Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1P8X3P5 | CRYSTAL_1P8X3P5_0.9 MM_230-3002 | 32.768KHZ | IC | 1 | Y3 |
7X5MM | O4-0_7X5MM_1.9MM_230-76593_24.5 | 24.576MHz | IC | 1 | Y5 |
100MIL_TH | JUMPER1X2_100MIL_TH_4MM_210-300 | SHORT_100mil | IO | 10 | JP1; JP2; JP3; JP4; JP5; JP6; JP7; JP8; JP9; JP10 |
0201_CC | CAP_NP_0201_CC_DISCRETE_0.33MM_ | 0.1UF | DISCRETE | 61 | C37; C40; C41; C42; C43; C56; C59; C60; C61; C71; C72; C74; C75; C76; C77; C79; C80; C95; C96; C98; C100; C101; C102; C127; C128; C130; C131; C133; C134; C135; C150; C154; C228; C230; C231; C232; C234; C259; C261; C264; C265; C267; C330; C331; C333; C334; C336; C337; C339; C380; C381; C382; C386; C387; C389; C410; C411; C412; C415; C417; C418 |
0201_CC | CAP_NP_0201_CC_DISCRETE_0.33 MM | 0.01UF | DISCRETE | 52 | C39; C44; C57; C58; C62; C63; C73; C78; C94; C97; C99; C103; C126; C129; C132; C159; C229; C233; C246; C262; C263; C266; C268; C287; C293; C298; C300; C304; C306; C310; C314; C315; C319; C322; C326; C332; C338; C358; C359; C361; C364; C374; C376; C378; C379; C383; C385; C388; C409; C416; C448; C455 |
0201_CC | CAP_NP_0201_CC_DISCRETE_0.33 _1 | 0.22UF | DISCRETE | 49 | C278; C286; C292; C294; C295; C296; C297; C299; C301; C302; C303; C305; C307; C308; C309; C311; C312; C313; C316; C317; C318; C320; C321; C323; C324; C325; C327; C344; C351; C352; C353; C354; C355; C356; C357; C360; C362; C363; C365; C366; C367; C368; C369; C370; C371; C372; C373; C375; C377 |
0603LED | LED_0603LED_IC_1.1MM_370-75143_ | LED_GREEN | IC | 7 | D1; D3; D5; D6; D9; D12; D13 |
0603LED | LED_0603LED_IC_1.1MM_370-75145_ | LED_ORANGE | IC | 1 | D2 |
0603LED | LED_0603LED_IC_1.1MM_370-75144_ | LED_YELLOW | IC | 2 | D7; D10 |
0603LED | LED_0603LED_IC_0.65MM_370-75905 | RED LED | IC | 2 | D14; D15 |
0603_CC | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | DISCRETE | 8 | L1; L3; L14; L21; L23; L25; L27; L1000 |
0603_CC | BEAD_0603_CC_0.95MM_180-30008_1 | 120OHM | DISCRETE | 2 | L7; L9 |
BATT_MS | LICELL_BATT_MS_2.8MM_670-00010_ | LICELL | IC | 1 | B1 |
BGA96_OPTIONAL | 2G_DDR3_SDRAM_128MX16_96P_BGA96 | MT41J128M16HA-15E | IC | 8 | U7; U13; U16; U21; U40; U47; U53; U56 |
C035S | TEST PAD_C035S_0.1 MM_280-75148 | TEST POINT | IC | 57 | TP1; TP2; TP4; TP6; TP9; TP11; TP12; TP15; TP16; TP18; TP20; TP21; TP23; TP24; TP26; TP27; TP29; TP30; TP31; TP33; TP34; TP37; TP39; TP44; TP46; TP48; TP50; TP51; TP54; TP55; TP58; TP59; TP62; TP63; TP65; TP66; TP67; TP70; TP71; TP72; TP75; TP78; TP79; TP80; TP82; TP83; TP85; TP86; TP87; TP89; TP90; TP91; TP92; TP93; TP94; TP95; TP100 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | DISCRETE | 7 | C93; C146; C335; C413; C414; C449; C486 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | DISCRETE | 9 | C1; C15; C53; C112; C137; C161; C186; C237; C396 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 220pF | DISCRETE | 1 | C5 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_5 | 10PF | DISCRETE | 5 | C6; C206; C207; C208; C217 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | DISCRETE | 9 | C7; C158; C173; C174; C236; C436; C466; C473; C475 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 0.1UF | DISCRETE | 81 | C8; C12; C13; C21; C22; C23; C24; C25; C26; C46; C47; C48; C66; C67; C68; C84; C118; C120; C124; C136; C152; C153; C155; C156; C157; C168; C172; C176; C178; C179; C182; C184; C191; C193; C195; C197; C202; C209; C211; C220; C221; C223; C241; C242; C272; C276; C277; C291; C341; C342; C343; C391; C392; C397; C405; C420; C421; C423; C426; C427; C428; C437; C450; C451; C452; C453; C454; C456; C457; C467; C468; C469; C476; C477; C479; C480; C488; C490; C492; C494; C1000 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 0.1UF | DISCRETE | 20 | C9; C30; C138; C139; C141; C163; C204; C216; C403; C404; C438; C442; C443; C446; C460; C462; C463; C464; C465; C474 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.01uF | DISCRETE | 13 | C10; C16; C85; C88; C109; C110; C111; C116; C390; C425; C430; C431; C432 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_4 | 1.0UF | DISCRETE | 9 | C29; C54; C188; C190; C393; C399; C400; C401; C444 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56 | 27 PF | DISCRETE | 1 | C64 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.59M | 18PF | DISCRETE | 4 | C82; C83; C107; C108 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 2.2pF | DISCRETE | 2 | C105; C106 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.047UF | DISCRETE | 2 | C119; C270 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2200PF | DISCRETE | 2 | C122; C125 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74M | 33PF | DISCRETE | 1 | C123 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 2.2UF | DISCRETE | 2 | C164; C495 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 100PF | DISCRETE | 6 | C248; C252; C256; C258; C281; C289 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_6 | 1000PF | DISCRETE | 5 | C250; C253; C254; C282; C288 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_7 | 4700PF | DISCRETE | 1 | C433 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_5 | 3300pF | DISCRETE | 1 | C435 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 470PF | DISCRETE | 3 | C439; C440; C441 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | DISCRETE | 12 | C2; C32; C51; C114; C117; C167; C170; C185; C238; C461; C484; C487 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.1 UF | DISCRETE | 3 | C3; C4; C90 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 4.7UF | DISCRETE | 12 | C11; C49; C65; C205; C224; C249; C255; C257; C279; C280; C283; C345 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.87 | 20.0PF | DISCRETE | 3 | C14; C27; C28 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0MM | 10UF | DISCRETE | 23 | C19; C31; C34; C38; C50; C69; C115; C140; C189; C210; C219; C225; C239; C243; C244; C251; C284; C285; C290; C348; C349; C395; C445 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 2.2uF | DISCRETE | 4 | C87; C142; C274; C398 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.91M | 82pF | DISCRETE | 1 | C121 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_1 | 1.0 UF | DISCRETE | 5 | C162; C203; C402; C483; C485 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.022UF | DISCRETE | 1 | C218 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.2_1 | 4.7uF | DISCRETE | 14 | C20; C33; C52; C113; C177; C183; C187; C194; C196; C198; C215; C394; C491; C493 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.27M | 10.0uF | DISCRETE | 18 | C36; C45; C55; C70; C81; C104; C149; C160; C175; C227; C235; C269; C328; C329; C340; C384; C419; C447 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.473 | 0.22UF | DISCRETE | 2 | C169; C489 