作品名:[AD 9][2层] 没时间画了,还有两根线给你们留着了哈(AT89S51+8050+继电器)原理图和PCB源文件 5 ], j) L9 A+ m! I( `+ R" y0 ~
文件描述 1. 作品用途:没时间画了,还有两根线给你们留着了哈(AT89S51+8050+继电器)原理图和PCB源文件 2. 软件版本:AD 9 3. 层数:2层板 4. 用到的主要芯片:AT89S51+8050+继电器 5. PCB尺寸:227mm*150mm
' b, G \2 k2 _作品截图如下: 全层截图: ) [% o6 ~( D" Q& j4 U% m
叠层信息截图如下:
3 y0 S2 m% _5 d: |. nBOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1000uF | C1, C3, C4, C4A | RB.2/.4 | 4 | 104p | C2, CA4 | RAD0.1 | 2 | 104p | C5, C6, C7, C8, C9, C10, C11, C12, C13, C14 | RAD0.2 | 10 | 30p | CA1, CA2 | RAD0.1 | 2 | 10u | CA3 | RB.1/.2 | 1 | DIODE | D1, D2, D3, D4 | DIODE0.4 | 4 | 7805 | IC1 | SIP3 | 1 | 7812 | IC2 | SIP3 | 1 | ML | J1 | SIP2 | 1 | MR | J2 | SIP2 | 1 | MA | J3 | SIP2 | 1 | MB | J4 | SIP2 | 1 | MC | J5 | SIP2 | 1 | CON2 | JA1, JA2, JA3, JA4, JA5, JA6, Jpw2 | SIP2 | 7 | CON10 | Jin1 | SIP10 | 1 | CON9 | JP0, JP1, JP2, JP3 | SIP9 | 4 | 24V | Jpw1 | SIP2 | 1 | RELAY-DPDT | K1, K2, K3, K4, K5, K6, K7, K8, K9, K10 | RELAY8 | 10 | MOSFET N | Q1, Q2, Q3, Q3A | TO-126 | 4 | 8050 | Q4, Q5, Q6, Q7, Q8, Q9, Q10, Q11, Q12, Q13 | TO-126 | 10 | 10 | R1 | AXIAL0.5 | 1 | 10k | R2, R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, RA1 | axial0.3 | 15 | 4.7k | R16, R17, R18, R19, R20, R21, R22, R23, R24, R25, R26, R27, R28, R29, Rin5, Rin6, Rin7, Rin8 | RAD0.1 | 18 | 4.7k | Rin1, Rin2, Rin3, Rin4 | axial0.3 | 4 | SW-PB | S1 | SW4A | 1 | HEADER 8X2 | U1, U2, U3, U6, U7 | DIP16 | 5 | HEADER 4X2 | U4 | DIP8 | 1 | AT89S51 | U5 | AT89S51 | 1 | 12MHz | Y1 | rad0.2 | 1 |
9 |$ p f( C8 o0 {) Z" I5 M x+ T) T' u附件: 原理图和PCB源文件如下:
) A7 i' d. s* s4 ^5 q9 O 5 N( I3 {' d8 _
