查看: 851|回复: 13
[allegro16.3][16层]XILINX的vc709评估板(SOC_IRONWOOD_FHG1761+DDR3_SO-DIMM+USB...
发表于 2019-12-23 15:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][16层]XILINX的vc709评估板(SOC_IRONWOOD_FHG1761+DDR3_SO-DIMM+USB)原理图和pcb文件
) m- x- H! h7 M0 g& I5 d! n7 m$ G4 `# x1 `! E6 i
7 n! I# P" N. R9 ?/ \" z0 Y2 E. m" R
文件描述:
+ n4 \3 f) v% C+ R* h/ y/ u  ?6 l% H# V. Z  @5 S1 q/ h
1. 作品用途:XILINX的vc709评估板
2. 软件版本:allegro16.3
3. 层数:16层
4. 用到的主要芯片:SOC_IRONWOOD_FHG1761+DDR3_SO-DIMM+USB
5. PCB尺寸:11.2*4.999mm
; i9 z, ?0 a4 c; S. ~8 r, _外挂内存条,实现面向高带宽、高性能应用的 40Gbs 连接功能平台。3 T- Z4 F. i# a0 \3 k7 h
作品截图如下:
& [7 a8 \- v% u' y4 d6 J: z  T6 `& f5 O
顶层截图:
- r& U+ b2 r& Z( Z! N. f2 w; Y1 R. W' h  y8 Z
  w! k" \) K$ X+ f/ a: x8 P4 _3 r
底层截图:
: O) w" G4 r$ ]
. B: ^9 M9 i' E8 u0 g1 S- a' X$ e6 h6 ?% z- Z, I  n- s
全层截图:
- Y; Q1 w4 v  `9 F" ]9 K- D& a. Q8 L5 m% f+ z# p5 ?7 @
- h* F: C! E1 L( N
. s0 f1 j7 F* q' |  `; i8 A
! [" M) y+ `3 w8 v  P7 P: n
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
32K10K_400_NEWSMA_32K10K-40032K10K-400L5IC4J25; J26; J31; J32
4020_1UF_04020.1UFIC138C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C100; C102; C103; C104; C105; C121; C122; C124; C133; C137; C138; C139; C140; C347; C348; C349; C351; C352; C353; C354; C355; C356; C357; C358; C359; C360; C361; C362; C363; C364; C366; C367; C393; C394; C416; C417; C423; C424; C461; C462; C463; C490; C491; C492
4020_01UF_04020.01UFIC8C109; C187; C188; C189; C192; C213; C214; C375
4020_022UF_04020.022UFIC2C141; C142
4024_7UF_04024.7UFIC23C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C493; C494; C495; C496; C497; C498; C499; C500; C501; C502; C503; C504
4020_068UF_04020.068UFIC15C170; C253; C254; C255; C257; C258; C259; C260; C261; C262; C378; C379; C380; C381; C382
402DNP_C_0402DNPIC2C217; C218
4020_22UF_04020.22UFIC16C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C246
4021000PF_04021000PFIC4C268; C269; C270; C271
402820PF_0402820PFIC11C292; C293; C294; C296; C297; C298; C299; C387; C388; C389; C390
4024_7K_04024.7KIC92R1; R3; R4; R5; R6; R7; R8; R9; R10; R11; R13; R14; R15; R16; R17; R18; R20; R21; R22; R23; R24; R25; R26; R27; R28; R30; R31; R32; R33; R36; R37; R38; R39; R40; R41; R42; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R85; R88; R98; R99; R100; R101; R109; R110; R111; R112; R122; R123; R124; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R244; R391; R392; R397; R398; R421
