Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
6191024-071-R | CONN SOCKET 30_40_6191024-071-R | 6191024-071-R | IC | 1 | J1102 |
A6BGA-65PITCH | AA_12_A6BGA-65PITCH_(S1+S2+S3+S | ATLASVI | IC | 1 | U101 |
ACA-5036 | RFANT5220110A0T_0_ACA-5036_ACA- | ACA-5036 | IC | 1 | ANT701 |
BAT-CON2-2_54 | CONN PCB 4_0_BAT-CON2-2_54_CON | CON 3 | IC | 1 | BAT501 |
CDRH3D16 | INDUCTOR_CDRH3D16_CDRH3D16-100 | CDRH3D16-100 | IC | 1 | L402 |
CON24_P0M4_4M9 | CONN SOCKET 30_22_CON24_P0M4_4M | ST30L | IC | 1 | J1001 |
DC_045BCH | PJK-118_1_DC_045BCH_DS-0514-065 | DS-0514-065S | IC | 1 | J501 |
DO_213AA | DIODE ZENER1_1_DO_213AA_BZT55C1 | BZT55C16 | IC | 1 | D404 |
DO_213AA | DIODE ZENER1_1_DO_213AA_BZT52C6 | BZT52C6V8-7-F. | IC | 1 | D406 |
ESD10X06 | DIODE BI-DIR TRIG_ESD10X06_LXES | LXES1UBBB1-008 | IC | 1 | ESD801 |
ESD12X08 | DIODE TVS_ESD12X08_ESD9B5V | ESD9B5V | IC | 1 | ESD101 |
ESD12X08 | DIODE BI-DIR TRIG_ESD12X08_ESD9 | ESD9B5V | IC | 28 | ESD401; ESD402; ESD403; ESD404; ESD405; ESD406; ESD407; ESD408; ESD601; ESD602; ESD603; ESD901; ESD911; ESD912; ESD913; ESD914; ESD1101; ESD1102; ESD1103; ESD1104; ESD1105; ESD1106; ESD1107; ESD1108; ESD1109; ESD1110; ESD1112; ESD1113 |
ESD12X08 | DIODE BI-DIR TRIG_ESD12X08_ESD5 | ESD5B5VL | IC | 7 | ESD902; ESD903; ESD904; ESD905; ESD906; ESD907; ESD908 |
ESD12X08 | DIODE BI-DIR TRIG_ESD12X08_ES_1 | ESD5B5VL-2/TR | IC | 2 | ESD909; ESD910 |
FBGA-96 | MT41J128M16_20_FBGA-96_MT41J256 | MT41J256M16(Micron) | IC | 1 | U201 |
FC_135 | CRYSTAL_4_FC_135_FC_135/32.768K | FC_135/32.768KHz/12.5pF | IC | 1 | Y101 |
FPC4_P1MA | CONN SOCKET 30_61_FPC4_P1MA_L50 | L50204213013 | IC | 1 | J401 |
FPC16_P0M5A | CONN SOCKET 30_48_FPC16_P0M5A_C | CON16 | IC | 1 | J1101 |
FPC50_P0M5A | CONN SOCKET 30_60_FPC50_P0M5A_C | C50_0.5K_02F | IC | 1 | J402 |
HDMI_C | HDMI_5_HDMI_C_MINI HDMI RECEPTA | Mini HDMI Receptacle | IC | 1 | P401 |
IHLP-2525AH-01 | INDUCTOR_1_IHLP-2525AH-01_4.7UH | 4.7uH/3A | IC | 1 | L501 |
LCC8 | BMP085_1_LCC8_BMP085 | BMP085 | IC | 1 | U804 |
LFB212G45 | LFB212G45CG2D013_1_LFB212G45_LF | LFB212G45CG2D013 | IC | 1 | U704 |
LGA60 | KM28C256_6_LGA60_K9GCGD8U0A-MCB | K9GCGD8U0A-MCB0/NC | IC | 1 | U303 |
MIC_2PAD_SMD | MICROPHONE_2_MIC_2PAD_SMD_PAD_M | PAD_MIC | IC | 1 | MIC601 |
