1206_0.1UF0.1uFDISCRETE4C172; C185; C187; C191
CC1206C_NP_CC1206_10UF10uFDISCRETE4C183; C184; C320; C334
CC1206C_NP_CC1206_68NF68nFDISCRETE2C193; C196
CC1210C_NP_CC1210_DISCRETE_22NF 1KV22nF 1kVDISCRETE2C161; C162
CC1210CAP_NP_CC1210_DISCRETE_#2.2UF 1#2.2uF 100VDISCRETE3C164; C287; C288
CC1210C_NP_CC1210_DISCRETE_#22UF#22uFDISCRETE3C290; C291; C294
CC1808CAP_NP_CC1808_DISCRETE_@1000PF@1000pF 5KVDISCRETE1C300
CHOKE_9D9_2SP_12D3WLPOWER CHOKE_CHOKE_9D9_2SP_12D3W47uHDISCRETE1L15
COMMON_5DX10D_4DP_10CIRBCC-0603_0_COMMON_5DX10D_4DP_10#1200uHDISCRETE1L11
CONN_2D54_2SP_4W5D08L9D3HPINSTICK_MALE_2PX1R_CONN_2D54_2HXSPH2.54-S-S-02-G/FIO2J1; J2
DIO214_6D6_2SP_6D22WX7D11LDIODE1_1_DIO214_6D6_2SP_6D22WX7DIODE1_1DISCRETE1D23
DO214AC_4D_4D3L2D45W_2SP_ACDIODE1_1_DO214AC_4D_4D3L2D45W_2ES1DIC1D11
DO214AC_4D_4D3L2D45W_2SP_ACDIODE1_0_DO214AC_4D_4D3L2D45W_2#SS56AGIC1D16
FUSE_5D23_2SP_3D24W4D55L1HPTC_FUSE_5D23_2SP_3D24W4D55L1H_1.1A/16VDISCRETE1PTC1
FUSE_7D9_2SP_7D4W9D4L3D7HPTC_FUSE_7D9_2SP_7D4W9D4L3D7H_@@3AIC2RT1; RT2
GOLD_FINGER_1D_18X2SPPCIE 1X-36PIN_GOLD_FINGER_1D_18@PCIE 1X-36pinIC1J5
IND_4D65_2SP_7D2WL3HPOWER CHOKE_IND_4D65_2SP_7D2WL3#22uHDISCRETE1L9
IND_6D1_2SP_7D3W7D5L6HPOWER CHOKE_IND_6D1_2SP_7D3W7D510uHDISCRETE2L25; L26
LC0603BEAD_LC0603_DISCRETE_100MHZ100MHzDISCRETE7L1; L3; L4; L5; L6; L7; L8
LC0603BEAD_LC0603_100MHZ100MHzIC4L13; L14; L41; L71
LC0805BEAD_LC0805_#100MHZ#100MHzIC2L10; L12
LC1206BEAD_LC1206_#100MHZ#100MHZIC1L24
LED_2D35_2SP_1D25W2L_KBRT_CALED1_1_LED_2D35_2SP_1D25W2L_KBRLED1_1IC7D1; D2; D3; D4; D5; D6; D7
MB2-2313ADAPTER_0_MB2-2313_ADAPTER MOUNAdapter Mount-HoleIC1J36
OPTO_1D78X10D16_22DP_13D3W48D1LSFF_2X5_2_OPTO_1D78X10D16_22DP_SFF_2X5_10IC1TCVR1
PBGA_D8_18R_96SP_9W15D5LSDRAM_MICRON_MT41J64M16_PBGA_D864MX16IC1U2
POWER_6D3X5_3DPJACK_MALE_DIP3_POWER_6D3X5_3DP_JACK_MALE_DIP3IC1J10
PTC_5DX2D1_2DP_9W4D5L11HVARISTOR_PTC_5DX2D1_2DP_9W4D5L1VARISTORIC4P1; P2; P3; P4
QFN_D5X8D4_48SP_7WL1D6HASIC_ZARLINK_LE89116QVCSLAC_48_ASIC_ZARLINK_Le89116QVCSLAC_48IC1U5
RC0402R_RC0402_DISCRETE_100_1%100DISCRETE1R1
RC0402R_RC0402_DISCRETE_@33_1%@33DISCRETE4R2; R3; R6; R9
