查看: 686|回复: 13
[allegro16.3][6层]Atmel | SMART SAMA5D2(SAMA5D27+DDR+FPC)原理图和pcb文件
发表于 2019-12-17 19:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
8 t# V* ?; g7 x! y  J, r
文件描述:
8 R, ~/ m3 S/ S5 L6 ~
1. 作品用途:Atmel | SMART SAMA5D2
2. 软件版本:allegro16.3
3. 层数:6层
4. 用到的主要芯片:SAMA5D27+DDR+FPC
5. PCB尺寸:3456.693*5307.087 mil
% W+ V$ K6 h; j" Y) a
作品截图如下:
' V4 K+ {, V) S1 t! o! S2 w
顶层截图:
# F+ R8 o( J% b. D
. f. O' q/ G( o& f  X
底层截图:
  w5 P" V$ X& x& z6 r: I( @4 E2 ]6 z
8 D9 S; R) Z: v* j8 R$ k, v0 j
  v0 i& v3 y; K2 o: `6 ]
全层截图:
4 j% R3 E2 L. W2 a$ n( W2 I7 R7 W- g
4 e2 D8 ], X) p' W& }
叠层阻抗信息如下:
6 G$ l$ L# p+ U3 E" {% L& b" S; B  C& W
, M  r& L6 X3 t. e
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA9P4FAN48610_BGA9P4_FAN48610FAN48610IC1U22
BGA100FAT32UC3A_BGA100F_AT32UC3A4256HHAT32UC3A4256HHB-C1UR ( AT32UC3A4256J-C1UR, Factory Programmed )IC1U1
BGA153P5EMMC_BGA153P5_MTFC4GLDEA-0M WTMTFC4GLDEA-0M WTIC1U11
BGA289P8SAMA5D2X_BGA289_BGA289P8__SAMA5SAMA5D27-CNIC1U6
BGADDR96P8B90X140MT41K128M16JT-125_BGADDR96P8B90MT41K128M16JT-125:KIC2U4; U8
C117X68CAP_PN_C117X68_0.2F/3.3V0.2F/3.3VIC1C42
C0402C0402_C0402_100NF100nFIC95C1; C4; C8; C10; C15; C21; C24; C25; C29; C31; C38; C45; C46; C51; C52; C53; C54; C55; C58; C62; C63; C65; C66; C68; C69; C72; C76; C77; C78; C79; C80; C81; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C99; C100; C101; C102; C103; C104; C107; C108; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C123; C125; C126; C128; C129; C130; C131; C132; C133; C134; C135; C136; C138; C139; C140; C143; C144; C145; C146; C149; C150; C151; C153; C155; C156; C161; C167; C170; C172; C174; C175; C177; C178
C0402C0402_C0402_1NF1nFIC13C5; C30; C49; C50; C67; C74; C82; C84; C97; C105; C122; C137; C141
C0402C0402_C0402_DNP(1NF)DNP(1nF)IC1C7
C0402C0402_C0402_10PF10pFIC2C9; C127
C0402C0402_C0402_20PF20pFIC3C11; C14; C57
C0402C_GENERIC_C0402_100NF_100nFIC5C18; C75; C86; C160; C162
C0402C0402_C0402_22PF22pFIC6C34; C35; C40; C41; C106; C109
C0402C0402_C0402_27PF27pFIC2C47; C48
C0402C_GENERIC_C0402_10NF_10nFIC2C158; C159
C0402C_GENERIC_C0402_47NF_47nFIC1C166
C0603C0603_C0603_2.2UF2.2uFIC11C6; C16; C61; C73; C98; C124; C152; C154; C168; C171; C179
C0603C0603_C0603_DNP(1UF)DNP(1uF)IC1C44
C0603C0603_C0603_1UF1uFIC1C85
C0805C0603_C0805_10UF10uFIC24C2; C3; C12; C20; C22; C23; C26; C27; C28; C32; C33; C36; C37; C39; C59; C60; C64; C70; C71; C157; C163; C164; C176; C180
C0805C0603_C0805_4.7UF4.7uFIC12C13; C17; C19; C43; C56; C83; C142; C147; C148; C165; C169; C173
C0805C0603_C0805_22UF22uFIC1C181
CON4B100X60M1X3PIN_CON4B100X60M_1X3PIN1X3PinIC1J3