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 22UF | DISCRETE | 12 | C222; C245; C247; C260; C346; C347; C350; C406; C407; C408; C424; C434 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.4MM | 22UF | DISCRETE | 4 | C199; C201; C212; C214 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_0.88 | 0.1UF | DISCRETE | 4 | C226; C271; C478; C481 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.42 MM_ | 47uF | DISCRETE | 6 | C18; C35; C213; C273; C275; C470 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.413MM_ | 100UF | DISCRETE | 16 | C91; C92; C145; C147; C148; C151; C165; C166; C171; C180; C181; C422; C429; C458; C459; C496 |
CC1812_A | CAP_NP_CC1812_A_DISCRETE_2.79MM | 100UF | DISCRETE | 2 | C471; C472 |
CC7343A | CAP_POL_CC7343A_3.1MM_150-75053 | 100UF | DISCRETE | 2 | C17; C482 |
CC7343A | CAP_POL_CC7343A_3.1 MM_150-3002 | 150 UF | DISCRETE | 6 | C86; C89; C143; C144; C192; C240 |
CC7343A | CAP_POL_CC7343A_3.1MM_150-75127 | 47UF | DISCRETE | 1 | C200 |
CHOKE_0805 | DLW43_CHOKE_0805_1MM_180-76336_ | 90OHM | DISCRETE | 2 | L6; L8 |
CON8_SIMS15_15P7X16P4 | CON_SIMS15_CON8_SIMS15_15P7X16P | SIM CONN 8PIN | IO | 1 | J21 |
CON9_MICROAB_USB_SHELL_TH | MICRO_USB_CONN_9PIN_CON9_MICROA | USB AB 5 | IO | 1 | J9 |
CON19_0P5_15X6P7MM | HDMI_TYPE_A_VERT_CONNECTOR_CON1 | HDMI TYPE A 19 | IO | 1 | J5 |
CON19_SDCARD_28X16_SM | CONN_SDC013_19P_CON19_SDCARD_28 | CONN CRD 19 | IO | 2 | J1; J20 |
CON52_0P8_SMT_FULL-HALF_CUST | MINI_PCI_LATCH_52P_CON52_0P8_SM | CONN PCI EXP 52 | IO | 1 | J6 |
CON_60S_QSH_SM_A | QSH030_CON_60S_QSH_SM_A_IO_3.25 | QSH-030-01-L-D-A-K-TR | IO | 1 | J2 |
CON_120S_QSH_SM_05PITCH | QSH060_CON_120S_QSH_SM_05PITCH_ | QSH-060-01-L-D-A | IO | 1 | J19 |
CON_120S_QTH_0P5_SM | QTH060_CON_120S_QTH_0P5_SM_10.2 | CON PLUG 120 | IO | 2 | J23; J27 |
CON_180S_QTH_0P5_SM | QTH-090-01-L-D-A_CON_180S_QTH_0 | CON PLUG 180 | IO | 2 | J24; J26 |
CON_DB_9F_108_TH | CONN_DB9F_MTGTABS_CON_DB_9F_108 | DB9 SKT | IO | 1 | J18 |
CON_DF_30F_1MM_SM_RA | CON30_CON_DF_30F_1MM_SM_RA_IO_1 | CON 30 | IO | 2 | J22; J25 |
CON_LCD_32F_1_SM_RA | CON_RCPT_1X32_F_CON_LCD_32F_1_S | CON_1X30 | IO | 1 | J8 |
CON_MIC38P_AMP_SM | MICTOR_38_767004_CON_MIC38P_AMP | HDR_2X19_F | IC | 1 | P1 |
CON_SATA_22F_50_SM | CONN_RCPT_1X22_F_CON_SATA_22F_5 | SATA 22 | IO | 1 | J14 |
CON_SKT_44_0P5_SMT | CONN_SKT_44P_CON_SKT_44_0P5_SMT | QSH-020-01-L-D-DP-A | IO | 1 | J10 |
CRN_8_0P5_2X1 | RESISTOR_DIP_4_A-D_CRN_8_0P5_2X | 0 | DISCRETE | 6 | RN5; RN6; RN7; RN8; RN9; RN10 |
DFN6_2X2MM | LTC3025_DFN6_2X2MM_IC_0.80 MM_3 | LTC3025 | IC | 3 | U38; U39; U42 |
DO_VMN2 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | IC | 17 | D8; D16; D17; D18; D19; D20; D21; D22; D23; D24; D25; D26; D27; D28; D30; D33; D1000 |
FUSE_2P2X1P5 | FUSE_RESETTABLE_FUSE_2P2X1P5_1. | 0805L050 | IC | 2 | F1; F2 |
HDR102_100MIL | HDR_1X2_TH_HDR102_100MIL_IO_11. | HDR_1X2 | IO | 1 | J3 |
HDR210_HTST_SM | HTST-110-01-S-DV_HDR210_HTST_SM | HDR 2X10 | IO | 1 | J17 |
HXSON12_0P4_2P6X2P2MM_CUST | IP4791CZ12_12P_HXSON12_0P4_2P6X | IP4791CZ12 | IC | 1 | U10 |
IND2_4X4MM | INDUCTOR_IND2_4X4MM_DISCRETE_1. | 47UH | DISCRETE | 2 | L18; L29 |
IND_0603 | BEAD_IND_0603_0.95MM_180-30008_ | 120OHM | DISCRETE | 1 | L19 |
IND_1812FS_5X4MM | INDUCTOR_IND_1812FS_5X4MM_DISCR | 1.5UH | DISCRETE | 1 | L12 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3 MM | 0.47UH | DISCRETE | 1 | L2 |
