查看: 1284|回复: 5
[allegro16.6][10层]Exynos7420开发板(S5E7420+S2MPS15X+HDMI+四核A57+四核A53)...
发表于 2019-12-19 15:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][10层]Exynos7420开发板(S5E7420+S2MPS15X+HDMI+四核A57+四核A53)原理图和pcb文件
* o6 A3 i. e8 f& |$ ?0 z- i9 l& ^
文件描述:
4 M; ]7 h$ ~# {7 W% [" K
1. 作品用途:Exynos7420开发板
2. 软件版本:allegro16.6
3. 层数:10层
4. 用到的主要芯片:S5E7420+S2MPS15X+HDMI+四核A57+四核A53
5. PCB尺寸:222.1*113.3 mm
& c' n: z) T5 d, l; |8 C
作品截图如下:
! f- J9 z5 ?* m4 q& W
顶层截图:
9 ^' H9 y. I9 j4 {7 ~# k0 H' @; B$ J1 Y
底层截图:
0 w4 C# a1 U8 a0 t/ w0 n8 \; d
. E# b$ N3 k! I+ k
全层截图:
0 d2 L% z, l3 U( G- `1 _0 O
, k' B! e" ]9 S  W* E7 y
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1P27X40_SENSORHIF3F-20PA-2_8_1P27X40_SENSOR_11.27x40IC1CON34
15X2_2MM_FEMALE_SMTSOCKET_SMT180_15X2_2.00MM_15X_12240-230MG5U023IC4CON44; CON45; CON46; CON47
15X2_2_0MM_HEAD_SMTSOCKET_SMT180_15X2_2.00MM_15X2_2240-230MG5U023IC2CON40; CON41
3010-40M_SHORTHIF3F-20PA-2_8_3010-40M_SHORT_RREAR CAM CON. need-changeIC1CON15
3010-40M_SHORTHIF3F-20PA-2_8_3010-40M_SHORT_FFRONT CAM CON. need-changeIC1CON29
BEAD1005R_0_BEAD1005_BLM15PG121SN1DBLM15PG121SN1DIC1L42
BGA16C40P4X4_178X178X65_25B_MFFAN48630_0_BGA16C40P4X4_178X178FAN48630UC50XIC1U42
BGA28C40P4X7_160X280X63_30BTPD12S015YFFR_9_BGA28C40P4X7_16TPD12S015AYFFRIC1U45
BGA-169_0_4S2MPS15X_EVT1_2_BGA-169_0_4_(S1S2MPS15X_EVT1IC1U3
C0603C1005_C0603_1UF1uFDISCRETE116C2; C3; C6; C7; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C34; C35; C36; C37; C38; C39; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C60; C63; C64; C65; C66; C67; C68; C72; C73; C76; C83; C84; C85; C92; C93; C94; C95; C96; C102; C103; C106; C108; C109; C110; C111; C112; C113; C116; C117; C118; C119; C120; C124; C127; C129; C135; C137; C138; C140; C144; C145; C147; C148; C150; C153; C154; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C258; C259; C260; C261; C439; C495; C502; C833; C834; C835; C836; C837; C838
C0603C1005_C0603_NCNCIC8C58; C61; C114; C115; C125; C126; C136; C149
C0603CAPACITOR NON-POL_C0603_100NF100nFDISCRETE4C69; C71; C831; C832
C0603C1608_C0603_1UF1uFDISCRETE2C70; C130
C0603C1005_C0603_2.2UF2.2uFDISCRETE11C77; C78; C86; C87; C142; C151; C256; C494; C496; C500; C501
C0603C1005_C0603_1UF/10V1uF/10VIC16C208; C211; C214; C218; C219; C220; C221; C224; C225; C227; C228; C230; C236; C237; C239; C241
C0603C1005_C0603_220NF220nFDISCRETE3C223; C493; C497
C0603C1005_C0603_22PF22pFIC2C226; C229
C0603C1608_C0603_100NF100NFDISCRETE4C245; C247; C253; C254
C0603C_0_C0603_1UF1uFDISCRETE1C441
C0603C1005_2_C0603_100NF100nFDISCRETE2C485; C487
C0603C1005_2_C0603_1UF1uFDISCRETE1C488
C0603C1005_3_C0603_100NF100nFDISCRETE4C491; C504; C505; C506
C1005CAP NP_C1005_18PF18pFDISCRETE2C5; C9
C1005C1005_C1005_2.2NF2.2nFDISCRETE2C40; C41