OSC2520 | RAKON_IT2205_4_OSC2520_26MHZ/20 | 26MHz/20ppm XO/NC | IC | 1 | Y701 |
OSC3225 | CRYSTAL_0_OSC3225_24.576MHZ/20P | 24.576MHz/20PPM | IC | 1 | Y1001 |
PA1575-25X25 | ANTENNA_0_PA1575-25X25_GPS&GLON | GPS&GLONASS ANTENNA | IC | 1 | G_A801 |
PJK-633 | PHONE-JACK-HTJ-035-40A_0_PJK-63 | Earphone | IC | 1 | J601 |
POWERDI_123 | DIODE_POWERDI_123_SBR3U40P1 | SBR3U40P1 | IC | 5 | D501; D502; D503; D504; D505 |
QFN4X4 | RT7179_45_QFN4X4_TLSC3516/NC | TLSC3516/NC | IC | 1 | U408 |
QFN16 | WM8750_19_QFN16_AK8975 | AK8975 | IC | 1 | U803 |
QFN24 | WM8750_20_QFN24_MPU6050 | MPU6050 | IC | 1 | U801 |
QFN36-005 | RN5T566B_0_QFN36-005_RN5T566B | RN5T566b | IC | 1 | U700 |
QFN-24PIN | SE4150L_QFN24_0_QFN-24PIN_TRIG | TriG RF LITE | IC | 1 | G_U801 |
QFN-32 | IT6610_23_QFN-32_BIT1603 | BIT1603 | IC | 1 | U1002 |
QFN-40 | CSR8311A08 QFN-40-6X6_91_QFN-40 | CSR8311A08 | IC | 1 | U702 |
QFN-56 | CSR8311A08 QFN-40-6X6_0_QFN-56_ | CSR6031A10 | IC | 1 | U701 |
QFN-64 | IT6610_6_QFN-64_IT6610 | IT6610 | IC | 1 | U403 |
SAW-5PIN-1_4X1_1 | GPS-FILTER_0_SAW-5PIN-1_4X1_1_F | FAR-F6KA-1G5754-L4AJ/Fujitsu | IC | 1 | SAW_F801 |
SCD | ZEN056_9_SCD_ZEN056V230A | ZEN056V230A | IC | 1 | U503 |
SD-TB603-1111NO | MMC_INTERFACE_7_SD-TB603-1111NO | TF-01A-A-A0 | IC | 1 | P901 |
SE2611T | SE2579U_23_SE2611T_SE2611T | SE2611T | IC | 1 | U705 |
SHIELD_HOLE | TP_0_SHIELD_HOLE_TP | TP | IC | 9 | S1; S2; S3; S4; S5; S6; S7; S8; S9 |
SLP-10 | RCLAMP0514_1_SLP-10_ESDA6V8UD | ESDA6V8UD | IC | 1 | U404 |
SLP-10 | RCLAMP0514_2_SLP-10_ESDA6V8UD | ESDA6V8UD | IC | 1 | U405 |
SMC0402 | CAP NP_SMC0402_100NF | 100nF | DISCRETE | 90 | C105; C106; C107; C108; C109; C113; C115; C116; C117; C118; C121; C122; C203; C204; C301; C302; C303; C304; C307; C308; C309; C310; C416; C417; C429; C436; C438; C439; C440; C441; C442; C446; C447; C448; C449; C450; C451; C454; C455; C457; C462; C504; C505; C506; C507; C508; C509; C511; C514; C519; C520; C521; C526; C529; C534; C535; C536; C542; C548; C549; C551; C583; C586; C588; C601; C604; C605; C705; C725; C744; C815; C816; C820; C822; C825; C905; C907; C910; C913; C1002; C1004; C1005; C1015; C1017; C1021; C1023; C1027; C1033; C1036; C1040 |