IND_IHLP | INDUCTOR_IND_IHLP_DISCRETE_3.0 | 1uH | DISCRETE | 6 | L11; L15; L16; L17; L26; L28 |
IND_VLS3012_SM | INDUCTOR_IND_VLS3012_SM_DISCRET | 2.2UH | DISCRETE | 6 | L4; L5; L10; L20; L22; L24 |
IND_VLS3012_SM | INDUCTOR_IND_VLS3012_SM_DISCR_1 | 4.7UH | DISCRETE | 1 | L13 |
LFCSP16_0P65_4X4 | ADP2118_LFCSP_16P_LFCSP16_0P65_ | ADP2118 | IC | 5 | U24; U28; U29; U57; U72 |
MMCX_SMT | MMCX_SMT_MMCX_SMT_5.15MM_211-77 | 73415-2061 | IO | 7 | J4; J7; J11; J12; J13; J15; J16 |
MX61_SKT_HEATSINK | MARLEY_PCB_2_MX61_SKT_HEATSINK_ | SOCKET MPI | IC | 1 | XP1 |
OSC4_7P5X5MM | OSC4_SM_OSC4_7P5X5MM_IC_1.75MM_ | 50MHz | IC | 1 | Y1000 |
POT3_3224W | POT_POT3_3224W_DISCRETE_470-786 | 10K | DISCRETE | 3 | R327; R328; R331 |
POT3_3296W | POT_POT3_3296W_DISCRETE_470-301 | 100K | DISCRETE | 1 | R22 |
PSOP8 | TXB0102_PSOP8_0.9MM_315-78892_T | TXS0102 | IC | 2 | U51; U69 |
QFN12 | MAX11801_TQFN_12P_QFN12_IC_0.8M | MAX11801 | IC | 1 | U35 |
QFN24_0P5_3X5MM | LTC3614E_QFN24_QFN24_0P5_3X5MM_ | LTC3616 | IC | 1 | U2 |
QFN24_4X4MM_SLUG | LAN8720A-QFN24_QFN24_4X4MM_SLUG | LAN8720A | IC | 1 | U37 |
QFN26_0P5_5X5 | MC34716_A_QFN26_0P5_5X5_1MM_330 | MC34716EP | IC | 1 | U20 |
QFN48_0P4_6X6MM_EPAD | AR8031_QFN48_QFN48_0P4_6X6MM_EP | AR8031 | IC | 1 | U26 |
RAPC722 | DC_POWER_JACK_3_RAPC722_IO_11.0 | CON_1_PWR | IO | 1 | P2 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3106 | 110K | DISCRETE | 3 | R1; R5; R8 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | DISCRETE | 423 | R2; R4; R9; R11; R13; R14; R16; R17; R18; R21; R23; R35; R38; R40; R43; R44; R45; R47; R48; R49; R50; R51; R52; R53; R54; R56; R57; R58; R59; R60; R61; R71; R73; R77; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R92; R94; R100; R102; R103; R104; R105; R106; R109; R110; R111; R113; R117; R118; R119; R133; R135; R138; R139; R140; R147; R148; R151; R155; R156; R157; R159; R162; R163; R165; R173; R174; R175; R176; R178; R184; R185; R187; R188; R189; R190; R191; R192; R199; R201; R202; R203; R204; R216; R217; R219; R222; R224; R225; R227; R238; R240; R241; R242; R244; R245; R246; R247; R249; R255; R256; R257; R258; R259; R260; R263; R264; R265; R266; R269; R270; R274; R277; R290; R292; R293; R294; R295; R296; R297; R298; R300; R301; R302; R303; R305; R312; R313; R314; R316; R322; R324; R325; R326; R333; R335; R336; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R354; R355; R360; R361; R362; R363; R373; R375; R376; R378; R379; R381; R382; R383; R384; R385; R386; R387; R388; R391; R393; R394; R395; R407; R409; R411; R412; R413; R417; R418; R420; R421; R423; R425; R426; R427; R428; R429; R430; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R448; R449; R450; R451; R452; R453; R454; R455; R456; R457; R458; R459; R460; R461; R463; R464; R467; R470; R471; R483; R484; R485; R486; R487; R488; R495; R498; R499; R502; R503; R515; R516; R522; R523; R525; R530; R531; R532; R533; R534; R537; R538; R539; R540; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R553; R554; R556; R557; R565; R566; R573; R576; R585; R588; R589; R590; R592; R593; R594; R596; R598; R599; R600; R602; R603; R607; R609; R610; R612; R614; R616; R617; R618; R628; R629; R631; R638; R639; R640; R647; R650; R656; R657; R664; R666; R669; R671; R672; R674; R682; R687; R688; R689; R690; R691; R692; R693; R694; R695; R696; R697; R698; R699; R700; R701; R704; R711; R714; R715; R718; R719