RC0402R_RC0402_DISCRETE_1000_1%1000DISCRETE33R4; R5; R11; R12; R15; R17; R27; R29; R39; R42; R52; R54; R56; R64; R73; R76; R80; R91; R93; R112; R119; R120; R250; R295; R412; R423; R1255; R1256; R1260; R1650; R1660; R1666; R1667
RC0402R_RC0402_DISCRETE_200_1%200DISCRETE26R7; R8; R13; R14; R98; R99; R104; R106; R117; R118; R121; R122; R123; R124; R144; R194; R195; R196; R197; R198; R221; R230; R237; R239; R252; R353
RC0402R_RC0402_DISCRETE_4.7K_1%4.7KDISCRETE32R18; R43; R46; R48; R50; R61; R63; R67; R69; R71; R83; R92; R95; R103; R105; R107; R108; R110; R116; R180; R181; R182; R183; R184; R185; R290; R291; R1653; R1661; R1662; R1663; R1664
RC0402R_RC0402_DISCRETE_@1000_1%@1000DISCRETE17R19; R21; R23; R25; R31; R33; R60; R62; R66; R68; R70; R82; R96; R202; R293; R294; R1652
RC0402R_RC0402_DISCRETE_@4.7K_1%@4.7KDISCRETE27R20; R22; R24; R26; R28; R30; R32; R34; R35; R36; R37; R38; R40; R41; R53; R55; R57; R65; R74; R77; R81; R102; R292; R366; R465; R1651; R1665
RC0402R_RC0402_DISCRETE_240OHM/1%_1%240ohm/1%DISCRETE1R44
RC0402R_RC0402_DISCRETE_10K_1%10KDISCRETE17R45; R138; R139; R140; R141; R142; R143; R199; R251; R352; R355; R358; R359; R363; R364; R1254; R1259
RC0402R_RC0402_DISCRETE_33_1%33DISCRETE24R47; R49; R51; R58; R59; R84; R85; R86; R87; R88; R94; R100; R159; R161; R1257; R1600; R1605; R1606; R1654; R1655; R1656; R1657; R1658; R1659
RC0402R_RC0402_DISCRETE_@100_1%@100DISCRETE1R75
RC0402R_RC0402_DISCRETE_0_1%0DISCRETE21R89; R90; R101; R109; R113; R125; R126; R127; R128; R132; R133; R134; R135; R136; R269; R271; R1599; R1601; R1603; R1607; R1608
RC0402R_RC0402_13K13KDISCRETE4R111; R354; R356; R361
RC0402R_RC0402_DISCRETE_@10K_1%@10KDISCRETE4R190; R191; R192; R193
RC0402R_RC0402_DISCRETE_30K_1%30KDISCRETE1R345
RC0402R_RC0402_DISCRETE_4.75K_1%4.75KDISCRETE1R347
RC0402R_RC0402_DISCRETE_3K_1%3KDISCRETE1R360
RC0402R_RC0402_82OHM82ohmDISCRETE2R1597; R1598
RC0402R_RC0402_130130DISCRETE2R1602; R1604
RC0603R_RC0603_DISCRETE_7575DISCRETE4R10; R146; R152; R153
RC0603R_RC0603_DISCRETE_240_1%240DISCRETE1R16
RC0603R_RC0603_DISCRETE_@1M_1%@1MDISCRETE1R114