SMC0402 | CAP NP_SMC0402_1UF | 1uF | IC | 47 | C111; C120; C205; C422; C428; C430; C433; C435; C445; C456; C512; C513; C547; C560; C561; C579; C580; C581; C585; C590; C591; C592; C593; C594; C595; C596; C597; C610; C714; C729; C1009; C1012; C1013; C1014; C1016; C1020; C1024; C1026; C1028; C1029; C1030; C1032; C1035; C1037; C1039; C1102; C1103 |
SMC0402 | CAP NP_SMC0402_22PF | 22pF | IC | 16 | C114; C119; C402; C403; C404; C431; C432; C702; C715; C902; C1001; C1006; C1007; C1008; C1018; C1019 |
SMC0402 | CAP NP_SMC0402_10NF | 10nF | IC | 26 | C201; C202; C228; C229; C230; C231; C434; C452; C706; C708; C727; C735; C745; C806; C807; C808; C809; C811; C817; C823; C824; C906; C1025; C1031; C1034; C1038 |
SMC0402 | CAP NP_SMC0402_220NF | 220nF | IC | 23 | C207; C208; C209; C210; C211; C212; C213; C214; C224; C225; C226; C227; C245; C246; C247; C248; C443; C552; C553; C554; C555; C556; C557 |
SMC0402 | CAPNP_SMC0402_100NF/16V | 100nF/16V | IC | 2 | C401; C424 |
SMC0402 | CAP NP_SMC0402_100PF/16V | 100pF/16V | IC | 2 | C405; C412 |
SMC0402 | CAP NP_SMC0402_100PF | 100pF | IC | 4 | C408; C503; C587; C908 |
SMC0402 | CAP NP_2_SMC0402_100NF/16V | 100nF/16V | IC | 1 | C410 |
SMC0402 | CAP NP_2_SMC0402_100PF/16V | 100pF/16V | IC | 2 | C411; C418 |
SMC0402 | CAP NP_SMC0402_100NF/16V | 100nF/16V | IC | 3 | C413; C421; C427 |
SMC0402 | CAP NP_2_SMC0402_100NF | 100nF | IC | 1 | C414 |
SMC0402 | CAP NP_SMC0402_1UF/16V | 1uF/16V | IC | 1 | C425 |
SMC0402 | CAP NP_SMC0402_1UF/10V | 1uF/10V | IC | 1 | C444 |
SMC0402 | CAP NP_SMC0402_1NF | 1nF | IC | 8 | C458; C459; C460; C461; C568; C569; C730; C805 |
SMC0402 | CAP NP_SMC0402_220PF | 220pF | IC | 1 | C501 |
SMC0402 | CAP NP_0_SMC0402_1UF | 1uF | IC | 6 | C510; C523; C525; C528; C531; C544 |
SMC0402 | CAP NP_0_SMC0402_100PF | 100pF | IC | 3 | C527; C530; C537 |
SMC0402 | CAP NP_2_SMC0402_1UF | 1uF | IC | 2 | C533; C550 |
SMC0402 | CAP NP_SMC0402_330NF | 330nF | IC | 7 | C701; C731; C736; C737; C738; C739; C741 |
SMC0402 | CAP NP_SMC0402_15PF | 15pF | IC | 1 | C709 |
SMC0402 | CAP NP_SMC0402_470NF | 470nF | IC | 4 | C711; C716; C801; C812 |
SMC0402 | CAP NP_SMC0402_5.6PF | 5.6pF | IC | 2 | C717; C718 |
SMC0402 | CAP NP_SMC0402_1.8PF | 1.8pF | IC | 1 | C719 |
SMC0402 | CAP NP_SMC0402_NC | NC | IC | 2 | C720; C721 |
SMC0402 | CAP NP_SMC0402_330PF | 330pF | IC | 1 | C722 |
SMC0402 | CAP NP_SMC0402_6.8PF | 6.8pF | IC | 1 | C728 |