; R721; R722; R723; R724; R726; R727; R732; R733; R734; R736; R741; R742; R744; R748; R757; R758; R762; R763; R767; R768; R774; R775; R776; R777; R779; R780; R781; R782; R783; R784; R785; R786; R788; R789; R790; R791; R792; R793; R794; R795; R796; R797; R798; R799; R800; R801; R802; R803; R805; R806; R807; R808; R809; R810; R817; R819; R842; R843; R847; R854; R858; R859; R863; R864; R865; R868; R869; R875; R877; R878; R879; R880; R881; R882; R883; R884; R885; R886; R887; R888; R1200; R1201; R1202; R1203; R1204; R1205; R1206; R1207 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7624 | 100K | DISCRETE | 18 | R3; R7; R32; R37; R67; R123; R172; R210; R315; R497; R575; R591; R651; R703; R766; R862; R866; R867 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3111 | 301K | DISCRETE | 6 | R6; R75; R76; R212; R466; R563 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3104 | 68K | DISCRETE | 7 | R10; R708; R709; R710; R749; R755; R852 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7648 | 39.2K | DISCRETE | 1 | R12 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3125 | 4.7M | DISCRETE | 2 | R15; R42 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3067 | 24 | DISCRETE | 1 | R19 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-31_1 | 51.1K | DISCRETE | 1 | R20 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | 49.9 | DISCRETE | 6 | R24; R27; R288; R289; R678; R679 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | DISCRETE | 2 | R25; R26 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | DISCRETE | 25 | R28; R33; R34; R41; R69; R120; R125; R152; R179; R253; R271; R272; R275; R276; R306; R358; R380; R526; R571; R574; R577; R579; R756; R812; R890 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | DISCRETE | 75 | R29; R39; R55; R62; R64; R66; R70; R99; R107; R124; R131; R198; R218; R231; R291; R299; R323; R329; R332; R334; R353; R370; R389; R390; R392; R401; R402; R424; R494; R500; R504; R524; R536; R569; R572; R578; R580; R581; R582; R595; R597; R601; R641; R649; R652; R653; R654; R655; R658; R659; R660; R661; R662; R667; R668; R670; R673; R675; R760; R761; R764; R765; R773; R778; R811; R814; R845; R846; R850; R872; R873; R876; R889; R1208; R1209 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7646 | 470 | DISCRETE | 3 | R30; R63; R65 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3108 | 165K | DISCRETE | 1 | R46 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-75_1 | 4.7K | DISCRETE | 66 | R91; R93; R108; R166; R167; R196; R197; R229; R268; R273; R371; R372; R374; R377; R408; R482; R505; R510; R512; R513; R584; R586; R605; R606; R608; R611; R613; R615; R619; R630; R663; R705; R713; R731; R735; R737; R745; R751; R771; R804; R816; R818; R820; R821; R822; R823; R824; R825; R826; R827; R828; R829; R830; R831; R832; R833; R834; R835; R836; R837; R838; R839; R840; R841; R853; R857 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3116 | 806K | DISCRETE | 1 | R115 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3109 | 220K | DISCRETE | 1 | R116 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3102 | 47K | DISCRETE | 23 | R121; R145; R180; R181; R182; R414; R415; R434; R462; R489; R490; R491; R492; R493; R517; R519; R520; R521; R642; R712; R739; R743; R856 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3077 | 240 | DISCRETE | 9 | R132; R160; R200; R237; R284; R447; R481; R509; R620 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3045 | 100 | DISCRETE | 11 | R141; R169; R170; R171; R261; R267; R304; R511; R644; R646; R891 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3085 | 1.6K | DISCRETE | 1 | R143 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7666 | 82.5K | DISCRETE | 2 | R146; R433 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3070 | 45.3 | DISCRETE | 4 | R149; R150; R154; R177 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-76_1 | 10M | DISCRETE | 2 | R161; R205 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-31_2 | 200K | DISCRETE | 2 | R213; R754 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7647 | 5.1K | DISCRETE | 1 | R228 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7620 | 16.2K | DISCRETE | 1 | R230 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7535 | 150 | DISCRETE | 6 | R232; R308; R368; R369; R769; R770 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-30_1 | 47 | DISCRETE | 27 | R233; R234; R235; R236; R278; R279; R280; R281; R282; R283; R285; R286; R287; R621; R622; R623; R624; R625; R626; R627; R677; R680; R681; R683; R684; R685; R686 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 MM_ | 200K | DISCRETE | 2 | R318; R676 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.5 MM_4 | 470K | DISCRETE | 2 | R319; R320 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 1M | DISCRETE | 2 | R321; R730 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-76_2 | 390 | DISCRETE | 2 | R356; R643 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 M_1 | 390 | DISCRETE | 2 | R357; R359 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-31_3 | 316K | DISCRETE | 1 | R365 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3000 | 1M | DISCRETE | 2 | R366; R750 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3095 | 12.1K | DISCRETE | 2 | R396; R634 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7606 | 15K | DISCRETE | 2 | R405; R849 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-31_4 | 97.6K | DISCRETE | 1 | R406 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-76_3 | 1.5K | DISCRETE | 3 | R419; R422; R587 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3112 | 357K | DISCRETE | 1 | R465 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7625 | 200 | DISCRETE | 1 | R474 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3092 | 6.04K | DISCRETE | 2 | R475; R508 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7835 | 2.2K | DISCRETE | 1 | R558 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3093 | 8.25K | DISCRETE | 1 | R559 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3105 | 82K | DISCRETE | 1 | R564 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7760 | 6.98K | DISCRETE | 1 | R632 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3027 | 100 | DISCRETE | 1 | R633 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3090 | 4.42K | DISCRETE | 1 | R635 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3087 | 2.37K | DISCRETE | 1 | R665 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3089 | 3.57K | DISCRETE | 2 | R720; R759 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_1 | 100 | DISCRETE | 3 | R728; R729; R752 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3091 | 4.99K | DISCRETE | 2 | R738; R746 