RC0603R_RC0603_DISCRETE_47.5K_1%47.5KDISCRETE1R160
RC0603R_RC0603_DISCRETE_@150K_1%@150KDISCRETE1R162
RC0603R_RC0603_DISCRETE_75K_1%75KDISCRETE1R163
RC0603R_RC0603_DISCRETE_200_1%200DISCRETE1R164
RC0603R_RC0603_DISCRETE_1K_1%1KDISCRETE1R166
RC0603R_RC0603_DISCRETE_100K_1%100KDISCRETE1R167
RC0603R_RC0603_DISCRETE_150OHM_1%150ohmDISCRETE1R168
RC0603R_RC0603_DISCRETE_402K_1%402KDISCRETE1R176
RC0603R_RC0603_DISCRETE_#220K#220KDISCRETE2R331; R335
RC0603RES SMD_RC0603_DISCRETE_#10#10DISCRETE1R332
RC0603RES SMD_RC0603_DISCRETE_#10K#10KDISCRETE3R333; R338; R344
RC0603R_RC0603_DISCRETE_#20K#20kDISCRETE1R334
RC0603R_RC0603_DISCRETE_#68#68DISCRETE1R336
RC0603RES SMD_RC0603_DISCRETE_#1K#1KDISCRETE2R337; R343
RC0603RES SMD_RC0603_DISCRETE_@1K@1KDISCRETE1R339
RC0603R_RC0603_DISCRETE_#120K#120KDISCRETE1R340
RC0603R_RC0603_DISCRETE_#100K_1%#100KDISCRETE1R341
RC0603R_RC0603_DISCRETE_#38.3K#38.3KDISCRETE1R342
RC0603R_RC0603_DISCRETE_6.34K_1%6.34KDISCRETE1R357
RC0603R_RC0603_DISCRETE_26.1K_1%26.1KDISCRETE1R362
RC0603R_RC0603_DISCRETE_5.76K_1%5.76KDISCRETE1R365
RC0805R_RC0805_DISCRETE_0.1OHM_1%0.1ohmDISCRETE1R137
RC0805R_RC0805_DISCRETE_200K_1%200KDISCRETE4R170; R171; R177; R178
RC0805R_RC0805_DISCRETE_3.01KOHM_1%3.01KohmDISCRETE2R172; R175
RC0805R_RC0805_DISCRETE_0_1%0DISCRETE2R173; R174
RC0805R_RC0805_DISCRETE_@0_1%@0DISCRETE2R413; R417
RC1206R_RC1206_DISCRETE_100K_1%100KDISCRETE1R115
RC1206R_RC1206_DISCRETE_20_1%20DISCRETE1R165
RC1206R_RC1206_DISCRETE_0.03OHM_1%0.03ohmDISCRETE1R169
RC1206R_RC1206_DISCRETE_1M_1%1MDISCRETE1R179
RC1206RES SMD_RC1206_DISCRETE_#47K#47kDISCRETE2R329; R330
RC1206R_RC1206_DISCRETE_1K_1%1KDISCRETE1R346
RC1210R_RC1210_DISCRETE_@0@0DISCRETE2R155; R158
RC2512R_RC2512_DISCRETE_0_1%0DISCRETE2R210; R211
RES_CAL_D5_4X2SP_1W2LRP_8P4R_1_RES_CAL_D5_4X2SP_1W_133DISCRETE2RP7; RP9
RES_CAL_D5_4X2SP_1W2LRP_8P4R_1_RES_CAL_D5_4X2SP_1W2L10KDISCRETE1RP13
RES_CAL_D5_8SP_1W2LRP_8P4R_RES_CAL_D5_8SP_1W2L_100100DISCRETE5RP1; RP2; RP3; RP4; RP5
RES_D5_8SP_1W2LRP_8P4R_RES_D5_8SP_1W2L_DISCRET200DISCRETE1RP11
RJ11_1D27X2D54_1X1X4DPRJ11_1X1_0_RJ11_1D27X2D54_1X1X4RJ11_1X1_4IC1J4
