查看: 296|回复: 0
[allegro16.3][16层]FMC+ASP+MAIN原理图和pcb文件
发表于 2019-12-21 14:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
) m- x- H! h7 M0 g& I5 d! n7 m$ G
$ I2 l$ V$ ]5 ^# G
文件描述:
+ n4 \3 f) v% C
0 q. s* S9 K$ E2 |9 B. O2 O/ u
) ~( G3 n7 N% v6 K6 Z
1. 软件版本:allegro16.3
2. 层数:16层
3. 用到的主要芯片:FMC+ASP+MAIN
4. PCB尺寸:162.1*233.4 mm
. D3 C" q; S, Y6 X% d
作品截图如下:
9 \! ^! p7 e$ A! Y+ A4 ~" c- v
顶层截图:
- r& U+ b2 r& Z( Z! N
5 r. Q1 B0 B9 `1 U; n7 Z
底层截图:
% \" T5 J# N6 X1 q
. B: ^9 M9 i' E8 u0 g1 S- a' X
% |, L+ m8 c- h) ~) X" c
全层截图:
- Y; Q1 w4 v  `9 F" ]9 K- D& a/ s  s7 S: u" R4 R7 ^$ h
$ X$ A( {+ V' A
叠层阻抗信息:
. s0 f1 j7 F* q' |  `; i8 A. I' d6 x+ [2 J9 T" d; t* ?0 ?
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA48H6_080XCF32P_FSG48CIC3IC2; IC3; IC4
BGA209C100P11X19_1400X2200X180CY7C1474V33-167BGCIC2IC17; IC18
BGA256C127P20X20_2700X2700X170NADSP-21369KBPZ-3AIC1IC31
BGA1136C100P34X34_3500X3500X340FMC_FPGA_TOPIC1IC9
BGA1136C100P34X34_3500X3500X340MAIN_FPGA_TOPIC1IC28
C0402CAPCERSMDCL2_0402-10NF,16V_GEN10nFDISCRETE140C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C645; C646; C647; C648; C649; C650; C651; C652; C653; C654; C655; C656; C657; C658; C660; C661; C662; C663; C664; C666; C667; C668; C674; C676; C677; C678; C680; C681; C682; C683; C684; C685; C686; C688; C691; C692; C693; C694; C695; C696; C697; C698; C699; C708
C0402CAPCERSMDCL2_0402-22NF,16V_GEN22nFDISCRETE349C106; C107; C108; C109; C194; C195; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226; C227; C228; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C246; C247; C248; C250; C251; C252; C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C263; C264; C265; C268; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C294; C296; C297; C298; C299; C300; C301; C302; C303; C304; C306; C307; C308; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C342; C343; C344; C345; C346; C347; C348; C349; C350; C351; C352; C353; C354; C355; C356; C357; C358; C359; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387; C388; C389; C390; C391; C392; C393; C394; C395; C396; C397; C398; C399; C400; C401; C430; C431; C432; C433; C467; C468; C469; C470; C471; C472; C473; C474; C475; C476; C477; C478; C479; C480; C481; C482; C483; C484; C485; C486; C487; C488; C489; C490; C493; C494; C495; C496; C497; C498; C499; C500; C501; C502; C503; C504; C505; C506; C507; C508; C509; C510; C511; C512; C513; C514; C515; C516; C517; C518; C519; C520; C521; C522; C523; C524; C525; C526; C527; C528; C529; C530; C531; C532; C533; C534; C535; C536; C537; C538; C539; C540; C541; C542; C543; C544; C545; C546; C547; C548; C549; C550; C551; C552; C553; C554; C555; C556; C557; C558; C559; C560; C561; C562; C568; C569; C570; C571; C572; C573; C574; C575; C576; C577; C578; C579; C580; C581; C582; C584; C585; C586; C587; C588; C589; C590; C591; C592; C593; C594; C595; C596; C597; C598; C599; C600; C601; C602; C603; C604; C605; C606; C607; C608; C609; C610; C611; C612; C613; C614; C615; C616; C617; C618; C619; C620; C621; C622; C623; C624; C625; C707
C0402RSMD0402_1/16W-100,1%100DISCRETE4R145; R146; R147; R148
C0603CAPCERSMDCL2_0603-100NF,16V100nFDISCRETE6C5; C73; C457; C460; C671; C701
C0603CAPCERSMDCL2_0603-47NF,16V47nFDISCRETE98C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C110; C111; C112; C186; C187; C190; C191; C402; C403; C404; C405; C406; C407; C408; C409; C410; C411; C412; C413; C414; C415; C416; C417; C418; C419; C420; C421; C422; C423; C424; C425; C426; C427; C428; C429; C434; C435; C436; C437; C438; C439; C440; C441; C442; C443; C444; C445; C446; C447; C450; C452; C453; C454; C456; C459; C466; C632; C633; C634; C635; C700; C702; C703; C704; C710; C711; C714; C715
C0603CAPCERSMDCL2_0603-10NF,50V10nFDISCRETE71C104; C105; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C188; C189; C196; C197; C198; C199; C449; C455; C458; C461; C462; C463; C464; C465; C626; C629; C631; C636; C637; C638; C639; C640; C641; C642; C643; C669; C670; C672; C705; C713
C0603CAPCERSMDCL2_0603-1.0NF,50V1nFDISCRETE1C673
C0603FERRITE_SMD-BLM18AG102SN1,MURATADISCRETE1L21
C0603RSMD0603_1/10W-150,1%150DISCRETE3R1; R2; R48
C0603RSMD0603_1/10W-10K,1%10kDISCRETE19R4; R5; R94; R123; R124; R125; R126; R127; R128; R129; R130; R161; R181; R182; R183; R184; R185; R207; R208
C0603RSMD0603_1/10W-3.3K,1%3.3kDISCRETE40R7; R8; R9; R10; R11; R12; R13; R14; R36; R51; R70; R82; R95; R96; R105; R106; R107; R108; R109; R110; R111; R117; R155; R156; R157; R158; R159; R160; R162; R172; R188; R189; R190; R191; R195; R196; R205; R206; R209; R225
C0603RSMD0603_1/10W-270,1%270DISCRETE4R15; R16; R18; R47
C0603RSMD0603_1/10W-180,1%180DISCRETE11R17; R19; R49; R60; R61; R83; R84; R86; R87; R89; R90
C0603RSMD0603_1/10W-100,1%100DISCRETE22R20; R21; R28; R39; R40; R54; R55; R62; R77; R78; R79; R85; R88; R91; R114; R115; R121; R122; R153; R154; R177; R178
C0603RSMD0603_1/10W-6.2K,1%6.2kDISCRETE2R22; R27
C0603RSMD0603_1/10W-200,1%200DISCRETE28R23; R24; R25; R30; R31; R32; R33; R34; R37; R38; R41; R42; R52; R53; R56; R57; R58; R59; R71; R72; R73; R74; R75; R76; R80; R81; R167; R168
C0603RSMD0603_1/10W-4.7K,1%4.7kDISCRETE13R26; R29; R92; R93; R113; R116; R119; R120; R169; R170; R171; R218; R224
C0603RSMD0603_1/10W-820,1%820DISCRETE3R35; R50; R69