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3098 | 21.5K | DISCRETE | 1 | R747 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3113 | 470K | DISCRETE | 1 | R753 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7622 | 71.5K | DISCRETE | 1 | R815 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | DISCRETE | 55 | R74; R95; R96; R97; R98; R114; R134; R137; R142; R144; R164; R168; R193; R194; R195; R206; R208; R209; R211; R214; R215; R223; R239; R243; R248; R251; R252; R337; R364; R403; R404; R416; R432; R435; R472; R476; R478; R479; R480; R501; R506; R507; R514; R518; R527; R528; R529; R552; R583; R636; R637; R772; R787; R871; R874 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7542 | 1.0K | DISCRETE | 6 | R101; R136; R220; R221; R262; R307 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7577 | 4.99K | DISCRETE | 3 | R126; R128; R562 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7581 | 47.5K | DISCRETE | 1 | R127 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7798 | 1.37K | DISCRETE | 2 | R129; R568 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7650 | 12.4K | DISCRETE | 1 | R130 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3015 | 3.12K | DISCRETE | 1 | R153 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 10 | DISCRETE | 5 | R226; R309; R317; R645; R855 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7543 | 15 | DISCRETE | 2 | R311; R870 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 49.9 | DISCRETE | 4 | R397; R398; R399; R431 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 0 | DISCRETE | 1 | R400 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7624 | 1.0M | DISCRETE | 4 | R410; R496; R725; R813 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_2 | 10.0K | DISCRETE | 7 | R535; R706; R716; R717; R740; R860; R861 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7792 | 191 | DISCRETE | 1 | R555 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7801 | 3.9K | DISCRETE | 1 | R560 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7556 | 2.49K | DISCRETE | 1 | R561 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7666 | 2.21K | DISCRETE | 1 | R707 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3014 | 470K | DISCRETE | 1 | R844 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7607 | 0.1 | DISCRETE | 1 | R848 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | DISCRETE | 10 | R31; R36; R68; R122; R183; R186; R254; R469; R570; R648 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7924 | 0.02 | DISCRETE | 9 | R72; R112; R207; R250; R330; R367; R468; R567; R604 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8032 | 2.7K | DISCRETE | 1 | R851 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-7592 | 0 | DISCRETE | 4 | R158; R310; R477; R702 |
RC2512 | RES_RC2512_DISCRETE_470-76607_0 | 0.01 | DISCRETE | 2 | R78; R473 |
RCA_8_10 | NETW_B8_10P_RCA_8_10_470-75833_ | 10K | DISCRETE | 4 | RN1; RN2; RN3; RN4 |
RJ45_10_2LED_2SHL | RJ45_GETH_VER_RJ45_10_2LED_2SHL | RJ45-10 | IO | 1 | U32 |
SC70-5 | 1G126_SC70-5_IC_1.1MM_312-79761 | NC7SP126 | IC | 1 | U15 |
SC70-6 | ADG849_SC70_6P_SC70-6_IC_1.10MM | ADG849 | IC | 2 | U46; U52 |
SC70_6LEAD | FDG6316P_SC70_6LEAD_1MM_480-779 | FDG6316P | IC | 2 | U30; U66 |
SC70_6LEAD | NC7WP14_SC70_6LEAD_1.1MM_312-79 | NC7WP14 | IC | 1 | U64 |
SC-70 | 100201_SO-1_SC-70_1.1 MM_312-30 | NL17SZ126DF | IC | 2 | U34; U74 |