RJ45_1D27_1X1X8DP_15D1W17D7LRJ45_0_RJ45_1D27_1X1X8DP_15D1W1RJ45IO1J3
SIP1PPINSTICK_MALE_1PX1R_SIP1P_@1P*1@1P*1RIC1J20
SOD123_3D28_2SP_1D65W2D7L1H_ACDIODE21_1_SOD123_3D28_2SP_1D65W#1N4148W 75V 0.15AIC1D17
SOD123_3D28_2SP_ACDIODE21_0_SOD123_3D28_2SP_AC_SDSD204H 40V 2AIC5D19; D20; D21; D22; D58
SOIC_1D27X5D4_8SP_4D9W3D9L_G1MP6002_0_SOIC_1D27X5D4_8SP_4D9W#MP6001DNIC1U14
SOIC_1D27X5D16_8SP_5D1LDC_DC_MPS_MP1482DS_C165_SOIC_1DADJIC2U16; U17
SOIC_1D27X9D6_16SP_10D31LASIC_ZARLINK_LE89810_SOIC16_SOIASIC_ZARLINK_Le89810_SOIC16IC1U6
SOIC_1D27X9D57_16SP_10D5LFLASH_MXIC_MX25L12845E_SOP16_SO128MbIC1U18
SOP_1D27X5D156_8SP_5LTHYRISTOR_BOURNS_ISP61089_SOP_1ISP61089IC1U7
SOP_2D54X9D_4SP_6D5W4D58L3D9HKPC627_SOP_2D54X9D_4SP_6D5W4D58#EL817S1BTAIC1U15
SOT23DIODE_REG_0_SOT23_IC_#TL431 2.#TL431 2.5VIC1D18
SOT23_1D9X2D4_3SP_1D3W2D9L_GSDPMOS1_1_SOT23_1D9X2D4_3SP_1D3W2P-CHIC1Q10
SOT23_1D9_3SP_1D2W2D9L_A_NC_CDIODE1_2_SOT23_1D9_3SP_1D2W2D9LDIODE1_2IC2D9; D10
SOT23_1D9_3SP_1D2W2D9L_A_NC_CDIODE1_2_SOT23_1D9_3SP_1D2W2D_1#BAS21IC1D15
SOT23_1D9_3SP_1D3W2D9L_A_NC_CDIODE1_2_SOT23_1D9_3SP_1D3W2D9L#BAS16IC1D8
SOT23_3SP_BECBJT_NPN1_1_SOT23_3SP_BEC_TMBT44TMBT4401IC3Q4; Q9; Q18
SOT23_3SP_GSDNMOS1_1_SOT23_3SP_GSD_AO3414AO3414IC1Q2
SOT143_1D92X2D2_4SP_1D4W3D04LSR3V3_SOT143_1D92X2D2_4SP_1D4W3SR3V3IC1D24
SOT223_2D3_4SP_BC1EC2BJT_PNP1_2_SOT223_2D3_4SP_BC1ECFZT955IC1Q3
SW_PUSH_3DX3D2_6DP_7D2WSW_1_SW_PUSH_3DX3D2_6DP_7D2W_IONNNIO1SW1
SW_PUSH_4D5X2D5X7_2DP_CONTACTSW_14GND_SW_PUSH_4D5X2D5X7_2DP_DIPIC1S1
TP_40S0D0CWIRE_MOUNT_1_TP_40S0D0C_WIREMOUWIREMOUNTIC8J6; J7; J9; J12; J13; J14; J15; J16
TSOP_D5X19D4_48SP_12W18D4LFLASH_H27U1G8F2B_TSOP48_TSOP_D5@1GbIC1U3
TSSOP_D5X7D48_48SP_12D6L74LVTH162245_0_TSSOP_D5X7D48_4874LVTH162244IC1U9
XFMR_1D27X15D7_24SP_17D5L_M-TEKTRANSFORMER_XFMR_1D27X15D7_24SPGS2402SIPIC1T1
XFMR_2D5X10D_8DP_14D5WLEE13_XFMR_2D5X10D_8DP_14D5WL_#1#119uHIC1T2
XTAL_1D5X2D2_4SP_2D5W3D2L0D65HXTAL_2_XTAL_1D5X2D2_4SP_2D5W3D225MHzIC1X1
附件:
pcb文件如下:0 n6 a, o2 L' [6 b# L4 P
游客,如果您要查看本帖隐藏内容请回复
/ m1 ]0 _, m1 b$ z
GMT+8, 2025-7-20 15:02 , Processed in 0.140625 second(s), 28 queries , Gzip On.