C0603RSMD0603_1/10W-51,1%51DISCRETE18R43; R44; R45; R46; R63; R64; R65; R66; R67; R68; R131; R132; R133; R134; R136; R137; R140; R141
C0603RSMD0603_1/10W-1M,1%1MDISCRETE2R99; R211
C0603RSMD0603_1/10W-100K,1%100kDISCRETE5R101; R200; R215; R216; R217
C0603RSMD0603_1/10W-330,1%330DISCRETE2R112; R118
C0603RSMD0603_-00,0DISCRETE10R138; R139; R142; R143; R144; R186; R187; R192; R193; R194
C0603RSMD0603_1/10W-1K,1%1kDISCRETE17R149; R150; R151; R152; R163; R164; R173; R174; R175; R176; R179; R180; R201; R202; R203; R204; R212
C0603RSMD0603_1/10W-13K,1%13kDISCRETE1R165
C0603RSMD0603_1/10W-8.2K,1%8.2kDISCRETE1R166
C0603RSMD0603_1/10W-3K,1%3kDISCRETE1R213
C0603RSMD0603_1/10W-47,1%47DISCRETE1R219
C0603RSMD0603_1/10W-120K,1%120kDISCRETE1R226
C0805CAPCERSMDCL2_0805-10UF,10V_GEN10uFDISCRETE9C145; C644; C659; C665; C675; C679; C687; C689; C690
C0805RSMD0805_125MW-10K,1%10kDISCRETE4R102; R103; R197; R198
C0805RSMD0805_125MW-3.3K,1%3.3kDISCRETE4R104; R135; R199; R214
C0805POLELCAPTAN_SMD-6.8UF,6.3V6.8uFDISCRETE2C448; C451
C2512RSMD2512_2W-0R05,1%0R05DISCRETE1R220
C3216POLELCAPTAN_SMD-22UF,6.3V22uFDISCRETE32C7; C192; C193; C200; C201; C202; C203; C204; C229; C230; C249; C266; C267; C295; C305; C339; C340; C341; C491; C492; C563; C564; C565; C566; C567; C583; C627; C628; C630; C706; C709; C712
C7343POLELCAPTAN_SMD-47UF,10V47uFDISCRETE3C1; C2; C3
C7343POLELCAPTAN_SMD_X-150UF,16V150uFDISCRETE1C4
C7343POLELCAPTAN_SMD-22UF,16V_GEN22uFDISCRETE2C6; C146
C7343POLELCAPTAN_SMD_X-100UF,20V100uFDISCRETE1C72
CON10MC_3M2500CON10P-N2510-5002RBIO1J4
D0805LED-HSMS-C170HERDISCRETE2LD7; LD8
DIOM5027X244NDIODE_SCHOTTKY_CA-15MQ040NDISCRETE3D1; D2; D3
EMI_PI4701FILTER-8200PF,001DISCRETE8L1; L6; L7; L9; L10; L11; L13; L17
FAIRCHILD_POWER33_MLP08TFDMC7696-DRAIN=P3V3DISCRETE3IC41; IC58; IC59
HARTING_02011602101CONVME64XP1-02 01 160 2101-P12V=P12VRAW,P3V3=P3V3RAW,VCC=P5VRAWIO1P1
HARTING_02011602101CONVME64XP2-02 01 160 2101-VCC=P5VRAWIO1P2
INDC3216X130NFERRITE_SMD-74279216,WURTHDISCRETE1L16
INDC_WURTH_7427511FERRITE_SMD-7427511,WURTHDISCRETE1L8
INDUC_NR10050INDUCTANCE_NR10050-22UH22uHDISCRETE6L3; L4; L5; L12; L14; L15
IND_COOPER_UP3BINDUCTANCE_UP3B-1UH1uHDISCRETE1L2
IND_WURTH_WE-SUKWFERRITE_WE-SUKW-7427512,WURTHDISCRETE3L18; L19; L20
LCC10_1206R8SMD-10K10kDISCRETE1RZ1
LED_AVAGO_HSMF-C113HSMF-C113DISCRETE6LD1; LD2; LD3; LD4; LD5; LD6
MOLEX_47082-001CON7P-47082-1000IO1J3
NUT_M2-5NUT-BN629-1348426,FOR M2.5 SCREWfor M2.5 screwMECHANICAL4NUT1; NUT2; NUT3; NUT4
OSCSC254P490X696X180-6NOSC_6P_ENDIS_OUT_COMPOUT_145-CCPD-034-50-200.000,200.000MHZ-VCCA200.000MHzIC1QZ1