4024_7K_0402DNPIC5R12; R19; R29; R89; R125
4024_22K_04024.22KIC11R34; R74; R75; R76; R78; R79; R80; R81; R343; R344; R345
40210_0K_040210.0KIC34R44; R192; R193; R197; R199; R200; R201; R202; R203; R204; R205; R206; R207; R208; R209; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R349; R350; R351; R352; R353; R354; R355; R356
4021_00K_04021.00KIC28R45; R83; R198; R276; R278; R279; R281; R282; R283; R284; R286; R287; R288; R289; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382
402DNP_R_0402DNPIC17R56; R136; R137; R233; R234; R235; R236; R238; R241; R242; R243; R245; R246; R247; R248; R439; R440
402249_0402249IC3R84; R86; R87
402787_0402787IC6R90; R91; R93; R346; R347; R348
40215_040215IC4R94; R95; R96; R97
40280_6_040280.6IC10R105; R106; R159; R160; R161; R162; R163; R164; R451; R452
402100_0402100IC40R113; R114; R115; R116; R118; R119; R120; R121; R165; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R389; R390; R419; R420; R449; R450; R453; R454
4025_62K_04025.62KIC1R117
4021_07K_04021.07KIC1R144
40286_6K_040286.6KIC1R145
40249_9_040249.9IC8R147; R148; R149; R150; R151; R152; R153; R154
4023_48K_04023.48KIC1R155
402220_0402220IC2R226; R227
402100K_0402100KIC2R259; R359
4020_04020IC13R261; R262; R263; R264; R265; R361; R362; R363; R364; R365; R366; R367; R368
4022_7K_04022.7KIC1R293
4022_00K_04022.00KIC10R294; R295; R296; R299; R300; R301; R302; R303; R383; R436
402261_0402261IC4R306; R307; R395; R396
40275K_040275KIC4R333; R334; R335; R388
4021_21K_04021.21KIC5R337; R338; R339; R340; R341
402787_0402DNPIC1R358
0402_SHORT0402_SHORT0402_SHORTIC12Z14; Z15; Z16; Z18; Z19; Z20; Z21; Z22; Z23; Z24; Z25; Z26
6031UF_06031UFIC13C167; C168; C169; C173; C174; C175; C471; C472; C473; C475; C476; C477; C478
603FERRITE-220_0603FERRITE-220IC7L10; L21; L22; L23; L24; L27; L28
0603_SHORT0603_SHORT0603_SHORTIC13Z1; Z2; Z3; Z4; Z6; Z7; Z8; Z9; Z10; Z11; Z12; Z13; Z27
80510UF_080510UFIC2C65; C252
80510UF_080510UFIC6C110; C111; C112; C249; C250; C251
8054_7UF_08054.7UFIC7C219; C220; C221; C222; C224; C376; C377
805100PF_0805100PFIC2C486; C487
805FERRITE-600FERRITE-600IC5L1; L2; L3; L4; L5
0805_A40_1UF_0805_CPACK0.1UFIC18CP1; CP2; CP3; CP4; CP5; CP6; CP7; CP8; CP9; CP10; CP11; CP12; CP13; CP14; CP15; CP16; CP17; CP18
120622UF_120622UFIC15C51; C78; C99; C101; C106; C107; C108; C114; C115; C116; C117; C119; C120; C368; C369