CON4B160X70V_A1X4PIN_CON4B160X70V_A_1X4PIN1X4PinIC1J5
DCK6FNADG849_DCK6FN_ADG849ADG849IC1U13
DFN8_1P5RAT24C08B-PU_DFN8_1P5R_AT24MAC40AT24MAC402-MAHM-TIC1U18
FPCB50_2P5XF2M_OMRON50PTS_0_FPCB50_2P5_5050 Pin FPC ConnectorIC1J2
H2M1X2PTS_MALE_STRIGHT_2.00MM_H2M_DNP(Header 1X2 2.54MM)IC1J15
H2M1X2PTS_MALE_STRIGHT_2.00MM_H2_2Header 1X2IC6JP3; JP4; JP5; JP6; JP7; JP8
H2P201X2PTS_MALE_STRIGHT_2.00MM_H2P2DNP(Header 1X2 2.00MM)IC1J4
H2P201X2PTS_MALE_STRIGHT_2.00MM_H2_1Header 1X2IC3JP1; JP2; JP9
H2X2LMZHEADER 2X2_H2X2LMZ_DNP(HEADER 2DNP(Header 2X2)IC1J24
H2X3MZ2X3PTS_MALE_STRAIGHT_2.54MM_H2XHeader 2X3IC1J16
H2X10LMZ2X10PTS_MALE_ANGLE_2.54MM_H2X10DNP(Header 2X10)IC2J25; J26
H6M1X6PTS_MALE_STRAIGHT_2.54MM_H6MHeader 1X6IC1J1
H8M1X8PTS_FEMALE_STRAIGHT_2.54_H8MSocket 1X8IC5J7; J8; J9; J21; J22
H10M1X10PTS_FEMALE_STRAIGHT_2.54_H1Socket 1X10IC1J20
HS2X5_2JZ2X5PTS_MALE_STRAIGHT_1.27MM_HS2DNP(Header 2X5)IC1J10
HS2X5_2JZ2X5PTS_MALE_STRAIGHT_1.27MM_H_1Header 2X5IC1J11
HS2X7_2JZ2X7PIN_HS2X7_2JZ_DNP(HEADER 2X7DNP(Header 2X7)IC1J12
HS2X15_2MZ2X15PTS_MALE_STRAIGHT_2.54_HS2XHeader 2X15IC1J18
H_S2X18MZ2X18PTS_FEMALE_STRAIGHT_2.54_H_Socket 2X18IC1J17
L0603L_SMT_L0603_10UH_150MA10uH_150mAIC4L12; L14; L20; L22
L1008L_10UH-150 MA_L1008_2.2UH2.2uHIC3L1; L5; L6
L1008L_10UH-150 MA_L1008_0.47UH0.47uHIC1L27
LED4B32X28RGB_FULL COLOR_LED_LED4B32X28_RRGB LEDIC1D2
LED0805LED RED KPG-1608_0_LED0805_REDREDIC2D1; D4
LED0805LED BLUE KPG-1608_0_LED0805_BLUBLUEIC1D3
MHC50D30PTH_2_MHC50D30_PTHPTHIC3MH1; MH2; MH4
MHC50D30PTH_3_MHC50D30_PTHPTHIC1MH3
QFN32_1P5HKSZ8081RNB_0_QFN32_1P5H_KSZ8081KSZ8081RNBIC1U3
QFN40_1P4HACT8945A_QFN40_1P4H_ACT8945AQJ4ACT8945AQJ405-TIC1U2
R0402R_GENERIC_R0402_10K_10KIC33R1; R6; R7; R31; R32; R33; R34; R48; R60; R65; R66; R67; R68; R100; R127; R186; R187; R209; R217; R218; R225; R226; R229; R230; R272; R301; R312; R313; R318; R319; R323; R340; R345
R0402R_GENERIC_R0402_200K200KIC2R2; R184
R0402R_GENERIC_R0402_100K_100KIC14R3; R12; R15; R43; R53; R74; R75; R104; R183; R242; R243; R332; R333; R346
R0402R_GENERIC_R0402_330R_330RIC15R4; R5; R46; R76; R77; R78; R79; R92; R93; R118; R120; R132; R133; R134; R135
R0402R_GENERIC_R0402_68K_68KIC5R8; R189; R192; R241; R245
R0402R_GENERIC_R0402_1K_1KIC12R9; R45; R51; R52; R54; R55; R56; R57; R58; R69; R152; R275
R0402R_GENERIC_R0402_6.8K 1%_6.8K 1%IC3R10; R180; R181
R0402R_GENERIC_R0402_DNP(11K 1%)_DNP(11K 1%)IC1R11
R0402R_GENERIC_R0402_49.9K 1%49.9K 1%IC2R13; R14
R0402R_GENERIC_R0402_100R 1%_100R 1%IC13R16; R17; R20; R91; R94; R117; R119; R123; R146; R227; R261; R280; R310