QFN50P400X400X100-25N-S225PCA9552BS-VDD=P3V3,VSS=GNDIC1IC25
QFN50P500X500X80-29N-S325MAX1230BCTI+-VDD=P5V_MAXIC1IC36
QFN50P700X700X100-49N-S510AD9512BCPZ-VS=P3V3IC2IC12; IC14
QFN50P900X900X100-65N_S485AD9510BCPZ-VS=P3V3IC1IC23
QFP50P900X900X160-48NISPPAC-CLK5610AV-01TN48CIC1IC22
QFP65P1600X2200X160-100NCY7C1472V33-167AXI167MhzIC2IC26; IC27
RESC6432X60NRSMD2512_1W-0R005,1%0R005DISCRETE7R6; R97; R100; R210; R221; R222; R223
RESMELF5822NRESCARBON_1W_MELF-1M,2%1MDISCRETE2R3; R98
SAMTEC_ASP-134486-01ASP-134486-01IO2J1; J2
SAMTEC_HTSS-107-01-F-D-03CON14P-HTSS-107-01-F-D-03IO1J7
SAMTEC_MTLW-102-07-L-S-250CON2P-MTLW-102-07-L-S-250IO1J6
SAMTEC_MTLW-110-07-L-D-250CON20P-MTLW-110-07-L-D-250-NOIO1J8
SCREW_M2-5SCREW-BN5687-3061600,M2.5 L=10MMM2.5 L=10mmMECHANICAL4SCREW1; SCREW2; SCREW3; SCREW4
SOIC8S_127MC10EP52DG-(GND:5; P3V3:8)IC1IC15
SOIC127P598X200-8NDS18B20Z+IC1IC24
SOIC127P600X175-8NMC100EPT21DGIC1IC16
SOIC127P600X175-8NM25P20-VMN6P-VCC=P3V3D,VSS=GNDIC1IC29
SOIC127P600X175-8NFM25W256-GIC1IC30
SOP65P210X110-6_5NSN74LVC1G126DCK-VCC=P3V3IC2IC44; IC45
SOP65P490X110-8NMC100EP11DTGIC2IC10; IC11
SOP65P640X110-14N74LCX125MTC-VCC=P3V3IC3IC20; IC48; IC49
SOP65P640X110-14N74LCX126MTC-VCC=P3V3IC1IC21
SOT23TRANS MOSFET_GSD-2N7002,SOT23DISCRETE17T1; T2; T3; T4; T5; T6; T7; T8; T9; T10; T11; T12; T13; T14; T15; T16; T17
SOT23_5LT1964ES5-BYPIC1IC54
SOT65P210X110-6NPRTR5V0U4YDISCRETE1D4
SOT65P210X110-6NSN74LVC1G97DCKT-NO,VCC=P3V3IC3IC19; IC55; IC56
SOT65P210X110-6NSN74LVC1G97DCKT-VCC=P3V3IC11IC34; IC35; IC42; IC43; IC46; IC47; IC50; IC51; IC52; IC53; IC57
SOT95P285X100-6NLMP8645MKIC3IC37; IC38; IC39
SOT223_5LP3961-1V81.8VDISCRETE1IC1
SW4PSMD_DTSL6SWPB1UNI-DTSL_6IC1PB1
SW_MULTICOMP_MCDHN-04F-T-VSW4INT-MCDHN-04F-T-VDISCRETE1SW1
TO170P1524X483-5_6N-R1075X945IPS7081SPBFIC1IC40
TP_HOLE_08_GNDTP_GND_HOLE+GND-0.8MMIO3MHZ25_N; TP8; TP9
TP_SMD_2X2TP_SMD-2X2MMIO46DSPRST_N; DSP_P3V3_G; DSP_P3V3; FMC_P3V3_G; FMC_P3V3; FMC_P12V; FMC_P12V_ON; FMC_PWR_DIS; FPGA_P3V3_G; FPGA_P3V3; FTP0; FTP1; FTP2; FTP3; FTP4; LOCK_ISP_N; P3V3_F; P12V_F; POWER_SCL; POWER_SDA; PROM_P1V8; REFVTT_1.95V; TAG; TDO_ISP; TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; VTT_P1V3
TSSOP20MA_065MC100EP56DTG-VCC=P3V3,VEE=GNDIC1IC13
TSSOP48MC_050SN74LVTH16245ADGGR-P3V3=P3V3AIC4IC5; IC8; IC32; IC33
TSSOP48MC_050SN74LVTH16244ADGGR-P3V3=P3V3AIC2IC6; IC7
TYCO_1410147VITA41.2_P0IO1J5
WASHER_500X270X30WASHER-BN678-8303525,FOR M2.5 SCREWfor M2.5 screwMECHANICAL4WASHER1; WASHER2; WASHER3; WASHER4
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
3 y5 Y4 _  z6 y+ z2 |0 Q
GMT+8, 2025-7-20 14:50 , Processed in 0.140625 second(s), 28 queries , Gzip On.