SMC0402 | CAP NP_SMC0402_2.2NF | 2.2nF | IC | 1 | C740 |
SMC0402 | CAP NP_SMC0402_100NF/NC | 100nF/NC | IC | 2 | C746; C827 |
SMC0402 | C_2_SMC0402_22PF | 22pF | IC | 2 | C802; C803 |
SMC0402 | C_2_SMC0402_0.5PF/NC | 0.5pF/NC | IC | 1 | C804 |
SMC0402 | C_2_SMC0402_1UF | 1uF | IC | 1 | C810 |
SMC0402 | C_2_SMC0402_10NF | 10nF | IC | 1 | C814 |
SMC0402 | CAP NP_SMC0402_2.2NF/50V | 2.2nF/50V | IC | 1 | C821 |
SMC0402 | CAP NP_SMC0402_100NF_ | 100nF | IC | 1 | C826 |
SMC0402 | CAP NP_SMC0402_47PF | 47pF | IC | 2 | C1010; C1011 |
SMC0402 | CAP NP_SMC0402_33PF | 33pF | IC | 8 | C1101; C1104; C1105; C1106; C1107; C1108; C1109; C1110 |
SMC0603 | CAP NP_SMC0603_2.2UF/10V | 2.2uF/10V | IC | 2 | C110; C112 |
SMC0603 | CAP POL_SMC0603_4.7UF | 4.7uF | IC | 7 | C223; C703; C723; C742; C818; C903; C1111 |
SMC0603 | CAP NP_SMC0603_100NF/25V | 100nF/25V | IC | 1 | C420 |
SMC0603 | CAP NP_SMC0603_2.2UF | 2.2uF | IC | 11 | C423; C704; C707; C710; C712; C713; C724; C726; C733; C734; C743 |
SMC0603 | CAP NP_0_SMC0603_4.7UF | 4.7uF | IC | 1 | C516 |
SMC0603 | CAP NP_SMC0603_1UF | 1uF | IC | 2 | C562; C563 |
SMC0603 | C_2_SMC0603_2.2UF | 2.2uF | IC | 1 | C813 |
SMC0603 | CAP NP_SMC0603_4.7UF | 4.7uF | DISCRETE | 2 | C819; C904 |
SMC0603 | CAP NP_2_SMC0603_2.2UF | 2.2uF | IC | 2 | C1003; C1022 |
SMC0805 | CAP POL_SMC0805_10UF/16V | 10uF/16V | IC | 2 | C406; C426 |
SMC0805 | CAP POL_SMC0805_10UF | 10uF | IC | 7 | C407; C415; C437; C502; C518; C909; C911 |
SMC0805 | CAP POL_SMC0805_10UF/25V | 10uF/25V | IC | 1 | C419 |
SMC0805 | CAP NP_SMC0805_10UF | 10uF | IC | 1 | C453 |
SMC0805 | CAP NP_SMC0805_22UF | 22uF | IC | 2 | C515; C589 |
SMC0805 | CAP POL_SMC0805_22UF | 22uF | IC | 3 | C532; C901; C912 |
SMC1206 | CAP NP_2_SMC1206_10UF/25V | 10uF/25V | IC | 1 | C409 |
SMC1206 | CAP NP_SMC1206_22UF | 22uF | IC | 3 | C584; C598; C599 |
SMF0603 | FUSE_SMF0603_ERBSE0R50U | ERBSE0R50U | IC | 1 | F401 |
SML0402 | FERRITE BEAD_0_SML0402_FBM-11-1 | FBM-11-100505-301/100mA,0402 | IC | 3 | FB801; FB802; FB803 |
SML0402 | INDUCTOR_2_SML0402_7.5NH*/HIGH | 7.5nH*/HIGH Q | IC | 1 | L802 |
SML0603 | FERRITE BEAD_0_SML0603_FBM-11-1 | FBM-11-160808-600A30T | IC | 5 | FB401; FB403; FB404; FB1101; FB1102 |
SML0603 | FERRITE BEAD_0_SML0603_FBM-11_1 | FBM-11-160808-600A30T/NC | IC | 1 | FB402 |