120647UF_120647UFIC13C52; C123; C125; C126; C127; C129; C130; C131; C132; C143; C371; C372; C373
1206100UF_1206100UFIC21C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C399; C400; C401; C402; C404; C418; C419; C420; C421; C422
120610UF_120610UFIC9C328; C333; C334; C335; C340; C341; C342; C343; C344
121010UF_121010UFIC10C134; C135; C136; C374; C464; C465; C467; C468; C469; C470
1224_SMTLVK25R005FER0.005IC9R325; R326; R328; R329; R330; R331; R385; R386; R387
27730214472773021447FERRITE-78IC7L8; L29; L30; L32; L33; L34; L35
ASP_134486_01ASP_134486_01ASP_134486_01IC1J35
BNX016-01BNX016-0150MOHMIC1U73
C402-25100_C402DNPIC2R2; R43
CAP_F330UF_8_3MMX8_3MM330UFIC8C172; C320; C321; C322; C324; C325; C391; C392
CONN_USB_MINI_B_THCONN_USB_MINI_B_THCONN_USB_MINI_B_THIC1J17
CON_MOL_20P_74441_001074441-001074441-0010IC4P2; P3; P4; P5
CON_MOL_5569_6P39-30-1060_JACK_500X54039-30-1060IC1J18
DDR3_SO-DIMM_SHIELDEDDDR3_SO-DIMMDDR3_SO-DIMM_SHIELDEDIC2J1; J3
DIGILENT_USB_JTAGDIGILENT_USB_JTAGDIGILENT_USB_JTAGIC1U26
EFS_R_PDSS_T22PTD08D210WPTD08D210WACIC5U20; U21; U22; U62; U63
EGP_R_PDSS_T12PTD08A020WPTD08A020WIC2U15; U25
FIDCUTFIDCUTFIDCUTIC6FID1; FID2; FID3; FID4; FID5; FID6
HDR_1X2HDR_1X2HDR_1X2IC6J9; J10; J11; J12; J50; J53
HDR_1X3HDR_1X3HDR_1X3IC3J42; J43; J54
HDR_1X3_LOCK_MOLEXWM2701-ND22_11_2032IC1J48
HDR_2X3HDR_2X3HDR_2X3IC1J49
HDR_BOX_2X5HDR-2X5-SHR_HDR-2X5-SHRHDR_BOX_2X5IC1J5
HSMF_C15XHSMF-C155LED-GRN-REDIC1DS1
IND_IHLP2020BZ_ERINDUCTOR_0_4_7UH4.7UHIC8L6; L7; L11; L12; L13; L14; L15; L16
LED_0603LED-GRN-SMT_LED_0603LED-GRN-SMTIC9DS2; DS3; DS4; DS5; DS6; DS7; DS8; DS9; DS10
LED_0603LED-GREEN-SMT_LED_0603LED-GRN-SMTIC4DS14; DS16; DS17; DS18
MH_250H125HOLE_MH_125_250MH_125_250IC5MH1; MH2; MH3; MH5; MH6
MINIMELFDL4148DL4148IC1D1
MSOP_8INA333_MSOP-8INA333IC11U16; U53; U54; U55; U57; U58; U59; U60; U66; U67; U68
OSCON_C616SVPF180M180UFIC6C479; C480; C482; C483; C484; C485
OSC_EG2121CA_6PSIT9122233.333333MHZIC1U13
OSC_EG2121CA_6PSIT9102200MHZIC1U51
OSC_SIT8103_PKG2SIT810380.00000MHZIC1U40
PC28F00AG18FEPC28F00AG18FEPC28F00AG18FEIC1U3
PCIE_8LANE_EDGEPCIE_8LANE_EDGEPCIE_8LANE_EDGEIC1P1
PFC_S_PQFP_G80UCD9248PFC_QFP50P14X14-80UCD9248PFCIC3U42; U43; U64
QFN36_6X6MMSI5324C-C-GMSI5324C-C-GMIC1U24
QFN_24PCA9548ARGER_QFN24PCA9548ARGERIC1U52
QFN_28CP2103GM_MLP-28CP2103GMIC1U44
QFN_RSV_16SN74AVC4T245SN74AVC4T245IC3U37; U38; U39
QFN_RSW_10SN74AVC2T245SN74AVC2T245IC1U7
RES_WSL3637WSL36370.005IC2R35; R82