C1005C1005_C1005_4.7UF4.7uFDISCRETE23C75; C79; C82; C88; C91; C104; C105; C123; C139; C141; C143; C152; C206; C207; C209; C212; C213; C215; C217; C246; C492; C662; C663
C1005C1608_C1005_NCNCIC4C80; C89; C146; C255
C1005C1608_C1005_1UF1uFIC1C99
C1005C1608_C1005_4.7UF4.7uFDISCRETE4C122; C131; C133; C155
C1005C1005_C1005_NCNCIC4C134; C498; C499; C564
C1005C1608_C1005_10UF/10V_CO1CL10A1010uF/10VIC3C173; C174; C178
C1005C1005_C1005_2.2UF/10V_CO1CL05A42.2uF/10VIC14C175; C179; C181; C183; C185; C187; C189; C191; C193; C195; C197; C199; C201; C204
C1005C1005_C1005_2.2UF/10V2.2uF/10VIC9C210; C216; C232; C233; C234; C235; C238; C240; C244
C1005C1608_C1005_100NF100NFDISCRETE1C231
C1005C1005_C1005_4.7UF/10V4.7uF/10VIC2C242; C243
C1005C1005_2_C1005_4.7UF/6.3V4.7uF/6.3VIC1C383
C1005C1005_C1005_10UF/10V10uF/10VIC1C442
C1005C1005_2_C1005_4.7UF4.7uFDISCRETE2C484; C486
C1005C1005_3_C1005_10UF/10V10uF/10VIC1C489
C1005CAP_1UF_0402_20%_6.3V_MURATA_C11uFIC10C805; C806; C807; C808; C809; C810; C811; C813; C814; C815
C1005CAP_100NF_0402_10%_6.3V_MURATA_100nFIC1C818
C1005CAP_100NF_0402_10%_10V_MURATA_C100nFIC6C819; C820; C821; C822; C823; C824
C1005CAP_330PF_0402_10%_50V_MURATA_C330pFIC4C825; C826; C827; C828
C1608C1608_C1608_10UF10uFIC7C74; C81; C90; C121; C128; C257; C666
C1608C1608_C1608_22UF22UFIC6C98; C100; C101; C132; C668; C669
C1608C1005_C1608_22UF_CO1CL10A106KQ822uFDISCRETE3C172; C190; C198
C1608C1005_C1608_22UF_CO1CL10A226MQ822uFDISCRETE11C180; C182; C184; C186; C188; C192; C194; C200; C202; C203; C205
C1608C1608_C1608_22UF_CO1CL10A106KQ822uFDISCRETE1C196
C1608C1005_C1608_10UF10uFIC2C440; C667
C1608CAP_10UF_0805_10%_6.3V_MURATA_C10uFIC5C800; C801; C802; C803; C804
C1608CAP_10UF_0603_20%_6.3V_MURATA_C10uFIC1C817
C1608CAP_10UF_0603_5%_6.3V_MURATA_C110uFIC1C829
C1608C1608_C1608_10UF/10V/C160810uF/10V/C1608IC1C830
C2012C1608_C2012_22UF22uFIC1C97
C2012C1608_C2012_47UF/10V47uF/10VIC2C176; C177
C3225C1005_C3225_11000UF_3.3V11000uF_3.3VIC1C222
CC5V_T1A_12X-TAL_CC5V_T1A_12_CC5V_T1A_12CC5V_T1A_12IC1X4
DM3AT-SF-PEJM5MICRO_SD_DM3AT-SF-PEJM5_DM3AT-SDM3AT-SF-PEJM5IC1J24
DSUB9-RA-FETE_DB9_FEMALE_5747844-6_DSUB9-RDSUB9-RA-FEIC1CON43
ES0402V014BTES0402V014BT_0_ES0402V014BT_ES0ES0402V014BTIC15D2; D3; D4; D12; D13; D14; D15; D16; D17; D33; D34; D35; D36; D37; D38
HDMI_SMDH6_1L9_0HDMI-QJ51193_HDMI_SMDH6_1L9_0_HHDMI-QJ51193IC1CN1
JUMPER_DIP180_2X1_2JUMPER_DIP180_2X1_2.54MM_JUMPER1125-1102SG5B11511IC1J25
KHS10SW DIP-10_0_KHS10_KHS10KHS10IC1SW1
KLMBG4WEBC-B031KLMAG2GEAC-B002_0_KLMBG4WEBC-B0KLMBG4WEBC-B031IC1U57
L2012LQH32C_0_L2012_CIGT201210UMR47SCIGT201210UMR47SNEIC9L1; L4; L6; L7; L8; L9; L10; L11; L13
L2012LQH32C_0_L2012_CIGT201210UMR24SCIGT201210UMR24SNEIC5L2; L3; L5; L12; L14
L2012R_0_L2012_1239AS-H-R47M(0.47UH)1239AS-H-R47M(0.47uH)IC1L77