SML0603 | INDUCTOR_3_SML0603_100NH | 100nH | IC | 1 | L801 |
SML0603 | BEAD_0_SML0603_2.2UH/L0603 | 2.2uH/L0603 | IC | 2 | L1001; L1002 |
SMR0402 | R_SMR0402_240R/F | 240R/F | IC | 1 | R101 |
SMR0402 | R_SMR0402_0R_ | 0R | IC | 3 | R103; R104; R105 |
SMR0402 | R_SMR0402_0R | 0R | IC | 5 | R106; R107; R120; R124; R125 |
SMR0402 | R_SMR0402_33R | 33R | IC | 2 | R108; R109 |
SMR0402 | R_SMR0402_44.2R/F | 44.2R/F | IC | 1 | R110 |
SMR0402 | RES_SMR0402_0R | 0R | IC | 34 | R111; R315; R319; R320; R321; R322; R323; R324; R325; R326; R426; R702; R705; R706; R707; R708; R709; R710; R717; R801; R808; R809; R811; R812; R814; R815; R818; R822; R825; R826; R911; R1007; R1009; R1017 |
SMR0402 | RES_SMR0402_10K | 10K | IC | 40 | R112; R113; R114; R115; R116; R119; R308; R309; R318; R328; R401; R410; R413; R419; R428; R432; R437; R439; R443; R444; R448; R501; R505; R510; R701; R712; R713; R714; R715; R722; R901; R902; R904; R905; R910; R912; R1014; R1015; R1018; R1110 |
SMR0402 | R_SMR0402_10M | 10M | IC | 1 | R117 |
SMR0402 | RES_SMR0402_10K/NC | 10K/NC | IC | 18 | R118; R302; R303; R304; R305; R306; R307; R422; R427; R429; R433; R445; R805; R806; R807; R908; R1013; R1016 |
SMR0402 | RES_SMR0402_0R/NC | 0R/NC | IC | 14 | R122; R420; R447; R610; R611; R704; R720; R721; R802; R803; R804; R810; R813; R819 |
SMR0402 | RES_SMR0402_4.7K | 4.7K | IC | 7 | R123; R126; R127; R128; R441; R442; R1010 |
SMR0402 | RES_SMR0402_240R/F | 240R/F | IC | 1 | R201 |
SMR0402 | RES_SMR0402_1K | 1K | IC | 7 | R202; R203; R405; R502; R506; R604; R1108 |
SMR0402 | RES_SMR0402_90R | 90R | IC | 1 | R204 |
SMR0402 | RES_SMR0402_100K | 100K | IC | 17 | R301; R310; R311; R312; R313; R314; R411; R446; R503; R508; R509; R512; R513; R514; R515; R602; R1109 |
SMR0402 | RES_SMR0402_10R | 10R | IC | 2 | R402; R421 |
SMR0402 | RES_SMR0402_33R | 33R | IC | 14 | R403; R404; R408; R903; R1002; R1003; R1004; R1005; R1101; R1102; R1103; R1105; R1106; R1107 |
SMR0402 | RES_SMR0402_680K/F | 680K/F | IC | 1 | R406 |
SMR0402 | RES_SMR0402_750K | 750K | IC | 2 | R407; R907 |
SMR0402 | RES_SMR0402_3.9K | 3.9K | IC | 1 | R409 |
SMR0402 | RES_SMR0402_91K/F | 91K/F | IC | 1 | R412 |
SMR0402 | RES_SMR0402_50K | 50K | IC | 1 | R416 |
