查看: 444|回复: 3
[padsVX.2x][4层板] SMDriver工业PCB+EP2C8T144 +A3966+PT4115+MIC4427BM
发表于 2019-12-20 16:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[padsVX.2x][4层板] SMDriver工业PCB+EP2C8T144 +A3966+PT4115+MIC4427BM
3 f4 _( Z$ o) U) o* A1 ~' H. A  p! k7 P
文件描述
1. 作品功能:
2. 软件版本:padsVX.2x
3. 层数:4层板
4. 用到的主要芯片/接口:EP2C8T144 +A3966+PT4115+MIC4427BM
5. PCB板尺寸:90mm*225mm
# \6 S$ [$ q* L8 e) p
顶层
# o, ~2 C9 \) ~+ g2 J4 s" n" J7 V
底层
/ g  u, C8 E, I8 ~% b% K
全层
8 P2 J. y: g/ F- H0 \
" }) @' D% a& [3 L1 l3 ?+ z
6 r. H$ v# x) }  J+ C
BOM
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C3PD_SMD_0603_CAP680pF
C4PD_SMD_0603_CAP1uF
C5PD_SMD_0603_CAP680pF
C6PD_SMD_0603_CAP1uF
C7PD_SMD_0603_CAP680pF
C8PD_SMD_0603_CAP1uF
C9PD_SMD_0603_CAP680pF
C10PD_SMD_0603_CAP1uF
C11PD_SMD_0603_CAP680pF
C12PD_SMD_0603_CAP1uF
C13PD_SMD_0603_CAP680pF
C14PD_SMD_0603_CAP1uF
C15PD_SMD_0603_CAP680pF
C16PD_SMD_0603_CAP1uF
C17PD_SMD_0603_CAP680pF
C18PD_SMD_0603_CAP1uF
C19PD_SMD_0603_CAP680pF
C20PD_SMD_0603_CAP1uF
C21PD_SMD_0603_CAP100nF
C22PD_SMD_0603_CAP100nF
C23PD_SMD_0603_CAP100nF
C24PD_SMD_0603_CAP100nF
C25PD_SMD_0603_CAP680pF
C26PD_SMD_0603_CAP1uF
C27PD_SMD_0603_CAP680pF
C28PD_SMD_0603_CAP1uF
C29PD_CAP_SMD-6.3X5.3100uF/16V
C30PD_CAP_SMD-6.3X5.3100uF/16V
C33PD_SMD_0603_CAP0.1uF
C34PD_SMD_0603_CAP0.1uF
C35PD_SMD_0603_CAP0.1uF
C36PD_SMD_0603_CAP0.1uF
C37PD_SMD_0603_CAP0.1uF
C38PD_SMD_0603_CAP0.1uF
C39PD_SMD_0603_CAP0.1uF
C41PD_CAP_SMD-4X5.310uF/16V
C42PD_CAP_SMD-4X5.310uF/16V
C43PD_CAP_SMD-4X5.310uF/16V
C44PD_CAP_SMD-4X5.310uF/16V
C45PD_SMD_0603_CAP1nF
C64PD_SMD_0603_CAP1nF
C70PD_CAP_SMD-6.3X5.3100uF/16V
C71PD_SMD_0603_CAP100nF
C73PD_CAP_SMD-6.3X5.3100uF/16V
C74PD_CAP_SMD-6.3X5.3100uF/16V
C75PD_SMD_0603_CAP100nF
C77PD_CAP_SMD-6.3X5.3100uF/16V
C78PD_SMD_0603_CAP0.1uF
C80PD_CAP_SMD-6.3X5.3100uF/16V
C81PD_CAP_SMD-6.3X5.3100uF/16V
C82PD_CAP_SMD-6.3X5.3100uF/16V
C83PD_SMD_0603_CAP0.1uF
C84PD_CAP_SMD-6.3X5.3100uF/16V
C85PD_CAP_SMD-6.3X5.3100uF/16V
C86PD_CAP_SMD-6.3X5.3100uF/16V
C88PD_SMD_0603_CAP0.1uF
C89PD_CAP_SMD-6.3X5.3100uF/16V
D1PD_DIODE-SS34-SS141N4148
D2PD_DIODE-SS34-SS141N4148
D3PD_DIODE-SS34-SS141N4148
D4PD_DIODE-SS34-SS141N4148
D5DIODE_0603
D6DIODE_0603
D7DIODE_0603
D8DIODE_0603
D9PD_DIODE-SS34-SS14SS34