L2016INDUCTOR_L2016_CIG21L2R2MNECIG21L2R2MNEIC1L41
L2016LQH32C_0_L2016_CIGT201610UM1R0SCIGT201610UM1R0SNEIC1L57
MAX3380ECUPMAX3380ECUP_MAX3380ECUP_MAX3380MAX3380ECUPIC1U105
MM8130-2600MM8430-2610_MM8130-2600_MM8130-MM8130-2600DISCRETE1CON1
MM8130-2600MM8130-2600_MM8130-2600_MM8130-MM8130-2600IC2J19; J20
MTH_D320C650MTH_P1_D0_2.6X12_MTH_D320C650_GGNDIC4MTH1; MTH2; MTH3; MTH4
POWERPINCON1_POWERPIN_HOLE2.4HOLE2.4IC1HOLE1
POWERPINCON1_POWERPIN_HOLE3.7HOLE3.7IC6HOLE2; HOLE3; HOLE4; HOLE5; HOLE6; HOLE7
QTE020-01-X-D-A_LCDSAMTEC_40PIN_QTE-020-01-L-D-A_QQTE-020-01-L-D-AIC2CON38; CON39
QTH-030-01-X-D-A_MODEM_7420SAMTEC_60PIN_QTH-030-01-L-D-A_QQTH-030-01-L-D-AIC1CON2
R0402RES_0R_0402_5%_YAGEO_R0402_0R0RDISCRETE100R542; R545; R703; R707; R708; R709; R710; R711; R712; R713; R714; R715; R716; R717; R718; R719; R722; R723; R724; R725; R726; R727; R728; R729; R730; R731; R732; R733; R734; R735; R736; R737; R739; R740; R741; R742; R743; R744; R745; R746; R747; R748; R749; R750; R751; R752; R753; R754; R757; R758; R759; R760; R762; R763; R764; R765; R766; R767; R768; R769; R770; R771; R772; R773; R774; R775; R776; R777; R778; R779; R780; R781; R782; R783; R784; R785; R786; R787; R788; R789; R790; R791; R792; R793; R794; R799; R804; R805; R806; R807; R815; R816; R817; R818; R819; R831; R832; R833; R834; R854
R0402RES_100K_0402_5%_YAGEO_R0402_10100KDISCRETE1R543
R0402RES_10K_0402_5%_YAGEO_R0402_10K10KDISCRETE5R544; R556; R557; R801; R802
R0402RES_26.7K_0402_1%_YAGEO_R0402_226.7KDISCRETE1R558
R0402RES_0R_0402_5%_YAGEO_R0402_NCNCIC8R795; R796; R797; R798; R800; R808; R809; R810
R0402RES_0R_0402_5%_YAGEO_R0402_10K10KIC4R835; R836; R837; R838
R0603R_R0603_49.9K49.9KDISCRETE8R407; R408; R409; R410; R411; R412; R413; R414
R0603R_R0603_10K10KDISCRETE2R415; R821
R0603R_R0603_22R_060322R_0603IC1R426
R0603R_R0603_0R_06030R_0603IC1R427
R1005R_0_R1005_BLM15PX221SN1DBLM15PX221SN1DIC1L40
R1005R1005_0_R1005_100K_F100K_FIC3R1; R9; R11
R1005R1005_0_R1005_10K10KDISCRETE18R2; R3; R4; R5; R6; R8; R10; R12; R13; R14; R67; R68; R69; R72; R73; R125; R439; R440
R1005R1005_0_R1005_10K_F10K_FIC1R15
R1005RESISTOR_R1005_1M_F1M_FIC1R16
R1005R1005_0_R1005_0R0RDISCRETE34R19; R20; R22; R66; R74; R80; R83; R91; R92; R93; R100; R101; R104; R105; R106; R107; R108; R109; R110; R111; R113; R114; R115; R118; R123; R436; R437; R441; R625; R626; R702; R820; R826; R827
R1005R1005_0_R1005_0R.0R.IC1R21
R1005R1005_0_R1005_200R_F200R_FIC1R55
R1005R1005_0_R1005_8.2K_F8.2K_FIC4R65; R81; R82; R84
R1005R1005_0_R1005_49.9K49.9KDISCRETE4R70; R71; R76; R77
R1005R1005_0_R1005_NCNCIC5R79; R126; R131; R442; R701
R1005R_R1005_240R_F240R_FIC6R85; R86; R87; R88; R89; R90
R1005R1005_0_R1005_787K787KDISCRETE2R102; R825
R1005R1005_0_R1005_200K NC200K NCIC1R112
R1005R1005_0_R1005_100K100KDISCRETE1R116