SMR0402 | RES_SMR0402_100R | 100R | IC | 8 | R417; R449; R450; R451; R452; R816; R817; R820 |
SMR0402 | RES_SMR0402_22K | 22K | IC | 2 | R418; R425 |
SMR0402 | RES_SMR0402_220R | 220R | IC | 1 | R423 |
SMR0402 | RES_SMR0402_15K | 15K | IC | 1 | R424 |
SMR0402 | RES_SMR0402_47K | 47K | IC | 4 | R430; R438; R440; R716 |
SMR0402 | RES_SMR0402_6.8K/F | 6.8K/F | IC | 1 | R431 |
SMR0402 | RES_SMR0402_2.49K | 2.49K | IC | 1 | R434 |
SMR0402 | RES_SMR0402_475R/F | 475R/F | IC | 1 | R436 |
SMR0402 | R_SMR0402_1K | 1k | IC | 1 | R504 |
SMR0402 | R_SMR0402_1K/F | 1K/F | IC | 4 | R516; R517; R608; R609 |
SMR0402 | RESISTOR_SMR0402_50K | 50K | IC | 1 | R518 |
SMR0402 | RESISTOR_SMR0402_36K/F | 36K/F | IC | 2 | R520; R525 |
SMR0402 | RESISTOR_SMR0402_24K/F | 24K/F | IC | 1 | R521 |
SMR0402 | RESISTOR_SMR0402_250K/F | 250K/F | IC | 1 | R522 |
SMR0402 | RESISTOR_SMR0402_30K/F | 30K/F | IC | 1 | R523 |
SMR0402 | RESISTOR_SMR0402_100K/F | 100K/F | IC | 3 | R524; R528; R532 |
SMR0402 | RESISTOR_SMR0402_4.2K/F | 4.2K/F | IC | 1 | R526 |
SMR0402 | RESISTOR_SMR0402_230K/F | 230K/F | IC | 1 | R527 |
SMR0402 | RESISTOR_SMR0402_80K/F | 80K/F | IC | 1 | R529 |
SMR0402 | RESISTOR_SMR0402_0R | 0R | IC | 3 | R530; R531; R540 |
SMR0402 | RESISTOR_SMR0402_100K/NC | 100K/NC | IC | 1 | R533 |
SMR0402 | RESISTOR_SMR0402_100K | 100K | IC | 3 | R534; R537; R539 |
SMR0402 | RESISTOR_SMR0402_10K | 10K | IC | 2 | R535; R536 |
SMR0402 | RES_SMR0402_100K/NC | 100K/NC | IC | 1 | R703 |
SMR0402 | RES_SMR0402_820R | 820R | IC | 1 | R906 |
SMR0402 | RES_SMR0402_80K | 80K | IC | 1 | R909 |
SMR0402 | RES_SMR0402_75R | 75R | IC | 2 | R1001; R1011 |
SMR0402 | RES_SMR0402_56R | 56R | IC | 2 | R1006; R1008 |
SMR0402 | RES_SMR0402_1M | 1M | IC | 1 | R1012 |
SMR0402X4 | RES_2_SMR0402X4_33R | 33R | IC | 6 | RA401; RA402; RA403; RA404; RA405; RA406 |
SMR0402X4 | RES_2_SMR0402X4_10K | 10K | IC | 1 | RA901 |
SMR0603 | RES_SMR0603_1.1R | 1.1R | IC | 2 | R414; R415 |
SMR0603 | RES_SMR0603_0R | 0R | IC | 1 | R435 |
SMR1206 | RES_SMR1206_200MR/F | 200mR/F | IC | 1 | R507 |
SMR1206 | RES_SMR1206_80MR/F | 80mR/F | IC | 1 | R511 |
SMR1206 | RES_SMR1206_43.2R | 43.2R | IC | 1 | R1104 |
SOD523 | DIODE_0_SOD523_MA2S728 | MA2S728 | IC | 2 | D101; D102 |
SOD523 | DIODE_SOD523_MA2S728 | MA2S728 | IC | 1 | D506 |