D10PD_DIODE-SS34-SS14SS34
J50CON-4-1.25
L1PD_RES_1/4WInductor
L2PD_RES_1/4W4.7uH
L3PD_RES_1/4W4.7uH
L4PD_RES_1/4W4.7uH
L5PD_RES_1/4W4.7uH
LED1PD_LED_DUAL
LED2PD_LED_DUAL
Q1SOT23M2
Q2TO-252
Q3TO-252
Q4TO-252
Q5TO-252
Q17SOT23M2
R00PD_SMD_0603100
R0PD_SMD_0603100
R1PD_SMD_06031k
R2PD_SMD_06031k
R3PD_SMD_060339K
R4PD_SMD_060310K
R5PD_SMD_060356K
R625120.5
R725120.5
R8PD_SMD_06031K
R9PD_SMD_06031K
R10PD_SMD_060339K
R11PD_SMD_060310K
R12PD_SMD_060356K
R1325120.5
R1425120.5
R15PD_SMD_06031k
R16PD_SMD_06031k
R17PD_SMD_060339K
R18PD_SMD_060310K
R19PD_SMD_060356K
R2025120.5
R2125120.5
R22PD_SMD_06031k
R23PD_SMD_06031k
R24PD_SMD_060339K
R25PD_SMD_060310K
R26PD_SMD_060356K
R2725120.5
R2825120.5
R29PD_SMD_06031k
R30PD_SMD_06031k
R31PD_SMD_060339K
R32PD_SMD_060310K
R33PD_SMD_060356K
R3425120.5
R3525120.5
R36PD_SMD_06031k
R37PD_SMD_06031k
R38PD_SMD_060339K
R39PD_SMD_060310K
R40PD_SMD_060356K
R4125120.5
R4225120.5
R43PD_SMD_06031k
R44PD_SMD_06031k
R45PD_SMD_060339K
R46PD_SMD_060310K
R47PD_SMD_060356K
R4825120.5
R4925120.5
R50PD_SMD_06031k
R51PD_SMD_06031k
R52PD_SMD_060339K
R53PD_SMD_060310K
R54PD_SMD_060356K
R5525120.5
R5625120.5
R57PD_SMD_06031k
R58PD_SMD_06031k
R59PD_SMD_060339K
R60PD_SMD_060310K
R61PD_SMD_060356K
R6225120.5
R6325120.5
R64PD_SMD_06031k
R65PD_SMD_06031k
R66PD_SMD_060339K
R67PD_SMD_060310K
R68PD_SMD_060356K
R6925120.5
R7025120.5
R71PD_SMD_060356K
R72PD_SMD_060339K
R73PD_SMD_060310K
R74PD_SMD_06031k
R75PD_SMD_06031k
R7625120.5
R7725120.5
R78PD_SMD_060356K
R79PD_SMD_060339K
R80PD_SMD_060310K
R81PD_SMD_06031k
R82PD_SMD_06031k
R8325120.5
R8425120.5
R85PD_SMD_06031K
R86R1/2W0.24/0.5w
R87PD_SMD_06031K
R88R1/2W0.24/0.5w
R89PD_SMD_06031K
R90R1/2W0.24/0.5w
R91PD_SMD_06031K
R92R1/2W0.24/0.5w
R93PD_SMD_0603330
R94PD_SMD_0603330
R95PD_SMD_0603330
R96PD_SMD_0603100k
R97PD_SMD_0603330
R98PD_SMD_0603330
R99PD_SMD_0603330
R100PD_SMD_0603100k
R101PD_SMD_0603330
R102PD_SMD_0603330
R103PD_SMD_0603330
R104PD_SMD_0603100k
R105PD_SMD_0603330
R106PD_SMD_0603330
R107PD_SMD_0603330
R108PD_SMD_0603100k
R109PD_SMD_06031K
R121PD_SMD_06031K
R122PD_SMD_06031K
R123PD_SMD_060310K
R124PD_SMD_060310K
R125PD_SMD_060310K
R126PD_SMD_060310K
R156PD_SMD_0603100
R157PD_SMD_0603100