R1005R1005_0_R1005_200K200KDISCRETE4R121; R122; R127; R822
R1005R1005_0_R1005_14K14KDISCRETE1R124
R1005R_R1005_0R0RDISCRETE1R364
R1005R_R1005_DNPDNPIC2R365; R366
R1005R_R1005_100K100KDISCRETE1R367
R1005R_R1005_10K10KDISCRETE1R416
R1005R_R1005_NCNCIC2R429; R430
R1005R1005_0_R1005_0R NC0R NCIC1R435
R1005R1005,0 OHM_R1005_0R0RDISCRETE4R624; R629; R823; R824
R1005R1005_0_R1005_30K30KDISCRETE1R630
R1005R1005_0_R1005_2.2K2.2KDISCRETE10R664; R665; R685; R686; R687; R688; R689; R690; R691; R692
R1005R1005_0_R1005_2.2K NC2.2K NCIC18R666; R667; R674; R675; R677; R678; R679; R680; R681; R682; R683; R684; R811; R812; R813; R814; R839; R840
R1005R1005_0_R1005_1K1KDISCRETE2R668; R669
R1608INDUCTOR_R1608_BLM18KG300TN1BLM18KG300TN1IC1L55
R1608R_R1608_0R_16080R_1608IC4R136; R163; R164; R165
R1608RES_0R_0603_5%_YAGEO_R1608_0R0RIC13R841; R842; R843; R844; R845; R846; R847; R848; R849; R850; R851; R852; R853
R2012R_R2012_PMR10EZPFV2L00 (2MR)PMR10EZPFV2L00 (2mR)IC10R117; R130; R132; R134; R140; R143; R160; R161; R162; R828
S2ABB01S2ABB01_0_S2ABB01_S2ABB01_6330S2ABB01_6330IC1U71
S5E7420_POP_BGA1084_0P4S5E7420_EPOP_EVT1_2.5X15_S5E742S5E7420_ePOP_EVT1_14.5x15IC1U1
SC-70SN74LVC1G14DBVT_0_SC-70_SN74LVCSN74LVC1G125DCKTIC1U73
SC-70SN74AUP1G14_SC-70_SN74AUP1G14DCSN74AUP1G14DCKTIC1U106
SCO-32OSCILLATOR_SCO-32_26MHZ_SCO-32_26MHz_SCO-32_1.8VIC1OSC1
SHEADER_2X10_P2_54SAMTEC_JTAG_HTST-110-01-L-DV_SHHTST-110-01-L-DVIC1CON42
SHORTNETCON_SHORT_NETCONNETCONIC6XC1; XC2; XC3; XC4; XC5; XC6
SKHRA_2_5X_4_5SKHRAHA010_SKHRA_2_5X_4_5_SKHRASKHRAAA010IC3SW8; SW10; SW11
SKHRA_2_5X_4_5SKHRAHA010_SKHRA_2_5X_4_5_SKH_1SKHRAHA010IC1SW9
SON65P_200X200X80_7N_TPS2553TMP_1_SON65P_200X200X80_7N_TPS2TPS2553DRVIC1U43
TP0_8-SMDTP_P0_0.8_D0_TP0_8-SMD_TPTPIC40TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP10; TP11; TP75; TP76; TP77; TP78; TP79; TP80; TP81; TP82; TP100; TP111; TP112; TP113; TP116; TP118; TP119; TP121; TP122; TP123; TP124; TP125; TP126; TP127; TP128; TP133; TP134; TP135; TP136; TP137; TP138; TP139; TP141
TP0_8-SMDTP_P0.8_D0_TP0_8-SMD_TP_NCTPIC3TP13; TP14; TP15
TP0_8-SMDTP_P0_0.8_D0_TP0_8-SMD_TP_03TP_03IC1TP93
TP0_8-SMDTP-SMD-P1.0_TP0_8-SMD_N.M.n.m.IC12TP101; TP102; TP103; TP104; TP105; TP106; TP107; TP108; TP109; TP110; TP132; TP140
UFS_FBGA-153_11X10UFS2.0_KBX_11X10_1_UFS_FBGA-153UFS2.0_KBX(11mmX10mm)IC1U58
UUSB3-AB-S-S-SM-TRMICRO_USB3.0_UUSB3-AB-S-S-SM-TRUUSB3-AB-S-S-SM-TRIC1J23
XTAL_2520CRYSTAL_SX-8_XTAL_2520_NDK STD_NDK STD_CSW_5IC1X2
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
发表于 2020-4-4 00:19 | 只看该作者
发表于 2020-4-5 23:34 | 只看该作者
感谢分享热热热8 s/ m9 X4 h6 _' ^3 T
发表于 2020-4-24 13:47 | 只看该作者
这个牛逼,学习学习!
( G/ j9 e+ J; P. @0 [8 m1 k2 B  T
GMT+8, 2025-7-19 05:03 , Processed in 0.140625 second(s), 27 queries , Gzip On.