SOD-123 | DIODE_SOD-123_MBR0540T1 | MBR0540T1 | IC | 1 | D402 |
SOD-323 | DIODE_0_SOD-323_RB501V | RB501V | IC | 1 | D401 |
SOD-323 | DIODE TVS_SOD-323_SD12 | SD12 | IC | 2 | D407; D901 |
SOD-323 | DIODE_0_SOD-323_1SS355 | 1SS355 | IC | 2 | D1001; D1002 |
SOT23-3 | MOSFET N_0_SOT23-3_WPM3401 | WPM3401 | IC | 2 | Q401; Q501 |
SOT23-5 | AT1308_1_SOT23-5_LP3301B5F | LP3301B5F | IC | 1 | U401 |
SOT23-5 | RT7179_16_SOT23-5_RT9193-18PB | RT9193-18PB | IC | 3 | U406; U1003; U1004 |
SOT23-5 | RT7179_17_SOT23-5_RT9193-33PB | RT9193-33PB | IC | 2 | U407; U1001 |
SOT23-5 | RT9193-33PB_0_SOT23-5_RT9193-33 | RT9193-33PB | IC | 3 | U703; U706; U902 |
SOT23-5 | RT9193-33PB_0_SOT23-5_RT9193-18 | RT9193-18PB | IC | 1 | U707 |
SOT23-5 | RT9193-33PB_0_SOT23-5_RT9193-30 | RT9193-30PB | IC | 1 | U802 |
SOT23-5 | RT7179_29_SOT23-5_LPW5206-B5F | LPW5206-B5F | IC | 1 | U903 |
SOT23-5 | RT7179_16_SOT23-5_RT9193-28PB | RT9193-28PB | IC | 1 | U1005 |
SOT23-6 | BOOST-SOT236_3_SOT23-6_LP3304S | LP3304S | IC | 1 | U402 |
SOT-23 | 10CTQ150/TO_0_SOT-23_BAV99 | BAV99 | IC | 2 | D403; D405 |
SOT-23 | BCX18L_SOT-23_MMBT3906 | MMBT3906 | IC | 1 | Q402 |
SOT-23 | NPN_SOT-23_MMBT3904 | MMBT3904 | IC | 1 | Q504 |
SOT-23 | NPN_0_SOT-23_MMBT3904 | MMBT3904 | IC | 1 | Q1101 |
SOT-23 | S-1000C_3_SOT-23_XC61FN2712MR | XC61FN2712MR | IC | 1 | U302 |
SOT-23-6L | RT7179_39_SOT-23-6L_SGM6600-ADJ | SGM6600-ADJYN6G | IC | 1 | U901 |
SOT-26 | IRF7416_7_SOT-26_WPM2037 | WPM2037 | IC | 2 | Q502; Q503 |
TCXO3_2X2_5 | TCXO_0_TCXO3_2X2_5_26MHZ | 26MHz | IC | 1 | Y801 |
TDFN-10 | LP28200-84-SO_36_TDFN-10_LP2830 | LP28300-QVF | IC | 1 | U504 |
TO24 | TO42_3_TO24_TO24 | TO24 | IC | 1 | SW101 |
TP | TP_2_TP_TP | TP | IC | 15 | TP101; TP201; TP202; TP301; TP302; TP401; TP701; TP702; TP703; TP704; TP705; TP706; TP801; TP901; TP902 |
TP | T POINT R_TP_TP | TP | IC | 1 | TP501 |
TP2M5X1M5 | TP_S_TP2M5X1M5_TEST | TEST | IC | 4 | MOTOR+1; MOTOR-1; VLEDN401; VLEDP401 |
TSOP1-48 | KM28C256_4_TSOP1-48_K9LCG08U0A- | K9LCG08U0A-SCB0 | IC | 1 | U301 |
UAF10U-CXX4 | CON4_8_UAF10U-CXX4_UAF10U-CXX4 | UAF10U-CXX4 | IC | 1 | J901 |
VLS252012 | INDUCTOR_2_VLS252012_VLS252012T | VLS252012T-4R7MR81 | IC | 2 | L401; L901 |
VLS252012 | INDUCTOR_VLS252012_LQM2HPN1R0MG | LQM2HPN1R0MGC | IC | 2 | L502; L503 |