R158PD_SMD_0603100
R159PD_SMD_0603100
R160PD_SMD_0603470
R161PD_SMD_0603330
R162PD_SMD_0603330
R163PD_SMD_06031k
R164PD_SMD_06034.7K
R165PD_SMD_0603330
R166PD_SMD_060310K
R167PD_SMD_0603330
R168PD_SMD_060310K
R169PD_SMD_0603100K
R170PD_SMD_0603100K
R171PD_SMD_0603330
R172PD_SMD_060310K
R173PD_SMD_0603330
R174PD_SMD_060310K
R175PD_SMD_0603100K
R176PD_SMD_0603100K
R177PD_SMD_0603330
R178PD_SMD_060310K
R179PD_SMD_0603330
R180PD_SMD_060310K
R181PD_SMD_0603100K
R182PD_SMD_0603100K
R183PD_SMD_0603330
R184PD_SMD_060310K
R185PD_SMD_0603330
R186PD_SMD_060310K
R187PD_SMD_0603100K
R188PD_SMD_0603100K
R189PD_SMD_0603330
R190PD_SMD_060310K
R191PD_SMD_0603330
R192PD_SMD_060310K
R193PD_SMD_0603100K
R194PD_SMD_0603100K
R195PD_SMD_0603330
R196PD_SMD_060310K
R197PD_SMD_0603330
R198PD_SMD_060310K
R199PD_SMD_0603100K
R200PD_SMD_0603100K
R201PD_SMD_0603330
R202PD_SMD_060310K
R203PD_SMD_0603330
R204PD_SMD_060310K
R205PD_SMD_0603100K
R206PD_SMD_0603100K
R207PD_SMD_0603330
R208PD_SMD_060310K
R209PD_SMD_0603330
R210PD_SMD_060310K
R211PD_SMD_0603100K
R212PD_SMD_0603100K
R213PD_SMD_0603330
R214PD_SMD_060310K
R215PD_SMD_0603330
R216PD_SMD_060310K
R217PD_SMD_0603100K
R218PD_SMD_0603100K
R219PD_SMD_0603330
R220PD_SMD_060310K
R221PD_SMD_0603330
R222PD_SMD_060310K
R223PD_SMD_0603100K
R224PD_SMD_0603100K
U6SO16WB
U7SO16WB
U8SO16WB
U9SO16WB
U10SO16WB
U11SO16WB
U12PD_IC_SOIC_8-LEAD
U13TQFP144
U14PD_IC_SOT-89-5
U15PD_IC_SOT-89-5
U16PD_IC_SOT-89-5
U17PD_IC_SOT-89-5
U18SOT23-5
U19SOT23-5
U20SOT23-5
U21SOT23-5
U22PD_IC_SO-8
U23PD_IC_SO-8
U24PD_IC_SO-8
U25PD_IC_SO-8
U26PD_IC_SO-8
U27PD_IC_SO-8
U28PD_IC_SO-8
U29PD_IC_SOIC-14
U30PD_IC_SOIC-14
U31PD_IC_SOIC-14
U32PD_IC_SOIC-14
U33PD_IC_SOIC-14
U35PD_IC_TO-252LM1117-3.3
U36PD_IC_TO-252LM1117-1.2
U37TQFP144
U38PD_IC_SOIC_8-LEAD
U39SO16WB
X1PD_CRYSTAL-50M-32M-4P32MHZ
% ]% d/ w3 Y8 i8 D: z
& ?( \! t" T& l3 z
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
2 _. J) b7 W( e
' H5 G" H8 P, S0 M: B
发表于 2020-4-15 06:06 | 只看该作者
好作品,布局整齐
发表于 2020-8-24 00:07 | 只看该作者
    无聊
    2025-6-15 15:21
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2020-8-25 16:27 | 只看该作者
    学习一下学习一下学习一下
    GMT+8, 2025-7-16 11:14 , Processed in 0.156250 second(s), 27 queries , Gzip On.