R0402R_GENERIC_R0402_11K 1%_11K 1%IC1R18
R0402R_GENERIC_R0402_0R0RIC32R19; R30; R35; R40; R42; R50; R80; R81; R136; R137; R155; R178; R194; R196; R198; R200; R202; R203; R206; R247; R249; R252; R258; R260; R270; R271; R281; R290; R294; R302; R316; R329
R0402R_GENERIC_R0402_2.2M 1%_2.2M 1%IC1R21
R0402R_GENERIC_R0402_1.5M 1%_1.5M 1%IC1R22
R0402R_GENERIC_R0402_39R39RIC16R23; R25; R49; R140; R161; R163; R165; R222; R239; R246; R251; R259; R278; R279; R282; R285
R0402R_GENERIC_R0402_DNP(3.9K 1%)_DNP(3.9K 1%)IC1R24
R0402R_GENERIC_R0402_DNP(8.2K 1%)_DNP(8.2K 1%)IC1R26
R0402R_GENERIC_R0402_2.43K 1%_2.43K 1%IC1R27
R0402R_GENERIC_R0402_DNP(330R)_DNP(330R)IC11R28; R193; R195; R197; R199; R201; R204; R205; R248; R253; R257
R0402R_GENERIC_R0402_DNP(1M)_DNP(1M)IC4R29; R64; R103; R138
R0402R_GENERIC_R0402_DNP(0R)DNP(0R)IC18R36; R37; R38; R39; R41; R99; R158; R240; R244; R268; R273; R283; R292; R299; R336; R341; R342; R344
R0402R_GENERIC_0_R0402_100R 1%100R 1%IC1R44
R0402R_GENERIC_0_R0402_22R22RIC92R47; R61; R72; R73; R82; R83; R84; R85; R86; R87; R88; R89; R90; R95; R97; R98; R101; R102; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R122; R141; R143; R145; R148; R150; R154; R156; R157; R159; R160; R162; R164; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R188; R190; R191; R207; R208; R213; R215; R216; R219; R220; R221; R223; R224; R228; R231; R265; R266; R267; R274; R276; R277; R286; R287; R288; R289; R291; R295; R296; R297; R298; R304; R305; R307; R308; R311; R315; R322; R324
R0402R_GENERIC_R0402_470R_470RIC7R59; R63; R314; R317; R325; R326; R328
R0402R0603_R0402_6.49K 1%6.49K 1%IC1R70
R0402R_GENERIC_0_R0402_DNP(0R)DNP(0R)IC2R96; R121
R0402R_GENERIC_R0402_47K_47KIC11R105; R142; R144; R147; R149; R151; R232; R233; R234; R236; R237
R0402R_GENERIC_R0402_240R 1%_240R 1%IC2R124; R238
R0402R_GENERIC_0_R0402_2.2K2.2KIC6R125; R126; R306; R309; R331; R334
R0402R_GENERIC_R0402_DNP(10K)_DNP(10K)IC2R128; R320
R0402R_GENERIC_0_R0402_DNP(2.2K)DNP(2.2K)IC1R139
R0402R_GENERIC_R0402_DNP(100R 1%)_DNP(100R 1%)IC1R153
R0402R_GENERIC_R0402_DNP(1K)_DNP(1K)IC2R179; R254
R0402R_GENERIC_R0402_390R 1%_390R 1%IC1R185
R0402R_GENERIC_R0402_DNP(47K)_DNP(47K)IC2R235; R255
R0402R_GENERIC_R0402_23.2K 1%_23.2K 1%IC1R250
R0402R_GENERIC_R0402_20K 1%_20K 1%IC1R256
R0402R_GENERIC_0_R0402_DNP(22R)DNP(22R)IC1R262
R0402R_GENERIC_R0402_5.62K 1%_5.62K 1%IC1R263
R0402R_GENERIC_R0402_DNP(68K)DNP(68K)IC2R337; R343
R0402R_GENERIC_R0402_68K68KIC2R338; R339
R0603BEAD_ FERRITE_R0603_180OHM AT 1180ohm at 100MHzIC19L2; L3; L4; L7; L8; L9; L10; L11; L13; L15; L16; L17; L18; L19; L21; L23; L24; L25; L26