SAMTEC_TST_110_XX_X_DSAMTEC_TST_110_XX_X_DTST-110-01-G-DIC1J19
SC70_5NC7SZ66NC7SZ66P5XIC1U27
SC70_6SN74AVC1T45SN74AVC1T45IC5U45; U46; U47; U70; U72
SI570570BAB000544DG_5X710MHZ-810MHZIC1U34
SOC_IRONWOOD_FHG1761SOC_IRONWOOD_FHG1761DNPIC1U1
SOD_123DDZ9678_SOD_123DDZ9678IC1D2
SOD_123BZX84C4V7_SOT23BZT52C5V1-TPIC3D3; D4; D7
SON10_TPS51200TPS51200DRCTTPS51200DRCTIC1U23
SOT23_3REF3012AIDBZT_SOT23_3REF3012AIDBZTIC1U35
SOT143SP0503BAHT_SOT143SP0503BAHTGIC1X5
SOT_23SI2300DS_SOT23SI2300DSIC1Q1
SOT_23NDS331N_SOT23NDS331NIC9Q2; Q5; Q6; Q7; Q8; Q10; Q15; Q16; Q17
SOT_89FCX491A_SOT_89FCX491AIC3Q11; Q12; Q13
SW_450_5001201M2S3ABE2_SLIDE_2POS1201M2S3AQE2IC1SW12
SW_SDA_10PSDA05H1SBDSDA05H1SBDIC1SW11
SW_SDA_16PSDA08H1SBDSDA08H1SBDIC1SW2
SW_TL3301_G_4PTL3301EF100QG-NDTL3301EF100QGIC7SW3; SW4; SW5; SW6; SW7; SW8; SW9
S_PVQFN_N16PCA9546A4CH_I2C_SWITCHIC1U14
T-18_AXIAL1N5335BRLG1N5335BRLGIC5D5; D8; D9; D10; D11
TANT_D330UF_TANT_D330UFIC3C113; C280; C281
TANT_D330UF_LOW_ESR330UFIC11C171; C284; C285; C286; C288; C289; C290; C291; C383; C385; C386
TANT_E680UF_TANT_E680UFIC6C155; C279; C407; C408; C409; C410
TO_PMOD_7LMZ12002LMZ12002IC1U36
TSOT_5ADP123ADP123IC1U10
TSSOP8_65P440X300MMM24C08-WDW6TPM24C08-WDW6TPIC1U6
TSSOP_16CD74HC4051_TSSOP-16CD74HC4051IC3U4; U5; U61
TSSOP_20TXS0108ETXS0108EIC5U2; U8; U9; U11; U32
TSSOP_20SN74LV541APWRSN74LV541APWRIC1U19
XTAL_CS_023_125X98XTAL_CS_023_125X98114.285MHZIC1X6
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
$ Q6 d4 d( t, Q& ~# E" N) w; e
# L9 P& _2 A5 c: N1 i" g& {1 m
参与人数 1威望 +5 收起 理由
leleeda + 5
发表于 2020-5-31 14:21 | 只看该作者
下载下来学习学习
; x  m' ~& {' F0 n
    郁闷
    2020-6-3 15:14
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    发表于 2020-6-2 11:25 | 只看该作者
    看看,感谢分享
    $ j  n; L8 o( s0 h' W
    擦汗
    2025-7-18 15:45
  • 签到天数: 137 天
    [LV.7]常住居民III
    发表于 2020-6-21 13:09 | 只看该作者
    发表于 2020-6-23 02:01 | 只看该作者
    zhaogefengzhuang ,kanyxiai
    + P2 [8 e: E# ~
    2024-8-26 15:16
    发表于 2020-7-1 21:53 | 只看该作者
    看看,感谢分享
    发表于 2020-12-7 01:32 | 只看该作者
    谢谢,学习一下
    发表于 2020-12-9 18:32 | 只看该作者
    最近剛好有需要,學習一下,受教了,謝謝。# }( q( A  Z$ \. R' ]) S3 a
    擦汗
    2021-9-6 15:33
  • 签到天数: 68 天
    [LV.6]常住居民II
    发表于 2020-12-22 10:52 | 只看该作者
    非常优秀,谢谢分享!!
    13#
    发表于 2023-5-2 10:27 | 只看该作者
    感谢分享,学习学习7 Z. d! n9 M* U
    14#
    发表于 2023-7-6 11:52 | 只看该作者
    GMT+8, 2025-7-20 20:09 , Processed in 0.156250 second(s), 31 queries , Gzip On.