SH0805_40 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | DISCRETE | 8 | SH1; SH2; SH3; SH4; SH5; SH6; SH7; SH8 |
SKT_BGA625_0P8_22X22 | IMX61_TO1_9_SKT_BGA625_0P8_22X2 | iMX6Q | IC | 1 | U17 |
SLP1616P6 | RCCLAMP_SLP1616P6_0.65MM_312-76 | RCLAMP0504P.TCT | IC | 1 | U43 |
SO8WST | M25P32_SO8WST_IC_2.5MM_334-7733 | M25P32-VMW6TG | IC | 1 | U78 |
SO8_PAK | FDMS6681Z_SO8_PAK_IC_1.10MM_480 | FDMS6681Z | IC | 1 | Q4 |
SOD123 | DIODE_SCHTKY_SOD123_1.0 MM_480- | MBR140SFT | IC | 2 | D11; D32 |
SOD123 | DIODE_ZENER21_SOD123_IC_1.35MM_ | MMSZ5231BT1G | IC | 1 | D31 |
SOD323 | DIODE_SCHTKY_SOD323_1.1MM_480-7 | NSR0320 | IC | 1 | D4 |
SOD-923 | DIODE_TVS_SOD-923_IC_0.40MM_480 | ESD9L5.0ST5G | IC | 1 | D29 |
SOIC8 | PI90LV179-8P_SOIC8_IC_1.75MM_31 | PI90LV179 | IC | 1 | U23 |
SOT23 | NPN_SOT23_1.12 MM_480-75173_MMB | MMBT3904LT1G | IC | 3 | Q2; Q5; Q6 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | IC | 2 | U44; U45 |
SOT323_3P | BAT54SW_SOT323_3P_1.1MM_480-779 | BAT54SW | IC | 3 | U61; U63; U68 |
SOT353 | 1G125_SOT353_IC_1.1MM_312-75305 | NL17SZ125 | IC | 5 | U1; U14; U25; U49; U71 |
SOT353 | 1G07_SOT353_1.1MM_312-75421_NL1 | NL17SZ07DFT2G | IC | 5 | U27; U75; U76; U77; U79 |
SOT363 | PNP_DUAL_SOT363_IC_1.1MM_480-77 | MBT3906DW1T1 | IC | 1 | Q8 |
SOT-23 | MOSFET_EN_SOT-23_IC_1.11 MM_480 | BSS138LT1G | IC | 1 | Q1 |
SOT-23 | MOSFET_P_SOT-23_1.11MM_480-7687 | BSS84LT1 | IC | 2 | Q3; Q7 |
SOT-23-5 | MIC2774_SOT-23-5_IC_1.45MM_315- | MIC2774N-23BM5 | IC | 1 | U70 |
SSOT6_1P7X3 | FDC6331L_SSOT6_1P7X3_IC_1.1MM_3 | FDC6331L | IC | 7 | U3; U4; U5; U12; U22; U55; U58 |
SW4_STJW_SM | TACT SWITCH_SW4_STJW_SM_4.1MM_5 | STJW-690-RTR | IC | 2 | SW3; SW7 |
SW_6P_10X6_TH | SW6_DPDT_SW_6P_10X6_TH_IC_7.7MM | DPDT Switch | IC | 1 | SW6 |
SW_DIP8_4POS_SM | SW_DIP4_SW_DIP8_4POS_SM_IC_2.32 | SW DIP-4 | IC | 1 | SW4 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_2.36M | SW DIP-8 | IC | 4 | SW1; SW2; SW5; SW8 |
TEST_LOOP | TESTLOOP_TEST_LOOP_4.8 MM_210-7 | TEST POINT RED | IC | 6 | TP35; TP36; TP41; TP53; TP81; TP84 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | IC | 8 | TP8; TP10; TP49; TP52; TP74; TP88; TP97; TP99 |
TP_PTH | T POINT TH_TP_PTH_IC_0.1 MM_210 | TP_PTH | IC | 29 | TP3; TP5; TP7; TP13; TP14; TP17; TP19; TP22; TP25; TP28; TP32; TP38; TP40; TP42; TP43; TP45; TP47; TP56; TP57; TP60; TP61; TP64; TP68; TP69; TP73; TP76; TP77; TP96; TP98 |
TSOP48_SKT | 980020-48-P2_TSOP48_SKT_5.33MM_ | 980020-48-P2 | IC | 1 | U31 |
TSOP56_SK | S-TSO-SM-056-C1_TSOP56_SK_5.33M | SKT TSOP 56 SMT | IC | 1 | U60 |
TSOT-23_0P95 | LTC3406ES5_TSOT-23_0P95_IC_1MM_ | LTC3406ES5 | IC | 6 | U6; U11; U18; U36; U41; U54 |
TSOT-23_0P95 | LX1995_TSOT-23_0P95_1MM_312-794 | CAT4238 | IC | 2 | U33; U73 |
TSSOP8 | AT24CXX_TSSOP8_IC_1.2MM_334-760 | AT24C512B-TH-B | IC | 1 | U59 |
TSSOP16 | MAX7310_TSSOP_16_TSSOP16_IC_1.1 | MAX7310 | IC | 2 | U19; U48 |
TSSOP20 | MAX3380_TSSOP20_IC_1.1MM_312-75 | MAX3380ECUP+ | IC | 1 | U65 |
US8_2P4X2P1MM | NC7WZ123_US8_2P4X2P1MM_0.9MM_31 | NC7WZ132K8X | IC | 3 | U50; U62; U67 |
XO6_2P54_7X5MM | XO_6P_XO6_2P54_7X5MM_IC_2.0MM_2 | 100MHZ | IC | 1 | Y1 |
XSON10_0P5_1P1X2P6MM | IP4283CZ10_10P_XSON10_0P5_1P1X2 | IP4283CZ10 | IC | 2 | U8; U9 |
XTAL4_SX_3225 | XTAL_13Y_A_XTAL4_SX_3225_0.7MM_ | 24MHz | IC | 1 | Y2 |
XTLOSC4_JXS75_SM | XTAL_13Y_A_XTLOSC4_JXS75_SM_1.0 | 25MHZ | IC | 1 | Y4 |