R0603R_GENERIC_R0603_2R2_2R2IC3R129; R293; R300
R0603R_GENERIC_R0603_0R0RIC9R130; R211; R214; R264; R284; R303; R321; R327; R330
R0603R_GENERIC_R0603_1R 1%_1R 1%IC3R131; R182; R269
R0603R_GENERIC_R0603_DNP(0R)DNP(0R)IC2R210; R212
R0805R_GENERIC_R0805_0R0RIC3R62; R71; R347
R0805R_GENERIC_R0805_DNP(0R)DNP(0R)IC1R335
RJ45_13F-64GY_P12_4J00-0061 PULSE_0_RJ45_13F-64GY_RJ45 ConnectorIC1J6
SD13_5B267X180SD_MMCPLUS_SD13_5B267X180_SD CASD Card ConnectorIC1J19
SOD123RB160M-60TR_SOD123_RB160M-60TRRB160M-60TRIC1D5
SOD123LL4148_SOD123_1N4148W1N4148WIC2D7; D8
SOD123RB160M-60TR_SOD123_(REPLACED WI(replaced with 0R-1206 -see User Guide)IC1D9
SOIC8JASP2525A-SO8_SOIC8JA_SP2525A-1ENSP2525A-1EN-LIC1U16
SOIC8JGAT25DF321_SU_0_SOIC8JG_AT25DF32AT25DF321AIC1U9
SOIC8JGQSPI_N25Q_8PIN_SOIC8JG_DNP(N25QDNP(N25Q128A13ESE40F)IC1U10
SOT23_123SSL-LX15D-RP/SOT23_2_SOT23_123_BAT54CIC1D6
SOT23_123IRLML2402_0_SOT23_123_BSS138BSS138IC8Q1; Q2; Q3; Q4; Q5; Q6; Q8; Q9
SOT23_123PMOS_0_SOT23_123_DNP(IRLML6402)DNP(IRLML6402)IC1Q7
SOT23_123TLV431A_SOT23_123_TLV431ATLV431AIC1U7
SOT143BPRTR5V0U2X_SOT143B_PRTR5V0U2XPRTR5V0U2XIC1U5
SOT353_51G126_0_SOT353_5__NL17SZ126DFT2NL17SZ126DFT2GIC4U14; U15; U20; U21
SOT563_6DMC2400UV_SOT563_6_DMC2400UVDMC2400UVIC2U17; U19
SWS4B60SSWITCH2_0_SWS4B60S_TACT SWITCHTact SwitchIC3BP1; BP2; BP3
TP30TP_TP30_SMDSMDIC27TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP12; TP13; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP30
TP80TP_TP80_SMDSMDIC3TP11; TP14; TP29
TSSOP8FATPS2113_TSSOP8FA_TPS2113TPS2113IC1U12
USB4_2ALSINGLE USB TYPE A_USB4_2AL_SINGSingle USB Type AIC1J13
USBMICRO5_6AUSB_MICROAB_0_USBMICRO5_6A_MICRMicroUSB AB ConnectorIC2J14; J23
X4S32X25XTAL_13Y_A_X4S32X25__12MHZ CL=112MHz CL=15pFIC2Y1; Y4
X4S32X2512MHZ_X4S32X25_25MHZ CL=20PF25MHz CL=20pFIC1Y2
X4S70X1532_0.768K_X4S70X15_32.768KHZ CL32.768KHz CL=12.5pFIC1Y3
附件:
原理图和pcb文件如下:
游客,如果您要查看本帖隐藏内容请回复
( ^: M( a& v2 v+ }* y4 E4 n
    2020-4-30 15:20
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2019-12-17 22:17 | 只看该作者
    好东西 看看- D0 U! X$ z9 m& X% F7 b+ }# c1 `6 z
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2019-12-18 13:09 | 只看该作者
    谢谢分享
    “来自电巢APP”
    2025-7-25 15:33
  • 签到天数: 558 天
    [LV.9]以坛为家II
    发表于 2020-2-11 18:35 | 只看该作者
    下载看看,学习一下
    2025-7-23 15:37
  • 签到天数: 140 天
    [LV.7]常住居民III
    发表于 2020-2-12 12:18 | 只看该作者
    好东西,谢谢.
    * C% X8 @  D: a: N* H& X7 Q. A6 ?
    发表于 2020-2-13 11:35 | 只看该作者
    ddddddddddddddd& F5 ]+ h4 _. D7 j
    GMT+8, 2025-7-28 02:34 , Processed in 0.171875 second(s), 27 queries , Gzip On.
